RTEMS 5.2
schedulersimpleimpl.h
1
13/*
14 * Copyright (C) 2011 On-Line Applications Research Corporation (OAR).
15 *
16 * The license and distribution terms for this file may be
17 * found in the file LICENSE in this distribution or at
18 * http://www.rtems.org/license/LICENSE.
19 */
20
21#ifndef _RTEMS_SCORE_SCHEDULERSIMPLEIMPL_H
22#define _RTEMS_SCORE_SCHEDULERSIMPLEIMPL_H
23
27
28#ifdef __cplusplus
29extern "C" {
30#endif
31
47{
49}
50
61 const void *to_insert,
62 const Chain_Node *next
63)
64{
65 const unsigned int *priority_to_insert;
66 const Thread_Control *thread_next;
67
68 priority_to_insert = (const unsigned int *) to_insert;
69 thread_next = (const Thread_Control *) next;
70
71 return *priority_to_insert <= _Thread_Get_priority( thread_next );
72}
73
82 Chain_Control *chain,
83 Thread_Control *to_insert,
84 unsigned int insert_priority
85)
86{
88 chain,
89 &to_insert->Object.Node,
90 &insert_priority,
92 );
93}
94
103 const Scheduler_Control *scheduler,
104 Thread_Control *the_thread,
105 Scheduler_Node *node
106)
107{
108 (void) scheduler;
109 (void) node;
110
111 _Chain_Extract_unprotected( &the_thread->Object.Node );
112}
113
125 const Scheduler_Control *scheduler,
126 Thread_Control *the_thread,
127 bool force_dispatch
128)
129{
132 Thread_Control *heir = (Thread_Control *) _Chain_First( &context->Ready );
133
134 ( void ) the_thread;
135
136 _Scheduler_Update_heir( heir, force_dispatch );
137}
138
141#ifdef __cplusplus
142}
143#endif
144
145#endif
146/* end of include file */
Chain Handler API.
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
RTEMS_INLINE_ROUTINE void _Chain_Extract_unprotected(Chain_Node *the_node)
Extracts this node (unprotected).
Definition: chainimpl.h:558
RTEMS_INLINE_ROUTINE void _Chain_Insert_ordered_unprotected(Chain_Control *the_chain, Chain_Node *to_insert, const void *left, Chain_Node_order order)
Inserts a node into the chain according to the order relation.
Definition: chainimpl.h:864
RTEMS_INLINE_ROUTINE Chain_Node * _Chain_First(const Chain_Control *the_chain)
Returns pointer to chain's first node.
Definition: chainimpl.h:260
RTEMS_INLINE_ROUTINE Scheduler_simple_Context * _Scheduler_simple_Get_context(const Scheduler_Control *scheduler)
Gets context of the scheduler.
Definition: schedulersimpleimpl.h:46
RTEMS_INLINE_ROUTINE void _Scheduler_simple_Extract(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
Extracts the threads node.
Definition: schedulersimpleimpl.h:102
RTEMS_INLINE_ROUTINE bool _Scheduler_simple_Priority_less_equal(const void *to_insert, const Chain_Node *next)
Checks if the priority is less or equal than the priority of the node.
Definition: schedulersimpleimpl.h:60
RTEMS_INLINE_ROUTINE void _Scheduler_simple_Insert(Chain_Control *chain, Thread_Control *to_insert, unsigned int insert_priority)
Inserts the thread control with the given priority into the chain.
Definition: schedulersimpleimpl.h:81
RTEMS_INLINE_ROUTINE void _Scheduler_simple_Schedule_body(const Scheduler_Control *scheduler, Thread_Control *the_thread, bool force_dispatch)
Scheduling decision logic.
Definition: schedulersimpleimpl.h:124
RTEMS_INLINE_ROUTINE void _Scheduler_Update_heir(Thread_Control *new_heir, bool force_dispatch)
Updates the heir.
Definition: schedulerimpl.h:1184
RTEMS_INLINE_ROUTINE Scheduler_Context * _Scheduler_Get_context(const Scheduler_Control *scheduler)
Gets the context of the scheduler.
Definition: schedulerimpl.h:58
RTEMS_INLINE_ROUTINE Priority_Control _Thread_Get_priority(const Thread_Control *the_thread)
Returns the priority of the thread.
Definition: threadimpl.h:1584
Inlined Routines Associated with the Manipulation of the Scheduler.
Manipulation of Threads Simple-Priority-Based Ready Queue.
Definition: chain.h:68
Chain_Node Node
Definition: objectdata.h:41
Scheduler node for per-thread data.
Definition: schedulernode.h:79
Simple scheduler context.
Definition: schedulersimple.h:68
Scheduler control.
Definition: scheduler.h:269
Definition: thread.h:732
Objects_Control Object
Definition: thread.h:734
unsigned context
Definition: tlb.h:1
Definition: chain.h:86
