RTEMS 5.2
mcf5272.h
1/*
2 * Coldfire MCF5272 definitions.
3 * Contents of this file based on information provided in
4 * Motorola MCF5272 User's Manual.
5 *
6 * Copyright (C) 2004 Jay Monkman <jtm@lopingdog.com>
7 *
8 * The license and distribution terms for this file may be
9 * found in the file LICENSE in this distribution or at
10 * http://www.rtems.org/license/LICENSE.
11 */
12
13#ifndef __MCF5272_H__
14#define __MCF5272_H__
15
16#ifndef ASM
17#include <rtems.h>
18#endif
19
20#define bit(x) (1 << (x))
21
22#define MCF5272_SIM_BASE(mbar) ((mbar) + 0x0000)
23#define MCF5272_INT_BASE(mbar) ((mbar) + 0x0020)
24#define MCF5272_CS_BASE(mbar) ((mbar) + 0x0040)
25#define MCF5272_GPIO_BASE(mbar) ((mbar) + 0x0080)
26#define MCF5272_QSPI_BASE(mbar) ((mbar) + 0x00A0)
27#define MCF5272_PWM_BASE(mbar) ((mbar) + 0x00C0)
28#define MCF5272_DMAC_BASE(mbar) ((mbar) + 0x00E0)
29#define MCF5272_UART0_BASE(mbar) ((mbar) + 0x0100)
30#define MCF5272_UART1_BASE(mbar) ((mbar) + 0x0140)
31#define MCF5272_SDRAMC_BASE(mbar) ((mbar) + 0x0180)
32#define MCF5272_TIMER_BASE(mbar) ((mbar) + 0x0200)
33#define MCF5272_PLIC_BASE(mbar) ((mbar) + 0x0300)
34#define MCF5272_ENET_BASE(mbar) ((mbar) + 0x0840)
35#define MCF5272_USB_BASE(mbar) ((mbar) + 0x1000)
36
37
38/* RAMBAR - SRAM Base Address Register */
39#define MCF5272_RAMBAR_BA (0xfffff000) /* SRAM Base Address */
40#define MCF5272_RAMBAR_WP (0x00000100) /* Write Protect */
41#define MCF5272_RAMBAR_CI (0x00000020) /* CPU Space mask */
42#define MCF5272_RAMBAR_SC (0x00000010) /* Supervisor Code Space Mask */
43#define MCF5272_RAMBAR_SD (0x00000008) /* Supervisor Data Space Mask */
44#define MCF5272_RAMBAR_UC (0x00000004) /* User Code Space Mask */
45#define MCF5272_RAMBAR_UD (0x00000002) /* User Data Space Mask */
46#define MCF5272_RAMBAR_V (0x00000001) /* Contents of RAMBAR are valid */
47
48/* MBAR - Module Base Address Register */
49#define MCF5272_MBAR_BA (0xffff0000) /* Base Address */
50#define MCF5272_MBAR_SC (0x00000010) /* Supervisor Code Space Mask */
51#define MCF5272_MBAR_SD (0x00000008) /* Supervisor Data Space Mask */
52#define MCF5272_MBAR_UC (0x00000004) /* User Code Space Mask */
53#define MCF5272_MBAR_UD (0x00000002) /* User Data Space Mask */
54#define MCF5272_MBAR_V (0x00000001) /* Contents of MBAR are valid */
55
56/* CACR - Cache Control Register */
57#define MCF5272_CACR_CENB (0x80000000) /* Cache Enable */
58#define MCF5272_CACR_CPDI (0x10000000) /* Disable CPUSHL Invalidation */
59#define MCF5272_CACR_CFRZ (0x08000000) /* Cache Freeze */
60#define MCF5272_CACR_CINV (0x01000000) /* Cache Invalidate */
61#define MCF5272_CACR_CEIB (0x00000400) /* Cache Enable Noncacheable
62 instruction bursting */
63#define MCF5272_CACR_DCM (0x00000200) /* Default cache mode - noncacheable*/
64#define MCF5272_CACR_DBWE (0x00000100) /* Default Buffered Write Enable */
65#define MCF5272_CACR_DWP (0x00000020) /* Default Write Protection */
66#define MCF5272_CACR_CLNF (0x00000003) /* Cache Line Fill */
67
68/* ACRx - Cache Access Control Registers */
69#define MCF5272_ACR_BA (0xff000000) /* Address Base */
70#define MCF5272_ACR_BAM (0x00ff0000) /* Address Mask */
71#define MCF5272_ACR_EN (0x00008000) /* Enable */
72#define MCF5272_ACR_SM_USR (0x00000000) /* Match if user mode */
73#define MCF5272_ACR_SM_SVR (0x00002000) /* Match if supervisor mode */
74#define MCF5272_ACR_SM_ANY (0x00004000) /* Match Always */
75#define MCF527_ACR_CM (0x00000040) /* Cache Mode (1 - noncacheable) */
76#define MCF5272_ACR_BWE (0x00000020) /* Buffered Write Enable */
77#define MCF5272_ACR_WP (0x00000004) /* Write Protect */
78#define MCF5272_ACR_BASE(base) ((base) & MCF5272_ACR_BA)
79#define MCF5272_ACR_MASK(mask) (((mask) >> 8) & MCF5272_ACR_BAM)
80
81
82#define MCF5272_ICR1_INT1_PI (bit(31))
83#define MCF5272_ICR1_INT1_IPL(x) ((x) << 28)
84#define MCF5272_ICR1_INT1_MASK ((7) << 28)
85#define MCF5272_ICR1_INT2_PI (bit(27))
86#define MCF5272_ICR1_INT2_IPL(x) ((x) << 24)
87#define MCF5272_ICR1_INT2_MASK ((7) << 24)
88#define MCF5272_ICR1_INT3_PI (bit(23))
89#define MCF5272_ICR1_INT3_IPL(x) ((x) << 20)
90#define MCF5272_ICR1_INT3_MASK ((7) << 20)
91#define MCF5272_ICR1_INT4_PI (bit(19))
92#define MCF5272_ICR1_INT4_IPL(x) ((x) << 16)
93#define MCF5272_ICR1_INT4_MASK ((7) << 16)
94#define MCF5272_ICR1_TMR0_PI (bit(15))
95#define MCF5272_ICR1_TMR0_IPL(x) ((x) << 12)
96#define MCF5272_ICR1_TMR0_MASK ((7) << 12)
97#define MCF5272_ICR1_TMR1_PI (bit(11))
98#define MCF5272_ICR1_TMR1_IPL(x) ((x) << 8)
99#define MCF5272_ICR1_TMR1_MASK ((7) << 8)
100#define MCF5272_ICR1_TMR2_PI (bit(7))
101#define MCF5272_ICR1_TMR2_IPL(x) ((x) << 4)
102#define MCF5272_ICR1_TMR2_MASK ((7) << 4)
103#define MCF5272_ICR1_TMR3_PI (bit(3))
104#define MCF5272_ICR1_TMR3_IPL(x) ((x) << 0)
105#define MCF5272_ICR1_TMR3_MASK ((7) << 0)
106
107#define MCF5272_ICR3_USB4_PI (bit(31))
108#define MCF5272_ICR3_USB4_IPL(x) ((x) << 28)
109#define MCF5272_ICR3_USB4_MASK ((7) << 28)
110#define MCF5272_ICR3_USB5_PI (bit(27))
111#define MCF5272_ICR3_USB5_IPL(x) ((x) << 24)
112#define MCF5272_ICR3_USB5_MASK ((7) << 24)
113#define MCF5272_ICR3_USB6_PI (bit(23))
114#define MCF5272_ICR3_USB6_IPL(x) ((x) << 20)
115#define MCF5272_ICR3_USB6_MASK ((7) << 20)
116#define MCF5272_ICR3_USB7_PI (bit(19))
117#define MCF5272_ICR3_USB7_IPL(x) ((x) << 16)
118#define MCF5272_ICR3_USB7_MASK ((7) << 16)
119#define MCF5272_ICR3_DMA_PI (bit(15))
120#define MCF5272_ICR3_DMA_IPL(x) ((x) << 12)
121#define MCF5272_ICR3_DMA_MASK ((7) << 12)
122#define MCF5272_ICR3_ERX_PI (bit(11))
123#define MCF5272_ICR3_ERX_IPL(x) ((x) << 8)
124#define MCF5272_ICR3_ERX_MASK ((7) << 8)
125#define MCF5272_ICR3_ETX_PI (bit(7))
126#define MCF5272_ICR3_ETX_IPL(x) ((x) << 4)
127#define MCF5272_ICR3_ETX_MASK ((7) << 4)
128#define MCF5272_ICR3_ENTC_PI (bit(3))
129#define MCF5272_ICR3_ENTC_IPL(x) ((x) << 0)
130#define MCF5272_ICR3_ENTC_MASK ((7) << 0)
131
132
133#define MCF5272_USR_RB (bit(7))
134#define MCF5272_USR_FE (bit(6))
