RTEMS 6.1
hwlib.h
1
7/******************************************************************************
8*
9* Copyright 2013 Altera Corporation. All Rights Reserved.
10*
11* Redistribution and use in source and binary forms, with or without
12* modification, are permitted provided that the following conditions are met:
13*
14* 1. Redistributions of source code must retain the above copyright notice,
15* this list of conditions and the following disclaimer.
16*
17* 2. Redistributions in binary form must reproduce the above copyright notice,
18* this list of conditions and the following disclaimer in the documentation
19* and/or other materials provided with the distribution.
20*
21* 3. The name of the author may not be used to endorse or promote products
22* derived from this software without specific prior written permission.
23*
24* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDER "AS IS" AND ANY EXPRESS OR
25* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
26* MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE, ARE DISCLAIMED. IN NO
27* EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
28* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT
29* OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
30* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
31* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING
32* IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
33* OF SUCH DAMAGE.
34*
35******************************************************************************/
36
37#ifndef __HWLIB_H__
38#define __HWLIB_H__
39
40#ifdef __cplusplus
41#include <cstddef>
42#include <cstdbool>
43#include <cstdint>
44#else /* __cplusplus */
45#include <stddef.h>
46#include <stdbool.h>
47#include <stdint.h>
48#endif /* __cplusplus */
49
50#include "alt_hwlibs_ver.h"
51
52#ifdef __cplusplus
53extern "C"
54{
55#endif /* __cplusplus */
56
60typedef int32_t ALT_STATUS_CODE;
61
65#define ALT_E_SUCCESS 0
66
68#define ALT_E_ERROR (-1)
70#define ALT_E_FPGA_CFG (-2)
72#define ALT_E_FPGA_CRC (-3)
74#define ALT_E_FPGA_CFG_STM (-4)
76#define ALT_E_FPGA_PWR_OFF (-5)
78#define ALT_E_FPGA_NO_SOC_CTRL (-6)
80#define ALT_E_FPGA_NOT_USER_MODE (-7)
82#define ALT_E_ARG_RANGE (-8)
84#define ALT_E_BAD_ARG (-9)
86#define ALT_E_BAD_OPERATION (-10)
88#define ALT_E_INV_OPTION (-11)
90#define ALT_E_TMO (-12)
92#define ALT_E_RESERVED (-13)
94#define ALT_E_BAD_CLK (-14)
96#define ALT_E_BAD_VERSION (-15)
98#define ALT_E_BUF_OVF (-20)
99
103#define ALT_E_FALSE (0)
107#define ALT_E_TRUE (1)
108
109/* Note, additional positive status codes may be defined to return
110 * a TRUE condition with additional information */
111
112
113/* Some other useful definitions */
114
132#define ALT_HWLIBS_VERSION(a,b,c) (((a)*10000)+((b)*100)+(c))
133
134#define ALTERA_HWLIBS_VERSION_CODE ALT_HWLIBS_VERSION(ALTERA_ACDS_MAJOR_REV, \
135 ALTERA_ACDS_MINOR_REV, ALTERA_HWLIBS_REV)
136
140#define ALTERA_INTERNAL_ONLY_DOCS 1
141
142
147#ifndef ALT_HPS_ADDR
148#define ALT_HPS_ADDR 0
149#endif
150
154#define ALT_MILLISECS_IN_A_SEC 1000
155#define ALT_MICROSECS_IN_A_SEC 1000000
156#define ALT_NANOSECS_IN_A_SEC 1000000000
157
158#define ALT_TWO_TO_POW0 (1)
159#define ALT_TWO_TO_POW1 (1<<1)
160#define ALT_TWO_TO_POW2 (1<<2)
161#define ALT_TWO_TO_POW3 (1<<3)
162#define ALT_TWO_TO_POW4 (1<<4)
163#define ALT_TWO_TO_POW5 (1<<5)
164#define ALT_TWO_TO_POW6 (1<<6)
165#define ALT_TWO_TO_POW7 (1<<7)
166#define ALT_TWO_TO_POW8 (1<<8)
167#define ALT_TWO_TO_POW9 (1<<9)
168#define ALT_TWO_TO_POW10 (1<<10)
169#define ALT_TWO_TO_POW11 (1<<11)
170#define ALT_TWO_TO_POW12 (1<<12)
171#define ALT_TWO_TO_POW13 (1<<13)
172#define ALT_TWO_TO_POW14 (1<<14)
173#define ALT_TWO_TO_POW15 (1<<15)
174#define ALT_TWO_TO_POW16 (1<<16)
175#define ALT_TWO_TO_POW17 (1<<17)
176#define ALT_TWO_TO_POW18 (1<<18)
177#define ALT_TWO_TO_POW19 (1<<19)
178#define ALT_TWO_TO_POW20 (1<<20)
179#define ALT_TWO_TO_POW21 (1<<21)
180#define ALT_TWO_TO_POW22 (1<<22)
181#define ALT_TWO_TO_POW23 (1<<23)
182#define ALT_TWO_TO_POW24 (1<<24)
183#define ALT_TWO_TO_POW25 (1<<25)
184#define ALT_TWO_TO_POW26 (1<<26)
185#define ALT_TWO_TO_POW27 (1<<27)
186#define ALT_TWO_TO_POW28 (1<<28)
187#define ALT_TWO_TO_POW29 (1<<29)
188#define ALT_TWO_TO_POW30 (1<<30)
189#define ALT_TWO_TO_POW31 (1<<31)
190
191#ifdef __cplusplus
192}
193#endif /* __cplusplus */
194#endif /* __HWLIB_H__ */
195
Definition: hwlib.h:60
