RTEMS 5.2
mcf5235.h
1/*
2 *******************************************
3 * Definitions from Motorola/FreeScale *
4 *******************************************
5 */
6
7/*
8 * File: mcf5235.h
9 * Purpose: MCF5235 definitions
10 *
11 * Notes:
12 */
13
14#ifndef _CPU_MCF5235_H
15#define _CPU_MCF5235_H
16
17#include <stdint.h>
18
19/********************************************************************/
20
21/*
22 * File: mcf5xxx.h
23 * Purpose: Definitions common to all ColdFire processors
24 *
25 * Notes:
26 */
27
28#ifndef _CPU_MCF5XXX_H
29#define _CPU_MCF5XXX_H
30
31/***********************************************************************/
32/*
33 * The basic data types
34 */
35
36typedef unsigned char uint8; /* 8 bits */
37typedef unsigned short int uint16; /* 16 bits */
38typedef unsigned long int uint32; /* 32 bits */
39
40typedef signed char int8; /* 8 bits */
41typedef signed short int int16; /* 16 bits */
42typedef signed long int int32; /* 32 bits */
43
44typedef volatile uint8 vuint8; /* 8 bits */
45typedef volatile uint16 vuint16; /* 16 bits */
46typedef volatile uint32 vuint32; /* 32 bits */
47
48/***********************************************************************/
49/*
50 * Common M68K & ColdFire definitions
51 *
52 ***********************************************************************/
53
54#define ADDRESS uint32
55#define INSTRUCTION uint16
56#define ILLEGAL 0x4AFC
57#define CPU_WORD_SIZE 16
58
59#define MCF5XXX_SR_T (0x8000)
60#define MCF5XXX_SR_S (0x2000)
61#define MCF5XXX_SR_M (0x1000)
62#define MCF5XXX_SR_IPL (0x0700)
63#define MCF5XXX_SR_IPL_0 (0x0000)
64#define MCF5XXX_SR_IPL_1 (0x0100)
65#define MCF5XXX_SR_IPL_2 (0x0200)
66#define MCF5XXX_SR_IPL_3 (0x0300)
67#define MCF5XXX_SR_IPL_4 (0x0400)
68#define MCF5XXX_SR_IPL_5 (0x0500)
69#define MCF5XXX_SR_IPL_6 (0x0600)
70#define MCF5XXX_SR_IPL_7 (0x0700)
71#define MCF5XXX_SR_X (0x0010)
72#define MCF5XXX_SR_N (0x0008)
73#define MCF5XXX_SR_Z (0x0004)
74#define MCF5XXX_SR_V (0x0002)
75#define MCF5XXX_SR_C (0x0001)
76
77#define MCF5XXX_CACR_CENB (0x80000000)
78#define MCF5XXX_CACR_CPDI (0x10000000)
79#define MCF5XXX_CACR_CPD (0x10000000)
80#define MCF5XXX_CACR_CFRZ (0x08000000)
81#define MCF5XXX_CACR_CINV (0x01000000)
82#define MCF5XXX_CACR_DIDI (0x00800000)
83#define MCF5XXX_CACR_DISD (0x00400000)
84#define MCF5XXX_CACR_INVI (0x00200000)
85#define MCF5XXX_CACR_INVD (0x00100000)
86#define MCF5XXX_CACR_CEIB (0x00000400)
87#define MCF5XXX_CACR_DCM_WR (0x00000000)
88#define MCF5XXX_CACR_DCM_CB (0x00000100)
89#define MCF5XXX_CACR_DCM_IP (0x00000200)
90#define MCF5XXX_CACR_DCM (0x00000200)
91#define MCF5XXX_CACR_DCM_II (0x00000300)
92#define MCF5XXX_CACR_DBWE (0x00000100)
93#define MCF5XXX_CACR_DWP (0x00000020)
94#define MCF5XXX_CACR_EUST (0x00000010)
95#define MCF5XXX_CACR_CLNF_00 (0x00000000)
96#define MCF5XXX_CACR_CLNF_01 (0x00000002)
97#define MCF5XXX_CACR_CLNF_10 (0x00000004)
98#define MCF5XXX_CACR_CLNF_11 (0x00000006)
99
100#define MCF5XXX_ACR_AB(a) ((a)&0xFF000000)
101#define MCF5XXX_ACR_AM(a) (((a)&0xFF000000) >> 8)
102#define MCF5XXX_ACR_EN (0x00008000)
103#define MCF5XXX_ACR_SM_USER (0x00000000)
104#define MCF5XXX_ACR_SM_SUPER (0x00002000)
105#define MCF5XXX_ACR_SM_IGNORE (0x00006000)
106#define MCF5XXX_ACR_ENIB (0x00000080)
107#define MCF5XXX_ACR_CM (0x00000040)
108#define MCF5XXX_ACR_DCM_WR (0x00000000)
109#define MCF5XXX_ACR_DCM_CB (0x00000020)
110#define MCF5XXX_ACR_DCM_IP (0x00000040)
111#define MCF5XXX_ACR_DCM_II (0x00000060)
112#define MCF5XXX_ACR_CM (0x00000040)
113#define MCF5XXX_ACR_BWE (0x00000020)
114#define MCF5XXX_ACR_WP (0x00000004)
115
116#define MCF5XXX_RAMBAR_BA(a) ((a)&0xFFFFC000)
117#define MCF5XXX_RAMBAR_PRI_00 (0x00000000)
118#define MCF5XXX_RAMBAR_PRI_01 (0x00004000)
119#define MCF5XXX_RAMBAR_PRI_10 (0x00008000)
120#define MCF5XXX_RAMBAR_PRI_11 (0x0000C000)
121#define MCF5XXX_RAMBAR_WP (0x00000100)
122#define MCF5XXX_RAMBAR_CI (0x00000020)
123#define MCF5XXX_RAMBAR_SC (0x00000010)
124#define MCF5XXX_RAMBAR_SD (0x00000008)
125#define MCF5XXX_RAMBAR_UC (0x00000004)
126#define MCF5XXX_RAMBAR_UD (0x00000002)
127#define MCF5XXX_RAMBAR_V (0x00000001)
128
129/***********************************************************************/
130/*
131 * The ColdFire family of processors has a simplified exception stack
132 * frame that looks like the following:
133 *
134 * 3322222222221111 111111
135 * 1098765432109876 5432109876543210
136 * 8 +----------------+----------------+
137 * | Program Counter |
138 * 4 +----------------+----------------+
139 * |FS/Fmt/Vector/FS| SR |
140 * SP --> 0 +----------------+----------------+
141 *
142 * The stack self-aligns to a 4-byte boundary at an exception, with
143 * the FS/Fmt/Vector/FS field indicating the size of the adjustment
144 * (SP += 0,1,2,3 bytes).
145 */
146
147#define MCF5XXX_RD_SF_FORMAT(PTR) \
148 ((*((uint16 *)(PTR)) >> 12) & 0x00FF)
149
150#define MCF5XXX_RD_SF_VECTOR(PTR) \
151 ((*((uint16 *)(PTR)) >> 2) & 0x00FF)
152
153#define MCF5XXX_RD_SF_FS(PTR) \
154 ( ((*((uint16 *)(PTR)) & 0x0C00) >> 8) | (*((uint16 *)(PTR)) & 0x0003) )
155
156#define MCF5XXX_SF_SR(PTR) *((uint16 *)(PTR)+1)
157#define MCF5XXX_SF_PC(PTR) *((uint32 *)(PTR)+1)
158
159/********************************************************************/
160/*
161 * Functions provided by mcf5xxx.s
162 */
163
164int asm_set_ipl (uint32);
165void mcf5xxx_wr_cacr (uint32);
166void mcf5xxx_wr_acr0 (uint32);
167void mcf5xxx_wr_acr1 (uint32);
168void mcf5xxx_wr_acr2 (uint32);
169void mcf5xxx_wr_acr3 (uint32);
170void mcf5xxx_wr_other_a7 (uint32);
171void mcf5xxx_wr_other_sp (uint32);
172void mcf5xxx_wr_vbr (uint32);
173void mcf5xxx_wr_macsr (uint32);
174void mcf5xxx_wr_mask (uint32);
175void mcf5xxx_wr_acc0 (uint32);
176void mcf5xxx_wr_accext01 (uint32);
177void mcf5xxx_wr_accext23 (uint32);
178void mcf5xxx_wr_acc1 (uint32);
179void mcf5xxx_wr_acc2 (uint32);
180void mcf5xxx_wr_acc3 (uint32);
181void mcf5xxx_wr_sr (uint32);
182void mcf5xxx_wr_rambar0 (uint32);
183void mcf5xxx_wr_rambar1 (uint32);
184void mcf5xxx_wr_mbar (uint32);
185void mcf5xxx_wr_mbar0 (uint32);
186void mcf5xxx_wr_mbar1 (uint32);
187
188/********************************************************************/
189
190#endif /* _CPU_MCF5XXX_H */
191
192
193/********************************************************************/
194/*
195 * Memory map definitions from linker command files
196 */
197extern char __IPSBAR[];
198
199/*********************************************************************
200*
201* Watchdog Timer Modules (WTM)
202*
203*********************************************************************/
204
205/* Register read/write macros */
206#define MCF5235_WCR (*(vuint16*)((uintptr_t)__IPSBAR + (0x140000)))
207#define MCF5235_WMR (*(vuint16*)((uintptr_t)__IPSBAR + (0x140002)))
208#define MCF5235_WCNTR (*(vuint16*)((uintptr_t)__IPSBAR + (0x140004)))
209#define MCF5235_WSR (*(vuint16*)((uintptr_t)__IPSBAR + (0x140006)))
210
211/* Bit definitions and macros for MCF5235_WTM_WCR */
212#define MCF5235_WCR_EN (0x0001)
213#define MCF5235_WCR_HALTED (0x0002)
214#define MCF5235_WCR_DOZE (0x0004)
215#define MCF5235_WCR_WAIT (0x0008)
216
217/* Bit definitions and macros for MCF5235_WTM_WMR */
218#define MCF5235_WMR_WM0 (0x0001)
219#define MCF5235_WMR_WM1 (0x0002)
220#define MCF5235_WMR_WM2 (0x0004)
221#define MCF5235_WMR_WM3 (0x0008)
222#define MCF5235_WMR_WM4 (0x0010)
223#define MCF5235_WMR_WM5 (0x0020)
224#define MCF5235_WMR_WM6 (0x0040)
225#define MCF5235_WMR_WM7 (0x0080)
226#define MCF5235_WMR_WM8 (0x0100)
227#define MCF5235_WMR_WM9 (0x0200)
228#define MCF5235_WMR_WM10 (0x0400)
229#define MCF5235_WMR_WM11 (0x0800)
230#define MCF5235_WMR_WM12 (0x1000)
231#define MCF5235_WMR_WM13 (0x2000)
232#define MCF5235_WMR_WM14 (0x4000)
233#define MCF5235_WMR_WM15 (0x8000)
234
235/* Bit definitions and macros for MCF5235_WTM_WCNTR */
236#define MCF5235_WCNTR_WC0 (0x0001)
237#define MCF5235_WCNTR_WC1 (0x0002)
238#define MCF5235_WCNTR_WC2 (0x0004)
239#define MCF5235_WCNTR_WC3 (0x0008)
240#define MCF5235_WCNTR_WC4 (0x0010)
241#define MCF5235_WCNTR_WC5 (0x0020)
242#define MCF5235_WCNTR_WC6 (0x0040)
243#define MCF5235_WCNTR_WC7 (0x0080)
244#define MCF5235_WCNTR_WC8 (0x0100)
245#define MCF5235_WCNTR_WC9 (0x0200)
246#define MCF5235_WCNTR_WC10 (0x0400)
247#define MCF5235_WCNTR_WC11 (0x0800)
248#define MCF5235_WCNTR_WC12 (0x1000)
249#define MCF5235_WCNTR_WC13 (0x2000)
250#define MCF5235_WCNTR_WC14 (0x4000)
251#define MCF5235_WCNTR_WC15 (0x8000)
252#define MCF5235_WSR_WS0 (0x0001)
253#define MCF5235_WSR_WS1 (0x0002)
254#define MCF5235_WSR_WS2 (0x0004)
255#define MCF5235_WSR_WS3 (0x0008)
256#define MCF5235_WSR_WS4 (0x0010)
257#define MCF5235_WSR_WS5 (0x0020)
258#define MCF5235_WSR_WS6 (0x0040)
259#define MCF5235_WSR_WS7 (0x0080)
260#define MCF5235_WSR_WS8 (0x0100)
261#define MCF5235_WSR_WS9 (0x0200)
262#define MCF5235_WSR_WS10 (0x0400)
263#define MCF5235_WSR_WS11 (0x0800)
264#define MCF5235_WSR_WS12 (0x1000)
265#define MCF5235_WSR_WS13 (0x2000)
266#define MCF5235_WSR_WS14 (0x4000)
267#define MCF5235_WSR_WS15 (0x8000)
268
269/********************************************************************/
270
271/*********************************************************************
272*
273* Universal Asynchronous Receiver Transmitter (UART)
274*
275*********************************************************************/
276
277/* Register read/write macros */
278#define MCF5235_UART_UMR0 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000200)))
279#define MCF5235_UART_USR0 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000204)))
280#define MCF5235_UART_UCSR0 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000204)))
281#define MCF5235_UART_UCR0 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000208)))
282#define MCF5235_UART_URB0 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x00020C)))
283#define MCF5235_UART_UTB0 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x00020C)))
284#define MCF5235_UART_UIPCR0 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000210)))
285#define MCF5235_UART_UACR0 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000210)))
286#define MCF5235_UART_UISR0 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000214)))
287#define MCF5235_UART_UIMR0 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000214)))
288#define MCF5235_UART_UBG10 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000218)))
289#define MCF5235_UART_UBG20 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x00021C)))
290#define MCF5235_UART_UIP0 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000234)))
291#define MCF5235_UART_UOP10 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000238)))
292#define MCF5235_UART_UOP00 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x00023C)))
293#define MCF5235_UART_UMR1 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000240)))
294#define MCF5235_UART_USR1 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000244)))
295#define MCF5235_UART_UCSR1 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000244)))
296#define MCF5235_UART_UCR1 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000248)))
297#define MCF5235_UART_URB1 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x00024C)))
298#define MCF5235_UART_UTB1 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x00024C)))
299#define MCF5235_UART_UIPCR1 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000250)))
300#define MCF5235_UART_UACR1 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000250)))
301#define MCF5235_UART_UISR1 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000254)))
302#define MCF5235_UART_UIMR1 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000254)))
303#define MCF5235_UART_UBG11 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000258)))
304#define MCF5235_UART_UBG21 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x00025C)))
305#define MCF5235_UART_UIP1 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000274)))
306#define MCF5235_UART_UOP11 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000278)))
307#define MCF5235_UART_UOP01 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x00027C)))
308#define MCF5235_UART_UMR2 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000280)))
309#define MCF5235_UART_USR2 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000284)))
310#define MCF5235_UART_UCSR2 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000284)))
311#define MCF5235_UART_UCR2 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000288)))
312#define MCF5235_UART_URB2 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x00028C)))
313#define MCF5235_UART_UTB2 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x00028C)))
314#define MCF5235_UART_UIPCR2 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000290)))
315#define MCF5235_UART_UACR2 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000290)))
316#define MCF5235_UART_UISR2 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000294)))
317#define MCF5235_UART_UIMR2 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000294)))
318#define MCF5235_UART_UBG12 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000298)))
319#define MCF5235_UART_UBG22 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x00029C)))
320#define MCF5235_UART_UIP2 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x0002B4)))
321#define MCF5235_UART_UOP12 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x0002B8)))
322#define MCF5235_UART_UOP02 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x0002BC)))
323#define MCF5235_UART_UMR(x) (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000200+((x)*0x040))))
324#define MCF5235_UART_USR(x) (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000204+((x)*0x040))))
325#define MCF5235_UART_UCSR(x) (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000204+((x)*0x040))))
326#define MCF5235_UART_UCR(x) (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000208+((x)*0x040))))
327#define MCF5235_UART_URB(x) (*(vuint8 *)((uintptr_t)__IPSBAR + (0x00020C+((x)*0x040))))
328#define MCF5235_UART_UTB(x) (*(vuint8 *)((uintptr_t)__IPSBAR + (0x00020C+((x)*0x040))))
329#define MCF5235_UART_UIPCR(x) (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000210+((x)*0x040))))
330#define MCF5235_UART_UACR(x) (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000210+((x)*0x040))))
331#define MCF5235_UART_UISR(x) (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000214+((x)*0x040))))
332#define MCF5235_UART_UIMR(x) (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000214+((x)*0x040))))
333#define MCF5235_UART_UBG1(x) (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000218+((x)*0x040))))
334#define MCF5235_UART_UBG2(x) (*(vuint8 *)((uintptr_t)__IPSBAR + (0x00021C+((x)*0x040))))
335#define MCF5235_UART_UIP(x) (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000234+((x)*0x040))))
336#define MCF5235_UART_UOP1(x) (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000238+((x)*0x040))))
337#define MCF5235_UART_UOP0(x) (*(vuint8 *)((uintptr_t)__IPSBAR + (0x00023C+((x)*0x040))))
338
339/* Bit definitions and macros for MCF5235_UART_UMR */
340#define MCF5235_UART_UMR_BC(x) (((x)&0x03)<<0)
341#define MCF5235_UART_UMR_PT (0x04)
342#define MCF5235_UART_UMR_PM(x) (((x)&0x03)<<3)
343#define MCF5235_UART_UMR_ERR (0x20)
344#define MCF5235_UART_UMR_RXIRQ (0x40)
345#define MCF5235_UART_UMR_RXRTS (0x80)
346#define MCF5235_UART_UMR_SB(x) (((x)&0x0F)<<0)
347#define MCF5235_UART_UMR_TXCTS (0x10)
348#define MCF5235_UART_UMR_TXRTS (0x20)
349#define MCF5235_UART_UMR_CM(x) (((x)&0x03)<<6)
350#define MCF5235_UART_UMR_PM_MULTI_ADDR (0x1C)
351#define MCF5235_UART_UMR_PM_MULTI_DATA (0x18)
352#define MCF5235_UART_UMR_PM_NONE (0x10)
353#define MCF5235_UART_UMR_PM_FORCE_HI (0x0C)
354#define MCF5235_UART_UMR_PM_FORCE_LO (0x08)
355#define MCF5235_UART_UMR_PM_ODD (0x04)
356#define MCF5235_UART_UMR_PM_EVEN (0x00)
357#define MCF5235_UART_UMR_BC_5 (0x00)
358#define MCF5235_UART_UMR_BC_6 (0x01)
359#define MCF5235_UART_UMR_BC_7 (0x02)
360#define MCF5235_UART_UMR_BC_8 (0x03)
361#define MCF5235_UART_UMR_CM_NORMAL (0x00)
362#define MCF5235_UART_UMR_CM_ECHO (0x40)
363#define MCF5235_UART_UMR_CM_LOCAL_LOOP (0x80)
364#define MCF5235_UART_UMR_CM_REMOTE_LOOP (0xC0)
365#define MCF5235_UART_UMR_STOP_BITS_1 (0x07)
366#define MCF5235_UART_UMR_STOP_BITS_15 (0x08)
367#define MCF5235_UART_UMR_STOP_BITS_2 (0x0F)
368#define MCF5235_UART_USR_RXRDY (0x01)
369#define MCF5235_UART_USR_FFULL (0x02)
370#define MCF5235_UART_USR_TXRDY (0x04)
371#define MCF5235_UART_USR_TXEMP (0x08)
372#define MCF5235_UART_USR_OE (0x10)
373#define MCF5235_UART_USR_PE (0x20)
374#define MCF5235_UART_USR_FE (0x40)
375#define MCF5235_UART_USR_RB (0x80)
376#define MCF5235_UART_UCSR_TCS(x) (((x)&0x0F)<<0)
377#define MCF5235_UART_UCSR_RCS(x) (((x)&0x0F)<<4)
378#define MCF5235_UART_UCSR_RCS_SYS_CLK (0xD0)
379#define MCF5235_UART_UCSR_RCS_CTM16 (0xE0)
380#define MCF5235_UART_UCSR_RCS_CTM (0xF0)
381#define MCF5235_UART_UCSR_TCS_SYS_CLK (0x0D)
382#define MCF5235_UART_UCSR_TCS_CTM16 (0x0E)
383#define MCF5235_UART_UCSR_TCS_CTM (0x0F)
384#define MCF5235_UART_UCR_RXC(x) (((x)&0x03)<<0)
385#define MCF5235_UART_UCR_TXC(x) (((x)&0x03)<<2)
386#define MCF5235_UART_UCR_MISC(x) (((x)&0x07)<<4)
387#define MCF5235_UART_UCR_NONE (0x00)
388#define MCF5235_UART_UCR_STOP_BREAK (0x70)
389#define MCF5235_UART_UCR_START_BREAK (0x60)
390#define MCF5235_UART_UCR_BKCHGINT (0x50)
391#define MCF5235_UART_UCR_RESET_ERROR (0x40)
392#define MCF5235_UART_UCR_RESET_TX (0x30)
393#define MCF5235_UART_UCR_RESET_RX (0x20)
394#define MCF5235_UART_UCR_RESET_MR (0x10)
395#define MCF5235_UART_UCR_TX_DISABLED (0x08)
396#define MCF5235_UART_UCR_TX_ENABLED (0x04)
397#define MCF5235_UART_UCR_RX_DISABLED (0x02)
398#define MCF5235_UART_UCR_RX_ENABLED (0x01)
399#define MCF5235_UART_UIPCR_CTS (0x01)
400#define MCF5235_UART_UIPCR_COS (0x10)
401#define MCF5235_UART_UACR_IEC (0x01)
402#define MCF5235_UART_UISR_TXRDY (0x01)
403#define MCF5235_UART_UISR_RXRDY (0x02)
404#define MCF5235_UART_UISR_DB (0x04)
405#define MCF5235_UART_UISR_RXFTO (0x08)
406#define MCF5235_UART_UISR_TXFIFO (0x10)
407#define MCF5235_UART_UISR_RXFIFO (0x20)
408#define MCF5235_UART_UISR_COS (0x80)
409#define MCF5235_UART_UIMR_TXRDY (0x01)
410#define MCF5235_UART_UIMR_FFULL (0x02)
411#define MCF5235_UART_UIMR_DB (0x04)
412#define MCF5235_UART_UIMR_COS (0x80)
413#define MCF5235_UART_UIP_CTS (0x01)
414#define MCF5235_UART_UOP1_RTS (0x01)
415#define MCF5235_UART_UOP0_RTS (0x01)
416
417
418/*********************************************************************
419*
420* SDRAM Controller (SDRAMC)
421*
422*********************************************************************/
423
424/* Register read/write macros */
425#define MCF5235_SDRAMC_DCR (*(vuint16*)((uintptr_t)__IPSBAR + (0x000040)))
426#define MCF5235_SDRAMC_DACR0 (*(vuint32*)((uintptr_t)__IPSBAR + (0x000048)))
427#define MCF5235_SDRAMC_DMR0 (*(vuint32*)((uintptr_t)__IPSBAR + (0x00004C)))
428#define MCF5235_SDRAMC_DACR1 (*(vuint32*)((uintptr_t)__IPSBAR + (0x000050)))
429#define MCF5235_SDRAMC_DMR1 (*(vuint32*)((uintptr_t)__IPSBAR + (0x000054)))
430
431/* Bit definitions and macros for MCF5235_SDRAMC_DCR */
432#define MCF5235_SDRAMC_DCR_RC(x) (((x)&0x01FF)<<0)
433#define MCF5235_SDRAMC_DCR_RTIM(x) (((x)&0x0003)<<9)
434#define MCF5235_SDRAMC_DCR_IS (0x0800)
435#define MCF5235_SDRAMC_DCR_COC (0x1000)
436#define MCF5235_SDRAMC_DCR_NAM (0x2000)
437#define MCF5235_SDRAMC_DACR0_IP (0x00000008)
438#define MCF5235_SDRAMC_DACR0_PS(x) (((x)&0x00000003)<<4)
439#define MCF5235_SDRAMC_DACR0_MRS (0x00000040)
440#define MCF5235_SDRAMC_DACR0_CBM(x) (((x)&0x00000007)<<8)
441#define MCF5235_SDRAMC_DACR0_CASL(x) (((x)&0x00000003)<<12)
442#define MCF5235_SDRAMC_DACR0_RE (0x00008000)
443#define MCF5235_SDRAMC_DACR0_BA(x) (((x)&0x00003FFF)<<18)
444#define MCF5235_SDRAMC_DMR0_V (0x00000001)
445#define MCF5235_SDRAMC_DMR0_WP (0x00000100)
446#define MCF5235_SDRAMC_DMR0_BAM(x) (((x)&0x00003FFF)<<18)
447#define MCF5235_SDRAMC_DACR1_IP (0x00000008)
448#define MCF5235_SDRAMC_DACR1_PS(x) (((x)&0x00000003)<<4)
449#define MCF5235_SDRAMC_DACR1_MRS (0x00000040)
450#define MCF5235_SDRAMC_DACR1_CBM(x) (((x)&0x00000007)<<8)
451#define MCF5235_SDRAMC_DACR1_CASL(x) (((x)&0x00000003)<<12)
452#define MCF5235_SDRAMC_DACR1_RE (0x00008000)
453#define MCF5235_SDRAMC_DACR1_BA(x) (((x)&0x00003FFF)<<18)
454#define MCF5235_SDRAMC_DMR1_V (0x00000001)
455#define MCF5235_SDRAMC_DMR1_WP (0x00000100)
456#define MCF5235_SDRAMC_DMR1_BAM(x) (((x)&0x00003FFF)<<18)
457#define MCF5235_SDRAMC_DMR_BAM_4G (0xFFFC0000)
458#define MCF5235_SDRAMC_DMR_BAM_2G (0x7FFC0000)
459#define MCF5235_SDRAMC_DMR_BAM_1G (0x3FFC0000)
460#define MCF5235_SDRAMC_DMR_BAM_1024M (0x3FFC0000)
461#define MCF5235_SDRAMC_DMR_BAM_512M (0x1FFC0000)
462#define MCF5235_SDRAMC_DMR_BAM_256M (0x0FFC0000)
463#define MCF5235_SDRAMC_DMR_BAM_128M (0x07FC0000)
464#define MCF5235_SDRAMC_DMR_BAM_64M (0x03FC0000)
465#define MCF5235_SDRAMC_DMR_BAM_32M (0x01FC0000)
466#define MCF5235_SDRAMC_DMR_BAM_16M (0x00FC0000)
467#define MCF5235_SDRAMC_DMR_BAM_8M (0x007C0000)
468#define MCF5235_SDRAMC_DMR_BAM_4M (0x003C0000)
469#define MCF5235_SDRAMC_DMR_BAM_2M (0x001C0000)
470#define MCF5235_SDRAMC_DMR_BAM_1M (0x000C0000)
471#define MCF5235_SDRAMC_DMR_BAM_1024K (0x000C0000)
472#define MCF5235_SDRAMC_DMR_BAM_512K (0x00040000)
