RTEMS 5.2
atsam_sc16is752_spi_config Struct Reference
The SC16IS752 device configuration. More...
#include <sc16is752.h>
const char * device_path
 The device file path for the new device.
sc16is752_mode mode
 The SC16IS752 mode.
uint32_t input_frequency
 The input frequency in Hertz of the SC16IS752 chip. See XTAL1 and XTAL2 pins.
const char * spi_path
 The SPI bus device path.
uint8_t spi_chip_select
 The SPI chip select (starts with 0, the SPI driver uses SPI_ChipSelect(1 << spi_chip_select)).
uint32_t spi_speed_hz
 The SPI bus speed in Hertz.
const Pin irq_pin
 The interrupt pin, e.g. { PIO_PD28, PIOD, ID_PIOD, PIO_INPUT, PIO_IT_LOW_LEVEL }.
uint32_t server_index
 The index to identify the interrupt server used for interrupt processing.
See also
atsam_sc16is752_spi_create().
