RTEMS 5.2
#include <alt_clock_manager.h>
Data Fields | |
| ALT_CLK_t | ref_clk |
| uint32_t | mult |
| uint32_t | div |
| uint32_t | cntrs [6] |
| uint32_t | pshift [6] |
This type definition defines a structure to contain the generalized configuration settings for a PLL.
| uint32_t ALT_CLK_PLL_CFG_s::cntrs[6] |
Post-Scale Counters (C0 - C5) - range 1 to 512
| uint32_t ALT_CLK_PLL_CFG_s::div |
VCO Frequency Configuration - Divider (N) value, range 1 to 64
| uint32_t ALT_CLK_PLL_CFG_s::mult |
VCO Frequency Configuration - Multiplier (M) value, range 1 to 4096
| uint32_t ALT_CLK_PLL_CFG_s::pshift[6] |
Phase Shift - 1/8 (45 degrees) of negative phase shift per increment, range 0 to 4096
| ALT_CLK_t ALT_CLK_PLL_CFG_s::ref_clk |
PLL Reference Clock Source