473#define MCF5235_SDRAMC_DMR_BAM_256K (0x00000000)
474#define MCF5235_SDRAMC_DMR_WP (0x00000100)
475#define MCF5235_SDRAMC_DMR_CI (0x00000040)
476#define MCF5235_SDRAMC_DMR_AM (0x00000020)
477#define MCF5235_SDRAMC_DMR_SC (0x00000010)
478#define MCF5235_SDRAMC_DMR_SD (0x00000008)
479#define MCF5235_SDRAMC_DMR_UC (0x00000004)
480#define MCF5235_SDRAMC_DMR_UD (0x00000002)
481#define MCF5235_SDRAMC_DMR_V (0x00000001)
482
483/*********************************************************************
484*
485* DMA Timers (TIMER)
486*
487*********************************************************************/
488
489/* Register read/write macros */
490#define MCF5235_TIMER_DTMR0 (*(vuint16*)((uintptr_t)__IPSBAR + (0x000400)))
491#define MCF5235_TIMER_DTXMR0 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000402)))
492#define MCF5235_TIMER_DTER0 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000403)))
493#define MCF5235_TIMER_DTRR0 (*(vuint32*)((uintptr_t)__IPSBAR + (0x000404)))
494#define MCF5235_TIMER_DTCR0 (*(vuint32*)((uintptr_t)__IPSBAR + (0x000408)))
495#define MCF5235_TIMER_DTCN0 (*(vuint32*)((uintptr_t)__IPSBAR + (0x00040C)))
496#define MCF5235_TIMER_DTMR1 (*(vuint16*)((uintptr_t)__IPSBAR + (0x000440)))
497#define MCF5235_TIMER_DTXMR1 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000442)))
498#define MCF5235_TIMER_DTER1 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000443)))
499#define MCF5235_TIMER_DTRR1 (*(vuint32*)((uintptr_t)__IPSBAR + (0x000444)))
500#define MCF5235_TIMER_DTCR1 (*(vuint32*)((uintptr_t)__IPSBAR + (0x000448)))
501#define MCF5235_TIMER_DTCN1 (*(vuint32*)((uintptr_t)__IPSBAR + (0x00044C)))
502#define MCF5235_TIMER_DTMR2 (*(vuint16*)((uintptr_t)__IPSBAR + (0x000480)))
503#define MCF5235_TIMER_DTXMR2 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000482)))
504#define MCF5235_TIMER_DTER2 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000483)))
505#define MCF5235_TIMER_DTRR2 (*(vuint32*)((uintptr_t)__IPSBAR + (0x000484)))
506#define MCF5235_TIMER_DTCR2 (*(vuint32*)((uintptr_t)__IPSBAR + (0x000488)))
507#define MCF5235_TIMER_DTCN2 (*(vuint32*)((uintptr_t)__IPSBAR + (0x00048C)))
508#define MCF5235_TIMER3_DTMR (*(vuint16*)((uintptr_t)__IPSBAR + (0x0004C0)))
509#define MCF5235_TIMER_DTXMR3 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x0004C2)))
510#define MCF5235_TIMER_DTER3 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x0004C3)))
511#define MCF5235_TIMER_DTRR3 (*(vuint32*)((uintptr_t)__IPSBAR + (0x0004C4)))
512#define MCF5235_TIMER_DTCR3 (*(vuint32*)((uintptr_t)__IPSBAR + (0x0004C8)))
513#define MCF5235_TIMER3_DTCN (*(vuint32*)((uintptr_t)__IPSBAR + (0x0004CC)))
514#define MCF5235_TIMER_DTMR(x) (*(vuint16*)((uintptr_t)__IPSBAR + (0x000400+((x)*0x040))))
515#define MCF5235_TIMER_DTXMR(x) (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000402+((x)*0x040))))
516#define MCF5235_TIMER_DTER(x) (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000403+((x)*0x040))))
517#define MCF5235_TIMER_DTRR(x) (*(vuint32*)((uintptr_t)__IPSBAR + (0x000404+((x)*0x040))))
518#define MCF5235_TIMER_DTCR(x) (*(vuint32*)((uintptr_t)__IPSBAR + (0x000408+((x)*0x040))))
519#define MCF5235_TIMER_DTCN(x) (*(vuint32*)((uintptr_t)__IPSBAR + (0x00040C+((x)*0x040))))
520
521/* Bit definitions and macros for MCF5235_TIMER_DTMR */
522#define MCF5235_TIMER_DTMR_RST (0x0001)
523#define MCF5235_TIMER_DTMR_CLK(x) (((x)&0x0003)<<1)
524#define MCF5235_TIMER_DTMR_FRR (0x0008)
525#define MCF5235_TIMER_DTMR_ORRI (0x0010)
526#define MCF5235_TIMER_DTMR_OM (0x0020)
527#define MCF5235_TIMER_DTMR_CE(x) (((x)&0x0003)<<6)
528#define MCF5235_TIMER_DTMR_PS(x) (((x)&0x00FF)<<8)
529#define MCF5235_TIMER_DTMR_CE_ANY (0x00C0)
530#define MCF5235_TIMER_DTMR_CE_FALL (0x0080)
531#define MCF5235_TIMER_DTMR_CE_RISE (0x0040)
532#define MCF5235_TIMER_DTMR_CE_NONE (0x0000)
533#define MCF5235_TIMER_DTMR_CLK_DTIN (0x0006)
534#define MCF5235_TIMER_DTMR_CLK_DIV16 (0x0004)
535#define MCF5235_TIMER_DTMR_CLK_DIV1 (0x0002)
536#define MCF5235_TIMER_DTMR_CLK_STOP (0x0000)
537#define MCF5235_TIMER_DTXMR_MODE16 (0x01)
538#define MCF5235_TIMER_DTXMR_DMAEN (0x80)
539#define MCF5235_TIMER_DTER_CAP (0x01)
540#define MCF5235_TIMER_DTER_REF (0x02)
541
542/*********************************************************************
543*
544* System SRAM (SRAM)
545*
546*********************************************************************/
547
548/* Register read/write macros */
549#define MCF5235_SRAM_RAMBAR (*(vuint32*)((uintptr_t)__IPSBAR + (0x20000000)))
550
551/* Bit definitions and macros for MCF5235_SRAM_RAMBAR */
552#define MCF5235_SRAM_RAMBAR_V (0x00000001)
553#define MCF5235_SRAM_RAMBAR_UD (0x00000002)
554#define MCF5235_SRAM_RAMBAR_UC (0x00000004)
555#define MCF5235_SRAM_RAMBAR_SD (0x00000008)
556#define MCF5235_SRAM_RAMBAR_SC (0x00000010)
557#define MCF5235_SRAM_RAMBAR_CI (0x00000020)
558#define MCF5235_SRAM_RAMBAR_WP (0x00000100)
559#define MCF5235_SRAM_RAMBAR_SPV (0x00000200)
560#define MCF5235_SRAM_RAMBAR_PRI2 (0x00000400)
561#define MCF5235_SRAM_RAMBAR_PRI1 (0x00000800)
562#define MCF5235_SRAM_RAMBAR_BA(x) (((x)&0x0000FFFF)<<16)
563
564/*********************************************************************
565*
566* System Control Module (SCM)
567*
568*********************************************************************/
569
570/* Register read/write macros */
571#define MCF5235_SCM_IPSBAR (*(vuint32*)((uintptr_t)__IPSBAR + (0x000000)))
572#define MCF5235_SCM_RAMBAR (*(vuint32*)((uintptr_t)__IPSBAR + (0x000008)))
573#define MCF5235_SCM_CRSR (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000010)))
574#define MCF5235_SCM_CWCR (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000011)))
575#define MCF5235_SCM_LPICR (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000012)))
576#define MCF5235_SCM_CWSR (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000013)))
577#define MCF5235_SCM_DMAREQC (*(vuint32*)((uintptr_t)__IPSBAR + (0x000014)))
578#define MCF5235_SCM_MPARK (*(vuint32*)((uintptr_t)__IPSBAR + (0x00001C)))
579#define MCF5235_SCM_MPR (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000020)))
580#define MCF5235_SCM_PACR0 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000024)))
581#define MCF5235_SCM_PACR1 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000025)))
582#define MCF5235_SCM_PACR2 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000026)))
583#define MCF5235_SCM_PACR3 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000027)))
584#define MCF5235_SCM_PACR4 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000028)))
585#define MCF5235_SCM_PACR5 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x00002A)))
586#define MCF5235_SCM_PACR6 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x00002B)))
587#define MCF5235_SCM_PACR7 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x00002C)))
588#define MCF5235_SCM_PACR8 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x00002E)))
589#define MCF5235_SCM_GPACR0 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000030)))
590
591/* Bit definitions */
592#define MCF5235_SCM_IPSBAR_V (0x00000001)
593#define MCF5235_SCM_IPSBAR_BA(x) (((x)&0x00000003)<<30)
594#define MCF5235_SCM_RAMBAR_BDE (0x00000200)
595#define MCF5235_SCM_RAMBAR_BA(x) (((x)&0x0000FFFF)<<16)
596#define MCF5235_SCM_CRSR_CWDR (0x20)
597#define MCF5235_SCM_CRSR_EXT (0x80)
598#define MCF5235_SCM_CWCR_CWTIC (0x01)
599#define MCF5235_SCM_CWCR_CWTAVAL (0x02)
600#define MCF5235_SCM_CWCR_CWTA (0x04)
601#define MCF5235_SCM_CWCR_CWT(x) (((x)&0x07)<<3)
602#define MCF5235_SCM_CWCR_CWRI (0x40)
603#define MCF5235_SCM_CWCR_CWE (0x80)
604#define MCF5235_SCM_LPICR_XLPM_IPL(x) (((x)&0x07)<<4)
605#define MCF5235_SCM_LPICR_ENBSTOP (0x80)
606#define MCF5235_SCM_DMAREQC_DMAC0(x) (((x)&0x0000000F)<<0)
607#define MCF5235_SCM_DMAREQC_DMAC1(x) (((x)&0x0000000F)<<4)
608#define MCF5235_SCM_DMAREQC_DMAC2(x) (((x)&0x0000000F)<<8)
609#define MCF5235_SCM_DMAREQC_DMAC3(x) (((x)&0x0000000F)<<12)
610#define MCF5235_SCM_MPARK_LCKOUT_TIME(x) (((x)&0x0000000F)<<8)
611#define MCF5235_SCM_MPARK_PRKLAST (0x00001000)
612#define MCF5235_SCM_MPARK_TIMEOUT (0x00002000)
613#define MCF5235_SCM_MPARK_FIXED (0x00004000)
614#define MCF5235_SCM_MPARK_M1_PRTY(x) (((x)&0x00000003)<<16)
615#define MCF5235_SCM_MPARK_M0_PRTY(x) (((x)&0x00000003)<<18)
616#define MCF5235_SCM_MPARK_M2_PRTY(x) (((x)&0x00000003)<<20)
617#define MCF5235_SCM_MPARK_M3_PRTY(x) (((x)&0x00000003)<<22)
618#define MCF5235_SCM_MPARK_BCR24BIT (0x01000000)
619#define MCF5235_SCM_MPARK_M2_P_EN (0x02000000)
620#define MCF5235_SCM_MPR_MPR(x) (((x)&0x0F)<<0)
621#define MCF5235_SCM_PACR0_ACCESS_CTRL0(x) (((x)&0x07)<<0)
622#define MCF5235_SCM_PACR0_LOCK0 (0x08)
623#define MCF5235_SCM_PACR0_ACCESS_CTRL1(x) (((x)&0x07)<<4)
624#define MCF5235_SCM_PACR0_LOCK1 (0x80)
625#define MCF5235_SCM_PACR1_ACCESS_CTRL0(x) (((x)&0x07)<<0)
626#define MCF5235_SCM_PACR1_LOCK0 (0x08)
627#define MCF5235_SCM_PACR1_ACCESS_CTRL1(x) (((x)&0x07)<<4)
628#define MCF5235_SCM_PACR1_LOCK1 (0x80)
629#define MCF5235_SCM_PACR2_ACCESS_CTRL0(x) (((x)&0x07)<<0)
630#define MCF5235_SCM_PACR2_LOCK0 (0x08)
631#define MCF5235_SCM_PACR2_ACCESS_CTRL1(x) (((x)&0x07)<<4)
632#define MCF5235_SCM_PACR2_LOCK1 (0x80)
633#define MCF5235_SCM_PACR3_ACCESS_CTRL0(x) (((x)&0x07)<<0)
634#define MCF5235_SCM_PACR3_LOCK0 (0x08)
635#define MCF5235_SCM_PACR3_ACCESS_CTRL1(x) (((x)&0x07)<<4)
636#define MCF5235_SCM_PACR3_LOCK1 (0x80)
637#define MCF5235_SCM_PACR4_ACCESS_CTRL0(x) (((x)&0x07)<<0)
638#define MCF5235_SCM_PACR4_LOCK0 (0x08)
639#define MCF5235_SCM_PACR4_ACCESS_CTRL1(x) (((x)&0x07)<<4)
640#define MCF5235_SCM_PACR4_LOCK1 (0x80)
641#define MCF5235_SCM_PACR5_ACCESS_CTRL0(x) (((x)&0x07)<<0)
642#define MCF5235_SCM_PACR5_LOCK0 (0x08)
643#define MCF5235_SCM_PACR5_ACCESS_CTRL1(x) (((x)&0x07)<<4)
644#define MCF5235_SCM_PACR5_LOCK1 (0x80)
645#define MCF5235_SCM_PACR6_ACCESS_CTRL0(x) (((x)&0x07)<<0)
646#define MCF5235_SCM_PACR6_LOCK0 (0x08)
647#define MCF5235_SCM_PACR6_ACCESS_CTRL1(x) (((x)&0x07)<<4)
648#define MCF5235_SCM_PACR6_LOCK1 (0x80)
649#define MCF5235_SCM_PACR7_ACCESS_CTRL0(x) (((x)&0x07)<<0)
650#define MCF5235_SCM_PACR7_LOCK0 (0x08)
651#define MCF5235_SCM_PACR7_ACCESS_CTRL1(x) (((x)&0x07)<<4)
652#define MCF5235_SCM_PACR7_LOCK1 (0x80)
653#define MCF5235_SCM_PACR8_ACCESS_CTRL0(x) (((x)&0x07)<<0)
654#define MCF5235_SCM_PACR8_LOCK0 (0x08)
655#define MCF5235_SCM_PACR8_ACCESS_CTRL1(x) (((x)&0x07)<<4)
656#define MCF5235_SCM_PACR8_LOCK1 (0x80)
657#define MCF5235_SCM_GPACR0_ACCESS_CTRL(x) (((x)&0x0F)<<0)
658#define MCF5235_SCM_GPACR0_LOCK (0x80)
659
660
661/*********************************************************************
662*
