RTEMS 5.2
ofw_tree_node Struct Reference
#include <ofw_tree.h>
struct ofw_tree_nodeparent
struct ofw_tree_nodepeer
struct ofw_tree_nodechild
uint32_t node_handle
char * da_name
unsigned int properties
ofw_tree_property_tproperty
void * device
Memory representation of OpenFirmware device tree node.
Field Documentation
◆ da_name
char * ofw_tree_node::da_name
Disambigued name.
◆ device
void * ofw_tree_node::device
Member used solely by the kernel.
Pointer to a structure representing respective device. Its semantics is device dependent.
◆ node_handle
uint32_t ofw_tree_node::node_handle
Old OpenFirmware node handle.
◆ properties
unsigned int ofw_tree_node::properties
Number of properties.
The documentation for this struct was generated from the following files:
