RTEMS 5.2
rtems_rtl_obj_depends Struct Reference
#include <rtl-obj.h>
rtems_chain_node node
size_t dependents
rtems_rtl_objdepends []
Object file dependents. This is a list of tables of pointers to the object modules the object file depends on. The table is a list of tables because unresolved externals can exist when an object file is loaded and resolved later when the dependent object file is loaded.
Field Documentation
◆ dependents
size_t rtems_rtl_obj_depends::dependents
The number of dependent object pointers.
◆ depends
rtems_rtl_obj* rtems_rtl_obj_depends::depends[]
Dependtent objects. More follow.
◆ node
rtems_chain_node rtems_rtl_obj_depends::node
The node's link in the chain.
