| void | _Objects_MP_Handler_early_initialization (void) |
| | Intializes the global object node number used in the ID field of all objects. More...
| void | _Objects_MP_Handler_initialization (void) |
| | Intializes the inactive global object chain based on the maximum number of global objects configured. More...
| void | _Objects_MP_Open (Objects_Information *information, Objects_MP_Control *the_global_object, uint32_t the_name, Objects_Id the_id) |
| | Place the specified global object in the specified information table. More...
| bool | _Objects_MP_Allocate_and_open (Objects_Information *information, uint32_t the_name, Objects_Id the_id, bool is_fatal_error) |
| | Allocates a global object control block and places it in the specified information table. More...
| void | _Objects_MP_Close (Objects_Information *information, Objects_Id the_id) |
| | Removes a global object from the specified information table. More...
| Objects_Name_or_id_lookup_errors | _Objects_MP_Global_name_search (Objects_Information *information, Objects_Name the_name, uint32_t nodes_to_search, Objects_Id *the_id) |
| | Looks for the object with the_name in the global object tables indicated by information. More...
| bool | _Objects_MP_Is_remote (Objects_Id the_id, const Objects_Information *information) |
| | Checks if the object identifier is in the global object identifier cache of the specified object information. More...
Objects_MP_Control * | _Objects_MP_Allocate_global_object (void) |
| | This function allocates a Global Object control block.
| void | _Objects_MP_Free_global_object (Objects_MP_Control *the_global_object) |
| | This routine deallocates a Global Object control block. More...