135#define MCF5272_USR_PE (bit(5))
136#define MCF5272_USR_OE (bit(4))
137#define MCF5272_USR_TXEMP (bit(3))
138#define MCF5272_USR_TXRDY (bit(2))
139#define MCF5272_USR_FFULL (bit(1))
140#define MCF5272_USR_RXRDY (bit(0))
141
142#define MCF5272_TMR_PS_MASK 0xff00
143#define MCF5272_TMR_PS_SHIFT 8
144#define MCF5272_TMR_CE_DISABLE (0 << 6)
145#define MCF5272_TMR_CE_RISING (1 << 6)
146#define MCF5272_TMR_CE_FALLING (2 << 6)
147#define MCF5272_TMR_CE_ANY (3 << 6)
148#define MCF5272_TMR_OM (bit(5))
149#define MCF5272_TMR_ORI (bit(4))
150#define MCF5272_TMR_FRR (bit(3))
151#define MCF5272_TMR_CLK_STOP (0 << 1)
152#define MCF5272_TMR_CLK_MSTR (1 << 1)
153#define MCF5272_TMR_CLK_MSTR16 (2 << 1)
154#define MCF5272_TMR_CLK_TIN (3 << 1)
155#define MCF5272_TMR_RST (bit(0))
156#define MCF5272_TER_REF (bit(1))
157#define MCF5272_TER_CAP (bit(0))
158
159#define MCF5272_SCR_PRI (bit(8))
160#define MCF5272_SCR_AR (bit(7))
161#define MCF5272_SCR_SRST (bit(6))
162#define MCF5272_SCR_BUSLOCK (bit(3))
163#define MCF5272_SCR_HWR_128 (0)
164#define MCF5272_SCR_HWR_256 (1)
165#define MCF5272_SCR_HWR_512 (2)
166#define MCF5272_SCR_HWR_1024 (3)
167#define MCF5272_SCR_HWR_2048 (4)
168#define MCF5272_SCR_HWR_4096 (5)
169#define MCF5272_SCR_HWR_8192 (6)
170#define MCF5272_SCR_HWR_16384 (7)
171
172#define MCF5272_SPR_ADC (bit(15))
173#define MCF5272_SPR_WPV (bit(15))
174#define MCF5272_SPR_SMV (bit(15))
175#define MCF5272_SPR_PE (bit(15))
176#define MCF5272_SPR_HWT (bit(15))
177#define MCF5272_SPR_RPV (bit(15))
178#define MCF5272_SPR_EXT (bit(15))
179#define MCF5272_SPR_SUV (bit(15))
180#define MCF5272_SPR_ADCEN (bit(15))
181#define MCF5272_SPR_WPVEN (bit(15))
182#define MCF5272_SPR_SMVEN (bit(15))
183#define MCF5272_SPR_PEEN (bit(15))
184#define MCF5272_SPR_HWTEN (bit(15))
185#define MCF5272_SPR_RPVEN (bit(15))
186#define MCF5272_SPR_EXTEN (bit(15))
187#define MCF5272_SPR_SUVEN (bit(15))
188
189#define MCF5272_ENET_TX_RT (bit(25))
190#define MCF5272_ENET_ETHERN_EN (bit(1))
191#define MCF5272_ENET_RESET (bit(0))
192
193#define MCF5272_ENET_EIR_HBERR (bit(31))
194#define MCF5272_ENET_EIR_BABR (bit(30))
195#define MCF5272_ENET_EIR_BABT (bit(29))
196#define MCF5272_ENET_EIR_GRA (bit(28))
197#define MCF5272_ENET_EIR_TXF (bit(27))
198#define MCF5272_ENET_EIR_TXB (bit(26))
199#define MCF5272_ENET_EIR_RXF (bit(25))
200#define MCF5272_ENET_EIR_RXB (bit(24))
201#define MCF5272_ENET_EIR_MII (bit(23))
202#define MCF5272_ENET_EIR_EBERR (bit(22))
203#define MCF5272_ENET_EIR_UMINT (bit(21))
204
205#define MCF5272_ENET_RCR_PROM (bit(3))
206#define MCF5272_ENET_RCR_MII (bit(2))
207#define MCF5272_ENET_RCR_DRT (bit(1))
208#define MCF5272_ENET_RCR_LOOP (bit(0))
209
210#define MCF5272_ENET_TCR_FDEN (bit(2))
211#define MCF5272_ENET_TCR_HBC (bit(1))
212#define MCF5272_ENET_TCR_GTS (bit(0))
213
214
215#ifndef ASM
216typedef struct {
217 volatile uint32_t mbar; /* READ ONLY!! */
218
219 volatile uint16_t scr;
220 volatile uint16_t _res0;
221
