#define | AFEC_MR_SETTLING_Pos 20 |
#define | AFEC_MR_SETTLING_Msk (0x3u << AFEC_MR_SETTLING_Pos) |
| | (AFEC_MR) Trigger Selection
#define | AFEC_MR_SETTLING_AST3 (0x0u << 20) |
| | (AFEC_MR) ADC_SETTLING_AST3 3 periods of AFEClock
#define | AFEC_MR_SETTLING_AST5 (0x1u << 20) |
| | (AFEC_MR) ADC_SETTLING_AST5 5 periods of AFEClock
#define | AFEC_MR_SETTLING_AST9 (0x2u << 20) |
| | (AFEC_MR) ADC_SETTLING_AST9 9 periods of AFEClock
#define | AFEC_MR_SETTLING_AST17 (0x3u << 20) |
| | (AFEC_MR) ADC_SETTLING_AST17 17 periods of AFEClock
#define | AFEC_EMR_STM_Pos 25 |
#define | AFEC_EMR_STM_Msk (0x1u << AFEC_EMR_STM_Pos) |
| | (AFEC_EMR) Single Trigger Mode
#define | AFEC_EMR_STM_MULTI_TRIG (0x0u << 25) |
| | (AFEC_EMR) Single Trigger Mode: Multiple triggers are required to get an averaged result.
#define | AFEC_EMR_STM_SINGLE_TRIG (0x1u << 25) |
| | (AFEC_EMR) Single Trigger Mode: Only a Single Trigger is required to get an averaged value.
#define | AFEC_EMR_TAG_Pos 24 |
#define | AFEC_EMR_TAG_Msk (0x1u << AFEC_EMR_TAG_Pos) |
| | (AFEC_EMR) TAG of the AFEC_LDCR Register
#define | AFEC_EMR_TAG_CHNB_ZERO (0x0u << 24) |
| | (AFEC_EMR) TAG of the AFEC_LDCR Register: Sets CHNB to zero in AFEC_LDCR.
#define | AFEC_EMR_TAG_APPENDS (0x1u << 24) |
| | (AFEC_EMR) TAG of the AFEC_LDCR Register: Appends the channel number to the conversion result in AFEC_LDCR register.
#define | AFEC_EMR_CMPALL_Pos 9 |
#define | AFEC_EMR_CMPALL_Msk (0x1u << AFEC_EMR_TAG_Pos) |
| | (AFEC_EMR) Compare All Channels
#define | AFEC_EMR_CMPALL_ONE_CHANNEL_COMP (0x0u << 9) |
| | (AFEC_EMR) Compare All Channels: Only channel indicated in CMPSEL field is compared.
#define | AFEC_EMR_CMPALL_ALL_CHANNELS_COMP (0x1u << 9) |
| | (AFEC_EMR) Compare All Channels: All channels are compared.
#define | AFEC_ACR_PGA0_ON (0x1u << 2) |
#define | AFEC_ACR_PGA1_ON (0x1u << 3) |
#define | AFEC_GetModeReg(pAFEC) ((pAFEC)->AFEC_MR) |
#define | AFEC_SetModeReg(pAFEC, mode) ((pAFEC)->AFEC_MR = mode) |
#define | AFEC_GetExtModeReg(pAFEC) ((pAFEC)->AFEC_EMR) |
#define | AFEC_SetExtModeReg(pAFEC, mode) ((pAFEC)->AFEC_EMR = mode) |
#define | AFEC_StartConversion(pAFEC) ((pAFEC)->AFEC_CR = AFEC_CR_START) |
| #define | AFEC_EnableChannel(pAFEC, dwChannel) |
| #define | AFEC_DisableChannel(pAFEC, dwChannel) |
| #define | AFEC_EnableIt(pAFEC, dwMode) |
| #define | AFEC_DisableIt(pAFEC, dwMode) |
| #define | AFEC_SetChannelGain(pAFEC, dwMode) |
#define | AFEC_EnableDataReadyIt(pAFEC) ((pAFEC)->AFEC_IER = AFEC_IER_DRDY) |
#define | AFEC_GetStatus(pAFEC) ((pAFEC)->AFEC_ISR) |
#define | AFEC_GetCompareMode(pAFEC) (((pAFEC)->AFEC_EMR)& (AFEC_EMR_CMPMODE_Msk)) |
#define | AFEC_GetChannelStatus(pAFEC) ((pAFEC)->AFEC_CHSR) |
#define | AFEC_GetInterruptMaskStatus(pAFEC) ((pAFEC)->AFEC_IMR) |
#define | AFEC_GetLastConvertedData(pAFEC) ((pAFEC)->AFEC_LCDR) |
| void | AFEC_Initialize (Afec *pAFEC, uint32_t dwId) |
| | Initialize the AFE controller.
