RTEMS 5.2
erc32.h
1
7/* erc32.h
8 *
9 * This include file contains information pertaining to the ERC32.
10 * The ERC32 is a custom SPARC V7 implementation based on the Cypress
11 * 601/602 chipset. This CPU has a number of on-board peripherals and
12 * was developed by the European Space Agency to target space applications.
13 *
14 * NOTE: Other than where absolutely required, this version currently
15 * supports only the peripherals and bits used by the basic board
16 * support package. This includes at least significant pieces of
17 * the following items:
18 *
19 * + UART Channels A and B
20 * + General Purpose Timer
21 * + Real Time Clock
22 * + Watchdog Timer (so it can be disabled)
23 * + Control Register (so powerdown mode can be enabled)
24 * + Memory Control Register
25 * + Interrupt Control
26 *
27 * COPYRIGHT (c) 1989-1999.
28 * On-Line Applications Research Corporation (OAR).
29 *
30 * The license and distribution terms for this file may be
31 * found in the file LICENSE in this distribution or at
32 * http://www.rtems.org/license/LICENSE.
33 *
34 * Ported to ERC32 implementation of the SPARC by On-Line Applications
35 * Research Corporation (OAR) under contract to the European Space
36 * Agency (ESA).
37 *
38 * ERC32 modifications of respective RTEMS file: COPYRIGHT (c) 1995.
39 * European Space Agency.
40 */
41
42#ifndef _INCLUDE_ERC32_h
43#define _INCLUDE_ERC32_h
44
45#include <rtems/score/sparc.h>
46
47#ifdef __cplusplus
48extern "C" {
49#endif
50
51/*
52 * Interrupt Sources
53 *
54 * The interrupt source numbers directly map to the trap type and to
55 * the bits used in the Interrupt Clear, Interrupt Force, Interrupt Mask,
56 * and the Interrupt Pending Registers.
57 */
58
59#define ERC32_INTERRUPT_MASKED_ERRORS 1
60#define ERC32_INTERRUPT_EXTERNAL_1 2
61#define ERC32_INTERRUPT_EXTERNAL_2 3
62#define ERC32_INTERRUPT_UART_A_RX_TX 4
63#define ERC32_INTERRUPT_UART_B_RX_TX 5
64#define ERC32_INTERRUPT_CORRECTABLE_MEMORY_ERROR 6
65#define ERC32_INTERRUPT_UART_ERROR 7
66#define ERC32_INTERRUPT_DMA_ACCESS_ERROR 8
67#define ERC32_INTERRUPT_DMA_TIMEOUT 9
68#define ERC32_INTERRUPT_EXTERNAL_3 10
69#define ERC32_INTERRUPT_EXTERNAL_4 11
70#define ERC32_INTERRUPT_GENERAL_PURPOSE_TIMER 12
71#define ERC32_INTERRUPT_REAL_TIME_CLOCK 13
72#define ERC32_INTERRUPT_EXTERNAL_5 14
73#define ERC32_INTERRUPT_WATCHDOG_TIMEOUT 15
74
75#ifndef ASM
76
77/*
78 * Trap Types for on-chip peripherals
79 *
80 * Source: Table 8 - Interrupt Trap Type and Default Priority Assignments
81 *
82 * NOTE: The priority level for each source corresponds to the least
83 * significant nibble of the trap type.
84 */
85
86#define ERC32_TRAP_TYPE( _source ) SPARC_ASYNCHRONOUS_TRAP((_source) + 0x10)
87
88#define ERC32_TRAP_SOURCE( _trap ) ((_trap) - 0x10)
89
90#define ERC32_Is_MEC_Trap( _trap ) \
91 ( (_trap) >= ERC32_TRAP_TYPE( ERC32_INTERRUPT_MASKED_ERRORS ) && \
92 (_trap) <= ERC32_TRAP_TYPE( ERC32_INTERRUPT_WATCHDOG_TIMEOUT ) )
93
94/*
95 * Structure for ERC32 memory mapped registers.
96 *
97 * Source: Section 3.25.2 - Register Address Map
98 *
99 * NOTE: There is only one of these structures per CPU, its base address
100 * is 0x01f80000, and the variable MEC is placed there by the
101 * linkcmds file.