222 volatile uint16_t _res1;
223 volatile uint16_t spr;
224
225 volatile uint32_t pmr;
226
227 volatile uint16_t _res2;
228 volatile uint16_t alpr;
229
230 volatile uint32_t dir;
231} sim_regs_t;
233typedef struct {
234 volatile uint32_t icr1;
235 volatile uint32_t icr2;
236 volatile uint32_t icr3;
237 volatile uint32_t icr4;
238 volatile uint32_t isr;
239 volatile uint32_t pitr;
240 volatile uint32_t piwr;
241 volatile uint8_t _res0[3];
242 volatile uint8_t pivr;
245typedef struct {
246 volatile uint32_t csbr0;
247 volatile uint32_t csor0;
248 volatile uint32_t csbr1;
249 volatile uint32_t csor1;
250 volatile uint32_t csbr2;
251 volatile uint32_t csor2;
252 volatile uint32_t csbr3;
253 volatile uint32_t csor3;
254 volatile uint32_t csbr4;
255 volatile uint32_t csor4;
256 volatile uint32_t csbr5;
257 volatile uint32_t csor5;
258 volatile uint32_t csbr6;
259 volatile uint32_t csor6;
260 volatile uint32_t csbr7;
261 volatile uint32_t csor7;
264typedef struct {
265 volatile uint32_t pacnt;
266
267 volatile uint16_t paddr;
268 volatile uint16_t _res0;
269
270 volatile uint16_t _res1;
271 volatile uint16_t padat;
272
273 volatile uint32_t pbcnt;
274
275 volatile uint16_t pbddr;
276 volatile uint16_t _res2;
277
278 volatile uint16_t _res3;
279 volatile uint16_t pbdat;
280
281 volatile uint16_t pcddr;
282 volatile uint16_t _res4;
283
284 volatile uint16_t _res5;
285 volatile uint16_t pcdat;
286
287 volatile uint32_t pdcnt;
290typedef struct {
291 volatile uint32_t qmr;
292 volatile uint32_t qdlyr;
293 volatile uint32_t qwr;
294 volatile uint32_t qir;
295 volatile uint32_t qar;
296 volatile uint32_t qdr;
299typedef struct {
300 volatile uint8_t pwcr1;
301 volatile uint8_t _res0[3];
302
303 volatile uint8_t pwcr2;
304 volatile uint8_t _res1[3];
305
306 volatile uint8_t pwcr3;
307 volatile uint8_t _res2[3];
308
309 volatile uint8_t pwwd1;
310 volatile uint8_t _res3[3];
311
312 volatile uint8_t pwwd2;
313 volatile uint8_t _res4[3];
314
315 volatile uint8_t pwwd3;
316 volatile uint8_t _res5[3];
317} pwm_regs_t;
319typedef struct {
320 volatile uint32_t dcmr;
321
322 volatile uint16_t _res0;
323 volatile uint16_t dcir;
324
325 volatile uint32_t dbcr;
326
327 volatile uint32_t dsar;
328
329 volatile uint32_t ddar;
330} dma_regs_t;
332typedef struct {
333 volatile uint8_t umr; /* 0x000 */
334 volatile uint8_t _res0[3];
335
336 volatile uint8_t ucsr; /* 0x004 */
337 volatile uint8_t _res2[3];
338
339 volatile uint8_t ucr; /* 0x008 */
340 volatile uint8_t _res3[3];
341
342 volatile uint8_t udata; /* 0x00c */
343 volatile uint8_t _res4[3];
344
345 volatile uint8_t uccr; /* 0x010 */
346 volatile uint8_t _res6[3];
347
348 volatile uint8_t uisr; /* 0x014 */
349 volatile uint8_t _res8[3];
350
351 volatile uint8_t ubg1; /* 0x018 */
352 volatile uint8_t _res10[3];
353
354 volatile uint8_t ubg2; /* 0x01c */
355 volatile uint8_t _res11[3];
356
357 volatile uint8_t uabr1; /* 0x020 */
358 volatile uint8_t _res12[3];
359
