RTEMS 5.2
semaphoreimpl.h
1
10/*
11 * COPYRIGHT (c) 1989-2013.
12 * On-Line Applications Research Corporation (OAR).
13 *
14 * The license and distribution terms for this file may be
15 * found in the file LICENSE in this distribution or at
16 * http://www.rtems.org/license/LICENSE.
17 */
18
19#ifndef _RTEMS_POSIX_SEMAPHOREIMPL_H
20#define _RTEMS_POSIX_SEMAPHOREIMPL_H
21
25#include <rtems/seterr.h>
26
27#ifdef __cplusplus
28extern "C" {
29#endif
30
35#define POSIX_SEMAPHORE_MAGIC 0x5d367fe7UL
36
38 _POSIX_Semaphore_Allocate_unprotected( void )
39{
42}
43
51 POSIX_Semaphore_Control *the_semaphore
52)
53{
54 _Objects_Free( &_POSIX_Semaphore_Information, &the_semaphore->Object );
55}
56
58 sem_t *sem
59)
60{
61 return RTEMS_CONTAINER_OF( sem, POSIX_Semaphore_Control, Semaphore );
62}
63
64RTEMS_INLINE_ROUTINE bool _POSIX_Semaphore_Is_named( const sem_t *sem )
65{
66 return sem->_Semaphore._Queue._name != NULL;
67}
68
69RTEMS_INLINE_ROUTINE bool _POSIX_Semaphore_Is_busy( const sem_t *sem )
70{
71 return sem->_Semaphore._Queue._heads != NULL;
72}
73
74RTEMS_INLINE_ROUTINE void _POSIX_Semaphore_Initialize(
75 sem_t *sem,
76 const char *name,
77 unsigned int value
78)
79{
80 sem->_flags = (uintptr_t) sem ^ POSIX_SEMAPHORE_MAGIC;
81 _Semaphore_Initialize_named( &sem->_Semaphore, name, value );
82}
83
84RTEMS_INLINE_ROUTINE void _POSIX_Semaphore_Destroy( sem_t *sem )
85{
86 sem->_flags = 0;
87 _Semaphore_Destroy( &sem->_Semaphore );
88}
89
96
101 POSIX_Semaphore_Control *the_semaphore
102)
103{
106 &the_semaphore->Object
107 );
108}
109
110RTEMS_INLINE_ROUTINE POSIX_Semaphore_Control *_POSIX_Semaphore_Get_by_name(
111 const char *name,
112 size_t *name_length_p,
113 Objects_Get_by_name_error *error
114)
115{
118 name,
119 name_length_p,
120 error
121 );
122}
123
124#define POSIX_SEMAPHORE_VALIDATE_OBJECT( sem ) \
125 do { \
126 if ( \
127 ( sem ) == NULL \
128 || ( (uintptr_t) ( sem ) ^ POSIX_SEMAPHORE_MAGIC ) != ( sem )->_flags \
129 ) { \
130 rtems_set_errno_and_return_minus_one( EINVAL ); \
131 } \
132 } while ( 0 )
133
134#ifdef __cplusplus
135}
136#endif
137
138#endif
139/* end of include file */
#define NULL
Requests a GPIO pin group configuration.
Definition: bestcomm_api.h:77
Objects_Information _POSIX_Semaphore_Information
The POSIX Semaphore objects information.
#define RTEMS_CONTAINER_OF(_m, _type, _member_name)
Returns a pointer to the container of a specified member pointer.
Definition: basedefs.h:430
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
Objects_Control * _Objects_Get_by_name(const Objects_Information *information, const char *name, size_t *name_length_p, Objects_Get_by_name_error *error)
Gets an object control block identified by its name.
Definition: objectnametoidstring.c:26
RTEMS_INLINE_ROUTINE void _Objects_Free(Objects_Information *information, Objects_Control *the_object)
Frees an object.
Definition: objectimpl.h:930
RTEMS_INLINE_ROUTINE Objects_Control * _Objects_Allocate_unprotected(Objects_Information *information)
Allocates an object without locking the allocator mutex.
Definition: objectimpl.h:874
void _Objects_Namespace_remove_string(const Objects_Information *information, Objects_Control *the_object)
Removes object with a string name from its namespace.
Definition: objectnamespaceremove.c:25
RTEMS_INLINE_ROUTINE void _POSIX_Semaphore_Namespace_remove(POSIX_Semaphore_Control *the_semaphore)
POSIX Semaphore Namespace Remove.
Definition: semaphoreimpl.h:100
void _POSIX_Semaphore_Delete(POSIX_Semaphore_Control *the_semaphore)
POSIX Semaphore Delete.
Definition: semaphoredeletesupp.c:23
RTEMS_INLINE_ROUTINE void _POSIX_Semaphore_Free(POSIX_Semaphore_Control *the_semaphore)
POSIX Semaphore Free.
Definition: semaphoreimpl.h:50
This is a random number used to check if a semaphore object is properly initialized.
Definition: semaphoreimpl.h:35
POSIX API Implementation.
Semaphore Implementation.
Private Support Information for POSIX Semaphores.
Data which Ease the Burden of Consistently Setting Errno.
Definition: semaphore.h:44