102 */
103
104typedef struct {
105 volatile uint32_t Control; /* offset 0x00 */
106 volatile uint32_t Software_Reset; /* offset 0x04 */
107 volatile uint32_t Power_Down; /* offset 0x08 */
108 volatile uint32_t Unimplemented_0; /* offset 0x0c */
109 volatile uint32_t Memory_Configuration; /* offset 0x10 */
110 volatile uint32_t IO_Configuration; /* offset 0x14 */
111 volatile uint32_t Wait_State_Configuration; /* offset 0x18 */
112 volatile uint32_t Unimplemented_1; /* offset 0x1c */
113 volatile uint32_t Memory_Access_0; /* offset 0x20 */
114 volatile uint32_t Memory_Access_1; /* offset 0x24 */
115 volatile uint32_t Unimplemented_2[ 7 ]; /* offset 0x28 */
116 volatile uint32_t Interrupt_Shape; /* offset 0x44 */
117 volatile uint32_t Interrupt_Pending; /* offset 0x48 */
118 volatile uint32_t Interrupt_Mask; /* offset 0x4c */
119 volatile uint32_t Interrupt_Clear; /* offset 0x50 */
120 volatile uint32_t Interrupt_Force; /* offset 0x54 */
121 volatile uint32_t Unimplemented_3[ 2 ]; /* offset 0x58 */
122 /* offset 0x60 */
123 volatile uint32_t Watchdog_Program_and_Timeout_Acknowledge;
124 volatile uint32_t Watchdog_Trap_Door_Set; /* offset 0x64 */
125 volatile uint32_t Unimplemented_4[ 6 ]; /* offset 0x68 */
126 volatile uint32_t Real_Time_Clock_Counter; /* offset 0x80 */
127 volatile uint32_t Real_Time_Clock_Scalar; /* offset 0x84 */
128 volatile uint32_t General_Purpose_Timer_Counter; /* offset 0x88 */
129 volatile uint32_t General_Purpose_Timer_Scalar; /* offset 0x8c */
130 volatile uint32_t Unimplemented_5[ 2 ]; /* offset 0x90 */
131 volatile uint32_t Timer_Control; /* offset 0x98 */
132 volatile uint32_t Unimplemented_6; /* offset 0x9c */
133 volatile uint32_t System_Fault_Status; /* offset 0xa0 */
134 volatile uint32_t First_Failing_Address; /* offset 0xa4 */
135 volatile uint32_t First_Failing_Data; /* offset 0xa8 */
136 volatile uint32_t First_Failing_Syndrome_and_Check_Bits;/* offset 0xac */
137 volatile uint32_t Error_and_Reset_Status; /* offset 0xb0 */
138 volatile uint32_t Error_Mask; /* offset 0xb4 */
139 volatile uint32_t Unimplemented_7[ 2 ]; /* offset 0xb8 */
140 volatile uint32_t Debug_Control; /* offset 0xc0 */
141 volatile uint32_t Breakpoint; /* offset 0xc4 */
142 volatile uint32_t Watchpoint; /* offset 0xc8 */
143 volatile uint32_t Unimplemented_8; /* offset 0xcc */
144 volatile uint32_t Test_Control; /* offset 0xd0 */
145 volatile uint32_t Test_Data; /* offset 0xd4 */
146 volatile uint32_t Unimplemented_9[ 2 ]; /* offset 0xd8 */
147 volatile uint32_t UART_Channel_A; /* offset 0xe0 */
148 volatile uint32_t UART_Channel_B; /* offset 0xe4 */
149 volatile uint32_t UART_Status; /* offset 0xe8 */
151
152#endif
153
154/*
155 * The following constants are intended to be used ONLY in assembly
156 * language files.
157 *
158 * NOTE: The intended style of usage is to load the address of MEC
159 * into a register and then use these as displacements from
160 * that register.
161 */
162
163#ifdef ASM
164
165#define ERC32_MEC_CONTROL_OFFSET 0x00
166#define ERC32_MEC_SOFTWARE_RESET_OFFSET 0x04
167#define ERC32_MEC_POWER_DOWN_OFFSET 0x08
168#define ERC32_MEC_UNIMPLEMENTED_0_OFFSET 0x0C
169#define ERC32_MEC_MEMORY_CONFIGURATION_OFFSET 0x10
170#define ERC32_MEC_IO_CONFIGURATION_OFFSET 0x14
171#define ERC32_MEC_WAIT_STATE_CONFIGURATION_OFFSET 0x18
172#define ERC32_MEC_UNIMPLEMENTED_1_OFFSET 0x1C
173#define ERC32_MEC_MEMORY_ACCESS_0_OFFSET 0x20
174#define ERC32_MEC_MEMORY_ACCESS_1_OFFSET 0x24
175#define ERC32_MEC_UNIMPLEMENTED_2_OFFSET 0x28
176#define ERC32_MEC_INTERRUPT_SHAPE_OFFSET 0x44
177#define ERC32_MEC_INTERRUPT_PENDING_OFFSET 0x48
178#define ERC32_MEC_INTERRUPT_MASK_OFFSET 0x4C
179#define ERC32_MEC_INTERRUPT_CLEAR_OFFSET 0x50
180#define ERC32_MEC_INTERRUPT_FORCE_OFFSET 0x54
181#define ERC32_MEC_UNIMPLEMENTED_3_OFFSET 0x58
182#define ERC32_MEC_WATCHDOG_PROGRAM_AND_TIMEOUT_ACKNOWLEDGE_OFFSET 0x60
183#define ERC32_MEC_WATCHDOG_TRAP_DOOR_SET_OFFSET 0x64
184#define ERC32_MEC_UNIMPLEMENTED_4_OFFSET 0x6C
185#define ERC32_MEC_REAL_TIME_CLOCK_COUNTER_OFFSET 0x80
186#define ERC32_MEC_REAL_TIME_CLOCK_SCALAR_OFFSET 0x84
187#define ERC32_MEC_GENERAL_PURPOSE_TIMER_COUNTER_OFFSET 0x88
188#define ERC32_MEC_GENERAL_PURPOSE_TIMER_SCALAR_OFFSET 0x8C
189#define ERC32_MEC_UNIMPLEMENTED_5_OFFSET 0x90
190#define ERC32_MEC_TIMER_CONTROL_OFFSET 0x98
191#define ERC32_MEC_UNIMPLEMENTED_6_OFFSET 0x9C
192#define ERC32_MEC_SYSTEM_FAULT_STATUS_OFFSET 0xA0
193#define ERC32_MEC_FIRST_FAILING_ADDRESS_OFFSET 0xA4
194#define ERC32_MEC_FIRST_FAILING_DATA_OFFSET 0xA8
195#define ERC32_MEC_FIRST_FAILING_SYNDROME_AND_CHECK_BITS_OFFSET 0xAC
196#define ERC32_MEC_ERROR_AND_RESET_STATUS_OFFSET 0xB0
197#define ERC32_MEC_ERROR_MASK_OFFSET 0xB4
198#define ERC32_MEC_UNIMPLEMENTED_7_OFFSET 0xB8
199#define ERC32_MEC_DEBUG_CONTROL_OFFSET 0xC0
200#define ERC32_MEC_BREAKPOINT_OFFSET 0xC4
201#define ERC32_MEC_WATCHPOINT_OFFSET 0xC8
202#define ERC32_MEC_UNIMPLEMENTED_8_OFFSET 0xCC
203#define ERC32_MEC_TEST_CONTROL_OFFSET 0xD0
204#define ERC32_MEC_TEST_DATA_OFFSET 0xD4
205#define ERC32_MEC_UNIMPLEMENTED_9_OFFSET 0xD8
206#define ERC32_MEC_UART_CHANNEL_A_OFFSET 0xE0
207#define ERC32_MEC_UART_CHANNEL_B_OFFSET 0xE4
208#define ERC32_MEC_UART_STATUS_OFFSET 0xE8
209
210#endif
211
212/*
213 * The following defines the bits in the Configuration Register.
214 */
215
216#define ERC32_CONFIGURATION_POWER_DOWN_MASK 0x00000001
217#define ERC32_CONFIGURATION_POWER_DOWN_ALLOWED 0x00000001
218#define ERC32_CONFIGURATION_POWER_DOWN_DISABLED 0x00000000
219
220#define ERC32_CONFIGURATION_SOFTWARE_RESET_MASK 0x00000002
221#define ERC32_CONFIGURATION_SOFTWARE_RESET_ALLOWED 0x00000002
222#define ERC32_CONFIGURATION_SOFTWARE_RESET_DISABLED 0x00000000
223
224#define ERC32_CONFIGURATION_BUS_TIMEOUT_MASK 0x00000004
225#define ERC32_CONFIGURATION_BUS_TIMEOUT_ENABLED 0x00000004
226#define ERC32_CONFIGURATION_BUS_TIMEOUT_DISABLED 0x00000000
227
228#define ERC32_CONFIGURATION_ACCESS_PROTECTION_MASK 0x00000008
229#define ERC32_CONFIGURATION_ACCESS_PROTECTION_ENABLED 0x00000008
230#define ERC32_CONFIGURATION_ACCESS_PROTECTION_DISABLED 0x00000000
231
232/*
233 * The following defines the bits in the Memory Configuration Register.
234 */
235
236#define ERC32_MEMORY_CONFIGURATION_RAM_SIZE_MASK 0x00001C00
237#define ERC32_MEMORY_CONFIGURATION_RAM_SIZE_256K ( 0 << 10 )
238#define ERC32_MEMORY_CONFIGURATION_RAM_SIZE_512K ( 1 << 10 )
239#define ERC32_MEMORY_CONFIGURATION_RAM_SIZE_1MB ( 2 << 10 )
240#define ERC32_MEMORY_CONFIGURATION_RAM_SIZE_2MB ( 3 << 10 )
241#define ERC32_MEMORY_CONFIGURATION_RAM_SIZE_4MB ( 4 << 10 )
242#define ERC32_MEMORY_CONFIGURATION_RAM_SIZE_8MB ( 5 << 10 )
243#define ERC32_MEMORY_CONFIGURATION_RAM_SIZE_16MB ( 6 << 10 )
244#define ERC32_MEMORY_CONFIGURATION_RAM_SIZE_32MB ( 7 << 10 )
245
246#define ERC32_MEMORY_CONFIGURATION_PROM_SIZE_MASK 0x001C0000
247#define ERC32_MEMORY_CONFIGURATION_PROM_SIZE_128K ( 0 << 18 )
248#define ERC32_MEMORY_CONFIGURATION_PROM_SIZE_256K ( 1 << 18 )
249#define ERC32_MEMORY_CONFIGURATION_PROM_SIZE_512K ( 2 << 18 )
250#define ERC32_MEMORY_CONFIGURATION_PROM_SIZE_1M ( 3 << 18 )
251#define ERC32_MEMORY_CONFIGURATION_PROM_SIZE_2M ( 4 << 18 )
252#define ERC32_MEMORY_CONFIGURATION_PROM_SIZE_4M ( 5 << 18 )
253#define ERC32_MEMORY_CONFIGURATION_PROM_SIZE_8M ( 6 << 18 )
254#define ERC32_MEMORY_CONFIGURATION_PROM_SIZE_16M ( 7 << 18 )
255
256/*
257 * The following defines the bits in the Timer Control Register.
258 */
259
260#define ERC32_MEC_TIMER_CONTROL_GCR 0x00000001 /* 1 = reload at 0 */
261 /* 0 = stop at 0 */
262#define ERC32_MEC_TIMER_CONTROL_GCL 0x00000002 /* 1 = load and start */
263 /* 0 = no function */
264#define ERC32_MEC_TIMER_CONTROL_GSE 0x00000004 /* 1 = enable counting */
265 /* 0 = hold scalar and counter */
266#define ERC32_MEC_TIMER_CONTROL_GSL 0x00000008 /* 1 = load scalar and start*/
267 /* 0 = no function */
268
269#define ERC32_MEC_TIMER_CONTROL_RTCCR 0x00000100 /* 1 = reload at 0 */
270 /* 0 = stop at 0 */
271#define ERC32_MEC_TIMER_CONTROL_RTCCL 0x00000200 /* 1 = load and start */
272 /* 0 = no function */
273#define ERC32_MEC_TIMER_CONTROL_RTCSE 0x00000400 /* 1 = enable counting */
274 /* 0 = hold scalar and counter */
275#define ERC32_MEC_TIMER_CONTROL_RTCSL 0x00000800 /* 1 = load scalar and start*/
276 /* 0 = no function */
277
278/*
279 * The following defines the bits in the UART Control Registers.
280 *
281 */
282
283#define ERC32_MEC_UART_CONTROL_RTD 0x000000FF /* RX/TX data */
284
285/*
286 * The following defines the bits in the MEC UART Control Registers.
287 */
288
289#define ERC32_MEC_UART_STATUS_DR 0x00000001 /* Data Ready */
290#define ERC32_MEC_UART_STATUS_TSE 0x00000002 /* TX Send Register Empty */
291#define ERC32_MEC_UART_STATUS_THE 0x00000004 /* TX Hold Register Empty */
292#define ERC32_MEC_UART_STATUS_FE 0x00000010 /* RX Framing Error */
293#define ERC32_MEC_UART_STATUS_PE 0x00000020 /* RX Parity Error */
294#define ERC32_MEC_UART_STATUS_OE 0x00000040 /* RX Overrun Error */
295#define ERC32_MEC_UART_STATUS_CU 0x00000080 /* Clear Errors */
296#define ERC32_MEC_UART_STATUS_TXE 0x00000006 /* TX Empty */
297#define ERC32_MEC_UART_STATUS_CLRA 0x00000080 /* Clear UART A */
298#define ERC32_MEC_UART_STATUS_CLRB 0x00800000 /* Clear UART B */
299#define ERC32_MEC_UART_STATUS_ERRA 0x00000070 /* Error in UART A */
300#define ERC32_MEC_UART_STATUS_ERRB 0x00700000 /* Error in UART B */
301
302#define ERC32_MEC_UART_STATUS_DRA (ERC32_MEC_UART_STATUS_DR << 0)
303#define ERC32_MEC_UART_STATUS_TSEA (ERC32_MEC_UART_STATUS_TSE << 0)
304#define ERC32_MEC_UART_STATUS_THEA (ERC32_MEC_UART_STATUS_THE << 0)
305#define ERC32_MEC_UART_STATUS_FEA (ERC32_MEC_UART_STATUS_FE << 0)
306#define ERC32_MEC_UART_STATUS_PEA (ERC32_MEC_UART_STATUS_PE << 0)
307#define ERC32_MEC_UART_STATUS_OEA (ERC32_MEC_UART_STATUS_OE << 0)
308#define ERC32_MEC_UART_STATUS_CUA (ERC32_MEC_UART_STATUS_CU << 0)
309#define ERC32_MEC_UART_STATUS_TXEA (ERC32_MEC_UART_STATUS_TXE << 0)
310
311#define ERC32_MEC_UART_STATUS_DRB (ERC32_MEC_UART_STATUS_DR << 16)
312#define ERC32_MEC_UART_STATUS_TSEB (ERC32_MEC_UART_STATUS_TSE << 16)
313#define ERC32_MEC_UART_STATUS_THEB (ERC32_MEC_UART_STATUS_THE << 16)
314#define ERC32_MEC_UART_STATUS_FEB (ERC32_MEC_UART_STATUS_FE << 16)
315#define ERC32_MEC_UART_STATUS_PEB (ERC32_MEC_UART_STATUS_PE << 16)
316#define ERC32_MEC_UART_STATUS_OEB (ERC32_MEC_UART_STATUS_OE << 16)
317#define ERC32_MEC_UART_STATUS_CUB (ERC32_MEC_UART_STATUS_CU << 16)
318#define ERC32_MEC_UART_STATUS_TXEB (ERC32_MEC_UART_STATUS_TXE << 16)
319
320#ifndef ASM
321
322/*
323 * This is used to manipulate the on-chip registers.
324 *
325 * The following symbol must be defined in the linkcmds file and point
326 * to the correct location.
327 */
328
329extern ERC32_Register_Map ERC32_MEC;
330
331static __inline__ int bsp_irq_fixup(int irq)
332{
333 return irq;
334}
335
336/*
337 * Macros to manipulate the Interrupt Clear, Interrupt Force, Interrupt Mask,
338 * and the Interrupt Pending Registers.
339 *
340 * NOTE: For operations which are not atomic, this code disables interrupts
341 * to guarantee there are no intervening accesses to the same register.
342 * The operations which read the register, modify the value and then
343 * store the result back are vulnerable.
