RTEMS 5.2
drvmgr_key_value Union Reference
#include <drvmgr.h>
unsigned int i
char * str
void * ptr
Union of different values
Field Documentation
◆ i
unsigned int drvmgr_key_value::i
Key data type UNSIGNED INTEGER
◆ ptr
void* drvmgr_key_value::ptr
Key data type ADDRESS/POINTER
◆ str
char* drvmgr_key_value::str
Key data type STRING
The documentation for this union was generated from the following file:
