RTEMS 5.2
partimpl.h
1
9/* COPYRIGHT (c) 1989-2008.
10 * On-Line Applications Research Corporation (OAR).
11 *
12 * The license and distribution terms for this file may be
13 * found in the file LICENSE in this distribution or at
14 * http://www.rtems.org/license/LICENSE.
15 */
16
17#ifndef _RTEMS_RTEMS_PARTIMPL_H
18#define _RTEMS_RTEMS_PARTIMPL_H
19
21#include <rtems/score/address.h>
24
25#ifdef __cplusplus
26extern "C" {
27#endif
28
45 Partition_Control *the_partition
46)
47{
48 return _Chain_Get_unprotected( &the_partition->Memory );
49}
50
57 Partition_Control *the_partition,
58 Chain_Node *the_buffer
59)
60{
61 _Chain_Append_unprotected( &the_partition->Memory, the_buffer );
62}
63
71 void *the_buffer,
72 Partition_Control *the_partition
73)
74{
75 intptr_t offset;
76
77 offset = _Addresses_Subtract(
78 the_buffer,
79 the_partition->starting_address
80 );
81
82 return ((offset % the_partition->buffer_size) == 0);
83}
84
92 Chain_Node *the_buffer,
93 Partition_Control *the_partition
94)
95{
96 void *starting;
97 void *ending;
98
99 starting = the_partition->starting_address;
100 ending = _Addresses_Add_offset( starting, the_partition->length );
101
102 return (
103 _Addresses_Is_in_range( the_buffer, starting, ending ) &&
104 _Partition_Is_buffer_on_boundary( the_buffer, the_partition )
105 );
106}
107
108RTEMS_INLINE_ROUTINE bool _Partition_Is_buffer_size_aligned(
109 uint32_t buffer_size
110)
111{
112 return (buffer_size % CPU_SIZEOF_POINTER) == 0;
113}
114
115RTEMS_INLINE_ROUTINE bool _Partition_Is_buffer_area_aligned(
116 const void *starting_address
117)
118{
119 return (((uintptr_t) starting_address) % CPU_SIZEOF_POINTER) == 0;
120}
121
130{
132}
133
134RTEMS_INLINE_ROUTINE void _Partition_Initialize(
135 Partition_Control *the_partition,
136 void *starting_address,
137 uint32_t length,
138 uint32_t buffer_size,
139 rtems_attribute attribute_set
140)
141{
142 the_partition->starting_address = starting_address;
143 the_partition->length = length;
144 the_partition->buffer_size = buffer_size;
145 the_partition->attribute_set = attribute_set;
146 the_partition->number_of_used_blocks = 0;
147
149 &the_partition->Memory,
150 starting_address,
151 length / buffer_size,
152 buffer_size
153 );
154
155 _ISR_lock_Initialize( &the_partition->Lock, "Partition" );
156}
157
158RTEMS_INLINE_ROUTINE void _Partition_Destroy(
159 Partition_Control *the_partition
160)
161{
162 _ISR_lock_Destroy( &the_partition->Lock );
163}
164
173 Partition_Control *the_partition
174)
175{
176 _Objects_Free( &_Partition_Information, &the_partition->Object );
177}
178
180 Objects_Id id,
181 ISR_lock_Context *lock_context
182)
183{
185 id,
186 lock_context,
188 );
189}
190
191RTEMS_INLINE_ROUTINE void _Partition_Acquire_critical(
192 Partition_Control *the_partition,
193 ISR_lock_Context *lock_context
194)
195{
196 _ISR_lock_Acquire( &the_partition->Lock, lock_context );
197}
198
199RTEMS_INLINE_ROUTINE void _Partition_Release(
200 Partition_Control *the_partition,
201 ISR_lock_Context *lock_context
202)
203{
204 _ISR_lock_Release_and_ISR_enable( &the_partition->Lock, lock_context );
205}
206
209#ifdef __cplusplus
210}
211#endif
212
213#if defined(RTEMS_MULTIPROCESSING)
214#include <rtems/rtems/partmp.h>
215#endif
216
217#endif
218/* end of include file */
Information Required to Manipulate Physical Addresses.
