RTEMS 5.2
#include "chip.h"Go to the source code of this file.
| struct | _SpidCmd |
| Spi Transfer Request prepared by the application upper layer. More... | |
| struct | _Spid |
| #define | SPID_ERROR 1 |
| #define | SPID_ERROR_LOCK 2 |
| #define | SPID_CSR_SCBR(mck, spck) SPI_CSR_SCBR((mck) / (spck)) |
| #define | SPID_CSR_DLYBS(mck, delay) |
| #define | SPID_CSR_DLYBCT(mck, delay) |
Typedefs | |
| typedef void(* | SpidCallback) (uint8_t, void *) |
| typedef struct _SpidCmd | SpidCmd |
| typedef struct _Spid | Spid |
| uint32_t | SPID_Configure (Spid *pSpid, Spi *pSpiHw, uint8_t spiId, uint32_t SpiMode, sXdmad *pXdmad) |
| Initializes the Spid structure and the corresponding SPI & DMA hardware. select value. The driver will uses DMA channel 0 for RX and DMA channel 1 for TX. The DMA channels are freed automatically when no SPI command processing. More... | |
| void | SPID_ConfigureCS (Spid *pSpid, uint32_t dwCS, uint32_t dwCsr) |
| Configures the parameters for the device corresponding to the cs value. More... | |
| uint32_t | SPID_SendCommand (Spid *pSpid, SpidCmd *pCommand) |
| Starts a SPI master transfer. This is a non blocking function. It will return as soon as the transfer is started. More... | |
| void | SPID_Handler (Spid *pSpid) |
| void | SPID_DmaHandler (Spid *pSpid) |
| uint32_t | SPID_IsBusy (const Spid *pSpid) |
| Check if the SPI driver is busy. More... | |
Implementation of SPI driver, transfer data through DMA.
| #define SPID_CSR_DLYBCT | ( | mck, | |
| delay | |||
Calculates the value of the DLYBCT field of the Chip Select Register given delay in ns and MCK.
| #define SPID_CSR_DLYBS | ( | mck, | |
| delay | |||
Calculates the value of the DLYBS field of the Chip Select Register given delay in ns and MCK.
| #define SPID_CSR_SCBR | ( | mck, | |
| spck | |||
| ) | SPI_CSR_SCBR((mck) / (spck)) |
Calculates the value of the SCBR field of the Chip Select Register given MCK and SPCK.
| #define SPID_ERROR 1 |
An unspecified error has occurred.
| #define SPID_ERROR_LOCK 2 |
SPI driver is currently in use.
Constant structure associated with SPI port. This structure prevents client applications to have access in the same time.
| typedef void(* SpidCallback) (uint8_t, void *) |
SPI transfer complete callback.
This structure is sent to the SPI_SendCommand function to start the transfer. At the end of the transfer, the callback is invoked by the interrupt handler.
| uint32_t SPID_Configure | ( | Spid * | pSpid, |
| Spi * | pSpiHw, | ||
| uint8_t | spiId, | ||
| uint32_t | spiMode, | ||
| sXdmad * | pXdmad | ||
| pSpid | Pointer to a Spid instance. |
| pSpiHw | Associated SPI peripheral. |
| spiId | SPI peripheral identifier. |
| pDmad | Pointer to a Dmad instance. |
| void SPID_ConfigureCS | ( | Spid * | pSpid, |
| uint32_t | dwCS, | ||
| uint32_t | dwCsr | ||
| cs | number corresponding to the SPI chip select. |
| csr | SPI_CSR value to setup. |
| uint32_t SPID_IsBusy | ( | const Spid * | pSpid | ) |
| pCommand | Pointer to the SPI command to execute. |
