RTEMS 5.2
RTEMS Run-Time Linker ELF Headers. More...
| bool | rtems_rtl_rap_file_check (rtems_rtl_obj *obj, int fd) |
| bool | rtems_rtl_rap_file_load (rtems_rtl_obj *obj, int fd) |
| bool | rtems_rtl_rap_file_unload (rtems_rtl_obj *obj) |
| rtems_rtl_loader_format * | rtems_rtl_rap_file_sig (void) |
| bool rtems_rtl_rap_file_check | ( | rtems_rtl_obj * | obj, |
| int | fd | ||
The RAP format check handler.
| obj | The object being checked. |
| fd | The file descriptor. |
| bool rtems_rtl_rap_file_load | ( | rtems_rtl_obj * | obj, |
| int | fd | ||
The RAP format load handler.
| obj | The object to load. |
obj->entry = (void*)(uintptr_t) ehdr.e_entry;
| rtems_rtl_loader_format * rtems_rtl_rap_file_sig | ( | void | ) |
The RAP format signature handler.
| bool rtems_rtl_rap_file_unload | ( | rtems_rtl_obj * | obj | ) |
The RAP format unload handler.
| obj | The object to unload. |