Chain Handler API.
uint32_t rtems_attribute
Definition: attr.h:41
RTEMS_INLINE_ROUTINE Partition_Control * _Partition_Allocate(void)
Allocates a partition control block from the inactive chain of free partition control blocks.
Definition: partimpl.h:129
RTEMS_INLINE_ROUTINE void _Partition_Free(Partition_Control *the_partition)
Frees a partition control block to the inactive chain of free partition control blocks.
Definition: partimpl.h:172
Objects_Information _Partition_Information
The Classic Partition objects information.
RTEMS_INLINE_ROUTINE void * _Partition_Allocate_buffer(Partition_Control *the_partition)
Allocate a buffer from the_partition.
Definition: partimpl.h:44
RTEMS_INLINE_ROUTINE bool _Partition_Is_buffer_valid(Chain_Node *the_buffer, Partition_Control *the_partition)
Checks whether the_buffer is a valid buffer from the_partition.
Definition: partimpl.h:91
RTEMS_INLINE_ROUTINE void _Partition_Free_buffer(Partition_Control *the_partition, Chain_Node *the_buffer)
Frees the_buffer to the_partition.
Definition: partimpl.h:56
RTEMS_INLINE_ROUTINE bool _Partition_Is_buffer_on_boundary(void *the_buffer, Partition_Control *the_partition)
Checks whether is on a valid buffer boundary for the_partition.
Definition: partimpl.h:70
RTEMS_INLINE_ROUTINE void * _Addresses_Add_offset(const void *base, uintptr_t offset)
Adds offset to an address.
Definition: address.h:55
RTEMS_INLINE_ROUTINE intptr_t _Addresses_Subtract(const void *left, const void *right)
Subtracts two addresses.
Definition: address.h:95
RTEMS_INLINE_ROUTINE bool _Addresses_Is_in_range(const void *address, const void *base, const void *limit)
Checks if address is in range.
Definition: address.h:138
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
RTEMS_INLINE_ROUTINE Chain_Node * _Chain_Get_unprotected(Chain_Control *the_chain)
Gets the first node (unprotected).
Definition: chainimpl.h:630
void _Chain_Initialize(Chain_Control *the_chain, void *starting_address, size_t number_nodes, size_t node_size)
Initializes a chain header.
Definition: chain.c:26
RTEMS_INLINE_ROUTINE void _Chain_Append_unprotected(Chain_Control *the_chain, Chain_Node *the_node)
Appends a node (unprotected).
Definition: chainimpl.h:680
#define _ISR_lock_Acquire(_lock, _context)
Acquires an ISR lock inside an ISR disabled section.
Definition: isrlock.h:293
#define _ISR_lock_Release_and_ISR_enable(_lock, _context)
Releases an ISR lock.
Definition: isrlock.h:263
#define _ISR_lock_Destroy(_lock)
Destroys an ISR lock.
Definition: isrlock.h:199
#define _ISR_lock_Initialize(_lock, _name)
Initializes an ISR lock.
Definition: isrlock.h:185
RTEMS_INLINE_ROUTINE void _Objects_Free(Objects_Information *information, Objects_Control *the_object)
Frees an object.
Definition: objectimpl.h:930
Objects_Control * _Objects_Allocate(Objects_Information *information)
Allocates an object.
Definition: objectallocate.c:42
uint32_t Objects_Id
Definition: object.h:80
Objects_Control * _Objects_Get(Objects_Id id, ISR_lock_Context *lock_context, const Objects_Information *information)
Maps the specified object identifier to the associated local object control block.
Definition: objectgetlocal.c:28
Inlined Routines in the Object Handler.
Classic Partition Manager Data Structures.
MP Support in Partition Manager.
Definition: chain.h:68
Local ISR lock context for acquire and release pairs.
Definition: isrlock.h:65
Definition: partdata.h:37
Definition: partdata.h:49
uintptr_t number_of_used_blocks
Definition: partdata.h:51
uintptr_t length
Definition: partdata.h:45
size_t buffer_size
Definition: partdata.h:47
Chain_Control Memory
Definition: partdata.h:53
void * starting_address
Definition: partdata.h:43
Objects_Control Object
Definition: partdata.h:39
