RTEMS 5.2
usb_regs_t Struct Reference
volatile uint16_t _res0
volatile uint16_t fnr
volatile uint16_t _res1
volatile uint16_t fnmr
volatile uint16_t _res2
volatile uint16_t rfmr
volatile uint16_t _res3
volatile uint16_t rfmmr
volatile uint8_t _res4 [3]
volatile uint8_t far
volatile uint32_t asr
volatile uint32_t drr1
volatile uint32_t drr2
volatile uint16_t _res5
volatile uint16_t specr
volatile uint16_t _res6
volatile uint16_t ep0sr
volatile uint32_t iep0cfg
volatile uint32_t oep0cfg
volatile uint32_t ep1cfg
volatile uint32_t ep2cfg
volatile uint32_t ep3cfg
volatile uint32_t ep4cfg
volatile uint32_t ep5cfg
volatile uint32_t ep6cfg
volatile uint32_t ep7cfg
volatile uint32_t ep0ctl
volatile uint16_t _res7
volatile uint16_t ep1ctl
volatile uint16_t _res8
volatile uint16_t ep2ctl
volatile uint16_t _res9
volatile uint16_t ep3ctl
volatile uint16_t _res10
volatile uint16_t ep4ctl
volatile uint16_t _res11
volatile uint16_t ep5ctl
volatile uint16_t _res12
volatile uint16_t ep6ctl
volatile uint16_t _res13
volatile uint16_t ep7ctl
volatile uint32_t ep0isr
volatile uint16_t _res14
volatile uint16_t ep1isr
volatile uint16_t _res15
volatile uint16_t ep2isr
volatile uint16_t _res16
volatile uint16_t ep3isr
volatile uint16_t _res17
volatile uint16_t ep4isr
volatile uint16_t _res18
volatile uint16_t ep5isr
volatile uint16_t _res19
volatile uint16_t ep6isr
volatile uint16_t _res20
volatile uint16_t ep7isr
volatile uint32_t ep0imr
volatile uint16_t _res21
volatile uint16_t ep1imr
volatile uint16_t _res22
volatile uint16_t ep2imr
volatile uint16_t _res23
volatile uint16_t ep3imr
volatile uint16_t _res24
volatile uint16_t ep4imr
volatile uint16_t _res25
volatile uint16_t ep5imr
volatile uint16_t _res26
volatile uint16_t ep6imr
volatile uint16_t _res27
volatile uint16_t ep7imr
volatile uint32_t ep0dr
volatile uint32_t ep1dr
volatile uint32_t ep2dr
volatile uint32_t ep3dr
volatile uint32_t ep4dr
volatile uint32_t ep5dr
volatile uint32_t ep6dr
volatile uint32_t ep7dr
volatile uint16_t _res28
volatile uint16_t ep0dpr
volatile uint16_t _res29
volatile uint16_t ep1dpr
volatile uint16_t _res30
volatile uint16_t ep2dpr
volatile uint16_t _res31
volatile uint16_t ep3dpr
volatile uint16_t _res32
volatile uint16_t ep4dpr
volatile uint16_t _res33
volatile uint16_t ep5dpr
volatile uint16_t _res34
volatile uint16_t ep6dpr
volatile uint16_t _res35
volatile uint16_t ep7dpr
