RTEMS 5.2
Macros | Functions
sh.h File Reference
Hitachi SH CPU Department Source. More...
#define SH_HAS_FPU   0
#define CPU_MODEL_NAME   "SH-Multilib"
#define SH_HAS_SEPARATE_STACKS   1
#define CPU_NAME   "Hitachi SH"
#define SH_IRQDIS_MASK   0xf0
#define sh_disable_interrupts(_level)
#define sh_enable_interrupts(_level)
#define sh_flash_interrupts(_level)
#define sh_get_interrupt_level(_level)
#define sh_set_interrupt_level(_newlevel)
#define CPU_swap_u32(value)   sh_swap_u32( value )
#define CPU_swap_u16(value)   sh_swap_u16( value )
unsigned int sh_set_irq_priority (unsigned int irq, unsigned int prio)
This include file contains information pertaining to the Hitachi SH processor.
◆ sh_disable_interrupts
#define sh_disable_interrupts (   _level)
Value:
__asm__ volatile ( \
"stc sr,%0\n\t" \
"mov %0,r5\n\t" \
"or %1,r5\n\t" \
"ldc r5,sr\n\t"\
: "=&r" (_level ) \
: "r" (SH_IRQDIS_MASK) \
: "r5" );
register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__("g6")
The pointer to the current per-CPU control is available via register g6.
◆ sh_enable_interrupts
#define sh_enable_interrupts (   _level)
Value:
__asm__ volatile( "ldc %0,sr\n\t" \
"nop\n\t" \
:: "r" (_level) );
◆ sh_flash_interrupts
#define sh_flash_interrupts (   _level)
Value:
__asm__ volatile( \
"stc sr,r5\n\t" \
"ldc %1,sr\n\t" \
"nop\n\t" \
"or %0,r5\n\t" \
"ldc r5,sr\n\t" \
"nop\n\t" \
: : "r" (SH_IRQDIS_MASK), "r" (_level) : "r5");
◆ sh_get_interrupt_level
#define sh_get_interrupt_level (   _level)
Value:
uint32_t _tmpsr ; \
__asm__ volatile( "stc sr, %0" : "=r" (_tmpsr) ); \
_level = (_tmpsr & 0xf0) >> 4 ; \
◆ sh_set_interrupt_level
#define sh_set_interrupt_level (   _newlevel)
Value:
uint32_t _tmpsr; \
__asm__ volatile ( "stc sr, %0" : "=r" (_tmpsr) ); \
_tmpsr = ( _tmpsr & ~0xf0 ) | ((_newlevel) << 4) ; \
__asm__ volatile( "ldc %0,sr" :: "r" (_tmpsr) ); \