| uint32_t | AFEC_SetClock (Afec *pAFEC, uint32_t dwPres, uint32_t dwMck) |
| | Set AFE clock.
| void | AFEC_SetTiming (Afec *pAFEC, uint32_t dwStartup, uint32_t dwTracking, uint32_t dwSettling) |
| | Set AFE timing.
| void | AFEC_SetTrigger (Afec *pAFEC, uint32_t dwTrgSel) |
| | Set AFE trigger.
| void | AFEC_SetAnalogChange (Afec *pAFE, uint8_t bEnDis) |
| | Set analog change. IF enabled, it allows different analog settings for each channel, otherwise, DIFF0, GAIN0 and OFF0 are used for all channels.
| void | AFEC_SetSleepMode (Afec *pAFEC, uint8_t bEnDis) |
| | Enable/Disable sleep mode.
| void | AFEC_SetFastWakeup (Afec *pAFEC, uint8_t bEnDis) |
| | Enable/Disable fast wake up.
| void | AFEC_SetSequenceMode (Afec *pAFEC, uint8_t bEnDis) |
| | Enable/Disable sequence mode.
| void | AFEC_SetSequence (Afec *pAFEC, uint32_t dwSEQ1, uint32_t dwSEQ2) |
| | Set channel sequence.
| void | AFEC_SetSequenceByList (Afec *pAFEC, uint8_t ucChList[], uint8_t ucNumCh) |
| | Set channel sequence by given channel list.
| void | AFEC_SetTagEnable (Afec *pAFEC, uint8_t bEnDis) |
| | Set "TAG" mode, show channel number in last data or not.
| void | AFEC_SetCompareChannel (Afec *pAFEC, uint32_t dwChannel) |
| | Set compare channel.
| void | AFEC_SetCompareMode (Afec *pAFEC, uint32_t dwMode) |
| | Set compare mode.
| void | AFEC_SetComparisonWindow (Afec *pAFEC, uint32_t dwHi_Lo) |
| | Set comparison window.
uint8_t | AFEC_CheckConfiguration (Afec *pAFEC, uint32_t dwMcK) |
| uint32_t | AFEC_GetConvertedData (Afec *pAFEC, uint32_t dwChannel) |
| | Return the Channel Converted Data.
| void | AFEC_SetStartupTime (Afec *pAFEC, uint32_t dwUs) |
| void | AFEC_SetTrackingTime (Afec *pAFEC, uint32_t dwNs) |
| void | AFEC_SetAnalogOffset (Afec *pAFE, uint32_t dwChannel, uint32_t aoffset) |
| | Set analog offset to be used for channel CSEL.
| void | AFEC_SetAnalogControl (Afec *pAFE, uint32_t control) |
Purpose
Interface for configuration the Analog-to-Digital Converter (AFEC) peripheral.
Usage
- Configurate the pins for AFEC.
- Initialize the AFEC with AFEC_Initialize().
- Set AFEC clock and timing with AFEC_SetClock() and AFEC_SetTiming().
- Select the active channel using AFEC_EnableChannel().
- Start the conversion with AFEC_StartConversion().
- Wait the end of the conversion by polling status with AFEC_GetStatus().
- Finally, get the converted data using AFEC_GetConvertedData() or AFEC_GetLastConvertedData().