663* FlexCAN Module (CAN)
664*
665*********************************************************************/
666
667/* Register read/write macros */
668#define MCF5235_CAN_CANMCR0 (*(vuint32*)((uintptr_t)__IPSBAR + (0x1C0000)))
669#define MCF5235_CAN_CANCTRL0 (*(vuint32*)((uintptr_t)__IPSBAR + (0x1C0004)))
670#define MCF5235_CAN_TIMER0 (*(vuint32*)((uintptr_t)__IPSBAR + (0x1C0008)))
671#define MCF5235_CAN_RXGMASK0 (*(vuint32*)((uintptr_t)__IPSBAR + (0x1C0010)))
672#define MCF5235_CAN_RX14MASK0 (*(vuint32*)((uintptr_t)__IPSBAR + (0x1C0014)))
673#define MCF5235_CAN_RX15MASK0 (*(vuint32*)((uintptr_t)__IPSBAR + (0x1C0018)))
674#define MCF5235_CAN_ERRCNT0 (*(vuint32*)((uintptr_t)__IPSBAR + (0x1C001C)))
675#define MCF5235_CAN_ERRSTAT0 (*(vuint32*)((uintptr_t)__IPSBAR + (0x1C0020)))
676#define MCF5235_CAN_IMASK0 (*(vuint16*)((uintptr_t)__IPSBAR + (0x1C002A)))
677#define MCF5235_CAN_IFLAG0 (*(vuint16*)((uintptr_t)__IPSBAR + (0x1C0032)))
678#define MCF5235_CAN_CANMCR1 (*(vuint32*)((uintptr_t)__IPSBAR + (0x1F0000)))
679#define MCF5235_CAN_CANCTRL1 (*(vuint32*)((uintptr_t)__IPSBAR + (0x1F0004)))
680#define MCF5235_CAN_TIMER1 (*(vuint32*)((uintptr_t)__IPSBAR + (0x1F0008)))
681#define MCF5235_CAN_RXGMASK1 (*(vuint32*)((uintptr_t)__IPSBAR + (0x1F0010)))
682#define MCF5235_CAN_RX14MASK1 (*(vuint32*)((uintptr_t)__IPSBAR + (0x1F0014)))
683#define MCF5235_CAN_RX15MASK1 (*(vuint32*)((uintptr_t)__IPSBAR + (0x1F0018)))
684#define MCF5235_CAN_ERRCNT1 (*(vuint32*)((uintptr_t)__IPSBAR + (0x1F001C)))
685#define MCF5235_CAN_ERRSTAT1 (*(vuint32*)((uintptr_t)__IPSBAR + (0x1F0020)))
686#define MCF5235_CAN_IMASK1 (*(vuint16*)((uintptr_t)__IPSBAR + (0x1F002A)))
687#define MCF5235_CAN_IFLAG1 (*(vuint16*)((uintptr_t)__IPSBAR + (0x1F0032)))
688#define MCF5235_CAN_CANMCR(x) (*(vuint32*)((uintptr_t)__IPSBAR + (0x1C0000+((x)*0x30000))))
689#define MCF5235_CAN_CANCTRL(x) (*(vuint32*)((uintptr_t)__IPSBAR + (0x1C0004+((x)*0x30000))))
690#define MCF5235_CAN_TIMER(x) (*(vuint32*)((uintptr_t)__IPSBAR + (0x1C0008+((x)*0x30000))))
691#define MCF5235_CAN_RXGMASK(x) (*(vuint32*)((uintptr_t)__IPSBAR + (0x1C0010+((x)*0x30000))))
692#define MCF5235_CAN_RX14MASK(x) (*(vuint32*)((uintptr_t)__IPSBAR + (0x1C0014+((x)*0x30000))))
693#define MCF5235_CAN_RX15MASK(x) (*(vuint32*)((uintptr_t)__IPSBAR + (0x1C0018+((x)*0x30000))))
694#define MCF5235_CAN_ERRCNT(x) (*(vuint32*)((uintptr_t)__IPSBAR + (0x1C001C+((x)*0x30000))))
695#define MCF5235_CAN_ERRSTAT(x) (*(vuint32*)((uintptr_t)__IPSBAR + (0x1C0020+((x)*0x30000))))
696#define MCF5235_CAN_IMASK(x) (*(vuint16*)((uintptr_t)__IPSBAR + (0x1C002A+((x)*0x30000))))
697#define MCF5235_CAN_IFLAG(x) (*(vuint16*)((uintptr_t)__IPSBAR + (0x1C0032+((x)*0x30000))))
698
699#define MCF5235_CAN_MBUF0_CTRL(x) (*(vuint16 *)(void *)((uintptr_t)__IPSBAR + (0x1C0080+((x)*0x30000))))
700#define MCF5235_CAN_MBUF0_TMSTP(x) (*(vuint16 *)(void *)((uintptr_t)__IPSBAR + (0x1C0082+((x)*0x30000))))
701#define MCF5235_CAN_MBUF0_ID(x) (*(vuint32 *)(void *)((uintptr_t)__IPSBAR + (0x1C0084+((x)*0x30000))))
702#define MCF5235_CAN_MBUF0_BYTE0(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C0088+((x)*0x30000))))
703#define MCF5235_CAN_MBUF0_BYTE1(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C0089+((x)*0x30000))))
704#define MCF5235_CAN_MBUF0_BYTE2(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C008A+((x)*0x30000))))
705#define MCF5235_CAN_MBUF0_BYTE3(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C008B+((x)*0x30000))))
706#define MCF5235_CAN_MBUF0_BYTE4(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C008C+((x)*0x30000))))
707#define MCF5235_CAN_MBUF0_BYTE5(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C008D+((x)*0x30000))))
708#define MCF5235_CAN_MBUF0_BYTE6(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C008E+((x)*0x30000))))
709#define MCF5235_CAN_MBUF0_BYTE7(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C008F+((x)*0x30000))))
710#define MCF5235_CAN_MBUF1_CTRL(x) (*(vuint16 *)(void *)((uintptr_t)__IPSBAR + (0x1C0090+((x)*0x30000))))
711#define MCF5235_CAN_MBUF1_TMSTP(x) (*(vuint16 *)(void *)((uintptr_t)__IPSBAR + (0x1C0092+((x)*0x30000))))
712#define MCF5235_CAN_MBUF1_ID(x) (*(vuint32 *)(void *)((uintptr_t)__IPSBAR + (0x1C0094+((x)*0x30000))))
713#define MCF5235_CAN_MBUF1_BYTE0(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C0098+((x)*0x30000))))
714#define MCF5235_CAN_MBUF1_BYTE1(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C0099+((x)*0x30000))))
715#define MCF5235_CAN_MBUF1_BYTE2(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C009A+((x)*0x30000))))
716#define MCF5235_CAN_MBUF1_BYTE3(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C009B+((x)*0x30000))))
717#define MCF5235_CAN_MBUF1_BYTE4(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C009C+((x)*0x30000))))
718#define MCF5235_CAN_MBUF1_BYTE5(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C009D+((x)*0x30000))))
719#define MCF5235_CAN_MBUF1_BYTE6(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C009E+((x)*0x30000))))
720#define MCF5235_CAN_MBUF1_BYTE7(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C009F+((x)*0x30000))))
721#define MCF5235_CAN_MBUF2_CTRL(x) (*(vuint16 *)(void *)((uintptr_t)__IPSBAR + (0x1C00A0+((x)*0x30000))))
722#define MCF5235_CAN_MBUF2_ID(x) (*(vuint32 *)(void *)((uintptr_t)__IPSBAR + (0x1C00A4+((x)*0x30000))))
723#define MCF5235_CAN_MBUF2_BYTE0(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C00A8+((x)*0x30000))))
724#define MCF5235_CAN_MBUF2_BYTE1(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C00A9+((x)*0x30000))))
725#define MCF5235_CAN_MBUF2_BYTE2(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C00AA+((x)*0x30000))))
726#define MCF5235_CAN_MBUF2_BYTE3(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C00AB+((x)*0x30000))))
727#define MCF5235_CAN_MBUF2_BYTE4(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C00AC+((x)*0x30000))))
728#define MCF5235_CAN_MBUF2_BYTE5(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C00AD+((x)*0x30000))))
729#define MCF5235_CAN_MBUF2_BYTE6(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C00AE+((x)*0x30000))))
730#define MCF5235_CAN_MBUF2_BYTE7(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C00AF+((x)*0x30000))))
731#define MCF5235_CAN_MBUF3_CTRL(x) (*(vuint16 *)(void *)((uintptr_t)__IPSBAR + (0x1C00B0+((x)*0x30000))))
732#define MCF5235_CAN_MBUF3_ID(x) (*(vuint32 *)(void *)((uintptr_t)__IPSBAR + (0x1C00B4+((x)*0x30000))))
733#define MCF5235_CAN_MBUF3_BYTE0(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C00B8+((x)*0x30000))))
734#define MCF5235_CAN_MBUF3_BYTE1(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C00B9+((x)*0x30000))))
735#define MCF5235_CAN_MBUF3_BYTE2(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C00BA+((x)*0x30000))))
736#define MCF5235_CAN_MBUF3_BYTE3(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C00BB+((x)*0x30000))))
737#define MCF5235_CAN_MBUF3_BYTE4(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C00BC+((x)*0x30000))))
738#define MCF5235_CAN_MBUF3_BYTE5(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C00BD+((x)*0x30000))))
739#define MCF5235_CAN_MBUF3_BYTE6(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C00BE+((x)*0x30000))))
740#define MCF5235_CAN_MBUF3_BYTE7(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C00BF+((x)*0x30000))))
741#define MCF5235_CAN_MBUF4_CTRL(x) (*(vuint16 *)(void *)((uintptr_t)__IPSBAR + (0x1C00C0+((x)*0x30000))))
742#define MCF5235_CAN_MBUF4_ID(x) (*(vuint32 *)(void *)((uintptr_t)__IPSBAR + (0x1C00C4+((x)*0x30000))))
743#define MCF5235_CAN_MBUF4_BYTE0(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C00C8+((x)*0x30000))))
744#define MCF5235_CAN_MBUF4_BYTE1(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C00C9+((x)*0x30000))))
745#define MCF5235_CAN_MBUF4_BYTE2(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C00CA+((x)*0x30000))))
746#define MCF5235_CAN_MBUF4_BYTE3(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C00CB+((x)*0x30000))))
747#define MCF5235_CAN_MBUF4_BYTE4(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C00CC+((x)*0x30000))))
748#define MCF5235_CAN_MBUF4_BYTE5(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C00CD+((x)*0x30000))))
749#define MCF5235_CAN_MBUF4_BYTE6(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C00CE+((x)*0x30000))))
750#define MCF5235_CAN_MBUF4_BYTE7(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C00CF+((x)*0x30000))))
751#define MCF5235_CAN_MBUF5_CTRL(x) (*(vuint16 *)(void *)((uintptr_t)__IPSBAR + (0x1C00D0+((x)*0x30000))))
752#define MCF5235_CAN_MBUF5_ID(x) (*(vuint32 *)(void *)((uintptr_t)__IPSBAR + (0x1C00D4+((x)*0x30000))))
753#define MCF5235_CAN_MBUF5_BYTE0(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C00D8+((x)*0x30000))))
754#define MCF5235_CAN_MBUF5_BYTE1(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C00D9+((x)*0x30000))))
755#define MCF5235_CAN_MBUF5_BYTE2(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C00DA+((x)*0x30000))))
756#define MCF5235_CAN_MBUF5_BYTE3(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C00DB+((x)*0x30000))))
757#define MCF5235_CAN_MBUF5_BYTE4(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C00DC+((x)*0x30000))))
758#define MCF5235_CAN_MBUF5_BYTE5(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C00DD+((x)*0x30000))))
759#define MCF5235_CAN_MBUF5_BYTE6(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C00DE+((x)*0x30000))))
760#define MCF5235_CAN_MBUF5_BYTE7(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C00DF+((x)*0x30000))))
761#define MCF5235_CAN_MBUF6_CTRL(x) (*(vuint16 *)(void *)((uintptr_t)__IPSBAR + (0x1C00E0+((x)*0x30000))))
762#define MCF5235_CAN_MBUF6_ID(x) (*(vuint32 *)(void *)((uintptr_t)__IPSBAR + (0x1C00E4+((x)*0x30000))))
763#define MCF5235_CAN_MBUF6_BYTE0(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C00E8+((x)*0x30000))))
764#define MCF5235_CAN_MBUF6_BYTE1(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C00E9+((x)*0x30000))))
765#define MCF5235_CAN_MBUF6_BYTE2(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C00EA+((x)*0x30000))))
766#define MCF5235_CAN_MBUF6_BYTE3(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C00EB+((x)*0x30000))))
767#define MCF5235_CAN_MBUF6_BYTE4(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C00EC+((x)*0x30000))))
768#define MCF5235_CAN_MBUF6_BYTE5(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C00ED+((x)*0x30000))))
769#define MCF5235_CAN_MBUF6_BYTE6(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C00EE+((x)*0x30000))))
770#define MCF5235_CAN_MBUF6_BYTE7(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C00EF+((x)*0x30000))))