360 volatile uint8_t uabr2; /* 0x024 */
361 volatile uint8_t _res13[3];
362
363 volatile uint8_t utxfcsr; /* 0x028 */
364 volatile uint8_t _res14[3];
365
366 volatile uint8_t urxfcsr; /* 0x02c */
367 volatile uint8_t _res15[3];
368
369 volatile uint8_t ufpdn; /* 0x030 */
370 volatile uint8_t _res16[3];
371
372 volatile uint8_t uip; /* 0x034 */
373 volatile uint8_t _res17[3];
374
375 volatile uint8_t uop1; /* 0x038 */
376 volatile uint8_t _res18[3];
377
378 volatile uint8_t uop0; /* 0x03c */
379 volatile uint8_t _res19[3];
382typedef struct {
383 volatile uint16_t tmr0;
384 volatile uint16_t _res0;
385
386 volatile uint16_t trr0;
387 volatile uint16_t _res1;
388
389 volatile uint16_t tcap0;
390 volatile uint16_t _res2;
391
392 volatile uint16_t tcn0;
393 volatile uint16_t _res3;
394
395 volatile uint16_t ter0;
396 volatile uint16_t _res4;
397
398 volatile uint8_t _res40[12];
399
400 volatile uint16_t tmr1;
401 volatile uint16_t _res5;
402
403 volatile uint16_t trr1;
404 volatile uint16_t _res6;
405
406 volatile uint16_t tcap1;
407 volatile uint16_t _res7;
408
409 volatile uint16_t tcn1;
410 volatile uint16_t _res8;
411
412 volatile uint16_t ter1;
413 volatile uint16_t _res9;
414
415 volatile uint8_t _res91[12];
416
417 volatile uint16_t tmr2;
418 volatile uint16_t _res10;
419
420 volatile uint16_t trr2;
421 volatile uint16_t _res11;
422
423 volatile uint16_t tcap2;
424 volatile uint16_t _res12;
425
426 volatile uint16_t tcn2;
427 volatile uint16_t _res13;
428
429 volatile uint16_t ter2;
430 volatile uint16_t _res14;
431
432 volatile uint8_t _res140[12];
433
434 volatile uint16_t tmr3;
435 volatile uint16_t _res15;
436
437 volatile uint16_t trr3;
438 volatile uint16_t _res16;
439
440 volatile uint16_t tcap3;
441 volatile uint16_t _res17;
442
443 volatile uint16_t tcn3;
444 volatile uint16_t _res18;
445
446 volatile uint16_t ter3;
447 volatile uint16_t _res19;
448
449 volatile uint8_t _res190[12];
450
451 volatile uint16_t wrrr;
452 volatile uint16_t _res20;
453
454 volatile uint16_t wirr;
455 volatile uint16_t _res21;
456
457 volatile uint16_t wcr;
458 volatile uint16_t _res22;
459
460 volatile uint16_t wer;
461 volatile uint16_t _res23;
464typedef struct {
465 volatile uint32_t p0b1rr;
466 volatile uint32_t p1b1rr;
467 volatile uint32_t p2b1rr;
468 volatile uint32_t p3b1rr;
469 volatile uint32_t p0b2rr;
470 volatile uint32_t p1b2rr;
471 volatile uint32_t p2b2rr;
472 volatile uint32_t p3b2rr;
473
474 volatile uint8_t p0drr;
475 volatile uint8_t p1drr;
476 volatile uint8_t p2drr;
477 volatile uint8_t p3drr;
478
479 volatile uint32_t p0b1tr;
480 volatile uint32_t p1b1tr;
481 volatile uint32_t p2b1tr;
482 volatile uint32_t p3b1tr;
483 volatile uint32_t p0b2tr;
484 volatile uint32_t p1b2tr;
485 volatile uint32_t p2b2tr;
486 volatile uint32_t p3b2tr;
487
488 volatile uint8_t p0dtr;
489 volatile uint8_t p1dtr;
490 volatile uint8_t p2dtr;
491 volatile uint8_t p3dtr;
492
493 volatile uint16_t p0cr;
494 volatile uint16_t p1cr;
