RTEMS 5.2
| struct | QspiMemCmd_t |
| qspi command structure More... | |
| struct | QspiBuffer_t |
| qspi buffer structure More... | |
| struct | QspiInstFrame_t |
| qspi frame structure for QSPI mode More... | |
| union | QspiInstFrame_t::_QspiInstFrame |
| struct | QspiInstFrame_t::_QspiInstFrame::_QspiInstFrameBM |
| struct | Qspid_t |
| qspi driver structure More... | |
| #define | QSPI_SCBR(baudrate, masterClock) ((uint32_t) (masterClock / baudrate) << 8) |
| #define | QSPI_DLYBS(delay, masterClock) ((uint32_t) (((masterClock / 1000000) * delay) / 1000) << 16) |
| #define | QSPI_DLYBCT(delay, masterClock) ((uint32_t) (((masterClock / 1000000) * delay) / 32000) << 24) |
Enumerations | |
| enum | Access_t { CmdAccess = 0 , ReadAccess , WriteAccess } |
| qspi access modes | |
| enum | QspiMode_t { SpiMode = QSPI_MR_SMM_SPI , QspiMemMode = QSPI_MR_SMM_MEMORY } |
| qspi modes SPI or QSPI | |
| enum | QspiClockMode_t { ClockMode_00 = 0 , ClockMode_10 , ClockMode_01 , ClockMode_11 } |
| qspi clock modes , regarding clock phase and clock polarity | |
| enum | QspidStatus_t { QSPI_SUCCESS = 0 , QSPI_BUSY , QSPI_BUSY_SENDING , QSPI_READ_ERROR , QSPI_WRITE_ERROR , QSPI_UNKNOWN_ERROR , QSPI_INIT_ERROR , QSPI_INPUT_ERROR , QSPI_TOTAL_ERROR } |
| qspi status codes | |
| enum | QspiStatus_t { IsReceived = QSPI_SR_RDRF , IsTxSent = QSPI_SR_TDRE , IsTxEmpty = QSPI_SR_TXEMPTY , IsOverrun = QSPI_SR_OVRES , IsCsRise = QSPI_SR_CSR , IsCsAsserted = QSPI_SR_CSS , IsEofInst = QSPI_SR_INSTRE , IsEnabled = QSPI_SR_QSPIENS } |
| qspi status regiter bits | |
| void | QSPI_SwReset (Qspi *pQspi) |
| Resets a QSPI peripheral. More... | |
| void | QSPI_Disable (Qspi *pQspi) |
| Disables a QSPI peripheral. More... | |
| void | QSPI_Enable (Qspi *pQspi) |
| Enables a QSPI peripheral. More... | |
| QspidStatus_t | QSPI_EndTransfer (Qspi *pQspi) |
| Ends ongoing transfer by releasing CS of QSPI peripheral. More... | |
| uint32_t | QSPI_GetStatus (Qspi *pQspi, const QspiStatus_t rStatus) |
| Get the current status register of the given QSPI peripheral. More... | |
| void | QSPI_ConfigureClock (Qspi *pQspi, QspiClockMode_t ClockMode, uint32_t dwClockCfg) |
| Configures peripheral clock of a QSPI/SPI peripheral. More... | |
| QspidStatus_t | QSPI_SingleReadSPI (Qspid_t *pQspid, uint16_t *const pData) |
| Reads the data received by a SPI peripheral. This method must be called after a successful SPI_Write call. More... | |
| QspidStatus_t | QSPI_MultiReadSPI (Qspid_t *pQspid, uint16_t *const pData, uint32_t NumOfBytes) |
| Reads multiple data received by a SPI peripheral. This method must be called after a successful SPI_Write call. More... | |
| QspidStatus_t | QSPI_SingleWriteSPI (Qspid_t *pQspid, uint16_t const *pData) |
| Sends a single data through a SPI peripheral. More... | |
| QspidStatus_t | QSPI_MultiWriteSPI (Qspid_t *pQspid, uint16_t const *pData, uint32_t NumOfBytes) |
| Sends multiple data through a SPI peripheral. More... | |
| QspidStatus_t | QSPI_EnableIt (Qspi *pQspi, uint32_t dwSources) |
| Enables one or more interrupt sources of a QSPI peripheral. More... | |
| QspidStatus_t | QSPI_DisableIt (Qspi *pQspi, uint32_t dwSources) |
| Disables one or more interrupt sources of a QSPI peripheral. More... | |
| uint32_t | QSPI_GetItMask (Qspi *pQspi) |
| Return the interrupt mask register. More... | |
| uint32_t | QSPI_GetEnabledItStatus (Qspi *pQspi) |
| Returns enabled interrupt status. More... | |
| QspidStatus_t | QSPI_ConfigureInterface (Qspid_t *pQspid, QspiMode_t Mode, uint32_t dwConfiguration) |
| Configures QSPI/SPI. More... | |
| QspidStatus_t | QSPI_SendCommand (Qspid_t *pQspi, uint8_t const KeepCfg) |
| Send an instruction over QSPI (oly a flash command no data) More... | |
| QspidStatus_t | QSPI_SendCommandWithData (Qspid_t *pQspi, uint8_t const KeepCfg) |
| Send instruction over QSPI with data. More... | |
| QspidStatus_t | QSPI_ReadCommand (Qspid_t *pQspi, uint8_t const KeepCfg) |
| Send instruction over QSPI to read data. More... | |
| QspidStatus_t | QSPI_EnableMemAccess (Qspid_t *pQspi, uint8_t const KeepCfg, uint8_t ScrambleFlag) |
| Sends an instruction over QSPI and configures other related address like Addr , Frame and synchronise bus access before data read or write. More... | |
| QspidStatus_t | QSPI_ReadWriteMem (Qspid_t *pQspid, Access_t const ReadWrite) |
| Writes or reads the QSPI memory (0x80000000) to transmit or receive data from Flash memory. More... | |
Interface for Serial Peripheral Interface (SPI) controller.
