RTEMS 5.2
_rtems_rfs_file_shared Struct Reference
#include <rtems-rfs-file.h>
rtems_chain_node link
int references
rtems_rfs_inode_handle inode
rtems_rfs_block_map map
rtems_rfs_block_size size
rtems_rfs_time atime
rtems_rfs_time mtime
rtems_rfs_time ctime
rtems_rfs_file_systemfs
File data that is shared by various file handles accessing the same file. We hold various inode values common to the file that can change frequently so the inode is not thrashed yet we meet the requirements of the POSIX standard. The stat call needs to check the shared file data.
Field Documentation
◆ atime
rtems_rfs_time _rtems_rfs_file_shared::atime
The access time. The last time the file was read.
◆ ctime
rtems_rfs_time _rtems_rfs_file_shared::ctime
The change time. The last time the inode was written too.
◆ fs
rtems_rfs_file_system* _rtems_rfs_file_shared::fs
Hold a pointer to the file system data so users can take the handle and use it without the needing to hold the file system data pointer.
◆ inode
rtems_rfs_inode_handle _rtems_rfs_file_shared::inode
The inode for the file.
◆ link
rtems_chain_node _rtems_rfs_file_shared::link
The shared parts are maintained as a list.
◆ map
rtems_rfs_block_map _rtems_rfs_file_shared::map
The block map for the file. The handle holds the file's position not the map.
◆ mtime
rtems_rfs_time _rtems_rfs_file_shared::mtime
The modified time. The last time the file was written too.
◆ references
int _rtems_rfs_file_shared::references
Reference count the users of this data.
◆ size
rtems_rfs_block_size _rtems_rfs_file_shared::size
The size of the file as taken from the inode. The map's size and this size should be the same.
