RTEMS 5.2
rtems_bdbuf_config Struct Reference
#include <bdbuf.h>
uint32_t max_read_ahead_blocks
uint32_t max_write_blocks
rtems_task_priority swapout_priority
uint32_t swapout_period
uint32_t swap_block_hold
size_t swapout_workers
rtems_task_priority swapout_worker_priority
size_t task_stack_size
size_t size
uint32_t buffer_min
uint32_t buffer_max
rtems_task_priority read_ahead_priority
Buffering configuration definition. See confdefs.h for support on using this structure.
Field Documentation
◆ buffer_max
uint32_t rtems_bdbuf_config::buffer_max
Maximum buffer size supported. It is also the allocation size.
◆ buffer_min
uint32_t rtems_bdbuf_config::buffer_min
Minimum buffer size.
◆ max_read_ahead_blocks
uint32_t rtems_bdbuf_config::max_read_ahead_blocks
Number of blocks to read ahead.
◆ max_write_blocks
uint32_t rtems_bdbuf_config::max_write_blocks
Number of blocks to write at once.
◆ read_ahead_priority
rtems_task_priority rtems_bdbuf_config::read_ahead_priority
Priority of the read-ahead task.
◆ size
size_t rtems_bdbuf_config::size
Size of memory in the cache
◆ swap_block_hold
uint32_t rtems_bdbuf_config::swap_block_hold
Period a buffer is held.
◆ swapout_period
uint32_t rtems_bdbuf_config::swapout_period
Period swap-out checks buf timers.
◆ swapout_priority
rtems_task_priority rtems_bdbuf_config::swapout_priority
Priority of the swap out task.
◆ swapout_worker_priority
rtems_task_priority rtems_bdbuf_config::swapout_worker_priority
◆ swapout_workers
size_t rtems_bdbuf_config::swapout_workers
The number of worker threads for the swap-out task.
◆ task_stack_size
size_t rtems_bdbuf_config::task_stack_size
Task stack size for swap-out task and worker threads.
