RTEMS 5.2
ide_ctrl_fns_s Struct Reference
bool(* ctrl_probe )(int minor)
void(* ctrl_initialize )(int minor)
int(* ctrl_control )(int minor, uint32_t command, void *arg)
void(* ctrl_reg_read )(int minor, int regist, uint16_t *value)
void(* ctrl_reg_write )(int minor, int regist, uint16_t value)
void(* ctrl_read_block )(int minor, uint32_t block_size, rtems_blkdev_sg_buffer *bufs, uint32_t *cbuf, uint32_t *pos)
void(* ctrl_write_block )(int minor, uint32_t block_size, rtems_blkdev_sg_buffer *bufs, uint32_t *cbuf, uint32_t *pos)
rtems_status_code(* ctrl_config_io_speed )(int minor, uint16_t modes_available)
