RTEMS 5.2
Macros | Functions
rtd316.h File Reference
RTD316 driver interface defintions. More...
#define RTD316_DRIVER_TABLE_ENTRY    { rtd316_initialize, NULL, NULL, NULL, NULL, NULL }
rtems_device_driver rtd316_initialize (rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
 RTD316 Initialization Entry Point. More...
uint8_t rtd316_com_get_register (uint32_t addr, uint8_t reg)
 RTD316 Obtain Register Helper. More...
void rtd316_com_set_register (uint32_t addr, uint8_t reg, uint8_t val)
 RTD316 Set Register Helper. More...
◆ RTD316_DRIVER_TABLE_ENTRY
This macro defines the standard device driver table entry for a console device driver.
◆ rtd316_com_get_register()
uint8_t rtd316_com_get_register ( uint32_t  addr,
uint8_t  reg
This method is used to read registers on the RTD316.
Parameters
[in]addris the base address
[in]regis the register number
Returns
This method returns the value of the register.
◆ rtd316_com_set_register()
void rtd316_com_set_register ( uint32_t  addr,
uint8_t  reg,
uint8_t  val
This method is used to set registers on the RTD316.
Parameters
◆ rtd316_initialize()
rtems_device_driver rtd316_initialize ( rtems_device_major_number  major,
void *  arg
This method initializes the RTD316 device driver.
Parameters
[in]majoris the device driver major number
[in]minoris the device driver minor number
[in]argis the parameters to this call
Returns
This method returns RTEMS_SUCCESSFUL when the device driver is successfully initialized.