344 */
345
346#define ERC32_Clear_interrupt( _source ) \
347 do { \
348 ERC32_MEC.Interrupt_Clear = (1 << (_source)); \
349 } while (0)
350
351#define ERC32_Force_interrupt( _source ) \
352 do { \
353 uint32_t _level; \
354 \
355 _level = sparc_disable_interrupts(); \
356 ERC32_MEC.Test_Control = ERC32_MEC.Test_Control | 0x80000; \
357 ERC32_MEC.Interrupt_Force = (1 << (_source)); \
358 sparc_enable_interrupts( _level ); \
359 } while (0)
360
361#define ERC32_Is_interrupt_pending( _source ) \
362 (ERC32_MEC.Interrupt_Pending & (1 << (_source)))
363
364#define ERC32_Is_interrupt_masked( _source ) \
365 (ERC32_MEC.Interrupt_Mask & (1 << (_source)))
366
367#define ERC32_Mask_interrupt( _source ) \
368 do { \
369 uint32_t _level; \
370 \
371 _level = sparc_disable_interrupts(); \
372 ERC32_MEC.Interrupt_Mask |= (1 << (_source)); \
373 sparc_enable_interrupts( _level ); \
374 } while (0)
375
376#define ERC32_Unmask_interrupt( _source ) \
377 do { \
378 uint32_t _level; \
379 \
380 _level = sparc_disable_interrupts(); \
381 ERC32_MEC.Interrupt_Mask &= ~(1 << (_source)); \
382 sparc_enable_interrupts( _level ); \
383 } while (0)
384
385#define ERC32_Disable_interrupt( _source, _previous ) \
386 do { \
387 uint32_t _level; \
388 uint32_t _mask = 1 << (_source); \
389 \
390 _level = sparc_disable_interrupts(); \
391 (_previous) = ERC32_MEC.Interrupt_Mask; \
392 ERC32_MEC.Interrupt_Mask = _previous | _mask; \
393 sparc_enable_interrupts( _level ); \
394 (_previous) &= _mask; \
395 } while (0)
396
397#define ERC32_Restore_interrupt( _source, _previous ) \
398 do { \
399 uint32_t _level; \
400 uint32_t _mask = 1 << (_source); \
401 \
402 _level = sparc_disable_interrupts(); \
403 ERC32_MEC.Interrupt_Mask = \
404 (ERC32_MEC.Interrupt_Mask & ~_mask) | (_previous); \
405 sparc_enable_interrupts( _level ); \
406 } while (0)
407
408/* Make all SPARC BSPs have common macros for interrupt handling on local CPU */
409#define BSP_Clear_interrupt(_source) ERC32_Clear_interrupt(_source)
410#define BSP_Force_interrupt(_source) ERC32_Force_interrupt(_source)
411#define BSP_Is_interrupt_pending(_source) ERC32_Is_interrupt_pending(_source)
412#define BSP_Is_interrupt_masked(_source) ERC32_Is_interrupt_masked(_source)
413#define BSP_Unmask_interrupt(_source) ERC32_Unmask_interrupt(_source)
414#define BSP_Mask_interrupt(_source) ERC32_Mask_interrupt(_source)
415#define BSP_Disable_interrupt(_source, _previous) \
416 ERC32_Disable_interrupt(_source, _prev)
417#define BSP_Restore_interrupt(_source, _previous) \
418 ERC32_Restore_interrupt(_source, _previous)
419
420/* Make all SPARC BSPs have common macros for interrupt handling on any CPU */
421#define BSP_Cpu_Is_interrupt_masked(_source, _cpu) \
422 BSP_Is_interrupt_masked(_source)
423#define BSP_Cpu_Unmask_interrupt(_source, _cpu) \
424 BSP_Unmask_interrupt(_source)
425#define BSP_Cpu_Mask_interrupt(_source, _cpu) \
426 BSP_Mask_interrupt(_source)
427#define BSP_Cpu_Disable_interrupt(_source, _previous, _cpu) \
428 BSP_Disable_interrupt(_source, _prev)
429#define BSP_Cpu_Restore_interrupt(_source, _previous, _cpu) \
430 BSP_Cpu_Restore_interrupt(_source, _previous)
431
432/*
433 * The following macros attempt to hide the fact that the General Purpose
434 * Timer and Real Time Clock Timer share the Timer Control Register. Because
435 * the Timer Control Register is write only, we must mirror it in software
436 * and insure that writes to one timer do not alter the current settings
437 * and status of the other timer.
438 *
439 * This code promotes the view that the two timers are completely independent.
440 * By exclusively using the routines below to access the Timer Control
441 * Register, the application can view the system as having a General Purpose
442 * Timer Control Register and a Real Time Clock Timer Control Register
443 * rather than the single shared value.
444 *
445 * Each logical timer control register is organized as follows:
446 *
447 * D0 - Counter Reload
448 * 1 = reload counter at zero and restart
449 * 0 = stop counter at zero
450 *
451 * D1 - Counter Load
452 * 1 = load counter with preset value and restart
453 * 0 = no function
454 *
455 * D2 - Enable
456 * 1 = enable counting
457 * 0 = hold scaler and counter
458 *
459 * D3 - Scaler Load
460 * 1 = load scalar with preset value and restart
461 * 0 = no function
462 *
463 * To insure the management of the mirror is atomic, we disable interrupts
464 * around updates.
