RTEMS 6.1
Functions | Variables
timer.c File Reference
Timer controller for the mbed lpc1768 board. More...
#include <rtems/status-checks.h>
#include <bsp.h>
#include <bsp/irq.h>
#include <bsp/io.h>
#include <bsp/timer.h>
rtems_status_code lpc176x_timer_reset (const lpc176x_timer_number tnumber)
 resets timer counter and stops it.
rtems_status_code lpc176x_timer_set_mode (const lpc176x_timer_number tnumber, const lpc176x_timer_mode mode)
 Sets mode of the timer (timer, counter rising, counter falling or counter both edges)
rtems_status_code lpc176x_timer_start (const lpc176x_timer_number tnumber)
 Starts the timer counter.
rtems_status_code lpc176x_timer_is_started (const lpc176x_timer_number tnumber, bool *is_started)
 true if timer is started.
rtems_status_code lpc176x_timer_set_resolution (const lpc176x_timer_number tnumber, const lpc176x_microseconds resolution)
 sets the resolution in microseconds of the timer
rtems_status_code lpc176x_timer_match_config (const lpc176x_timer_number tnumber, const lpc176x_match_port match_port, const lpc176x_match_function function, const uint32_t match_value)
 Configures the timer match.
rtems_status_code lpc176x_timer_capture_config (const lpc176x_timer_number tnumber, const lpc176x_capture_port capture_port, const lpc176x_capture_function function)
 Configures the capture ports.
rtems_status_code lpc176x_timer_external_match_config (const lpc176x_timer_number number, const lpc176x_match_port match_port, const lpc176x_ext_match_function function)
 Configures the external match ports.
uint32_t lpc176x_timer_get_capvalue (const lpc176x_timer_number number, const lpc176x_capture_port capture_port)
 Gets the captured value.
uint32_t lpc176x_timer_get_timer_value (const lpc176x_timer_number tnumber)
 Gets the timer value.
rtems_status_code lpc176x_timer_set_timer_value (const lpc176x_timer_number tnumber, const uint32_t timer_value)
 Sets the timer value.
void lpc176x_timer_isr (void *arg)
 Timer generic isroutine.
rtems_status_code lpc176x_timer_init (const lpc176x_timer_number tnumber)
 Initializes timer in timer mode and resets counter but without starting it, and without any capture or match function.
rtems_status_code lpc176x_timer_init_with_interrupt (const lpc176x_timer_number tnumber, const lpc176x_isr_funct_vector *const vector)
const lpc176x_timer timers [LPC176X_TIMER_COUNT]
 Represents all the timers.
lpc176x_timer_functions functions_vector [LPC176X_TIMER_COUNT]
 Represents all the functions according to the timers.
◆ lpc176x_timer_capture_config()
rtems_status_code lpc176x_timer_capture_config ( lpc176x_timer_number  tnumber,
inline
Parameters
tnumberthe device to be modified
capture_portwhich port of this timer will be setted
functionAt which edge/s will the capture work, and if it will interrupt
◆ lpc176x_timer_external_match_config()
rtems_status_code lpc176x_timer_external_match_config ( lpc176x_timer_number  tnumber,
inline
Parameters
match_portwhich match for this timer
functionwhat should do when match: set, clear toggle or nothing
◆ lpc176x_timer_get_capvalue()
uint32_t lpc176x_timer_get_capvalue ( lpc176x_timer_number  tnumber,
lpc176x_capture_port  capnumber
inline
Parameters
capnumberwhich capture port for this timer
Returns
the captured value
◆ lpc176x_timer_get_timer_value()
uint32_t lpc176x_timer_get_timer_value ( lpc176x_timer_number  tnumber)
inline
Parameters
tnumberthe device
Returns
the timer value
◆ lpc176x_timer_init()
rtems_status_code lpc176x_timer_init ( lpc176x_timer_number  tnumber)
Parameters
tnumberwhich timer
Returns
RTEMS_SUCCESSFUL when everything ok.
