RTEMS 6.1
Data Structures | Macros | Typedefs | Enumerations | Functions
alt_dma_program.h File Reference
#include "hwlib.h"
#include "alt_dma_common.h"
struct  ALT_DMA_PROGRAM_s
#define ALT_DMA_PROGRAM_CACHE_LINE_SIZE   (32)
#define ALT_DMA_PROGRAM_CACHE_LINE_COUNT   (16)
#define ALT_DMA_PROGRAM_PROVISION_BUFFER_SIZE   (ALT_DMA_PROGRAM_CACHE_LINE_SIZE * ALT_DMA_PROGRAM_CACHE_LINE_COUNT)
#define ALT_DMA_CCR_OPT_SAF   (0 << 0)
#define ALT_DMA_CCR_OPT_SAI   (1 << 0)
#define ALT_DMA_CCR_OPT_SA_DEFAULT   ALT_DMA_CCR_OPT_SAI
#define ALT_DMA_CCR_OPT_SS8   (0 << 1)
#define ALT_DMA_CCR_OPT_SS16   (1 << 1)
#define ALT_DMA_CCR_OPT_SS32   (2 << 1)
#define ALT_DMA_CCR_OPT_SS64   (3 << 1)
#define ALT_DMA_CCR_OPT_SS128   (4 << 1)
#define ALT_DMA_CCR_OPT_SS_DEFAULT   ALT_DMA_CCR_OPT_SS8
#define ALT_DMA_CCR_OPT_SB1   (0x0 << 4)
#define ALT_DMA_CCR_OPT_SB2   (0x1 << 4)
#define ALT_DMA_CCR_OPT_SB3   (0x2 << 4)
#define ALT_DMA_CCR_OPT_SB4   (0x3 << 4)
#define ALT_DMA_CCR_OPT_SB5   (0x4 << 4)
#define ALT_DMA_CCR_OPT_SB6   (0x5 << 4)
#define ALT_DMA_CCR_OPT_SB7   (0x6 << 4)
#define ALT_DMA_CCR_OPT_SB8   (0x7 << 4)
#define ALT_DMA_CCR_OPT_SB9   (0x8 << 4)
#define ALT_DMA_CCR_OPT_SB10   (0x9 << 4)
#define ALT_DMA_CCR_OPT_SB11   (0xa << 4)
#define ALT_DMA_CCR_OPT_SB12   (0xb << 4)
#define ALT_DMA_CCR_OPT_SB13   (0xc << 4)
#define ALT_DMA_CCR_OPT_SB14   (0xd << 4)
#define ALT_DMA_CCR_OPT_SB15   (0xe << 4)
#define ALT_DMA_CCR_OPT_SB16   (0xf << 4)
#define ALT_DMA_CCR_OPT_SB_DEFAULT   ALT_DMA_CCR_OPT_SB1
#define ALT_DMA_CCR_OPT_SP(imm3)   ((imm3) << 8)
#define ALT_DMA_CCR_OPT_SP_DEFAULT   ALT_DMA_CCR_OPT_SP(0)
#define ALT_DMA_CCR_OPT_SC(imm4)   ((imm4) << 11)
#define ALT_DMA_CCR_OPT_SC_DEFAULT   ALT_DMA_CCR_OPT_SC(0)
#define ALT_DMA_CCR_OPT_DAF   (0 << 14)
#define ALT_DMA_CCR_OPT_DAI   (1 << 14)
#define ALT_DMA_CCR_OPT_DA_DEFAULT   ALT_DMA_CCR_OPT_DAI
#define ALT_DMA_CCR_OPT_DS8   (0 << 15)
#define ALT_DMA_CCR_OPT_DS16   (1 << 15)
#define ALT_DMA_CCR_OPT_DS32   (2 << 15)
#define ALT_DMA_CCR_OPT_DS64   (3 << 15)
#define ALT_DMA_CCR_OPT_DS128   (4 << 15)
