RTEMS 6.1
Support for the SPI bus on the Raspberry Pi GPIO P1 header (model A/B) and GPIO J8 header on model B+. More...
#include <bsp.h>#include <bsp/raspberrypi.h>#include <bsp/gpio.h>#include <bsp/rpi-gpio.h>#include <bsp/irq.h>#include <bsp/spi.h>#include <assert.h>Data Structures | |
| struct | rpi_spi_softc_t |
| Object containing the SPI bus configuration settings. More... | |
| struct | rpi_spi_desc_t |
| Object containing the SPI bus description. More... | |
| #define | SPI_POLLING(condition) |
| int | rpi_spi_init (bool bidirectional_mode) |
| Setups the Raspberry Pi SPI bus (located on the GPIO header) on the "/dev/spi" device file, and registers the bus on the libi2c API. | |
| #define SPI_POLLING | ( | condition | ) |
| int rpi_spi_init | ( | bool | bidirectional_mode | ) |
| [in] | bidirectional_mode | If TRUE sets the SPI bus to use 2-wire SPI, where the MOSI data line doubles as the slave out (SO) and slave in (SI) data lines. If FALSE the bus defaults to the usual 3-wire SPI, with 2 separate data lines (MOSI and MISO). |
| Returns | libi2c bus number. |
| <0 | Could not register the bus. See |
