RTEMS 5.2
Media Manager API. More...
| #define | RTEMS_MEDIA_MOUNT_BASE "/media" |
| #define | RTEMS_MEDIA_DELIMITER '-' |
Typedefs | |
| typedef rtems_status_code(* | rtems_media_listener) (rtems_media_event event, rtems_media_state state, const char *src, const char *dest, void *listener_arg) |
| Event listener. More... | |
| typedef rtems_status_code(* | rtems_media_worker) (rtems_media_state state, const char *src, char **dest, void *worker_arg) |
| Do the work corresponding to an event. More... | |
Enumerations | |
| enum | rtems_media_event { RTEMS_MEDIA_EVENT_DISK_ATTACH , RTEMS_MEDIA_EVENT_DISK_DETACH , RTEMS_MEDIA_EVENT_MOUNT , RTEMS_MEDIA_EVENT_UNMOUNT , RTEMS_MEDIA_EVENT_PARTITION_INQUIRY , RTEMS_MEDIA_EVENT_PARTITION_ATTACH , RTEMS_MEDIA_EVENT_PARTITION_DETACH , RTEMS_MEDIA_EVENT_ERROR } |
| enum | rtems_media_state { RTEMS_MEDIA_STATE_INQUIRY , RTEMS_MEDIA_STATE_READY , RTEMS_MEDIA_STATE_ABORTED , RTEMS_MEDIA_STATE_SUCCESS , RTEMS_MEDIA_STATE_FAILED , RTEMS_MEDIA_ERROR_DISK_UNKNOWN , RTEMS_MEDIA_ERROR_DISK_EXISTS , RTEMS_MEDIA_ERROR_DISK_OR_PARTITION_UNKNOWN , RTEMS_MEDIA_ERROR_DISK_OR_PARTITION_EXISTS , RTEMS_MEDIA_ERROR_PARTITION_UNKNOWN , RTEMS_MEDIA_ERROR_PARTITION_ORPHAN , RTEMS_MEDIA_ERROR_PARTITION_DETACH_WITH_MOUNT , RTEMS_MEDIA_ERROR_PARTITION_WITH_UNKNOWN_DISK , RTEMS_MEDIA_ERROR_MOUNT_POINT_UNKNOWN , RTEMS_MEDIA_ERROR_MOUNT_POINT_EXISTS , RTEMS_MEDIA_ERROR_MOUNT_POINT_ORPHAN } |
Base | |
| RTEMS_INLINE_ROUTINE rtems_status_code | rtems_media_initialize (void) |
| Initializes the media manager. More... | |
| rtems_status_code | rtems_media_listener_add (rtems_media_listener listener, void *listener_arg) |
| Adds the listener with argument listener_arg. More... | |
| rtems_status_code | rtems_media_listener_remove (rtems_media_listener listener, void *listener_arg) |
| Removes the listener with argument listener_arg. More... | |
| rtems_status_code | rtems_media_post_event (rtems_media_event event, const char *src, char **dest, rtems_media_worker worker, void *worker_arg) |
| Posts the event with source src. More... | |
Server | |
| rtems_status_code | rtems_media_server_initialize (rtems_task_priority priority, size_t stack_size, rtems_mode modes, rtems_attribute attributes) |
| Initializes the media manager and media server. More... | |
| rtems_status_code | rtems_media_server_post_event (rtems_media_event event, const char *src, rtems_media_worker worker, void *worker_arg) |
| Sends an event message to the media server. More... | |
Path Construction | |
| char * | rtems_media_create_path (const char *prefix, const char *name, rtems_device_major_number major) |
| Creates a new path as "prefix/name-major". More... | |
| char * | rtems_media_replace_prefix (const char *new_prefix, const char *path) |
| Replaces the prefix of the path with new_prefix. More... | |
| char * | rtems_media_append_minor (const char *path, rtems_device_minor_number minor) |
| Appends the minor number to the path resulting in "path-minor". More... | |
Support | |
| rtems_status_code | rtems_media_get_device_identifier (const char *device_path, dev_t *device_identifier) |
| Returns the device identifier for the device located at device_path in device_identifier. More... | |
| const char * | rtems_media_event_description (rtems_media_event event) |
| const char * | rtems_media_state_description (rtems_media_state state) |
Media Manager API.
