RTEMS 6.1
AArch64-specific ARM GPT system register accessors. More...
| uint64_t | arm_gt_clock_get_compare_value (void) |
| void | arm_gt_clock_set_compare_value (uint64_t cval) |
| uint64_t | arm_gt_clock_get_count (void) |
| void | arm_gt_clock_set_control (uint32_t ctl) |
| void | arm_generic_timer_get_config (uint32_t *frequency, uint32_t *irq) |
| void arm_generic_timer_get_config | ( | uint32_t * | frequency, |
| uint32_t * | irq | ||
This function gets the frequency and IRQ number used by the ARM General Purpose Timer.
| [out] | frequency | The frequency at which the timer will fire. |
| [out] | irq | The number of the IRQ on which the timer will fire. |
| uint64_t arm_gt_clock_get_compare_value | ( | void | ) |
This function returns the current compare value for the ARM General Purpose Timer.
| uint64_t arm_gt_clock_get_count | ( | void | ) |
This function returns the count for the ARM General Purpose Timer.
| void arm_gt_clock_set_compare_value | ( | uint64_t | cval | ) |
This function sets the current compare value for the ARM General Purpose Timer.
| [in] | cval | The value to set as the compare value |
| void arm_gt_clock_set_control | ( | uint32_t | ctl | ) |
This function sets the control register for the ARM General Purpose Timer.
| [in] | ctl | The value to set to the control register |
