RTEMS 5.2
rtemscompat.h
1#ifndef RTEMS_COMPAT_BSD_NET_H
2#define RTEMS_COMPAT_BSD_NET_H
3
4/* BSD -> rtems wrappers; stuff that must be defined
5 * prior to including most BSD headers
6 */
7
8/* Copyright: Till Straumann <strauman@slac.stanford.edu>, 2005;
9 * License: see LICENSE file.
10 */
11
12#include <rtems.h>
13#include <sys/errno.h>
14#include <sys/types.h>
15
16#include <stdlib.h>
17
18/* Check for RTEMS version; true if >= ma.mi.re */
19#define ISMINVERSION(ma,mi,re) \
20 ( __RTEMS_MAJOR__ > (ma) \
21 || (__RTEMS_MAJOR__ == (ma) && __RTEMS_MINOR__ > (mi)) \
22 || (__RTEMS_MAJOR__ == (ma) && __RTEMS_MINOR__ == (mi) && __RTEMS_REVISION__ >= (re)) \
23 )
24
25/* 'align' ARG is evaluated more than once */
26#define _DO_ALIGN(addr, align) (((uint32_t)(addr) + (align) - 1) & ~((align)-1))
27
28
29/* malloc/free are redefined :-( */
30static inline void *the_real_malloc(size_t n)
31{
32 return malloc(n);
33}
34
35static inline void the_real_free(void *p)
36{
37 return free(p);
38}
39
40#include <machine/rtems-bsd-kernel-space.h>
41#include <rtems/rtems_bsdnet.h>
42#include <rtems/rtems_bsdnet_internal.h>
43#ifdef __i386__
44#include <libcpu/cpu.h>
45#elif defined(__PPC__)
46#include <libcpu/io.h>
47#else
48#error "dunno what IO ops to use on this architecture"
49#endif
50#include <rtems/bspIo.h>
51
52#define NET_EMB(x,y,z) x ## y ## z
53#define NET_EMBEMB(x,y,z) NET_EMB(x,y,z)
54
55#define NET_STR(arg) #arg
56#define NET_STRSTR(arg) NET_STR(arg)
57
58#define NET_SOFTC NET_EMBEMB(,NETDRIVER_PREFIX,_softc)
59
60#define METHODS NET_EMBEMB(rtems_,NETDRIVER_PREFIX,_methods)
61extern struct _net_drv_tbl METHODS;
62
63#ifdef DEBUG_MODULAR
64#define METHODSPTR NET_EMBEMB(rtems_,NETDRIVER_PREFIX,_methods_p)
65extern struct _net_drv_tbl *volatile METHODSPTR;
66#else
67#define METHODSPTR (&METHODS)
68#endif
69
70#if defined(__LITTLE_ENDIAN__) || (__i386__)
71static inline uint16_t htole16(uint16_t v) { return v; }
72static inline uint32_t htole32(uint32_t v) { return v; }
73static inline uint64_t htole64(uint64_t v) { return v; }
74static inline uint16_t le16toh(uint16_t v) { return v; }
75static inline uint32_t le32toh(uint32_t v) { return v; }
76static inline uint64_t le64toh(uint64_t v) { return v; }
77#elif defined(__BIG_ENDIAN__)
78#ifdef __PPC__
79#include <libcpu/byteorder.h>
80
81/* Different RTEMS versions use different types
82 * for 32-bit (unsigned vs. unsigned long which
83 * always cause gcc warnings and possible alias
84 * violations, sigh).
85 */
86
87#if ISMINVERSION(4,8,0)
88typedef uint32_t rtemscompat_32_t;
89#else
90typedef unsigned rtemscompat_32_t;
91#endif
92
93static inline uint16_t
94htole16(uint16_t v)
95{
96uint16_t rval;
97 st_le16(&rval,v);
98 return rval;
99}
100
101static inline uint16_t
102le16toh(uint16_t v)
103{
104 return ld_le16((unsigned short*)&v);
105}
106
107static inline uint32_t
108htole32(uint32_t v)
109{
110rtemscompat_32_t rval;
111 st_le32(&rval,v);
112 return rval;
113}
114
115static inline uint32_t
116le32toh(uint32_t v)
117{
118rtemscompat_32_t vv = v;
119 return ld_le32(&vv);
120}
121
122/* Compiler generated floating point instructions for this
123 * and rtems_bsdnet_newproc()-generated tasks are non-FP
124 * :-(
125 */
126static inline uint64_t
127htole64(uint64_t v)
128{
129union {
130 rtemscompat_32_t tmp[2];
131 uint64_t rval;
132} u;
133
134 st_le32( &u.tmp[0], (unsigned)(v&0xffffffff) );
135 st_le32( &u.tmp[1], (unsigned)((v>>32)&0xffffffff) );
136
137 return u.rval;
138}
139
140#else
141#error "need htoleXX() implementation for this CPU arch"
142#endif
143
144#else
145#error "Unknown CPU endianness"
146#endif
147
148
149
150#ifdef __PPC__
151#define _out_byte(a,v) out_8((volatile uint8_t*)(a),(v))
152#define _inp_byte(a) in_8((volatile uint8_t*)(a))
153#ifdef NET_CHIP_LE
154#define _out_word(a,v) out_le16((volatile uint16_t*)(a),(v))
155#define _out_long(a,v) out_le32((volatile uint32_t *)(a),(v))
156#define _inp_word(a) in_le16((volatile uint16_t*)(a))
157#define _inp_long(a) in_le32((volatile uint32_t *)(a))
158#elif defined(NET_CHIP_BE)
159#define _out_word(a,v) out_be16((volatile uint16_t*)(a),(v))
160#define _out_long(a,v) out_be32((volatile uint32_t *)(a),(v))
161#define _inp_word(a) in_be16((volatile uint16_t*)(a))
162#define _inp_long(a) in_be32((volatile uint32_t *)(a))
163#else
164#error rtemscompat_defs.h must define either NET_CHIP_LE or NET_CHIP_BE
165#endif
166static inline void wrle32(unsigned *a, unsigned v)
167{
168 asm volatile("stwbrx %1,0,%2":"=m"(*a):"r"(v),"r"(a));
169}
170static inline unsigned rdle32(unsigned *a)
171{
172 asm volatile("lwbrx %0,0,%0":"=r"(a):"0"(a),"m"(*a));
173 return (unsigned)a;
174}
175static inline void orle32(unsigned *a,unsigned v) { wrle32(a, rdle32(a) | v); }
176static inline void anle32(unsigned *a,unsigned v) { wrle32(a, rdle32(a) & v); }
177
178static inline void wrle16(unsigned short *a, unsigned short v)
179{
180 asm volatile("sthbrx %1,0,%2":"=m"(*a):"r"(v),"r"(a));
181}
182static inline unsigned short rdle16(unsigned short *a)
183{
184 asm volatile("lhbrx %0,0,%0":"=r"(a):"0"(a),"m"(*a));
185 return (unsigned short)(unsigned)a;
186}
187static inline void orle16(unsigned short *a,unsigned short v) { wrle16(a, rdle16(a) | v); }
188static inline void anle16(unsigned short *a,unsigned short v) { wrle16(a, rdle16(a) & v); }
189#endif
190
191#ifdef __i386__
192#ifdef NET_CHIP_BE
193#error dunno how to output BE data
194#endif
195
196static inline void wrle32(volatile unsigned *p, unsigned v) { *p = v; }
197static inline void orle32(volatile unsigned *p, unsigned v) { *p |= v; }
198static inline void anle32(volatile unsigned *p, unsigned v) { *p &= v; }
199static inline unsigned rdle32(volatile unsigned *p) { return *p; }
200
201static inline void wrle16(volatile unsigned short *p, unsigned short v) { *p = v; }
202static inline void orle16(volatile unsigned short *p, unsigned short v) { *p |= v; }
203static inline void anle16(volatile unsigned short *p, unsigned short v) { *p &= v; }
204static inline unsigned short rdle16(volatile unsigned short *p) { return *p; }
205
206#ifdef NET_CHIP_MEM_IO
207
208#ifdef __i386__
209static inline void _out_byte(unsigned a, unsigned char v) { *(volatile unsigned char*)a = v; }
210static inline unsigned char _inp_byte(unsigned a) { return *(volatile unsigned char*)a; }
211#ifdef NET_CHIP_LE
212static inline void _out_word(unsigned a, unsigned short v) { *(volatile unsigned short*)a = v; }
213static inline unsigned short _inp_word(unsigned a) { return *(volatile unsigned short*)a; }
