RTEMS 5.2
qspi_dma.h
6/* */
7/* All rights reserved. */
8/* */
11/* */
14/* */
17/* */
29
37#ifndef QSPI_DMA_H
38#define QSPI_DMA_H
39
40/*----------------------------------------------------------------------------
41 * Headers
42 *----------------------------------------------------------------------------*/
43
44#include "chip.h"
45#ifndef __rtems__
46#include "../../../../utils/utility.h"
47#endif /* __rtems__ */
48
49/*----------------------------------------------------------------------------
50 * Definitions
51 *----------------------------------------------------------------------------*/
52
54#define QSPID_ERROR 1
55
57#define QSPID_ERROR_LOCK 2
58
59#define QSPID_CH_NOT_ENABLED 0xFF
60/*----------------------------------------------------------------------------
61 * Types
62 *----------------------------------------------------------------------------*/
63
65typedef void (*QspidCallback)(uint8_t, void *);
66
69typedef struct _Qspid {
70 Qspid_t Qspid;
74 uint8_t Polling;
76 uint8_t TxChNum;
78 uint8_t RxChNum;
80 volatile uint8_t progress;
82
83#ifdef __cplusplus
84extern "C" {
85#endif
86/*----------------------------------------------------------------------------
87 * Exported functions
88 *----------------------------------------------------------------------------*/
89
90uint32_t QSPID_Configure(QspiDma_t *pQspidma, QspiMode_t Mode,
91 uint32_t dwConfiguration, sXdmad *pXdmad);
92
93uint32_t QSPID_EnableQspiRxChannel(QspiDma_t *pQspidma);
94
95uint32_t QSPID_EnableQspiTxChannel(QspiDma_t *pQspidma);
96
97uint32_t QSPID_DisableQspiRxChannel(QspiDma_t *pQspidma);
98
99uint32_t QSPID_DisableQspiTxChannel(QspiDma_t *pQspidma);
100
101uint32_t QSPID_DisableSpiChannel(QspiDma_t *pQspidma);
102
103uint32_t QSPID_EnableSpiChannel(QspiDma_t *pQspidma);
104
105uint32_t QSPID_ReadWriteQSPI(QspiDma_t *pQspidma, Access_t const ReadWrite);
106
107uint32_t QSPID_ReadWriteSPI(QspiDma_t *pQspidma, Access_t const ReadWrite);
108
109uint32_t QSPID_IsBusy(volatile uint8_t *QspiSemaphore);
110
111#ifdef __cplusplus
112}
113#endif
114
115#endif /* #ifndef _SPI_DMA_ */
QspiMode_t
qspi modes SPI or QSPI
Definition: qspi.h:88
Access_t
qspi access modes
Definition: qspi.h:80
Enables a QSPI Rx channel. This function will allocate a dma Rx channel for QSPI.
Definition: qspi_dma.c:315
Starts a QSPI read or write operation.
Definition: qspi_dma.c:533
void(* QspidCallback)(uint8_t, void *)
Definition: qspi_dma.h:65
Disables a QSPI SPI Rx and Tx channels. This function will de-allocate privious allocated dma Rx,...
Definition: qspi_dma.c:502
Disables a QSPI Rx channel. This function will de-allocate previous allocated dma Rx channel for QSPI...
Definition: qspi_dma.c:446
Disables a QSPI Tx channel. This function will de-allocate previous allocated dma Tx channel for QSPI...
Definition: qspi_dma.c:475
uint32_t QSPID_Configure(QspiDma_t *pQspidma, QspiMode_t Mode, uint32_t dwConfiguration, sXdmad *pXdmad)
Initializes the pQspidma structure and the corresponding QSPI & DMA . hardware select value.
Definition: qspi_dma.c:284
Check if the QSPI driver is busy.
Definition: qspi_dma.c:613
struct _Qspid QspiDma_t
Enables a QSPI Tx channel. This function will allocate a dma Tx channel for QSPI.
Definition: qspi_dma.c:352
Enables a QSPI SPI Rx channel. This function will allocate a dma Rx channel for QSPI SPI mode.
Definition: qspi_dma.c:389
Starts a SPI master transfer. This is a non blocking function. It will return as soon as the transfer...
Definition: qspi_dma.c:576
qspi driver structure
Definition: qspi.h:176
Definition: qspi_dma.h:69
Definition: qspi_dma.h:80
uint8_t TxChNum
Definition: qspi_dma.h:76
uint8_t Polling
Definition: qspi_dma.h:74
sXdmad * pXdmad
Definition: qspi_dma.h:72
uint8_t RxChNum
Definition: qspi_dma.h:78
Definition: xdmad.h:127