771#define MCF5235_CAN_MBUF7_CTRL(x) (*(vuint16 *)(void *)((uintptr_t)__IPSBAR + (0x1C00F0+((x)*0x30000))))
772#define MCF5235_CAN_MBUF7_ID(x) (*(vuint32 *)(void *)((uintptr_t)__IPSBAR + (0x1C00F4+((x)*0x30000))))
773#define MCF5235_CAN_MBUF7_BYTE0(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C00F8+((x)*0x30000))))
774#define MCF5235_CAN_MBUF7_BYTE1(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C00F9+((x)*0x30000))))
775#define MCF5235_CAN_MBUF7_BYTE2(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C00FA+((x)*0x30000))))
776#define MCF5235_CAN_MBUF7_BYTE3(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C00FB+((x)*0x30000))))
777#define MCF5235_CAN_MBUF7_BYTE4(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C00FC+((x)*0x30000))))
778#define MCF5235_CAN_MBUF7_BYTE5(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C00FD+((x)*0x30000))))
779#define MCF5235_CAN_MBUF7_BYTE6(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C00FE+((x)*0x30000))))
780#define MCF5235_CAN_MBUF7_BYTE7(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C00FF+((x)*0x30000))))
781#define MCF5235_CAN_MBUF8_CTRL(x) (*(vuint16 *)(void *)((uintptr_t)__IPSBAR + (0x1C0100+((x)*0x30000))))
782#define MCF5235_CAN_MBUF8_ID(x) (*(vuint32 *)(void *)((uintptr_t)__IPSBAR + (0x1C0104+((x)*0x30000))))
783#define MCF5235_CAN_MBUF8_BYTE0(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C0108+((x)*0x30000))))
784#define MCF5235_CAN_MBUF8_BYTE1(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C0109+((x)*0x30000))))
785#define MCF5235_CAN_MBUF8_BYTE2(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C010A+((x)*0x30000))))
786#define MCF5235_CAN_MBUF8_BYTE3(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C010B+((x)*0x30000))))
787#define MCF5235_CAN_MBUF8_BYTE4(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C010C+((x)*0x30000))))
788#define MCF5235_CAN_MBUF8_BYTE5(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C010D+((x)*0x30000))))
789#define MCF5235_CAN_MBUF8_BYTE6(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C010E+((x)*0x30000))))
790#define MCF5235_CAN_MBUF8_BYTE7(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C010F+((x)*0x30000))))
791#define MCF5235_CAN_MBUF9_CTRL(x) (*(vuint16 *)(void *)((uintptr_t)__IPSBAR + (0x1C0100+((x)*0x30000))))
792#define MCF5235_CAN_MBUF9_ID(x) (*(vuint32 *)(void *)((uintptr_t)__IPSBAR + (0x1C0114+((x)*0x30000))))
793#define MCF5235_CAN_MBUF9_BYTE0(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C0118+((x)*0x30000))))
794#define MCF5235_CAN_MBUF9_BYTE1(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C0119+((x)*0x30000))))
795#define MCF5235_CAN_MBUF9_BYTE2(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C011A+((x)*0x30000))))
796#define MCF5235_CAN_MBUF9_BYTE3(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C011B+((x)*0x30000))))
797#define MCF5235_CAN_MBUF9_BYTE4(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C011C+((x)*0x30000))))
798#define MCF5235_CAN_MBUF9_BYTE5(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C011D+((x)*0x30000))))
799#define MCF5235_CAN_MBUF9_BYTE6(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C011E+((x)*0x30000))))
800#define MCF5235_CAN_MBUF9_BYTE7(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C011F+((x)*0x30000))))
801#define MCF5235_CAN_MBUF10_CTRL(x) (*(vuint16 *)(void *)((uintptr_t)__IPSBAR + (0x1C0120+((x)*0x30000))))
802#define MCF5235_CAN_MBUF10_ID(x) (*(vuint32 *)(void *)((uintptr_t)__IPSBAR + (0x1C0124+((x)*0x30000))))
803#define MCF5235_CAN_MBUF10_BYTE0(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C0128+((x)*0x30000))))
804#define MCF5235_CAN_MBUF10_BYTE1(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C0129+((x)*0x30000))))
805#define MCF5235_CAN_MBUF10_BYTE2(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C012A+((x)*0x30000))))
806#define MCF5235_CAN_MBUF10_BYTE3(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C012B+((x)*0x30000))))
807#define MCF5235_CAN_MBUF10_BYTE4(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C012C+((x)*0x30000))))
808#define MCF5235_CAN_MBUF10_BYTE5(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C012D+((x)*0x30000))))
809#define MCF5235_CAN_MBUF10_BYTE6(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C012E+((x)*0x30000))))
810#define MCF5235_CAN_MBUF10_BYTE7(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C012F+((x)*0x30000))))
811#define MCF5235_CAN_MBUF11_CTRL(x) (*(vuint16 *)(void *)((uintptr_t)__IPSBAR + (0x1C0130+((x)*0x30000))))
812#define MCF5235_CAN_MBUF11_ID(x) (*(vuint32 *)(void *)((uintptr_t)__IPSBAR + (0x1C0134+((x)*0x30000))))
813#define MCF5235_CAN_MBUF11_BYTE0(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C0138+((x)*0x30000))))
814#define MCF5235_CAN_MBUF11_BYTE1(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C0139+((x)*0x30000))))
815#define MCF5235_CAN_MBUF11_BYTE2(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C013A+((x)*0x30000))))
816#define MCF5235_CAN_MBUF11_BYTE3(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C013B+((x)*0x30000))))
817#define MCF5235_CAN_MBUF11_BYTE4(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C013C+((x)*0x30000))))
818#define MCF5235_CAN_MBUF11_BYTE5(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C013D+((x)*0x30000))))
819#define MCF5235_CAN_MBUF11_BYTE6(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C013E+((x)*0x30000))))
820#define MCF5235_CAN_MBUF11_BYTE7(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C013F+((x)*0x30000))))
821#define MCF5235_CAN_MBUF12_CTRL(x) (*(vuint16 *)(void *)((uintptr_t)__IPSBAR + (0x1C0140+((x)*0x30000))))
822#define MCF5235_CAN_MBUF12_ID(x) (*(vuint32 *)(void *)((uintptr_t)__IPSBAR + (0x1C0144+((x)*0x30000))))
823#define MCF5235_CAN_MBUF12_BYTE0(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C0148+((x)*0x30000))))
824#define MCF5235_CAN_MBUF12_BYTE1(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C0149+((x)*0x30000))))
825#define MCF5235_CAN_MBUF12_BYTE2(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C014A+((x)*0x30000))))
826#define MCF5235_CAN_MBUF12_BYTE3(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C014B+((x)*0x30000))))
827#define MCF5235_CAN_MBUF12_BYTE4(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C014C+((x)*0x30000))))
828#define MCF5235_CAN_MBUF12_BYTE5(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C014D+((x)*0x30000))))
829#define MCF5235_CAN_MBUF12_BYTE6(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C014E+((x)*0x30000))))
830#define MCF5235_CAN_MBUF12_BYTE7(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C014F+((x)*0x30000))))
831#define MCF5235_CAN_MBUF13_CTRL(x) (*(vuint16 *)(void *)((uintptr_t)__IPSBAR + (0x1C0150+((x)*0x30000))))
832#define MCF5235_CAN_MBUF13_ID(x) (*(vuint32 *)(void *)((uintptr_t)__IPSBAR + (0x1C0154+((x)*0x30000))))
833#define MCF5235_CAN_MBUF13_BYTE0(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C0158+((x)*0x30000))))
834#define MCF5235_CAN_MBUF13_BYTE1(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C0159+((x)*0x30000))))
835#define MCF5235_CAN_MBUF13_BYTE2(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C015A+((x)*0x30000))))
836#define MCF5235_CAN_MBUF13_BYTE3(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C015B+((x)*0x30000))))
837#define MCF5235_CAN_MBUF13_BYTE4(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C015C+((x)*0x30000))))
838#define MCF5235_CAN_MBUF13_BYTE5(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C015D+((x)*0x30000))))
839#define MCF5235_CAN_MBUF13_BYTE6(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C015E+((x)*0x30000))))
840#define MCF5235_CAN_MBUF13_BYTE7(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C015F+((x)*0x30000))))
841#define MCF5235_CAN_MBUF14_CTRL(x) (*(vuint16 *)(void *)((uintptr_t)__IPSBAR + (0x1C0160+((x)*0x30000))))
842#define MCF5235_CAN_MBUF14_ID(x) (*(vuint32 *)(void *)((uintptr_t)__IPSBAR + (0x1C0164+((x)*0x30000))))
843#define MCF5235_CAN_MBUF14_BYTE0(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C0168+((x)*0x30000))))
844#define MCF5235_CAN_MBUF14_BYTE1(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C0169+((x)*0x30000))))
845#define MCF5235_CAN_MBUF14_BYTE2(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C016A+((x)*0x30000))))
846#define MCF5235_CAN_MBUF14_BYTE3(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C016B+((x)*0x30000))))
847#define MCF5235_CAN_MBUF14_BYTE4(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C016C+((x)*0x30000))))
848#define MCF5235_CAN_MBUF14_BYTE5(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C016D+((x)*0x30000))))
849#define MCF5235_CAN_MBUF14_BYTE6(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C016E+((x)*0x30000))))
850#define MCF5235_CAN_MBUF14_BYTE7(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C016F+((x)*0x30000))))
851#define MCF5235_CAN_MBUF15_CTRL(x) (*(vuint16 *)(void *)((uintptr_t)__IPSBAR + (0x1C0170+((x)*0x30000))))
852#define MCF5235_CAN_MBUF15_ID(x) (*(vuint32 *)(void *)((uintptr_t)__IPSBAR + (0x1C0174+((x)*0x30000))))
853#define MCF5235_CAN_MBUF15_BYTE0(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C0178+((x)*0x30000))))
854#define MCF5235_CAN_MBUF15_BYTE1(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C0179+((x)*0x30000))))
855#define MCF5235_CAN_MBUF15_BYTE2(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C017A+((x)*0x30000))))
856#define MCF5235_CAN_MBUF15_BYTE3(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C017B+((x)*0x30000))))
857#define MCF5235_CAN_MBUF15_BYTE4(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C017C+((x)*0x30000))))
858#define MCF5235_CAN_MBUF15_BYTE5(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C017D+((x)*0x30000))))
859#define MCF5235_CAN_MBUF15_BYTE6(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C017E+((x)*0x30000))))
860#define MCF5235_CAN_MBUF15_BYTE7(x) (*(vuint8 *)(void *)((uintptr_t)__IPSBAR + (0x1C017F+((x)*0x30000))))
861#define MCF5235_CAN_MBUF0_DATAL(x) (*(vuint32 *)(void *)((uintptr_t)__IPSBAR + (0x1C0088+((x)*0x30000))))
862#define MCF5235_CAN_MBUF0_DATAH(x) (*(vuint32 *)(void *)((uintptr_t)__IPSBAR + (0x1C008C+((x)*0x30000))))
863#define MCF5235_CAN_MBUF1_DATAL(x) (*(vuint32 *)(void *)((uintptr_t)__IPSBAR + (0x1C0098+((x)*0x30000))))
864#define MCF5235_CAN_MBUF1_DATAH(x) (*(vuint32 *)(void *)((uintptr_t)__IPSBAR + (0x1C009C+((x)*0x30000))))
865#define MCF5235_CAN_MBUF2_DATAL(x) (*(vuint32 *)(void *)((uintptr_t)__IPSBAR + (0x1C00A8+((x)*0x30000))))
866#define MCF5235_CAN_MBUF2_DATAH(x) (*(vuint32 *)(void *)((uintptr_t)__IPSBAR + (0x1C00AC+((x)*0x30000))))
867
868
869/* Bit definitions and macros for MCF5235_CAN_CANMCR */