495 volatile uint16_t p2cr;
496 volatile uint16_t p3cr;
497 volatile uint16_t p0icr;
498 volatile uint16_t p1icr;
499 volatile uint16_t p2icr;
500 volatile uint16_t p3icr;
501 volatile uint16_t p0gmr;
502 volatile uint16_t p1gmr;
503 volatile uint16_t p2gmr;
504 volatile uint16_t p3gmr;
505 volatile uint16_t p0gmt;
506 volatile uint16_t p1gmt;
507 volatile uint16_t p2gmt;
508 volatile uint16_t p3gmt;
509
510 volatile uint8_t _res0;
511 volatile uint8_t pgmts;
512 volatile uint8_t pgmta;
513 volatile uint8_t _res1;
514 volatile uint8_t p0gcir;
515 volatile uint8_t p1gcir;
516 volatile uint8_t p2gcir;
517 volatile uint8_t p3gcir;
518 volatile uint8_t p0gcit;
519 volatile uint8_t p1gcit;
520 volatile uint8_t p2gcit;
521 volatile uint8_t p3gcit;
522 volatile uint8_t _res3[3];
523 volatile uint8_t pgcitsr;
524 volatile uint8_t _res4[3];
525 volatile uint8_t pdcsr;
526
527 volatile uint16_t p0psr;
528 volatile uint16_t p1psr;
529 volatile uint16_t p2psr;
530 volatile uint16_t p3psr;
531 volatile uint16_t pasr;
532 volatile uint8_t _res5;
533 volatile uint8_t plcr;
534 volatile uint16_t _res6;
535 volatile uint16_t pdrqr;
536 volatile uint16_t p0sdr;
537 volatile uint16_t p1sdr;
538 volatile uint16_t p2sdr;
539 volatile uint16_t p3sdr;
540 volatile uint16_t _res7;
541 volatile uint16_t pcsr;
544typedef struct {
545 volatile uint32_t ecr;
546 volatile uint32_t eir;
547 volatile uint32_t eimr;
548 volatile uint32_t ivsr;
549 volatile uint32_t rdar;
550 volatile uint32_t tdar;
551 volatile uint32_t _res0[10];
552 volatile uint32_t mmfr;
553 volatile uint32_t mscr;
554 volatile uint32_t _res1[17];
555 volatile uint32_t frbr;
556 volatile uint32_t frsr;
557 volatile uint32_t _res2[4];
558 volatile uint32_t tfwr;
559 volatile uint32_t _res3[1];
560 volatile uint32_t tfsr;
561 volatile uint32_t _res4[21];
562 volatile uint32_t rcr;
563 volatile uint32_t mflr;
564 volatile uint32_t _res5[14];
565 volatile uint32_t tcr;
566 volatile uint32_t _res6[158];
567 volatile uint32_t malr;
568 volatile uint32_t maur;
569 volatile uint32_t htur;
570 volatile uint32_t htlr;
571 volatile uint32_t erdsr;
572 volatile uint32_t etdsr;
573 volatile uint32_t emrbr;
574/* volatile uint8_t fifo[448]; */
577typedef struct {
578 volatile uint16_t _res0;
579 volatile uint16_t fnr;
580 volatile uint16_t _res1;
581 volatile uint16_t fnmr;
582 volatile uint16_t _res2;
583 volatile uint16_t rfmr;
584 volatile uint16_t _res3;
585 volatile uint16_t rfmmr;
586 volatile uint8_t _res4[3];
587 volatile uint8_t far;
588 volatile uint32_t asr;
589 volatile uint32_t drr1;
590 volatile uint32_t drr2;
591 volatile uint16_t _res5;
592 volatile uint16_t specr;
593 volatile uint16_t _res6;
594 volatile uint16_t ep0sr;
595
596 volatile uint32_t iep0cfg;
597 volatile uint32_t oep0cfg;
598 volatile uint32_t ep1cfg;
599 volatile uint32_t ep2cfg;
600 volatile uint32_t ep3cfg;
601 volatile uint32_t ep4cfg;
602 volatile uint32_t ep5cfg;
603 volatile uint32_t ep6cfg;
604 volatile uint32_t ep7cfg;
