RTEMS 5.2
ide_ctrl_cfg.h
1/*
2 * ide_ctrl_cfg.h
3 *
4 * LibChip library IDE controller header file - structures used for
5 * configuration and plugin interface definition.
6 *
7 * Copyright (C) 2002 OKTET Ltd., St.-Petersburg, Russia
8 * Author: Eugeny S. Mints <Eugeny.Mints@oktet.ru>
9 *
10 * The license and distribution terms for this file may be
11 * found in the file LICENSE in this distribution or at
12 * http://www.rtems.org/license/LICENSE.
13 */
14#ifndef __IDE_CTRL_CFG_H__
15#define __IDE_CTRL_CFG_H__
16
17#include <rtems/blkdev.h>
18
19#ifdef __cplusplus
20extern "C" {
21#endif
22
23/*
24 * Avaible drivers for IDE controllers
25 */
26typedef enum {
27 IDE_STD,
28 IDE_CUSTOM /* BSP specific driver */
29} ide_ctrl_devs_t;
30
31/* ATA modes: bit masks used in ctrl_config_io_speed call */
32#define ATA_MODES_PIO3 0x001
33#define ATA_MODES_PIO4 0x002
34
35#define ATA_MODES_PIO 0x003
36
37#define ATA_MODES_DMA0 0x004
38#define ATA_MODES_DMA1 0x008
39#define ATA_MODES_DMA2 0x010
40
41#define ATA_MODES_UDMA0 0x020
42#define ATA_MODES_UDMA1 0x040
43#define ATA_MODES_UDMA2 0x080
44#define ATA_MODES_UDMA3 0x100
45#define ATA_MODES_UDMA4 0x200
46#define ATA_MODES_UDMA5 0x400
47
48#define ATA_MODES_UDMA 0x7e0
49#define ATA_MODES_DMA 0x7fc
50
51
52/*
53 * Each driver for a particular controller have to provide following
54 * functions in such a structure. The only field which should not be NULL
55 * is contInit.
56 */
57typedef struct ide_ctrl_fns_s {
58 bool (*ctrl_probe)(int minor); /* probe routine */
59 void (*ctrl_initialize)(int minor);
60 int (*ctrl_control)(int minor, uint32_t command,
61 void *arg);
62 /*
63 * Functions which allow read/write registers of a particular controller.
64 * (these functions may be used from ide_controller_read_register,
65 * ide_controller_write_register)
66 */
67 void (*ctrl_reg_read)(int minor, int regist, uint16_t *value);
68 void (*ctrl_reg_write)(int minor, int regist, uint16_t value);
69
70 /*
71 * The function allows to escape overhead for read/write register
72 * functions calls
73 */
74 void (*ctrl_read_block)(int minor, uint32_t block_size,
75 rtems_blkdev_sg_buffer *bufs, uint32_t *cbuf,
76 uint32_t *pos);
77 void (*ctrl_write_block)(int minor, uint32_t block_size,
78 rtems_blkdev_sg_buffer *bufs, uint32_t *cbuf,
79 uint32_t *pos);
80
81 rtems_status_code (*ctrl_config_io_speed)(int minor,
82 uint16_t modes_available);
84
85/*
86 * IDE Controller configuration. Table of such configurations is provided
87 * by BSP
88 */
90 char *name; /* device name */
91 ide_ctrl_devs_t type; /* chip type */
92 ide_ctrl_fns_t *fns; /* pointer to the set of driver routines */
93 bool (*probe)(int minor); /* general probe routine */
94 uint8_t status; /* initialized/non initialized. Should be set
95 * to zero by static initialization
96 */
97 uint32_t port1; /* port number for the port of the device */
98 bool int_driven; /* interrupt/poll driven */
99 rtems_vector_number int_vec; /* the interrupt vector of the device */
100 void *params; /* contains either device specific data or a
101 * pointer to s device specific information
102 * table
103 */
105
106/* IDE controllers Table */
107extern ide_controller_bsp_table_t IDE_Controller_Table[];
108
109/* Number of rows in IDE_Controller_Table */
110extern unsigned long IDE_Controller_Count;
111
112
113#define IDE_CTRL_MAX_MINOR_NUMBER 4
114
115#define IDE_CTRL_NON_INITIALIZED 0
116#define IDE_CTRL_INITIALIZED 1
117
118#ifdef __cplusplus
119}
120#endif
121
122
123#endif /* __IDE_CTRL_CFG_H__ */
Block Device Management.
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
rtems_status_code
Classic API Status.
Definition: status.h:43
Definition: ide_ctrl_cfg.h:89
Definition: ide_ctrl_cfg.h:57
Block device scatter or gather buffer structure.
Definition: blkdev.h:68
