RTEMS 5.2
#include <rtems-rfs-file.h>
Data Fields | |
| int | flags |
| rtems_rfs_buffer_handle | buffer |
| rtems_rfs_block_pos | bpos |
| rtems_rfs_file_shared * | shared |
File data used to managed an open file.
| rtems_rfs_block_pos _rtems_rfs_file_handle::bpos |
The block position of this file handle.
| rtems_rfs_buffer_handle _rtems_rfs_file_handle::buffer |
The buffer of data at the file's position.
| int _rtems_rfs_file_handle::flags |
Special flags that can be controlled by the fctrl call.
| rtems_rfs_file_shared* _rtems_rfs_file_handle::shared |
Pointer to the shared file data.
