RTEMS 5.2
stm32f4xxxx_tim.h
1/*
2 * Copyright (c) 2013 Chris Nott. All rights reserved.
3 *
4 * Virtual Logic
5 * 21-25 King St.
6 * Rockdale NSW 2216
7 * Australia
8 * <rtems@vl.com.au>
9 *
10 * The license and distribution terms for this file may be
11 * found in the file LICENSE in this distribution or at
12 * http://www.rtems.org/license/LICENSE.
13 */
14
15#ifndef LIBBSP_ARM_STM32F4_STM32F4XXXX_TIM_H
16#define LIBBSP_ARM_STM32F4_STM32F4XXXX_TIM_H
17
18#include <bsp/utility.h>
19
21 uint16_t cr1; // Control register 1
22#define STM32F4_TIMER_CR1_CKD_DIV 0x0300
23#define STM32F4_TIMER_CR1_CKD_DIV1 0x0000
24#define STM32F4_TIMER_CR1_CKD_DIV2 0x0100
25#define STM32F4_TIMER_CR1_CKD_DIV3 0x0200
26#define STM32F4_TIMER_CR1_ARPE BSP_BIT16(7)
27#define STM32F4_TIMER_CR1_CMS 0x0060
28#define STM32F4_TIMER_CR1_CMS_EDGE 0x0000
29#define STM32F4_TIMER_CR1_CMS_CENTER1 0x0020
30#define STM32F4_TIMER_CR1_CMS_CENTER2 0x0040
31#define STM32F4_TIMER_CR1_CMS_CENTER3 0x0060
32#define STM32F4_TIMER_CR1_DIR BSP_BIT16(4)
33#define STM32F4_TIMER_CR1_DIR_UP 0x0000
34#define STM32F4_TIMER_CR1_DIR_DOWN 0x0010
35#define STM32F4_TIMER_CR1_DIR_OPM 0x0008
36#define STM32F4_TIMER_CR1_DIR_OPM_CONT 0x0000
37#define STM32F4_TIMER_CR1_DIR_OPM_STOP 0x0008
38#define STM32F4_TIMER_CR1_DIR_URS 0x0004
39#define STM32F4_TIMER_CR1_DIR_UDIS 0x0002
40#define STM32F4_TIMER_CR1_DIR_UDIS_EN 0x0000
41#define STM32F4_TIMER_CR1_DIR_UDIS_DIS 0x0002
42#define STM32F4_TIMER_CR1_CEN 0x0001
43 uint16_t reserved_02;
44 uint16_t cr2; // Control register 2
45 uint16_t reserved_06;
46 uint16_t smcr; // Slave mode control register
47 uint16_t reserved_0a;
48 uint16_t dier; // DMA / interrupt enable register
49#define STM32F4_TIMER_DIER_TDE BSP_BIT16(14) // Trigger DMA request enable
50#define STM32F4_TIMER_DIER_CC4DE BSP_BIT16(12) // Capture/compare 4 DMA request enable
51#define STM32F4_TIMER_DIER_CC3DE BSP_BIT16(11) // Capture/compare 3 DMA request enable
52#define STM32F4_TIMER_DIER_CC2DE BSP_BIT16(10) // Capture/compare 2 DMA request enable
53#define STM32F4_TIMER_DIER_CC1DE BSP_BIT16(9) // Capture/compare 1 DMA request enable
54#define STM32F4_TIMER_DIER_UDE BSP_BIT16(8) // Update DMA request enable
55#define STM32F4_TIMER_DIER_TIE BSP_BIT16(6) // Trigger interrupt enable
56#define STM32F4_TIMER_DIER_CC4IE BSP_BIT16(4) // Capture/compare 4 interrupt request enable
57#define STM32F4_TIMER_DIER_CC3IE BSP_BIT16(3) // Capture/compare 3 interrupt request enable
58#define STM32F4_TIMER_DIER_CC2IE BSP_BIT16(2) // Capture/compare 2 interrupt request enable
