RTEMS 5.2
Data Fields | |
| i2c_bus | base |
| volatile bbb_i2c_regs * | regs |
| struct { | |
| volatile uint32_t * ctrl_clkctrl | |
| volatile uint32_t * i2c_clkctrl | |
| volatile uint32_t * clkstctrl | |
| } | clkregs |
| struct { | |
| volatile uint32_t * conf_sda | |
| uint32_t mmode_sda | |
| volatile uint32_t * conf_scl | |
| uint32_t mmode_scl | |
| } | pinregs |
| rtems_id | task_id |
| rtems_vector_number | irq |
| i2c_msg * | buffer |
| size_t | buffer_pos |
| int | error |
| uint32_t | con_reg |
