RTEMS 5.2
rtems-rfs-block.h
1
13/*
14 * COPYRIGHT (c) 2010 Chris Johns <chrisj@rtems.org>
15 *
16 * The license and distribution terms for this file may be
17 * found in the file LICENSE in this distribution or at
18 * http://www.rtems.org/license/LICENSE.
19 */
20
21
22#if !defined (_RTEMS_RFS_BLOCK_H_)
23#define _RTEMS_RFS_BLOCK_H_
24
29
38#define rtems_rfs_block_get_number(_h, _b) \
39 ((rtems_rfs_block_no) \
40 (rtems_rfs_read_u32 (rtems_rfs_buffer_data (_h) + \
41 ((_b) * sizeof (rtems_rfs_block_no)))))
42
51#define rtems_rfs_block_set_number(_h, _b, _n) \
52 do { \
53 rtems_rfs_write_u32 (rtems_rfs_buffer_data (_h) + \
54 ((_b) * sizeof (rtems_rfs_block_no)), (_n)); \
55 rtems_rfs_buffer_mark_dirty (_h); \
56 } while (0)
57
93{
97 bool dirty;
98
103
108
118
124
130
135
140
145
147
151#define rtems_rfs_block_map_is_dirty(_m) ((_m)->dirty)
152
156#define rtems_rfs_block_map_count(_m) ((_m)->size.count)
157
161#define rtems_rfs_block_map_size(_m) (&((_m)->size))
162
166#define rtems_rfs_block_map_size_offset(_m) ((_m)->size.offset)
167
171#define rtems_rfs_block_map_last(_m) \
172 rtems_rfs_block_pos_last_block (&(_m)->bpos, &(_m)->size)
173
177#define rtems_rfs_block_map_past_end(_m, _p) \
178 rtems_rfs_block_pos_past_end (_p, &(_m)->size)
179
183#define rtems_rfs_block_map_pos(_f, _m) \
184 rtems_rfs_block_get_pos (_f, &(_m)->bpos)
185
189#define rtems_rfs_block_map_block(_m) ((_m)->bpos.bno)
190
194#define rtems_rfs_block_map_block_offset(_m) ((_m)->bpos.boff)
195
202static inline void
203rtems_rfs_block_map_set_size_offset (rtems_rfs_block_map* map,
204 rtems_rfs_block_off offset)
205{
206 map->size.offset = offset;
207 map->dirty = true;
208}
209
216static inline void
217rtems_rfs_block_map_set_size (rtems_rfs_block_map* map,
219{
221 map->dirty = true;
222}
238
251
267
282 rtems_rfs_pos_rel offset,
284
299
314 size_t blocks,
315 rtems_rfs_block_no* new_block);
316
330 size_t blocks);
331
343
344#endif
RTEMS File Systems Block Position and Size Management.
#define rtems_rfs_block_copy_size(_lhs, _rhs)
Definition: rtems-rfs-block-pos.h:163
rtems_rfs_inode_block rtems_rfs_block_no
Definition: rtems-rfs-block-pos.h:39
uint32_t rtems_rfs_block_off
Definition: rtems-rfs-block-pos.h:44
int rtems_rfs_block_map_seek(rtems_rfs_file_system *fs, rtems_rfs_block_map *map, rtems_rfs_pos_rel offset, rtems_rfs_buffer_block *block)
Definition: rtems-rfs-block.c:333
int rtems_rfs_block_map_shrink(rtems_rfs_file_system *fs, rtems_rfs_block_map *map, size_t blocks)
Definition: rtems-rfs-block.c:649
int rtems_rfs_block_map_free_all(rtems_rfs_file_system *fs, rtems_rfs_block_map *map)
Definition: rtems-rfs-block.c:796
int rtems_rfs_block_map_find(rtems_rfs_file_system *fs, rtems_rfs_block_map *map, rtems_rfs_block_pos *bpos, rtems_rfs_buffer_block *block)
Definition: rtems-rfs-block.c:233
int rtems_rfs_block_map_open(rtems_rfs_file_system *fs, rtems_rfs_inode_handle *inode, rtems_rfs_block_map *map)
Definition: rtems-rfs-block.c:95
struct rtems_rfs_block_map_s rtems_rfs_block_map
int rtems_rfs_block_map_next_block(rtems_rfs_file_system *fs, rtems_rfs_block_map *map, rtems_rfs_buffer_block *block)
Definition: rtems-rfs-block.c:345
int rtems_rfs_block_map_close(rtems_rfs_file_system *fs, rtems_rfs_block_map *map)
Definition: rtems-rfs-block.c:146
int rtems_rfs_block_map_grow(rtems_rfs_file_system *fs, rtems_rfs_block_map *map, size_t blocks, rtems_rfs_block_no *new_block)
Definition: rtems-rfs-block.c:406
Maps Blocks to the Media Interface Layers.
uint32_t rtems_rfs_buffer_block
Definition: rtems-rfs-buffer.h:62
RTEMS File System Data.
#define RTEMS_RFS_INODE_BLOCKS
Definition: rtems-rfs-file-system.h:67
int64_t rtems_rfs_pos_rel
Definition: rtems-rfs-file-system.h:95
Definition: mm.c:60
Definition: rtems-rfs-file-system.h:116
Definition: rtems-rfs-inode.h:182
Definition: rtems-rfs-block.h:93
rtems_rfs_buffer_handle singly_buffer
Definition: rtems-rfs-block.h:139
rtems_rfs_block_pos bpos
Definition: rtems-rfs-block.h:117
rtems_rfs_block_size size
Definition: rtems-rfs-block.h:107
rtems_rfs_inode_handle * inode
Definition: rtems-rfs-block.h:102
uint32_t blocks[RTEMS_RFS_INODE_BLOCKS]
Definition: rtems-rfs-block.h:134
rtems_rfs_block_no last_map_block
Definition: rtems-rfs-block.h:123
bool dirty
Definition: rtems-rfs-block.h:97
rtems_rfs_block_no last_data_block
Definition: rtems-rfs-block.h:129
rtems_rfs_buffer_handle doubly_buffer
Definition: rtems-rfs-block.h:144
Definition: rtems-rfs-block-pos.h:52
Definition: rtems-rfs-block-pos.h:142
Definition: rtems-rfs-buffer.h:92
unsigned size
Definition: tte.h:1