870#define MCF5235_CAN_CANMCR_MAXMB(x) (((x)&0x0000000F)<<0)
871#define MCF5235_CAN_CANMCR_SUPV (0x00800000)
872#define MCF5235_CAN_CANMCR_FRZACK (0x01000000)
873#define MCF5235_CAN_CANMCR_SOFTRST (0x02000000)
874#define MCF5235_CAN_CANMCR_HALT (0x10000000)
875#define MCF5235_CAN_CANMCR_FRZ (0x40000000)
876#define MCF5235_CAN_CANMCR_MDIS (0x80000000)
877#define MCF5235_CAN_CANCTRL_PROPSEG(x) (((x)&0x00000007)<<0)
878#define MCF5235_CAN_CANCTRL_LOM (0x00000008)
879#define MCF5235_CAN_CANCTRL_LBUF (0x00000010)
880#define MCF5235_CAN_CANCTRL_TSYNC (0x00000020)
881#define MCF5235_CAN_CANCTRL_BOFFREC (0x00000040)
882#define MCF5235_CAN_CANCTRL_SAMP (0x00000080)
883#define MCF5235_CAN_CANCTRL_LPB (0x00001000)
884#define MCF5235_CAN_CANCTRL_CLKSRC (0x00002000)
885#define MCF5235_CAN_CANCTRL_ERRMSK (0x00004000)
886#define MCF5235_CAN_CANCTRL_BOFFMSK (0x00008000)
887#define MCF5235_CAN_CANCTRL_PSEG2(x) (((x)&0x00000007)<<16)
888#define MCF5235_CAN_CANCTRL_PSEG1(x) (((x)&0x00000007)<<19)
889#define MCF5235_CAN_CANCTRL_RJW(x) (((x)&0x00000003)<<22)
890#define MCF5235_CAN_CANCTRL_PRESDIV(x) (((x)&0x000000FF)<<24)
891#define MCF5235_CAN_TIMER_TIMER(x) (((x)&0x0000FFFF)<<0)
892#define MCF5235_CAN_RXGMASK_MI(x) (((x)&0x1FFFFFFF)<<0)
893#define MCF5235_CAN_RX14MASK_MI(x) (((x)&0x1FFFFFFF)<<0)
894#define MCF5235_CAN_RX15MASK_MI(x) (((x)&0x1FFFFFFF)<<0)
895#define MCF5235_CAN_ERRCNT_TXECTR(x) (((x)&0x000000FF)<<0)
896#define MCF5235_CAN_ERRCNT_RXECTR(x) (((x)&0x000000FF)<<8)
897#define MCF5235_CAN_ERRSTAT_WAKINT (0x00000001)
898#define MCF5235_CAN_ERRSTAT_ERRINT (0x00000002)
899#define MCF5235_CAN_ERRSTAT_BOFFINT (0x00000004)
900#define MCF5235_CAN_ERRSTAT_FLTCONF(x) (((x)&0x00000003)<<4)
901#define MCF5235_CAN_ERRSTAT_TXRX (0x00000040)
902#define MCF5235_CAN_ERRSTAT_IDLE (0x00000080)
903#define MCF5235_CAN_ERRSTAT_RXWRN (0x00000100)
904#define MCF5235_CAN_ERRSTAT_TXWRN (0x00000200)
905#define MCF5235_CAN_ERRSTAT_STFERR (0x00000400)
906#define MCF5235_CAN_ERRSTAT_FRMERR (0x00000800)
907#define MCF5235_CAN_ERRSTAT_CRCERR (0x00001000)
908#define MCF5235_CAN_ERRSTAT_ACKERR (0x00002000)
909#define MCF5235_CAN_ERRSTAT_BITERR(x) (((x)&0x00000003)<<14)
910#define MCF5235_CAN_ERRSTAT_FLTCONF_ACTIVE (0x00000000)
911#define MCF5235_CAN_ERRSTAT_FLTCONF_PASSIVE (0x00000010)
912#define MCF5235_CAN_ERRSTAT_FLTCONF_BUSOFF (0x00000020)
913#define MCF5235_CAN_IMASK_BUF0M (0x0001)
914#define MCF5235_CAN_IMASK_BUF1M (0x0002)
915#define MCF5235_CAN_IMASK_BUF2M (0x0004)
916#define MCF5235_CAN_IMASK_BUF3M (0x0008)
917#define MCF5235_CAN_IMASK_BUF4M (0x0010)
918#define MCF5235_CAN_IMASK_BUF5M (0x0020)
919#define MCF5235_CAN_IMASK_BUF6M (0x0040)
920#define MCF5235_CAN_IMASK_BUF7M (0x0080)
921#define MCF5235_CAN_IMASK_BUF8M (0x0100)
922#define MCF5235_CAN_IMASK_BUF9M (0x0200)
923#define MCF5235_CAN_IMASK_BUF10M (0x0400)
924#define MCF5235_CAN_IMASK_BUF11M (0x0800)
925#define MCF5235_CAN_IMASK_BUF12M (0x1000)
926#define MCF5235_CAN_IMASK_BUF13M (0x2000)
927#define MCF5235_CAN_IMASK_BUF14M (0x4000)
928#define MCF5235_CAN_IMASK_BUF15M (0x8000)
929
930/* Bit definitions and macros for MCF5235_CAN_IFLAG */
931#define MCF5235_CAN_IFLAG_BUF0I (0x0001)
932#define MCF5235_CAN_IFLAG_BUF1I (0x0002)
933#define MCF5235_CAN_IFLAG_BUF2I (0x0004)
934#define MCF5235_CAN_IFLAG_BUF3I (0x0008)
935#define MCF5235_CAN_IFLAG_BUF4I (0x0010)
936#define MCF5235_CAN_IFLAG_BUF5I (0x0020)
937#define MCF5235_CAN_IFLAG_BUF6I (0x0040)
938#define MCF5235_CAN_IFLAG_BUF7I (0x0080)
939#define MCF5235_CAN_IFLAG_BUF8I (0x0100)
940#define MCF5235_CAN_IFLAG_BUF9I (0x0200)
941#define MCF5235_CAN_IFLAG_BUF10I (0x0400)
942#define MCF5235_CAN_IFLAG_BUF11I (0x0800)
943#define MCF5235_CAN_IFLAG_BUF12I (0x1000)
944#define MCF5235_CAN_IFLAG_BUF13I (0x2000)
945#define MCF5235_CAN_IFLAG_BUF14I (0x4000)
946#define MCF5235_CAN_IFLAG_BUF15I (0x8000)
947
948
949/*********************************************************************
950*
951* Chip Configuration Module (CCM)
952*
953*********************************************************************/
954
955/* Register read/write macros */
956#define MCF5235_CCM_CCR (*(vuint16*)((uintptr_t)__IPSBAR + (0x110004)))
957#define MCF5235_CCM_LPCR (*(vuint8 *)((uintptr_t)__IPSBAR + (0x110007)))
958#define MCF5235_CCM_CIR (*(vuint16*)((uintptr_t)__IPSBAR + (0x11000A)))
959#define MCF5235_CCM_RCON (*(vuint16*)((uintptr_t)__IPSBAR + (0x110008)))
960
961/* Bit definitions and macros for MCF5235_CCM_CCR */
962#define MCF5235_CCM_CCR_BMT(x) (((x)&0x0007)<<0)
963#define MCF5235_CCM_CCR_BME (0x0008)
964#define MCF5235_CCM_CCR_SZEN (0x0040)
965#define MCF5235_CCM_CCR_MODE(x) (((x)&0x0007)<<8)
966#define MCF5235_CCM_LPCR_STPMD(x) (((x)&0x03)<<3)
967#define MCF5235_CCM_LPCR_LPMD(x) (((x)&0x03)<<6)
968#define MCF5235_CCM_LPCR_LPMD_STOP (0xC0)
969#define MCF5235_CCM_LPCR_LPMD_WAIT (0x80)
970#define MCF5235_CCM_LPCR_LPMD_DOZE (0x40)
971#define MCF5235_CCM_LPCR_LPMD_RUN (0x00)
972#define MCF5235_CCM_CIR_PRN(x) (((x)&0x003F)<<0)
973#define MCF5235_CCM_CIR_PIN(x) (((x)&0x03FF)<<6)
974#define MCF5235_CCM_RCON_MODE (0x0001)
975#define MCF5235_CCM_RCON_BOOTPS(x) (((x)&0x0003)<<3)
976#define MCF5235_CCM_RCON_RLOAD (0x0020)
977#define MCF5235_CCM_RCON_RCSC(x) (((x)&0x0003)<<8)
978
979/*********************************************************************
980*
981* Chip Selects (CS)
982*
983*********************************************************************/
984
985/* Register read/write macros */
986#define MCF5235_CS_CSAR0 (*(vuint16*)((uintptr_t)__IPSBAR + (0x000080)))
987#define MCF5235_CS_CSMR0 (*(vuint32*)((uintptr_t)__IPSBAR + (0x000084)))
988#define MCF5235_CS_CSCR0 (*(vuint16*)((uintptr_t)__IPSBAR + (0x00008A)))
989#define MCF5235_CS_CSAR1 (*(vuint16*)((uintptr_t)__IPSBAR + (0x00008C)))
990#define MCF5235_CS_CSMR1 (*(vuint32*)((uintptr_t)__IPSBAR + (0x000090)))
991#define MCF5235_CS_CSCR1 (*(vuint16*)((uintptr_t)__IPSBAR + (0x000096)))
992#define MCF5235_CS_CSAR2 (*(vuint16*)((uintptr_t)__IPSBAR + (0x000098)))
993#define MCF5235_CS_CSMR2 (*(vuint32*)((uintptr_t)__IPSBAR + (0x00009C)))
994#define MCF5235_CS_CSCR2 (*(vuint16*)((uintptr_t)__IPSBAR + (0x0000A2)))
995#define MCF5235_CS_CSAR3 (*(vuint16*)((uintptr_t)__IPSBAR + (0x0000A4)))
996#define MCF5235_CS_CSMR3 (*(vuint32*)((uintptr_t)__IPSBAR + (0x0000A8)))
997#define MCF5235_CS_CSCR3 (*(vuint16*)((uintptr_t)__IPSBAR + (0x0000AE)))
998#define MCF5235_CS_CSAR4 (*(vuint16*)((uintptr_t)__IPSBAR + (0x0000B0)))
999#define MCF5235_CS_CSMR4 (*(vuint32*)((uintptr_t)__IPSBAR + (0x0000B4)))
1000#define MCF5235_CS_CSCR4 (*(vuint16*)((uintptr_t)__IPSBAR + (0x0000BA)))
1001#define MCF5235_CS_CSAR5 (*(vuint16*)((uintptr_t)__IPSBAR + (0x0000BC)))
1002#define MCF5235_CS_CSMR5 (*(vuint32*)((uintptr_t)__IPSBAR + (0x0000C0)))
1003#define MCF5235_CS_CSCR5 (*(vuint16*)((uintptr_t)__IPSBAR + (0x0000C6)))
1004#define MCF5235_CS_CSAR6 (*(vuint16*)((uintptr_t)__IPSBAR + (0x0000C8)))
1005#define MCF5235_CS_CSMR6 (*(vuint32*)((uintptr_t)__IPSBAR + (0x0000CC)))
1006#define MCF5235_CS_CSCR6 (*(vuint16*)((uintptr_t)__IPSBAR + (0x0000D2)))
1007#define MCF5235_CS_CSAR7 (*(vuint16*)((uintptr_t)__IPSBAR + (0x0000D4)))
1008#define MCF5235_CS_CSMR7 (*(vuint32*)((uintptr_t)__IPSBAR + (0x0000D8)))
1009#define MCF5235_CS_CSCR7 (*(vuint16*)((uintptr_t)__IPSBAR + (0x0000DE)))
1010#define MCF5235_CS_CSAR(x) (*(vuint16*)((uintptr_t)__IPSBAR + (0x000080+((x)*0x00C))))
1011#define MCF5235_CS_CSMR(x) (*(vuint32*)((uintptr_t)__IPSBAR + (0x000084+((x)*0x00C))))
1012#define MCF5235_CS_CSCR(x) (*(vuint16*)((uintptr_t)__IPSBAR + (0x00008A+((x)*0x00C))))
1013
1014/* Bit definitions and macros for MCF5235_CS_CSAR */
1015#define MCF5235_CS_CSAR_BA(x) ((uint16)(((x)&0xFFFF0000)>>16))
1016#define MCF5235_CS_CSMR_V (0x00000001)
1017#define MCF5235_CS_CSMR_UD (0x00000002)
1018#define MCF5235_CS_CSMR_UC (0x00000004)
1019#define MCF5235_CS_CSMR_SD (0x00000008)
1020#define MCF5235_CS_CSMR_SC (0x00000010)
1021#define MCF5235_CS_CSMR_CI (0x00000020)
1022#define MCF5235_CS_CSMR_AM (0x00000040)
1023#define MCF5235_CS_CSMR_WP (0x00000100)
1024#define MCF5235_CS_CSMR_BAM(x) (((x)&0x0000FFFF)<<16)
1025#define MCF5235_CS_CSMR_BAM_4G (0xFFFF0000)
1026#define MCF5235_CS_CSMR_BAM_2G (0x7FFF0000)
1027#define MCF5235_CS_CSMR_BAM_1G (0x3FFF0000)
1028#define MCF5235_CS_CSMR_BAM_1024M (0x3FFF0000)
1029#define MCF5235_CS_CSMR_BAM_512M (0x1FFF0000)
1030#define MCF5235_CS_CSMR_BAM_256M (0x0FFF0000)
1031#define MCF5235_CS_CSMR_BAM_128M (0x07FF0000)
1032#define MCF5235_CS_CSMR_BAM_64M (0x03FF0000)
1033#define MCF5235_CS_CSMR_BAM_32M (0x01FF0000)
1034#define MCF5235_CS_CSMR_BAM_16M (0x00FF0000)
1035#define MCF5235_CS_CSMR_BAM_8M (0x007F0000)
1036#define MCF5235_CS_CSMR_BAM_4M (0x003F0000)
1037#define MCF5235_CS_CSMR_BAM_2M (0x001F0000)
1038#define MCF5235_CS_CSMR_BAM_1M (0x000F0000)
1039#define MCF5235_CS_CSMR_BAM_1024K (0x000F0000)
1040#define MCF5235_CS_CSMR_BAM_512K (0x00070000)
1041#define MCF5235_CS_CSMR_BAM_256K (0x00030000)
1042#define MCF5235_CS_CSMR_BAM_128K (0x00010000)
1043#define MCF5235_CS_CSMR_BAM_64K (0x00000000)
1044#define MCF5235_CS_CSCR_SWWS(x) (((x)&0x0007)<<0)
1045#define MCF5235_CS_CSCR_BSTW (0x0008)
1046#define MCF5235_CS_CSCR_BSTR (0x0010)
1047#define MCF5235_CS_CSCR_BEM (0x0020)
1048#define MCF5235_CS_CSCR_PS(x) (((x)&0x0003)<<6)
1049#define MCF5235_CS_CSCR_AA (0x0100)
1050#define MCF5235_CS_CSCR_IWS(x) (((x)&0x000F)<<10)
1051#define MCF5235_CS_CSCR_SRWS(x) (((x)&0x0003)<<14)
1052#define MCF5235_CS_CSCR_PS_8 (0x0040)
1053#define MCF5235_CS_CSCR_PS_16 (0x0080)
1054#define MCF5235_CS_CSCR_PS_32 (0x0000)
1055
1056/*********************************************************************
1057*
1058* Edge Port Module (EPORT)
1059*
1060*********************************************************************/
1061
1062/* Register read/write macros */
1063#define MCF5235_EPORT_EPPAR (*(vuint16*)((uintptr_t)__IPSBAR + (0x130000)))
1064#define MCF5235_EPORT_EPDDR (*(vuint8 *)((uintptr_t)__IPSBAR + (0x130002)))
1065#define MCF5235_EPORT_EPIER (*(vuint8 *)((uintptr_t)__IPSBAR + (0x130003)))
1066#define MCF5235_EPORT_EPDR (*(vuint8 *)((uintptr_t)__IPSBAR + (0x130004)))
1067#define MCF5235_EPORT_EPPDR (*(vuint8 *)((uintptr_t)__IPSBAR + (0x130005)))
1068#define MCF5235_EPORT_EPFR (*(vuint8 *)((uintptr_t)__IPSBAR + (0x130006)))
1069
1070/* Bit definitions and macros for MCF5235_EPORT_EPPAR */
1071#define MCF5235_EPORT_EPPAR_EPPA1(x) (((x)&0x0003)<<2)
1072#define MCF5235_EPORT_EPPAR_EPPA2(x) (((x)&0x0003)<<4)
1073#define MCF5235_EPORT_EPPAR_EPPA3(x) (((x)&0x0003)<<6)
1074#define MCF5235_EPORT_EPPAR_EPPA4(x) (((x)&0x0003)<<8)
1075#define MCF5235_EPORT_EPPAR_EPPA5(x) (((x)&0x0003)<<10)
1076#define MCF5235_EPORT_EPPAR_EPPA6(x) (((x)&0x0003)<<12)
