RTEMS 5.2
boot.h
1/*
2 * Copyright (c) 2006 Jakub Jermar
3 * All rights reserved.
4 *
5 * Redistribution and use in source and binary forms, with or without
6 * modification, are permitted provided that the following conditions
7 * are met:
8 *
9 * - Redistributions of source code must retain the above copyright
10 * notice, this list of conditions and the following disclaimer.
11 * - Redistributions in binary form must reproduce the above copyright
12 * notice, this list of conditions and the following disclaimer in the
13 * documentation and/or other materials provided with the distribution.
14 * - The name of the author may not be used to endorse or promote products
15 * derived from this software without specific prior written permission.
16 *
17 * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR
18 * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
19 * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
20 * IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT,
21 * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
22 * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
23 * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
24 * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
25 * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF
26 * THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
27 */
28
35#ifndef KERN_sparc64_BOOT_H_
36#define KERN_sparc64_BOOT_H_
37
38#if 0
39#define VMA 0x400000
40#endif
41#define VMA 0x4000
42#define LMA VMA
43
44#ifndef __ASM__
45#ifndef __LINKER__
46
47#include <config.h>
48#include <arch/types.h>
49#include <genarch/ofw/ofw_tree.h>
50
51#define TASKMAP_MAX_RECORDS 32
52#define MEMMAP_MAX_RECORDS 32
53
54#define BOOTINFO_TASK_NAME_BUFLEN 32
55
56typedef struct {
57 void * addr;
58 uint32_t size;
59 char name[BOOTINFO_TASK_NAME_BUFLEN];
60} utask_t;
61
62typedef struct {
63 uint32_t count;
64 utask_t tasks[TASKMAP_MAX_RECORDS];
65} taskmap_t;
66
67typedef struct {
68 uintptr_t start;
69 uint32_t size;
70} memzone_t;
71
72typedef struct {
73 uint32_t total;
74 uint32_t count;
75 memzone_t zones[MEMMAP_MAX_RECORDS];
76} memmap_t;
77
82typedef struct {
83 uintptr_t physmem_start;
84 taskmap_t taskmap;
85 memmap_t memmap;
86 ballocs_t ballocs;
87 ofw_tree_node_t *ofw_root;
89
90extern bootinfo_t bootinfo;
91
92#endif
93#endif
94
95#endif
96
Definition: balloc.h:43
Definition: boot.h:82
Definition: boot.h:72
Definition: boot.h:67
Definition: ofw_tree.h:44
Definition: boot.h:62
Definition: boot.h:56
unsigned size
Definition: tte.h:1
