RTEMS 5.2
rtems_rtl_bit_alloc Struct Reference
#include <rtl-bit-alloc.h>
uint8_t * base
size_t size
uint32_t * bits
size_t block_size
size_t blocks
Bit Allocator data
Field Documentation
◆ base
uint8_t* rtems_rtl_bit_alloc::base
The memory being allocated.
◆ bits
uint32_t* rtems_rtl_bit_alloc::bits
The bit map indicating which blocks are allocated.
◆ block_size
size_t rtems_rtl_bit_alloc::block_size
The size of a block, the minimum allocation unit.
◆ blocks
size_t rtems_rtl_bit_alloc::blocks
The number of blocks in the memory.
◆ size
size_t rtems_rtl_bit_alloc::size
The number of bytes of memory being managed.