1077#define MCF5235_EPORT_EPPAR_EPPA7(x) (((x)&0x0003)<<14)
1078#define MCF5235_EPORT_EPPAR_EPPAx_LEVEL (0)
1079#define MCF5235_EPORT_EPPAR_EPPAx_RISING (1)
1080#define MCF5235_EPORT_EPPAR_EPPAx_FALLING (2)
1081#define MCF5235_EPORT_EPPAR_EPPAx_BOTH (3)
1082#define MCF5235_EPORT_EPDDR_EPDD1 (0x02)
1083#define MCF5235_EPORT_EPDDR_EPDD2 (0x04)
1084#define MCF5235_EPORT_EPDDR_EPDD3 (0x08)
1085#define MCF5235_EPORT_EPDDR_EPDD4 (0x10)
1086#define MCF5235_EPORT_EPDDR_EPDD5 (0x20)
1087#define MCF5235_EPORT_EPDDR_EPDD6 (0x40)
1088#define MCF5235_EPORT_EPDDR_EPDD7 (0x80)
1089#define MCF5235_EPORT_EPIER_EPIE1 (0x02)
1090#define MCF5235_EPORT_EPIER_EPIE2 (0x04)
1091#define MCF5235_EPORT_EPIER_EPIE3 (0x08)
1092#define MCF5235_EPORT_EPIER_EPIE4 (0x10)
1093#define MCF5235_EPORT_EPIER_EPIE5 (0x20)
1094#define MCF5235_EPORT_EPIER_EPIE6 (0x40)
1095#define MCF5235_EPORT_EPIER_EPIE7 (0x80)
1096#define MCF5235_EPORT_EPDR_EPD1 (0x02)
1097#define MCF5235_EPORT_EPDR_EPD2 (0x04)
1098#define MCF5235_EPORT_EPDR_EPD3 (0x08)
1099#define MCF5235_EPORT_EPDR_EPD4 (0x10)
1100#define MCF5235_EPORT_EPDR_EPD5 (0x20)
1101#define MCF5235_EPORT_EPDR_EPD6 (0x40)
1102#define MCF5235_EPORT_EPDR_EPD7 (0x80)
1103#define MCF5235_EPORT_EPPDR_EPPD1 (0x02)
1104#define MCF5235_EPORT_EPPDR_EPPD2 (0x04)
1105#define MCF5235_EPORT_EPPDR_EPPD3 (0x08)
1106#define MCF5235_EPORT_EPPDR_EPPD4 (0x10)
1107#define MCF5235_EPORT_EPPDR_EPPD5 (0x20)
1108#define MCF5235_EPORT_EPPDR_EPPD6 (0x40)
1109#define MCF5235_EPORT_EPPDR_EPPD7 (0x80)
1110#define MCF5235_EPORT_EPFR_EPF1 (0x02)
1111#define MCF5235_EPORT_EPFR_EPF2 (0x04)
1112#define MCF5235_EPORT_EPFR_EPF3 (0x08)
1113#define MCF5235_EPORT_EPFR_EPF4 (0x10)
1114#define MCF5235_EPORT_EPFR_EPF5 (0x20)
1115#define MCF5235_EPORT_EPFR_EPF6 (0x40)
1116#define MCF5235_EPORT_EPFR_EPF7 (0x80)
1117
1118
1119/*********************************************************************
1120*
1121* enhanced Time Processor Unit (ETPU)
1122*
1123*********************************************************************/
1124
1125/* Register read/write macros */
1126#define MCF5235_ETPU_EMCR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0000)))
1127#define MCF5235_ETPU_ECDCR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0004)))
1128#define MCF5235_ETPU_EMISCCR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D000C)))
1129#define MCF5235_ETPU_ESCMODR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0010)))
1130#define MCF5235_ETPU_EECR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0014)))
1131#define MCF5235_ETPU_ETBCR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0020)))
1132#define MCF5235_ETPU_ETB1R (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0024)))
1133#define MCF5235_ETPU_ETB2R (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0028)))
1134#define MCF5235_ETPU_EREDCR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D002C)))
1135#define MCF5235_ETPU_ECISR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0200)))
1136#define MCF5235_ETPU_ECDTRSR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0210)))
1137#define MCF5235_ETPU_ECIOSR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0220)))
1138#define MCF5235_ETPU_ECDTROSR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0230)))
1139#define MCF5235_ETPU_ECIER (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0240)))
1140#define MCF5235_ETPU_ECDTRER (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0250)))
1141#define MCF5235_ETPU_ECPSSR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0280)))
1142#define MCF5235_ETPU_ECSSR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0290)))
1143#define MCF5235_ETPU_EC0SCR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0404)))
1144#define MCF5235_ETPU_EC1SCR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0414)))
1145#define MCF5235_ETPU_EC2SCR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0424)))
1146#define MCF5235_ETPU_EC3SCR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0434)))
1147#define MCF5235_ETPU_EC4SCR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0444)))
1148#define MCF5235_ETPU_EC5SCR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0454)))
1149#define MCF5235_ETPU_EC6SCR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0464)))
1150#define MCF5235_ETPU_EC7SCR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0474)))
1151#define MCF5235_ETPU_EC8SCR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0484)))
1152#define MCF5235_ETPU_EC9SCR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0494)))
1153#define MCF5235_ETPU_EC10SCR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D04A4)))
1154#define MCF5235_ETPU_EC11SCR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D04B4)))
1155#define MCF5235_ETPU_EC12SCR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D04C4)))
1156#define MCF5235_ETPU_EC13SCR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D04D4)))
1157#define MCF5235_ETPU_EC14SCR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D04E4)))
1158#define MCF5235_ETPU_EC15SCR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D04F4)))
1159#define MCF5235_ETPU_EC16SCR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0504)))
1160#define MCF5235_ETPU_EC17SCR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0514)))
1161#define MCF5235_ETPU_EC18SCR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0524)))
1162#define MCF5235_ETPU_EC19SCR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0534)))
1163#define MCF5235_ETPU_EC20SCR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0544)))
1164#define MCF5235_ETPU_EC21SCR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0554)))
1165#define MCF5235_ETPU_EC22SCR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0564)))
1166#define MCF5235_ETPU_EC23SCR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0574)))
1167#define MCF5235_ETPU_EC24SCR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0584)))
1168#define MCF5235_ETPU_EC25SCR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0594)))
1169#define MCF5235_ETPU_EC26SCR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D05A4)))
1170#define MCF5235_ETPU_EC27SCR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D05B4)))
1171#define MCF5235_ETPU_EC28SCR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D05C4)))
1172#define MCF5235_ETPU_EC29SCR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D05D4)))
1173#define MCF5235_ETPU_EC30SCR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D05E4)))
1174#define MCF5235_ETPU_EC31SCR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D05F4)))
1175#define MCF5235_ETPU_ECnSCR(x) (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0404+((x)*0x010))))
1176#define MCF5235_ETPU_EC0CR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0400)))
1177#define MCF5235_ETPU_EC1CR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0410)))
1178#define MCF5235_ETPU_EC2CR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0420)))
1179#define MCF5235_ETPU_EC3CR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0430)))
1180#define MCF5235_ETPU_EC4CR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0440)))
1181#define MCF5235_ETPU_EC5CR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0450)))
1182#define MCF5235_ETPU_EC6CR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0460)))
1183#define MCF5235_ETPU_EC7CR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0470)))
1184#define MCF5235_ETPU_EC8CR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0480)))
1185#define MCF5235_ETPU_EC9CR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0490)))
1186#define MCF5235_ETPU_EC10CR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D04A0)))
1187#define MCF5235_ETPU_EC11CR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D04B0)))
1188#define MCF5235_ETPU_EC12CR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D04C0)))
1189#define MCF5235_ETPU_EC13CR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D04D0)))
1190#define MCF5235_ETPU_EC14CR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D04E0)))
1191#define MCF5235_ETPU_EC15CR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D04F0)))
1192#define MCF5235_ETPU_EC16CR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0500)))
1193#define MCF5235_ETPU_EC17CR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0510)))
1194#define MCF5235_ETPU_EC18CR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0520)))
1195#define MCF5235_ETPU_EC19CR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0530)))
1196#define MCF5235_ETPU_EC20CR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0540)))
1197#define MCF5235_ETPU_EC21CR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0550)))
1198#define MCF5235_ETPU_EC22CR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0560)))
1199#define MCF5235_ETPU_EC23CR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0570)))
1200#define MCF5235_ETPU_EC24CR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0580)))
1201#define MCF5235_ETPU_EC25CR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0590)))
1202#define MCF5235_ETPU_EC26CR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D05A0)))
1203#define MCF5235_ETPU_EC27CR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D05B0)))
1204#define MCF5235_ETPU_EC28CR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D05C0)))
1205#define MCF5235_ETPU_EC29CR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D05D0)))
1206#define MCF5235_ETPU_EC30CR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D05E0)))
1207#define MCF5235_ETPU_EC31CR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D05F0)))
1208#define MCF5235_ETPU_ECnCR(x) (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0400+((x)*0x010))))
1209#define MCF5235_ETPU_EC0HSSR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0408)))
1210#define MCF5235_ETPU_EC1HSSR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0418)))
1211#define MCF5235_ETPU_EC2HSSR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0428)))
1212#define MCF5235_ETPU_EC3HSSR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0438)))
1213#define MCF5235_ETPU_EC4HSSR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0448)))
1214#define MCF5235_ETPU_EC5HSSR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0458)))
1215#define MCF5235_ETPU_EC6HSSR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0468)))
1216#define MCF5235_ETPU_EC7HSSR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0478)))
1217#define MCF5235_ETPU_EC8HSSR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0488)))