#define ALT_DMA_CCR_OPT_DS_DEFAULT   ALT_DMA_CCR_OPT_DS8
#define ALT_DMA_CCR_OPT_DB1   (0x0 << 18)
#define ALT_DMA_CCR_OPT_DB2   (0x1 << 18)
#define ALT_DMA_CCR_OPT_DB3   (0x2 << 18)
#define ALT_DMA_CCR_OPT_DB4   (0x3 << 18)
#define ALT_DMA_CCR_OPT_DB5   (0x4 << 18)
#define ALT_DMA_CCR_OPT_DB6   (0x5 << 18)
#define ALT_DMA_CCR_OPT_DB7   (0x6 << 18)
#define ALT_DMA_CCR_OPT_DB8   (0x7 << 18)
#define ALT_DMA_CCR_OPT_DB9   (0x8 << 18)
#define ALT_DMA_CCR_OPT_DB10   (0x9 << 18)
#define ALT_DMA_CCR_OPT_DB11   (0xa << 18)
#define ALT_DMA_CCR_OPT_DB12   (0xb << 18)
#define ALT_DMA_CCR_OPT_DB13   (0xc << 18)
#define ALT_DMA_CCR_OPT_DB14   (0xd << 18)
#define ALT_DMA_CCR_OPT_DB15   (0xe << 18)
#define ALT_DMA_CCR_OPT_DB16   (0xf << 18)
#define ALT_DMA_CCR_OPT_DB_DEFAULT   ALT_DMA_CCR_OPT_DB1
#define ALT_DMA_CCR_OPT_DP(imm3)   ((imm3) << 22)
#define ALT_DMA_CCR_OPT_DP_DEFAULT   ALT_DMA_CCR_OPT_DP(0)
#define ALT_DMA_CCR_OPT_DC(imm4)   ((imm4) << 25)
#define ALT_DMA_CCR_OPT_DC_DEFAULT   ALT_DMA_CCR_OPT_DC(0)
#define ALT_DMA_CCR_OPT_ES8   (0 << 28)
#define ALT_DMA_CCR_OPT_ES16   (1 << 28)
#define ALT_DMA_CCR_OPT_ES32   (2 << 28)
#define ALT_DMA_CCR_OPT_ES64   (3 << 28)
#define ALT_DMA_CCR_OPT_ES128   (4 << 28)
#define ALT_DMA_CCR_OPT_ES_DEFAULT   ALT_DMA_CCR_OPT_ES8
#define ALT_DMA_CCR_OPT_DEFAULT
typedef struct ALT_DMA_PROGRAM_s ALT_DMA_PROGRAM_t
typedef enum ALT_DMA_PROGRAM_REG_e ALT_DMA_PROGRAM_REG_t
typedef enum ALT_DMA_PROGRAM_INST_MOD_e ALT_DMA_PROGRAM_INST_MOD_t
enum  ALT_DMA_PROGRAM_REG_e { ALT_DMA_PROGRAM_REG_SAR = 0x0 , ALT_DMA_PROGRAM_REG_DAR = 0x2 , ALT_DMA_PROGRAM_REG_CCR = 0x1 }
enum  ALT_DMA_PROGRAM_INST_MOD_e { ALT_DMA_PROGRAM_INST_MOD_NONE , ALT_DMA_PROGRAM_INST_MOD_SINGLE , ALT_DMA_PROGRAM_INST_MOD_BURST , ALT_DMA_PROGRAM_INST_MOD_PERIPH }
ALT_STATUS_CODE alt_dma_program_init (ALT_DMA_PROGRAM_t *pgm)
ALT_STATUS_CODE alt_dma_program_uninit (ALT_DMA_PROGRAM_t *pgm)
ALT_STATUS_CODE alt_dma_program_clear (ALT_DMA_PROGRAM_t *pgm)
ALT_STATUS_CODE alt_dma_program_validate (const ALT_DMA_PROGRAM_t *pgm)
ALT_STATUS_CODE alt_dma_program_progress_reg (ALT_DMA_PROGRAM_t *pgm, ALT_DMA_PROGRAM_REG_t reg, uint32_t current, uint32_t *progress)