214static inline void _out_long(unsigned a, unsigned v) { *(volatile unsigned *)a = v; }
215static inline unsigned _inp_long(unsigned a) { return *(volatile unsigned *)a; }
216#elif defined(NET_CHIP_BE)
217#error "BE memory IO not implemented for i386 yet"
218#else
219#error rtemscompat_defs.h must define either NET_CHIP_LE or NET_CHIP_BE
220#endif
221#else
222
223#error "Memory IO not implemented for this CPU architecture yet"
224
225#endif
226#elif defined(NET_CHIP_PORT_IO)
227#define _out_byte(addr,val) outport_byte((addr),(val))
228#define _out_word(addr,val) outport_word((addr),(val))
229#define _out_long(addr,val) outport_long((addr),(val))
230
231static inline u_int8_t _inp_byte(volatile unsigned char *a)
232{
233register u_int8_t rval;
234 inport_byte((unsigned short)(unsigned)a,rval);
235 return rval;
236}
237static inline u_int16_t _inp_word(volatile unsigned short *a)
238{
239register u_int16_t rval;
240 inport_word((unsigned short)(unsigned)a,rval);
241 return rval;
242}
243static inline u_int32_t _inp_long(volatile unsigned *a)
244{
245register u_int32_t rval;
246 inport_long((unsigned short)(unsigned)a,rval);
247 return rval;
248}
249#else
250#error either NET_CHIP_MEM_IO or NET_CHIP_PORT_IO must be defined
251#endif
252#endif
253
254#ifndef __FBSDID
255#define __FBSDID(arg)
256#endif
257
258#define device_printf(device,format,args...) printk(format,## args)
259
260static inline u_int8_t bus_space_do_read_1(u_long handle, unsigned reg)
261{
262 return _inp_byte((volatile unsigned char*)((handle)+(reg)));
263}
264
265static inline u_int16_t bus_space_do_read_2(u_long handle, unsigned reg)
266{
267 return _inp_word((volatile unsigned short*)((handle)+(reg)));
268}
269
270static inline u_int32_t bus_space_do_read_4(u_long handle, unsigned reg)
271{
272 return _inp_long((volatile unsigned *)((handle)+(reg)));
273}
274
275#define bus_space_read_1(tag,handle,reg) bus_space_do_read_1((handle),(reg))
276#define bus_space_read_2(tag,handle,reg) bus_space_do_read_2((handle),(reg))
277#define bus_space_read_4(tag,handle,reg) bus_space_do_read_4((handle),(reg))
278
279static inline void bus_space_do_write_multi_1(u_long handle, unsigned reg, unsigned char *addr, int cnt)
280{
281 int i; for (i=0; i<cnt; i++) _out_byte( (handle) + (reg), (addr)[i]);
282}
283
284static inline void bus_space_do_write_multi_2(u_long handle, unsigned reg, unsigned short *addr, int cnt)
285{
286 int i; for (i=0; i<cnt; i++) _out_word( (handle) + (reg), (addr)[i]);
287}
288
289static inline void bus_space_do_write_multi_4(u_long handle, unsigned reg, unsigned long *addr, int cnt)
290{
291 int i; for (i=0; i<cnt; i++) _out_long( (handle) + (reg), (addr)[i]);
292}
293
294
295#define bus_space_write_multi_1(tag, handle, reg, addr, cnt) \
296 bus_space_do_write_multi_1(handle, reg, addr, cnt)
297#define bus_space_write_multi_2(tag, handle, reg, addr, cnt) \
298 bus_space_do_write_multi_2(handle, reg, addr, cnt)
299#define bus_space_write_multi_4(tag, handle, reg, addr, cnt) \
300 bus_space_do_write_multi_4(handle, reg, addr, cnt)
301
302static inline void bus_space_do_read_multi_1(u_long handle, unsigned reg, unsigned char *addr, int cnt)
303{
304 int i; for (i=0; i<cnt; i++)
305 (addr)[i] = _inp_byte((volatile unsigned char*)((handle)+(reg)));
306}
307
308static inline void bus_space_do_read_multi_2(u_long handle, unsigned reg, unsigned short *addr, int cnt)
309{
310 int i; for (i=0; i<cnt; i++)
311 (addr)[i] = _inp_word((volatile unsigned short*)((handle)+(reg)));
312}
313
314static inline void bus_space_do_read_multi_4(u_long handle, unsigned reg, unsigned long *addr, int cnt)
315{
316 int i; for (i=0; i<cnt; i++)
317 (addr)[i] = _inp_long((volatile unsigned *)((handle)+(reg)));
318}
319
320#define bus_space_read_multi_1(tag, handle, reg, addr, cnt) \
321 bus_space_do_read_multi_1(handle, reg, addr, cnt)
322#define bus_space_read_multi_2(tag, handle, reg, addr, cnt) \
323 bus_space_do_read_multi_2(handle, reg, addr, cnt)
