RTEMS 5.2
RTEMS Run-Time Linker Indirect Pointer Management allows memory compaction in the allocator. More...
#include <rtems/chain.h>Go to the source code of this file.
| struct | rtems_rtl_ptr |
| struct | rtems_rtl_sptr |
| struct | rtems_rtl_ptr_chain |
| struct | rtems_rtl_sptr_chain |
| #define | rtems_rtl_ptr_type_get(_h, _t) ((_t*) rtems_rtl_ptr_get (_h)) |
| #define | rtems_rtl_sptr_type_get(_h, _t) ((_t*) rtems_rtl_sptr_get (_h)) |
Typedefs | |
| typedef struct rtems_rtl_ptr | rtems_rtl_ptr |
| typedef struct rtems_rtl_sptr | rtems_rtl_sptr |
| typedef struct rtems_rtl_ptr_chain | rtems_rtl_ptr_chain |
| typedef struct rtems_rtl_sptr_chain | rtems_rtl_sptr_chain |
| #define rtems_rtl_ptr_type_get | ( | _h, | |
| _t | |||
| ) | ((_t*) rtems_rtl_ptr_get (_h)) |
Return the pointer as the type provided.
| _h | The handle. |
| _t | The type. |
| #define rtems_rtl_sptr_type_get | ( | _h, | |
| _t | |||
| ) | ((_t*) rtems_rtl_sptr_get (_h)) |
| _h | The handle. |
| _t | The type. |