59#define STM32F4_TIMER_DIER_CC1IE BSP_BIT16(1) // Capture/compare 1 interrupt request enable
60#define STM32F4_TIMER_DIER_UIE BSP_BIT16(0) // Update interrupt request enable
61
62 uint16_t reserved_0e;
63 uint16_t sr; // Status register
64#define STM32F4_TIMER_SR_CC4OF BSP_BIT16(12) // Capture/compare 4 overcapture flag
65#define STM32F4_TIMER_SR_CC3OF BSP_BIT16(11) // Capture/compare 3 overcapture flag
66#define STM32F4_TIMER_SR_CC2OF BSP_BIT16(10) // Capture/compare 2 overcapture flag
67#define STM32F4_TIMER_SR_CC1OF BSP_BIT16(9) // Capture/compare 1 overcapture flag
68#define STM32F4_TIMER_SR_TIF BSP_BIT16(6) // Trigger interrupt flag
69#define STM32F4_TIMER_SR_CC4IF BSP_BIT16(4) // Capture/compare 4 interrupt flag
70#define STM32F4_TIMER_SR_CC3IF BSP_BIT16(3) // Capture/compare 3 interrupt flag
71#define STM32F4_TIMER_SR_CC2IF BSP_BIT16(2) // Capture/compare 2 interrupt flag
72#define STM32F4_TIMER_SR_CC1IF BSP_BIT16(1) // Capture/compare 1 interrupt flag
73#define STM32F4_TIMER_SR_UIF BSP_BIT16(0) // Update interrupt flag
74 uint16_t reserved_12;
75 uint16_t egr; // Event generation register
76#define STM32F4_TIMER_EGR_TG BSP_BIT16(6) // Trigger event
77#define STM32F4_TIMER_EGR_CC4G BSP_BIT16(4) // Capture/compare 4 event
78#define STM32F4_TIMER_EGR_CC3G BSP_BIT16(3) // Capture/compare 3 generation)
79#define STM32F4_TIMER_EGR_CC2G BSP_BIT16(2) // Capture/compare 2 generation)
80#define STM32F4_TIMER_EGR_CC1G BSP_BIT16(1) // Capture/compare 1 generation)
81#define STM32F4_TIMER_EGR_UG BSP_BIT16(0) // Update event
82 uint16_t reserved_16;
83 uint16_t ccmr1; // Capture / compare mode register 1
84#define STM32F4_TIMER_CCMR1_OC2CE BSP_BIT16(15) // Output compare 2 clear enable
85#define STM32F4_TIMER_CCMR1_OC2M(val) BSP_FLD16(val, 12, 14)
86#define STM32F4_TIMER_CCMR1_OC2M_GET(reg) BSP_FLD16GET(reg, 12, 14)
87#define STM32F4_TIMER_CCMR1_OC2M_SET(reg, val) BSP_FLD16SET(reg, val, 12, 14)
88#define STM32F4_TIMER_CCMR1_OC2M_FROZEN STM32F4_TIMER_CCMR1_OC2M(0)
89#define STM32F4_TIMER_CCMR1_OC2M_ACTIVE STM32F4_TIMER_CCMR1_OC2M(1)
90#define STM32F4_TIMER_CCMR1_OC2M_INACTIVE STM32F4_TIMER_CCMR1_OC2M(2)
91#define STM32F4_TIMER_CCMR1_OC2M_TOGGLE STM32F4_TIMER_CCMR1_OC2M(3)
92#define STM32F4_TIMER_CCMR1_OC2M_FORCE_LOW STM32F4_TIMER_CCMR1_OC2M(4)
93#define STM32F4_TIMER_CCMR1_OC2M_FORCE_HIGH STM32F4_TIMER_CCMR1_OC2M(5)
94#define STM32F4_TIMER_CCMR1_OC2M_PWM1 STM32F4_TIMER_CCMR1_OC2M(6)
95#define STM32F4_TIMER_CCMR1_OC2M_PWM2 STM32F4_TIMER_CCMR1_OC2M(7)
