RTEMS 5.2
tm27.h File Reference
Implementations for interrupt mechanisms for Time Test 27. More...
#define ERC32_BSP_USE_SYNCHRONOUS_TRAP   0
#define TEST_INTERRUPT_SOURCE   ERC32_INTERRUPT_EXTERNAL_1
#define TEST_INTERRUPT_SOURCE2   (ERC32_INTERRUPT_EXTERNAL_1+1)
#define TEST_VECTOR   ERC32_TRAP_TYPE( TEST_INTERRUPT_SOURCE )
#define TEST_VECTOR2   ERC32_TRAP_TYPE( TEST_INTERRUPT_SOURCE2 )
#define MUST_WAIT_FOR_INTERRUPT   1
#define Install_tm27_vector(handler)
#define Cause_tm27_intr()
#define Clear_tm27_intr()    ERC32_Clear_interrupt( TEST_INTERRUPT_SOURCE )
#define Lower_tm27_intr()   /* empty */
◆ Cause_tm27_intr
#define Cause_tm27_intr (   void)
Value:
do { \
ERC32_Force_interrupt( TEST_INTERRUPT_SOURCE+(Interrupt_nest>>1) ); \
nop(); \
nop(); \
nop(); \
} while (0)
◆ Install_tm27_vector
#define Install_tm27_vector (   handler)
Value:
set_vector( (handler), TEST_VECTOR, 1 ); \
set_vector( (handler), TEST_VECTOR2, 1 );