◆ lpc176x_timer_init_with_interrupt()
rtems_status_code lpc176x_timer_init_with_interrupt ( lpc176x_timer_number  tnumber,
const lpc176x_isr_funct_vector vector
Parameters
tnumberwhich timer to init
vectorthe functions to be used by the isr.
Returns
◆ lpc176x_timer_is_started()
rtems_status_code lpc176x_timer_is_started ( lpc176x_timer_number  tnumber,
bool *  is_started
inline
Parameters
tnumberthe timer number to check.
is_startedTRUE if the timer is running.
Returns
RTEMS_SUCCESSFUL if the started timer check was successfuly.
◆ lpc176x_timer_isr()
void lpc176x_timer_isr ( void *  lpc176x_timer_number)
Parameters
timernumberthe number of timer.
◆ lpc176x_timer_match_config()
rtems_status_code lpc176x_timer_match_config ( lpc176x_timer_number  tnumber,
Parameters
match_portwhich port of this timer will be setted
functionwhat the timer should do when match: stop timer, clear, and/or interrupt
match_valuethe value that the timer should match.
Returns
RTEMS_SUCCESSFUL if the timer was configured successfuly.
◆ lpc176x_timer_reset()
rtems_status_code lpc176x_timer_reset ( lpc176x_timer_number  tnumber)
inline
Parameters
tnumberthe device to be reseted
Returns
RTEMS_SUCCESSFUL if the timer was reseted successfuly.
◆ lpc176x_timer_set_mode()
rtems_status_code lpc176x_timer_set_mode ( lpc176x_timer_number  tnumber,
inline
Parameters
tnumberthe device to be setted
modethe desired mode
Returns
RTEMS_SUCCESSFUL if the timer's mode was setted successfuly.
◆ lpc176x_timer_set_resolution()
rtems_status_code lpc176x_timer_set_resolution ( lpc176x_timer_number  tnumber,
inline
Parameters
tnumberthe device to be modified.
resolutionhow many microseconds will mean each timer counter unit.
Returns
RTEMS_SUCCESSFUL if the timer resolution was setted successfuly.
◆ lpc176x_timer_set_timer_value()
rtems_status_code lpc176x_timer_set_timer_value ( lpc176x_timer_number  tnumber,
uint32_t  lpc176x_timer_value
inline
Parameters
tnumberthe timer to modify.
timer_valuethe value to set.
◆ lpc176x_timer_start()
rtems_status_code lpc176x_timer_start ( lpc176x_timer_number  tnumber)
inline
Parameters
tnumberthe device to be started
Returns
RTEMS_SUCCESSFUL if the timer's was started successfuly.
Variable Documentation
◆ functions_vector
lpc176x_timer_functions functions_vector[LPC176X_TIMER_COUNT]
Initial value:
.funct_vector = NULL
◆ timers
const lpc176x_timer timers[LPC176X_TIMER_COUNT]
Initial value:
.device = (lpc176x_timer_device *) LPC176X_TMR0_BASE_ADDR,
.module = LPC176X_MODULE_TIMER_0,
.pinselcap = LPC176X_TIMER0_CAPTURE_PORTS,
.pinselemat = LPC176X_TIMER0_EMATCH_PORTS,
.device = (lpc176x_timer_device *) LPC176X_TMR1_BASE_ADDR,
.module = LPC176X_MODULE_TIMER_1,
.pinselcap = LPC176X_TIMER1_CAPTURE_PORTS,
.pinselemat = LPC176X_TIMER1_EMATCH_PORTS,
.device = (lpc176x_timer_device *) LPC176X_TMR2_BASE_ADDR,
.module = LPC176X_MODULE_TIMER_2,
.pinselcap = LPC176X_TIMER2_CAPTURE_PORTS,
.pinselemat = LPC176X_TIMER2_EMATCH_PORTS,
.device = (lpc176x_timer_device *) LPC176X_TMR3_BASE_ADDR,
.module = LPC176X_MODULE_TIMER_3,
.pinselcap = LPC176X_TIMER3_CAPTURE_PORTS,
.pinselemat = LPC176X_TIMER3_EMATCH_PORTS,
Represents the timer device registers.
Definition: timer-defs.h:186