ALT_STATUS_CODE alt_dma_program_update_reg (ALT_DMA_PROGRAM_t *pgm, ALT_DMA_PROGRAM_REG_t reg, uint32_t val)
ALT_STATUS_CODE alt_dma_program_DMAADDH (ALT_DMA_PROGRAM_t *pgm, ALT_DMA_PROGRAM_REG_t addr_reg, uint16_t val)
ALT_STATUS_CODE alt_dma_program_DMAADNH (ALT_DMA_PROGRAM_t *pgm, ALT_DMA_PROGRAM_REG_t addr_reg, uint16_t val)
ALT_STATUS_CODE alt_dma_program_DMAEND (ALT_DMA_PROGRAM_t *pgm)
ALT_STATUS_CODE alt_dma_program_DMAFLUSHP (ALT_DMA_PROGRAM_t *pgm, ALT_DMA_PERIPH_t periph)
ALT_STATUS_CODE alt_dma_program_DMAGO (ALT_DMA_PROGRAM_t *pgm, ALT_DMA_CHANNEL_t channel, uint32_t val, ALT_DMA_SECURITY_t sec)
ALT_STATUS_CODE alt_dma_program_DMAKILL (ALT_DMA_PROGRAM_t *pgm)
ALT_STATUS_CODE alt_dma_program_DMALD (ALT_DMA_PROGRAM_t *pgm, ALT_DMA_PROGRAM_INST_MOD_t mod)
ALT_STATUS_CODE alt_dma_program_DMALDP (ALT_DMA_PROGRAM_t *pgm, ALT_DMA_PROGRAM_INST_MOD_t mod, ALT_DMA_PERIPH_t periph)
ALT_STATUS_CODE alt_dma_program_DMALP (ALT_DMA_PROGRAM_t *pgm, uint32_t iterations)
ALT_STATUS_CODE alt_dma_program_DMALPEND (ALT_DMA_PROGRAM_t *pgm, ALT_DMA_PROGRAM_INST_MOD_t mod)
ALT_STATUS_CODE alt_dma_program_DMALPFE (ALT_DMA_PROGRAM_t *pgm)
ALT_STATUS_CODE alt_dma_program_DMAMOV (ALT_DMA_PROGRAM_t *pgm, ALT_DMA_PROGRAM_REG_t chan_reg, uint32_t val)
ALT_STATUS_CODE alt_dma_program_DMANOP (ALT_DMA_PROGRAM_t *pgm)
ALT_STATUS_CODE alt_dma_program_DMARMB (ALT_DMA_PROGRAM_t *pgm)
ALT_STATUS_CODE alt_dma_program_DMASEV (ALT_DMA_PROGRAM_t *pgm, ALT_DMA_EVENT_t evt)
ALT_STATUS_CODE alt_dma_program_DMAST (ALT_DMA_PROGRAM_t *pgm, ALT_DMA_PROGRAM_INST_MOD_t mod)
ALT_STATUS_CODE alt_dma_program_DMASTP (ALT_DMA_PROGRAM_t *pgm, ALT_DMA_PROGRAM_INST_MOD_t mod, ALT_DMA_PERIPH_t periph)
ALT_STATUS_CODE alt_dma_program_DMASTZ (ALT_DMA_PROGRAM_t *pgm)
ALT_STATUS_CODE alt_dma_program_DMAWFE (ALT_DMA_PROGRAM_t *pgm, ALT_DMA_EVENT_t evt, bool invalid)
ALT_STATUS_CODE alt_dma_program_DMAWFP (ALT_DMA_PROGRAM_t *pgm, ALT_DMA_PERIPH_t periph, ALT_DMA_PROGRAM_INST_MOD_t mod)
ALT_STATUS_CODE alt_dma_program_DMAWMB (ALT_DMA_PROGRAM_t *pgm)