324#define bus_space_read_multi_4(tag, handle, reg, addr, cnt) \
325 bus_space_do_read_multi_4(handle, reg, addr, cnt)
326
327
328
329#define bus_space_write_1(tag, handle, reg, val) \
330 do { _out_byte( (handle) + (reg), (val)); } while (0)
331
332#define bus_space_write_2(tag, handle, reg, val) \
333 do { _out_word( (handle) + (reg), (val)); } while (0)
334
335#define bus_space_write_4(tag, handle, reg, val) \
336 do { _out_long( (handle) + (reg), (val)); } while (0)
337
338#define BPF_MTAP(a,b) do { } while (0)
339
340extern unsigned net_driver_ticks_per_sec;
341
342#ifdef __PPC__
343/* PPC has a timebase - based delay */
344#define DELAY(n) do { \
345 if ( (n) > 10000 ) \
346 rtems_task_wake_after((((n)*net_driver_ticks_per_sec)/1000000) + 1); \
347 else \
348 rtems_bsp_delay(n); \
349 } while (0)
350#else
351#warning "Have no good usec delay implementation"
352#define DELAY(n) do { \
353 rtems_task_wake_after((((n)*net_driver_ticks_per_sec)/1000000) + 1); \
354 } while (0)
355#endif
356
357
358#define IRQ_LOCKED(code) \
359 do { unsigned long _xtre_irq_flags; \
360 rtems_interrupt_disable(_xtre_irq_flags); \
361 do { code } while(0); \
362 rtems_interrupt_enable(_xtre_irq_flags); \
363 } while (0)
364
365typedef void (driver_intr_t)(void *);
366
367#define if_xname if_name
368
369/* need to replace those with LOCAL2PCI() and make sure the bus handle is initialized
370 * (on most BSPs we get away with PCI_DRAM_OFFSET [no bus handle needed at all]
371 */
372#ifndef PCI_DRAM_OFFSET
373#define PCI_DRAM_OFFSET 0
374#endif
375
376#ifndef PCI_MEM_BASE
377#define PCI_MEM_BASE 0
378#endif
379
380#define kvtop(a) ((unsigned long)(a) + PCI_DRAM_OFFSET)
381#define vtophys(a) ((unsigned long)(a) + PCI_DRAM_OFFSET)
382
383#define PCI2LOCAL(a,bus) ((unsigned long)(a) + PCI_MEM_BASE)
384
385#ifdef PCI0_IO_BASE /* special mvme5500 hack :-( */
386#define PCI_IO_2LOCAL(a,bus) ((unsigned long)(a) + PCI0_IO_BASE)
387#elif defined(PCI_IO_BASE)
388#define PCI_IO_2LOCAL(a,bus) ((unsigned long)(a) + PCI_IO_BASE)
389#elif defined(_IO_BASE)
390#define PCI_IO_2LOCAL(a,bus) ((unsigned long)(a) + _IO_BASE)
391#else
392#warning "Unable to determine base address of PCI IO space; using ZERO"
393#define PCI_IO_2LOCAL(a,bus) ((unsigned long)(a))
394#endif
395
396#define if_printf(if,fmt,args...) printf("%s:"fmt,(if)->if_name,args)
397
398#ifndef BUS_PROBE_DEFAULT
399#define BUS_PROBE_DEFAULT 0
400#endif
401
402static inline void *
403contigmalloc(
404 unsigned long size,
405 int type,
406 int flags,
407 unsigned long lo,
408 unsigned long hi,
409 unsigned long align,
410 unsigned long bound)
411{
412void *ptr = rtems_bsdnet_malloc(size + sizeof(ptr) + align-1, type, flags);
413char *rval = 0;
414 if ( ptr ) {
415 unsigned tmp = (unsigned)ptr + align - 1;
416 tmp -= tmp % align;
417 rval = (char*)tmp;
418 /* save backlink */
419 *(void**)(rval+size) = ptr;
420 }
421 return rval;
422}
423
424static inline void
425contigfree(void *ptr, size_t size, int type)
426{
427 rtems_bsdnet_free( *(void**)((unsigned)ptr + size), type);
428}
429
430/* callout stuff */
431#define callout_init(args...) do {} while (0);
432#define callout_reset(args...) do {} while (0);
433#define callout_stop(args...) do {} while (0);
434
435#define IFQ_DRV_IS_EMPTY(q) (0 == (q)->ifq_head)
436#define IFQ_DRV_DEQUEUE(q,m) IF_DEQUEUE((q),(m))
437#define IFQ_DRV_PREPEND(q,m) IF_PREPEND((q),(m))
438
439#define DO_ETHER_INPUT_SKIPPING_ETHER_HEADER(ifp,m) \
440 { struct ether_header *eh; \
441 eh = mtod(m, struct ether_header*); \
442 m->m_data += sizeof(struct ether_header); \
443 m->m_len -= sizeof(struct ether_header); \
444 m->m_pkthdr.len -= sizeof(struct ether_header); \
445 m->m_pkthdr.rcvif = ifp; \
446 ether_input(ifp, eh, m); \
447 } while (0)
448
449
450#ifndef __KERNEL_RCSID
451#define __KERNEL_RCSID(arg...)
452#endif
453
454#endif
Interface to Kernel Print Methods.
Definition: rtemscompat1.h:32
unsigned v
Definition: tte.h:0
unsigned size
Definition: tte.h:1
unsigned p
Definition: tte.h:17