96#define STM32F4_TIMER_CCMR1_OC2PE BSP_BIT16(11) // Output compare 2 preload enable
97#define STM32F4_TIMER_CCMR1_OC2FE BSP_BIT16(10) // Output compare 2 fast enable
98#define STM32F4_TIMER_CCMR1_CC2S(val) BSP_FLD16(val, 8, 9)
99#define STM32F4_TIMER_CCMR1_CC2S_GET(reg) BSP_FLD16GET(reg, 8, 9)
100#define STM32F4_TIMER_CCMR1_CC2S_SET(reg, val) BSP_FLD16SET(reg, val, 8, 9)
101#define STM32F4_TIMER_CCMR1_CC2S_OUTPUT STM32F4_TIMER_CCMR1_OC2S(0)
102#define STM32F4_TIMER_CCMR1_CC2S_TI2 STM32F4_TIMER_CCMR1_OC2S(1)
103#define STM32F4_TIMER_CCMR1_CC2S_TI1 STM32F4_TIMER_CCMR1_OC2S(2)
104#define STM32F4_TIMER_CCMR1_CC2S_TRC STM32F4_TIMER_CCMR1_OC2S(3)
105#define STM32F4_TIMER_CCMR1_OC1CE BSP_BIT16(7) // Output compare 1 clear enable
106#define STM32F4_TIMER_CCMR1_OC1M(val) BSP_FLD16(val, 4, 6)
107#define STM32F4_TIMER_CCMR1_OC1M_GET(reg) BSP_FLD16GET(reg, 4, 6)
108#define STM32F4_TIMER_CCMR1_OC1M_SET(reg, val) BSP_FLD16SET(reg, val, 4, 6)
109#define STM32F4_TIMER_CCMR1_OC1M_FROZEN STM32F4_TIMER_CCMR1_OC1M(0)
110#define STM32F4_TIMER_CCMR1_OC1M_ACTIVE STM32F4_TIMER_CCMR1_OC1M(1)
111#define STM32F4_TIMER_CCMR1_OC1M_INACTIVE STM32F4_TIMER_CCMR1_OC1M(2)
112#define STM32F4_TIMER_CCMR1_OC1M_TOGGLE STM32F4_TIMER_CCMR1_OC1M(3)
113#define STM32F4_TIMER_CCMR1_OC1M_FORCE_LOW STM32F4_TIMER_CCMR1_OC1M(4)
114#define STM32F4_TIMER_CCMR1_OC1M_FORCE_HIGH STM32F4_TIMER_CCMR1_OC1M(5)
115#define STM32F4_TIMER_CCMR1_OC1M_PWM1 STM32F4_TIMER_CCMR1_OC1M(6)
116#define STM32F4_TIMER_CCMR1_OC1M_PWM2 STM32F4_TIMER_CCMR1_OC1M(7)
117#define STM32F4_TIMER_CCMR1_OC1PE BSP_BIT16(3) // Output compare 1 preload enable
118#define STM32F4_TIMER_CCMR1_OC1FE BSP_BIT16(2) // Output compare 1 fast enable
119#define STM32F4_TIMER_CCMR1_CC1S(val) BSP_FLD16(val, 0, 1)
120#define STM32F4_TIMER_CCMR1_CC1S_GET(reg) BSP_FLD16GET(reg, 0, 1)
121#define STM32F4_TIMER_CCMR1_CC1S_SET(reg, val) BSP_FLD16SET(reg, val, 0, 1)
122#define STM32F4_TIMER_CCMR1_CC1S_OUTPUT STM32F4_TIMER_CCMR1_OC1S(0)
123#define STM32F4_TIMER_CCMR1_CC1S_TI2 STM32F4_TIMER_CCMR1_OC1S(1)
124#define STM32F4_TIMER_CCMR1_CC1S_TI1 STM32F4_TIMER_CCMR1_OC1S(2)
125#define STM32F4_TIMER_CCMR1_CC1S_TRC STM32F4_TIMER_CCMR1_OC1S(3)
126 uint16_t reserved_1a;
127 uint16_t ccmr2; // Capture / compare mode register 2
128#define STM32F4_TIMER_CCMR2_OC4CE BSP_BIT16(15) // Output compare 4 clear enable
129#define STM32F4_TIMER_CCMR2_OC4M(val) BSP_FLD16(val, 12, 14)
130#define STM32F4_TIMER_CCMR2_OC4M_GET(reg) BSP_FLD16GET(reg, 12, 14)