605 volatile uint32_t ep0ctl;
606
607 volatile uint16_t _res7;
608 volatile uint16_t ep1ctl;
609 volatile uint16_t _res8;
610 volatile uint16_t ep2ctl;
611 volatile uint16_t _res9;
612 volatile uint16_t ep3ctl;
613 volatile uint16_t _res10;
614 volatile uint16_t ep4ctl;
615 volatile uint16_t _res11;
616 volatile uint16_t ep5ctl;
617 volatile uint16_t _res12;
618 volatile uint16_t ep6ctl;
619 volatile uint16_t _res13;
620 volatile uint16_t ep7ctl;
621
622 volatile uint32_t ep0isr;
623
624 volatile uint16_t _res14;
625 volatile uint16_t ep1isr;
626 volatile uint16_t _res15;
627 volatile uint16_t ep2isr;
628 volatile uint16_t _res16;
629 volatile uint16_t ep3isr;
630 volatile uint16_t _res17;
631 volatile uint16_t ep4isr;
632 volatile uint16_t _res18;
633 volatile uint16_t ep5isr;
634 volatile uint16_t _res19;
635 volatile uint16_t ep6isr;
636 volatile uint16_t _res20;
637 volatile uint16_t ep7isr;
638
639 volatile uint32_t ep0imr;
640
641 volatile uint16_t _res21;
642 volatile uint16_t ep1imr;
643 volatile uint16_t _res22;
644 volatile uint16_t ep2imr;
645 volatile uint16_t _res23;
646 volatile uint16_t ep3imr;
647 volatile uint16_t _res24;
648 volatile uint16_t ep4imr;
649 volatile uint16_t _res25;
650 volatile uint16_t ep5imr;
651 volatile uint16_t _res26;
652 volatile uint16_t ep6imr;
653 volatile uint16_t _res27;
654 volatile uint16_t ep7imr;
655
656 volatile uint32_t ep0dr;
657 volatile uint32_t ep1dr;
658 volatile uint32_t ep2dr;
659 volatile uint32_t ep3dr;
660 volatile uint32_t ep4dr;
661 volatile uint32_t ep5dr;
662 volatile uint32_t ep6dr;
663 volatile uint32_t ep7dr;
664
665 volatile uint16_t _res28;
666 volatile uint16_t ep0dpr;
667 volatile uint16_t _res29;
668 volatile uint16_t ep1dpr;
669 volatile uint16_t _res30;
670 volatile uint16_t ep2dpr;
671 volatile uint16_t _res31;
672 volatile uint16_t ep3dpr;
673 volatile uint16_t _res32;
674 volatile uint16_t ep4dpr;
675 volatile uint16_t _res33;
676 volatile uint16_t ep5dpr;
677 volatile uint16_t _res34;
678 volatile uint16_t ep6dpr;
679 volatile uint16_t _res35;
680 volatile uint16_t ep7dpr;
681/* uint8_t ram[1024]; */
682} usb_regs_t;
683
684extern intctrl_regs_t *g_intctrl_regs;
685extern chipsel_regs_t *g_chipsel_regs;
686extern gpio_regs_t *g_gpio_regs;
687extern qspi_regs_t *g_qspi_regs;
688extern pwm_regs_t *g_pwm_regs;
689extern dma_regs_t *g_dma_regs;
690extern uart_regs_t *g_uart0_regs;
691extern uart_regs_t *g_uart1_regs;
692extern timer_regs_t *g_timer_regs;
693extern plic_regs_t *g_plic_regs;
694extern enet_regs_t *g_enet_regs;
695extern usb_regs_t *g_usb_regs;
696
697#endif /* ASM */
698
699#endif /* __MCF5272_H__ */
Definition: mcf5272.h:244
Definition: mcf5272.h:318
Definition: mcf5272.h:543
Definition: mcf5272.h:263
Definition: mcf5272.h:232
Definition: mcf5272.h:463
Definition: mcf5272.h:298
Definition: mcf5272.h:289
Definition: mcf5272.h:215
Definition: mcf5272.h:381
Definition: mcf5272.h:331
Definition: mcf5272.h:576