| #define QSPI_DLYBCT | ( | delay, | |
| masterClock | |||
| ) | ((uint32_t) (((masterClock / 1000000) * delay) / 32000) << 24) |
Calculates the value of the CSR DLYBCT field given the desired delay (in ns)
| #define QSPI_DLYBS | ( | delay, | |
| masterClock | |||
| ) | ((uint32_t) (((masterClock / 1000000) * delay) / 1000) << 16) |
Calculates the value of the CSR DLYBS field given the desired delay (in ns)
| #define QSPI_SCBR | ( | baudrate, | |
| masterClock | |||
| ) | ((uint32_t) (masterClock / baudrate) << 8) |
Here are several macros which should be used when configuring a SPI peripheral.
| void QSPI_ConfigureClock | ( | Qspi * | pQspi, |
| QspiClockMode_t | ClockMode, | ||
| uint32_t | dwClockCfg | ||
| pQspi | Pointer to an Qspi instance. |
| dwConfiguration | Desired clock configuration. |
| QspidStatus_t QSPI_ConfigureInterface | ( | Qspid_t * | pQspid, |
| QspiMode_t | Mode, | ||
| uint32_t | dwConfiguration | ||
| Mode | Mode for QSPI or SPI |
| dwConfiguration | Config of SPI or QSPI mode |
| void QSPI_Disable | ( | Qspi * | pQspi | ) |
| pQspi | Pointer to a Qspi instance. |
| QspidStatus_t QSPI_DisableIt | ( | Qspi * | pQspi, |
| uint32_t | dwSources | ||
| sources | Bitwise OR of selected interrupt sources. |
| void QSPI_Enable | ( | Qspi * | pQspi | ) |
| QspidStatus_t QSPI_EnableIt | ( | Qspi * | pQspi, |
| QspidStatus_t QSPI_EnableMemAccess | ( | Qspid_t * | pQspid, |
| uint8_t const | KeepCfg, | ||
| uint8_t | ScrambleFlag | ||
| KeepCfg | To keep Instruction from value or resets to zero |
| ScrambleFlag | Enable or disable scramble on QSPI |
| QspidStatus_t QSPI_EndTransfer | ( | Qspi * | pQspi | ) |
| uint32_t QSPI_GetEnabledItStatus | ( | Qspi * | pQspi | ) |
| uint32_t QSPI_GetItMask | ( | Qspi * | pQspi | ) |
| uint32_t QSPI_GetStatus | ( | Qspi * | pQspi, |
| const QspiStatus_t | rStatus | ||
| rStatus | Compare status with given status bit |
| QspidStatus_t QSPI_MultiReadSPI | ( | Qspid_t * | pQspid, |
| uint16_t *const | pData, | ||
| uint32_t | NumOfBytes | ||
| QspidStatus_t QSPI_MultiWriteSPI | ( | Qspid_t * | pQspid, |
| uint16_t const * | pData, | ||
| pQspid | Pointer to a Qspi instance. |
| pData | Pointer to a Tx buffer |
| NumOfBytes | Num of data to send. |
| QspidStatus_t QSPI_ReadCommand | ( | Qspid_t * | pQspid, |
| uint8_t const | KeepCfg | ||
| QspidStatus_t QSPI_ReadWriteMem | ( | Qspid_t * | pQspid, |
| Access_t const | ReadWrite | ||
| ReadWrite | Flag to indicate read/write QSPI memory access |
| QspidStatus_t QSPI_SendCommand | ( | Qspid_t * | pQspid, |
| KeepCfg | To keep Instruction fram value or restes to zero |
| QspidStatus_t QSPI_SendCommandWithData | ( | Qspid_t * | pQspid, |
| QspidStatus_t QSPI_SingleReadSPI | ( | Qspid_t * | pQspid, |
| uint16_t *const | pData | ||
| QspidStatus_t QSPI_SingleWriteSPI | ( | Qspid_t * | pQspid, |
| uint16_t const * | pData | ||