465 */
466
467#define ERC32_MEC_TIMER_COUNTER_RELOAD_AT_ZERO 0x00000001
468#define ERC32_MEC_TIMER_COUNTER_STOP_AT_ZERO 0x00000000
469
470#define ERC32_MEC_TIMER_COUNTER_LOAD_COUNTER 0x00000002
471
472#define ERC32_MEC_TIMER_COUNTER_ENABLE_COUNTING 0x00000004
473#define ERC32_MEC_TIMER_COUNTER_DISABLE_COUNTING 0x00000000
474
475#define ERC32_MEC_TIMER_COUNTER_LOAD_SCALER 0x00000008
476
477#define ERC32_MEC_TIMER_COUNTER_RELOAD_MASK 0x00000001
478#define ERC32_MEC_TIMER_COUNTER_ENABLE_MASK 0x00000004
479
480#define ERC32_MEC_TIMER_COUNTER_DEFINED_MASK 0x0000000F
481#define ERC32_MEC_TIMER_COUNTER_CURRENT_MODE_MASK 0x00000005
482
483extern uint32_t _ERC32_MEC_Timer_Control_Mirror;
484
485/*
486 * This macros manipulate the General Purpose Timer portion of the
487 * Timer Control register and promote the view that there are actually
488 * two independent Timer Control Registers.
489 */
490
491#define ERC32_MEC_Set_General_Purpose_Timer_Control( _value ) \
492 do { \
493 uint32_t _level; \
494 uint32_t _control; \
495 uint32_t __value; \
496 \
497 __value = ((_value) & 0x0f); \
498 _level = sparc_disable_interrupts(); \
499 _control = _ERC32_MEC_Timer_Control_Mirror; \
500 _control &= ERC32_MEC_TIMER_COUNTER_DEFINED_MASK << 8; \
501 _ERC32_MEC_Timer_Control_Mirror = _control | _value; \
502 _control &= (ERC32_MEC_TIMER_COUNTER_CURRENT_MODE_MASK << 8); \
503 _control |= __value; \
504 /* printf( "GPT 0x%x 0x%x 0x%x\n", _value, __value, _control ); */ \
505 ERC32_MEC.Timer_Control = _control; \
506 sparc_enable_interrupts( _level ); \
507 } while ( 0 )
508
509#define ERC32_MEC_Get_General_Purpose_Timer_Control( _value ) \
510 do { \
511 (_value) = _ERC32_MEC_Timer_Control_Mirror & 0xf; \
512 } while ( 0 )
513
514/*
515 * This macros manipulate the Real Timer Clock Timer portion of the
516 * Timer Control register and promote the view that there are actually
517 * two independent Timer Control Registers.
518 */
519
520#define ERC32_MEC_Set_Real_Time_Clock_Timer_Control( _value ) \
521 do { \
522 uint32_t _level; \
523 uint32_t _control; \
524 uint32_t __value; \
525 \
526 __value = ((_value) & 0x0f) << 8; \
527 _level = sparc_disable_interrupts(); \
528 _control = _ERC32_MEC_Timer_Control_Mirror; \
529 _control &= ERC32_MEC_TIMER_COUNTER_DEFINED_MASK; \
530 _ERC32_MEC_Timer_Control_Mirror = _control | __value; \
531 _control &= ERC32_MEC_TIMER_COUNTER_CURRENT_MODE_MASK; \
532 _control |= __value; \
533 /* printf( "RTC 0x%x 0x%x 0x%x\n", _value, __value, _control ); */ \
534 ERC32_MEC.Timer_Control = _control; \
535 sparc_enable_interrupts( _level ); \
536 } while ( 0 )
537
538#define ERC32_MEC_Get_Real_Time_Clock_Timer_Control( _value ) \
539 do { \
540 (_value) = (_ERC32_MEC_Timer_Control_Mirror >> 8) & 0xf; \
541 } while ( 0 )
542
543#endif /* !ASM */
544
545#ifdef __cplusplus
546}
547#endif
548
549#endif /* !_INCLUDE_ERC32_h */
Information Required to Build RTEMS for a Particular Member of the SPARC Family.
Definition: erc32.h:104
Definition: timerdata.h:41
