RTEMS 5.2
SPI bus control. More...
#include <spi.h>
int(* transfer )(spi_bus *bus, const spi_ioc_transfer *msgs, uint32_t msg_count)
 Transfers SPI messages. More...
int(* setup )(spi_bus *bus)
 Checks if maximum speed and bits per word are in a valid range for the device. More...
void(* destroy )(spi_bus *bus)
 Destroys the bus. More...
rtems_recursive_mutex mutex
 Mutex to protect the bus access.
uint32_t max_speed_hz
 Maximum Speed in Hz.
uint32_t speed_hz
 Indicates the speed of the current device message.
bool cs_change
 Indicates if chip select must be set high after transfer.
uint8_t cs
 Indicates which device is selected by chip select.
uint8_t bits_per_word
 Indicates the bits per word used on the device.
bool lsb_first
 Indicates if LSB is supposed to be transmitted first.
uint32_t mode
 Current mode.
uint16_t delay_usecs
 Indicates the delay between transfers on different chip select devices.
SPI bus control.
Field Documentation
◆ destroy
void(* spi_bus::destroy) (spi_bus *bus)
Destroys the bus.
Parameters
[in]busThe bus control.
◆ setup
int(* spi_bus::setup) (spi_bus *bus)
Parameters
Return values
0Successful operation.
negativeNegative error number in case of an error.
◆ transfer
int(* spi_bus::transfer) (spi_bus *bus, const spi_ioc_transfer *msgs, uint32_t msg_count)
Parameters
[in]msgsThe messages to transfer.
[in]msg_countThe count of messages to transfer. It must be positive.
Return values
