RTEMS 5.2
ERC32_Register_Map Struct Reference
volatile uint32_t Control
volatile uint32_t Software_Reset
volatile uint32_t Power_Down
volatile uint32_t Unimplemented_0
volatile uint32_t Memory_Configuration
volatile uint32_t IO_Configuration
volatile uint32_t Wait_State_Configuration
volatile uint32_t Unimplemented_1
volatile uint32_t Memory_Access_0
volatile uint32_t Memory_Access_1
volatile uint32_t Unimplemented_2 [7]
volatile uint32_t Interrupt_Shape
volatile uint32_t Interrupt_Pending
volatile uint32_t Interrupt_Mask
volatile uint32_t Interrupt_Clear
volatile uint32_t Interrupt_Force
volatile uint32_t Unimplemented_3 [2]
volatile uint32_t Watchdog_Program_and_Timeout_Acknowledge
volatile uint32_t Watchdog_Trap_Door_Set
volatile uint32_t Unimplemented_4 [6]
volatile uint32_t Real_Time_Clock_Counter
volatile uint32_t Real_Time_Clock_Scalar
volatile uint32_t General_Purpose_Timer_Counter
volatile uint32_t General_Purpose_Timer_Scalar
volatile uint32_t Unimplemented_5 [2]
volatile uint32_t Timer_Control
volatile uint32_t Unimplemented_6
volatile uint32_t System_Fault_Status
volatile uint32_t First_Failing_Address
volatile uint32_t First_Failing_Data
volatile uint32_t First_Failing_Syndrome_and_Check_Bits
volatile uint32_t Error_and_Reset_Status
volatile uint32_t Error_Mask
volatile uint32_t Unimplemented_7 [2]
volatile uint32_t Debug_Control
volatile uint32_t Breakpoint
volatile uint32_t Watchpoint
volatile uint32_t Unimplemented_8
volatile uint32_t Test_Control
volatile uint32_t Test_Data
volatile uint32_t Unimplemented_9 [2]
volatile uint32_t UART_Channel_A
volatile uint32_t UART_Channel_B
volatile uint32_t UART_Status