131#define STM32F4_TIMER_CCMR2_OC4M_SET(reg, val) BSP_FLD16SET(reg, val, 12, 14)
132#define STM32F4_TIMER_CCMR2_OC4M_FROZEN STM32F4_TIMER_CCMR2_OC4M(0)
133#define STM32F4_TIMER_CCMR2_OC4M_ACTIVE STM32F4_TIMER_CCMR2_OC4M(1)
134#define STM32F4_TIMER_CCMR2_OC4M_INACTIVE STM32F4_TIMER_CCMR2_OC4M(2)
135#define STM32F4_TIMER_CCMR2_OC4M_TOGGLE STM32F4_TIMER_CCMR2_OC4M(3)
136#define STM32F4_TIMER_CCMR2_OC4M_FORCE_LOW STM32F4_TIMER_CCMR2_OC4M(4)
137#define STM32F4_TIMER_CCMR2_OC4M_FORCE_HIGH STM32F4_TIMER_CCMR2_OC4M(5)
138#define STM32F4_TIMER_CCMR2_OC4M_PWM1 STM32F4_TIMER_CCMR2_OC4M(6)
139#define STM32F4_TIMER_CCMR2_OC4M_PWM2 STM32F4_TIMER_CCMR2_OC4M(7)
140#define STM32F4_TIMER_CCMR2_OC4PE BSP_BIT16(11) // Output compare 4 preload enable
141#define STM32F4_TIMER_CCMR2_OC4FE BSP_BIT16(10) // Output compare 4 fast enable
142#define STM32F4_TIMER_CCMR2_CC4S(val) BSP_FLD16(val, 8, 9)
143#define STM32F4_TIMER_CCMR2_CC4S_GET(reg) BSP_FLD16GET(reg, 8, 9)
144#define STM32F4_TIMER_CCMR2_CC4S_SET(reg, val) BSP_FLD16SET(reg, val, 8, 9)
145#define STM32F4_TIMER_CCMR2_CC4S_OUTPUT STM32F4_TIMER_CCMR2_OC4S(0)
146#define STM32F4_TIMER_CCMR2_CC4S_TI2 STM32F4_TIMER_CCMR2_OC4S(1)
147#define STM32F4_TIMER_CCMR2_CC4S_TI1 STM32F4_TIMER_CCMR2_OC4S(2)
148#define STM32F4_TIMER_CCMR2_CC4S_TRC STM32F4_TIMER_CCMR2_OC4S(3)
149#define STM32F4_TIMER_CCMR2_OC3CE BSP_BIT16(7) // Output compare 3 clear enable
150#define STM32F4_TIMER_CCMR2_OC3M(val) BSP_FLD16(val, 4, 6)
151#define STM32F4_TIMER_CCMR2_OC3M_GET(reg) BSP_FLD16GET(reg, 4, 6)
152#define STM32F4_TIMER_CCMR2_OC3M_SET(reg, val) BSP_FLD16SET(reg, val, 4, 6)
153#define STM32F4_TIMER_CCMR2_OC3M_FROZEN STM32F4_TIMER_CCMR2_OC3M(0)
154#define STM32F4_TIMER_CCMR2_OC3M_ACTIVE STM32F4_TIMER_CCMR2_OC3M(1)
155#define STM32F4_TIMER_CCMR2_OC3M_INACTIVE STM32F4_TIMER_CCMR2_OC3M(2)
156#define STM32F4_TIMER_CCMR2_OC3M_TOGGLE STM32F4_TIMER_CCMR2_OC3M(3)
157#define STM32F4_TIMER_CCMR2_OC3M_FORCE_LOW STM32F4_TIMER_CCMR2_OC3M(4)
158#define STM32F4_TIMER_CCMR2_OC3M_FORCE_HIGH STM32F4_TIMER_CCMR2_OC3M(5)
159#define STM32F4_TIMER_CCMR2_OC3M_PWM1 STM32F4_TIMER_CCMR2_OC3M(6)
160#define STM32F4_TIMER_CCMR2_OC3M_PWM2 STM32F4_TIMER_CCMR2_OC3M(7)
161#define STM32F4_TIMER_CCMR2_OC3PE BSP_BIT16(3) // Output compare 3 preload enable
162#define STM32F4_TIMER_CCMR2_OC3FE BSP_BIT16(2) // Output compare 3 fast enable
163#define STM32F4_TIMER_CCMR2_CC3S(val) BSP_FLD16(val, 0, 1)
164#define STM32F4_TIMER_CCMR2_CC3S_GET(reg) BSP_FLD16GET(reg, 0, 1)
165#define STM32F4_TIMER_CCMR2_CC3S_SET(reg, val) BSP_FLD16SET(reg, val, 0, 1)
166#define STM32F4_TIMER_CCMR2_CC3S_OUTPUT STM32F4_TIMER_CCMR2_OC3S(0)
167#define STM32F4_TIMER_CCMR2_CC3S_TI2 STM32F4_TIMER_CCMR2_OC3S(1)
168#define STM32F4_TIMER_CCMR2_CC3S_TI1 STM32F4_TIMER_CCMR2_OC3S(2)
169#define STM32F4_TIMER_CCMR2_CC3S_TRC STM32F4_TIMER_CCMR2_OC3S(3)
170 uint16_t reserved_1e;
171 uint16_t ccer; // Capture / compare enable register
172#define STM32F4_TIMER_CCER_CC4NP BSP_BIT16(15) // Capture / compare 4 output polarity
173#define STM32F4_TIMER_CCER_CC4P BSP_BIT16(13) // Capture / compare 4 output polarity
174#define STM32F4_TIMER_CCER_CC4E BSP_BIT16(12) // Capture / compare 4 output enable
175#define STM32F4_TIMER_CCER_CC3NP BSP_BIT16(11) // Capture / compare 3 output polarity
176#define STM32F4_TIMER_CCER_CC3P BSP_BIT16(9) // Capture / compare 3 output polarity
177#define STM32F4_TIMER_CCER_CC3E BSP_BIT16(8) // Capture / compare 3 output enable
178#define STM32F4_TIMER_CCER_CC2NP BSP_BIT16(7) // Capture / compare 2 output polarity
179#define STM32F4_TIMER_CCER_CC2P BSP_BIT16(5) // Capture / compare 2 output polarity
180#define STM32F4_TIMER_CCER_CC2E BSP_BIT16(4) // Capture / compare 2 output enable
181#define STM32F4_TIMER_CCER_CC1NP BSP_BIT16(3) // Capture / compare 1 output polarity
182#define STM32F4_TIMER_CCER_CC1P BSP_BIT16(1) // Capture / compare 1 output polarity
183#define STM32F4_TIMER_CCER_CC1E BSP_BIT16(0) // Capture / compare 1 output enable
184 uint16_t reserved_22;
185 uint32_t cnt; // Counter register
186#define STM32F4_TIMER_DR(val) BSP_FLD32(val, 0, 31)
187#define STM32F4_TIMER_DR_GET(reg) BSP_FLD32GET(reg, 0, 31)
188#define STM32F4_TIMER_DR_SET(reg, val) BSP_FLD32SET(reg, val, 0, 31)
189 uint16_t psc; // Prescalar
190 uint16_t reserved_2a;
191 uint32_t arr; // Auto-reload register
192 uint16_t rcr; // Repetition counter register
193 uint16_t rserved_32;
194 uint32_t ccr[4];// Capture / compare registers
195 uint16_t bdtr; // Break and dead-time register
196 uint16_t reserved_46;
197 uint16_t dcr; // DMA control register
198 uint16_t reserved_4a;
199 uint16_t dmar; // DMA address for full transfer
200 uint16_t reserved_4e;
201 uint16_t or; // Option register
202 uint16_t reserved_52;
203} __attribute__ ((packed));
204typedef struct stm32f4_tim_s stm32f4_tim;
205
206#endif /* LIBBSP_ARM_STM32F4_STM32F4XXXX_TIM_H */
unsigned short int uint16 __attribute__((__may_alias__))
Disable IRQ Interrupts.
Definition: mcf5282.h:37
Utility macros.
Definition: stm32f4xxxx_tim.h:20