1218#define MCF5235_ETPU_EC9HSSR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0498)))
1219#define MCF5235_ETPU_EC10HSSR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D04A8)))
1220#define MCF5235_ETPU_EC11HSSR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D04B8)))
1221#define MCF5235_ETPU_EC12HSSR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D04C8)))
1222#define MCF5235_ETPU_EC13HSSR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D04D8)))
1223#define MCF5235_ETPU_EC14HSSR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D04E8)))
1224#define MCF5235_ETPU_EC15HSSR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D04F8)))
1225#define MCF5235_ETPU_EC16HSSR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0508)))
1226#define MCF5235_ETPU_EC17HSSR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0518)))
1227#define MCF5235_ETPU_EC18HSSR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0528)))
1228#define MCF5235_ETPU_EC19HSSR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0538)))
1229#define MCF5235_ETPU_EC20HSSR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0548)))
1230#define MCF5235_ETPU_EC21HSSR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0558)))
1231#define MCF5235_ETPU_EC22HSSR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0568)))
1232#define MCF5235_ETPU_EC23HSSR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0578)))
1233#define MCF5235_ETPU_EC24HSSR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0588)))
1234#define MCF5235_ETPU_EC25HSSR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0598)))
1235#define MCF5235_ETPU_EC26HSSR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D05A8)))
1236#define MCF5235_ETPU_EC27HSSR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D05B8)))
1237#define MCF5235_ETPU_EC28HSSR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D05C8)))
1238#define MCF5235_ETPU_EC29HSSR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D05D8)))
1239#define MCF5235_ETPU_EC30HSSR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D05E8)))
1240#define MCF5235_ETPU_EC31HSSR (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D05F8)))
1241#define MCF5235_ETPU_ECnHSSR(x) (*(vuint32*)((uintptr_t)__IPSBAR + (0x1D0408+((x)*0x010))))
1242
1243/* Bit definitions and macros for MCF5235_ETPU_EMCR */
1244#define MCF5235_ETPU_EMCR_GTBE (0x00000001)
1245#define MCF5235_ETPU_EMCR_VIS (0x00000040)
1246#define MCF5235_ETPU_EMCR_SCMMISEN (0x00000200)
1247#define MCF5235_ETPU_EMCR_SCMMISF (0x00000400)
1248#define MCF5235_ETPU_EMCR_SCMSIZE(x) (((x)&0x0000001F)<<16)
1249#define MCF5235_ETPU_EMCR_ILF2 (0x01000000)
1250#define MCF5235_ETPU_EMCR_ILF1 (0x02000000)
1251#define MCF5235_ETPU_EMCR_MGE2 (0x04000000)
1252#define MCF5235_ETPU_EMCR_MGE1 (0x08000000)
1253#define MCF5235_ETPU_EMCR_GEC (0x80000000)
1254#define MCF5235_ETPU_ECDCR_PARM1(x) (((x)&0x0000007F)<<0)
1255#define MCF5235_ETPU_ECDCR_WR (0x00000080)
1256#define MCF5235_ETPU_ECDCR_PARM0(x) (((x)&0x0000007F)<<8)
1257#define MCF5235_ETPU_ECDCR_PWIDTH (0x00008000)
1258#define MCF5235_ETPU_ECDCR_PBASE(x) (((x)&0x000003FF)<<16)
1259#define MCF5235_ETPU_ECDCR_CTBASE(x) (((x)&0x0000001F)<<26)
1260#define MCF5235_ETPU_ECDCR_STS (0x80000000)
1261#define MCF5235_ETPU_EECR_ETB(x) (((x)&0x0000001F)<<0)
1262#define MCF5235_ETPU_EECR_CDFC(x) (((x)&0x00000003)<<14)
1263#define MCF5235_ETPU_EECR_FPSK(x) (((x)&0x00000007)<<16)
1264#define MCF5235_ETPU_EECR_HLTF (0x00800000)
1265#define MCF5235_ETPU_EECR_STF (0x10000000)
1266#define MCF5235_ETPU_EECR_MDIS (0x40000000)
1267#define MCF5235_ETPU_EECR_FEND (0x80000000)
1268#define MCF5235_ETPU_ETBCR_TCR1P(x) (((x)&0x000000FF)<<0)
1269#define MCF5235_ETPU_ETBCR_TCR1CTL(x) (((x)&0x00000003)<<14)
1270#define MCF5235_ETPU_ETBCR_TCR2P(x) (((x)&0x0000003F)<<16)
1271#define MCF5235_ETPU_ETBCR_AM (0x02000000)
1272#define MCF5235_ETPU_ETBCR_TCRCF(x) (((x)&0x00000003)<<27)
1273#define MCF5235_ETPU_ETBCR_TCR2CTL(x) (((x)&0x00000007)<<29)
1274#define MCF5235_ETPU_ETB1R_TCR1(x) (((x)&0x00FFFFFF)<<0)
1275#define MCF5235_ETPU_ETB2R_TCR2(x) (((x)&0x00FFFFFF)<<0)
1276#define MCF5235_ETPU_EREDCR_SRV2(x) (((x)&0x0000000F)<<0)
1277#define MCF5235_ETPU_EREDCR_SERVER_ID2(x) (((x)&0x0000000F)<<8)
1278#define MCF5235_ETPU_EREDCR_RSC2 (0x00004000)
1279#define MCF5235_ETPU_EREDCR_REN2 (0x00008000)
1280#define MCF5235_ETPU_EREDCR_SRV1(x) (((x)&0x0000000F)<<16)
1281#define MCF5235_ETPU_EREDCR_SERVER_ID1(x) (((x)&0x0000000F)<<24)
1282#define MCF5235_ETPU_EREDCR_RSC1 (0x40000000)
1283#define MCF5235_ETPU_EREDCR_REN1 (0x80000000)
1284#define MCF5235_ETPU_ECISR_CIS0 (0x00000001)
1285#define MCF5235_ETPU_ECISR_CIS1 (0x00000002)
1286#define MCF5235_ETPU_ECISR_CIS2 (0x00000004)
1287#define MCF5235_ETPU_ECISR_CIS3 (0x00000008)
1288#define MCF5235_ETPU_ECISR_CIS4 (0x00000010)
1289#define MCF5235_ETPU_ECISR_CIS5 (0x00000020)
1290#define MCF5235_ETPU_ECISR_CIS6 (0x00000040)
1291#define MCF5235_ETPU_ECISR_CIS7 (0x00000080)
1292#define MCF5235_ETPU_ECISR_CIS8 (0x00000100)
1293#define MCF5235_ETPU_ECISR_CIS9 (0x00000200)
1294#define MCF5235_ETPU_ECISR_CIS10 (0x00000400)
1295#define MCF5235_ETPU_ECISR_CIS11 (0x00000800)
1296#define MCF5235_ETPU_ECISR_CIS12 (0x00001000)
1297#define MCF5235_ETPU_ECISR_CIS13 (0x00002000)
1298#define MCF5235_ETPU_ECISR_CIS14 (0x00004000)
1299#define MCF5235_ETPU_ECISR_CIS15 (0x00008000)
1300#define MCF5235_ETPU_ECISR_CIS16 (0x00010000)
1301#define MCF5235_ETPU_ECISR_CIS17 (0x00020000)
1302#define MCF5235_ETPU_ECISR_CIS18 (0x00040000)
1303#define MCF5235_ETPU_ECISR_CIS19 (0x00080000)
1304#define MCF5235_ETPU_ECISR_CIS20 (0x00100000)
1305#define MCF5235_ETPU_ECISR_CIS21 (0x00200000)
1306#define MCF5235_ETPU_ECISR_CIS22 (0x00400000)
1307#define MCF5235_ETPU_ECISR_CIS23 (0x00800000)
1308#define MCF5235_ETPU_ECISR_CIS24 (0x01000000)
1309#define MCF5235_ETPU_ECISR_CIS25 (0x02000000)
1310#define MCF5235_ETPU_ECISR_CIS26 (0x04000000)
1311#define MCF5235_ETPU_ECISR_CIS27 (0x08000000)
1312#define MCF5235_ETPU_ECISR_CIS28 (0x10000000)
1313#define MCF5235_ETPU_ECISR_CIS29 (0x20000000)
1314#define MCF5235_ETPU_ECISR_CIS30 (0x40000000)
1315#define MCF5235_ETPU_ECISR_CIS31 (0x80000000)
1316#define MCF5235_ETPU_ECDTRSR_DTRS0 (0x00000001)
1317#define MCF5235_ETPU_ECDTRSR_DTRS1 (0x00000002)
1318#define MCF5235_ETPU_ECDTRSR_DTRS2 (0x00000004)
1319#define MCF5235_ETPU_ECDTRSR_DTRS3 (0x00000008)
1320#define MCF5235_ETPU_ECDTRSR_DTRS4 (0x00000010)
1321#define MCF5235_ETPU_ECDTRSR_DTRS5 (0x00000020)
1322#define MCF5235_ETPU_ECDTRSR_DTRS6 (0x00000040)
1323#define MCF5235_ETPU_ECDTRSR_DTRS7 (0x00000080)
1324#define MCF5235_ETPU_ECDTRSR_DTRS8 (0x00000100)
1325#define MCF5235_ETPU_ECDTRSR_DTRS9 (0x00000200)
1326#define MCF5235_ETPU_ECDTRSR_DTRS10 (0x00000400)
1327#define MCF5235_ETPU_ECDTRSR_DTRS11 (0x00000800)
1328#define MCF5235_ETPU_ECDTRSR_DTRS12 (0x00001000)
1329#define MCF5235_ETPU_ECDTRSR_DTRS13 (0x00002000)
1330#define MCF5235_ETPU_ECDTRSR_DTRS14 (0x00004000)
1331#define MCF5235_ETPU_ECDTRSR_DTRS15 (0x00008000)
1332#define MCF5235_ETPU_ECDTRSR_DTRS16 (0x00010000)
1333#define MCF5235_ETPU_ECDTRSR_DTRS17 (0x00020000)
1334#define MCF5235_ETPU_ECDTRSR_DTRS18 (0x00040000)
1335#define MCF5235_ETPU_ECDTRSR_DTRS19 (0x00080000)
1336#define MCF5235_ETPU_ECDTRSR_DTRS20 (0x00100000)
1337#define MCF5235_ETPU_ECDTRSR_DTRS21 (0x00200000)
1338#define MCF5235_ETPU_ECDTRSR_DTRS22 (0x00400000)
1339#define MCF5235_ETPU_ECDTRSR_DTRS23 (0x00800000)
1340#define MCF5235_ETPU_ECDTRSR_DTRS24 (0x01000000)
1341#define MCF5235_ETPU_ECDTRSR_DTRS25 (0x02000000)
1342#define MCF5235_ETPU_ECDTRSR_DTRS26 (0x04000000)
1343#define MCF5235_ETPU_ECDTRSR_DTRS27 (0x08000000)
1344#define MCF5235_ETPU_ECDTRSR_DTRS28 (0x10000000)
1345#define MCF5235_ETPU_ECDTRSR_DTRS29 (0x20000000)
1346#define MCF5235_ETPU_ECDTRSR_DTRS30 (0x40000000)
1347#define MCF5235_ETPU_ECDTRSR_DTRS31 (0x80000000)
1348#define MCF5235_ETPU_ECIOSR_CIOS0 (0x00000001)
1349#define MCF5235_ETPU_ECIOSR_CIOS1 (0x00000002)
1350#define MCF5235_ETPU_ECIOSR_CIOS2 (0x00000004)
1351#define MCF5235_ETPU_ECIOSR_CIOS3 (0x00000008)
1352#define MCF5235_ETPU_ECIOSR_CIOS4 (0x00000010)
1353#define MCF5235_ETPU_ECIOSR_CIOS5 (0x00000020)
1354#define MCF5235_ETPU_ECIOSR_CIOS6 (0x00000040)
1355#define MCF5235_ETPU_ECIOSR_CIOS7 (0x00000080)
1356#define MCF5235_ETPU_ECIOSR_CIOS8 (0x00000100)
1357#define MCF5235_ETPU_ECIOSR_CIOS9 (0x00000200)
1358#define MCF5235_ETPU_ECIOSR_CIOS10 (0x00000400)
1359#define MCF5235_ETPU_ECIOSR_CIOS11 (0x00000800)
1360#define MCF5235_ETPU_ECIOSR_CIOS12 (0x00001000)
1361#define MCF5235_ETPU_ECIOSR_CIOS13 (0x00002000)
1362#define MCF5235_ETPU_ECIOSR_CIOS14 (0x00004000)
1363#define MCF5235_ETPU_ECIOSR_CIOS15 (0x00008000)
1364#define MCF5235_ETPU_ECIOSR_CIOS16 (0x00010000)
1365#define MCF5235_ETPU_ECIOSR_CIOS17 (0x00020000)
1366#define MCF5235_ETPU_ECIOSR_CIOS18 (0x00040000)
1367#define MCF5235_ETPU_ECIOSR_CIOS19 (0x00080000)
1368#define MCF5235_ETPU_ECIOSR_CIOS20 (0x00100000)
1369#define MCF5235_ETPU_ECIOSR_CIOS21 (0x00200000)
1370#define MCF5235_ETPU_ECIOSR_CIOS22 (0x00400000)
1371#define MCF5235_ETPU_ECIOSR_CIOS23 (0x00800000)
1372#define MCF5235_ETPU_ECIOSR_CIOS24 (0x01000000)
1373#define MCF5235_ETPU_ECIOSR_CIOS25 (0x02000000)
1374#define MCF5235_ETPU_ECIOSR_CIOS26 (0x04000000)
1375#define MCF5235_ETPU_ECIOSR_CIOS27 (0x08000000)
1376#define MCF5235_ETPU_ECIOSR_CIOS28 (0x10000000)
1377#define MCF5235_ETPU_ECIOSR_CIOS29 (0x20000000)
1378#define MCF5235_ETPU_ECIOSR_CIOS30 (0x40000000)
1379#define MCF5235_ETPU_ECIOSR_CIOS31 (0x80000000)
1380#define MCF5235_ETPU_ECDTROSR_DTROS0 (0x00000001)
1381#define MCF5235_ETPU_ECDTROSR_DTROS1 (0x00000002)
1382#define MCF5235_ETPU_ECDTROSR_DTROS2 (0x00000004)
1383#define MCF5235_ETPU_ECDTROSR_DTROS3 (0x00000008)
1384#define MCF5235_ETPU_ECDTROSR_DTROS4 (0x00000010)
1385#define MCF5235_ETPU_ECDTROSR_DTROS5 (0x00000020)
1386#define MCF5235_ETPU_ECDTROSR_DTROS6 (0x00000040)
1387#define MCF5235_ETPU_ECDTROSR_DTROS7 (0x00000080)
1388#define MCF5235_ETPU_ECDTROSR_DTROS8 (0x00000100)
1389#define MCF5235_ETPU_ECDTROSR_DTROS9 (0x00000200)
1390#define MCF5235_ETPU_ECDTROSR_DTROS10 (0x00000400)
1391#define MCF5235_ETPU_ECDTROSR_DTROS11 (0x00000800)
1392#define MCF5235_ETPU_ECDTROSR_DTROS12 (0x00001000)
1393#define MCF5235_ETPU_ECDTROSR_DTROS13 (0x00002000)
1394#define MCF5235_ETPU_ECDTROSR_DTROS14 (0x00004000)
1395#define MCF5235_ETPU_ECDTROSR_DTROS15 (0x00008000)
1396#define MCF5235_ETPU_ECDTROSR_DTROS16 (0x00010000)
1397#define MCF5235_ETPU_ECDTROSR_DTROS17 (0x00020000)
1398#define MCF5235_ETPU_ECDTROSR_DTROS18 (0x00040000)
1399#define MCF5235_ETPU_ECDTROSR_DTROS19 (0x00080000)
1400#define MCF5235_ETPU_ECDTROSR_DTROS20 (0x00100000)
1401#define MCF5235_ETPU_ECDTROSR_DTROS21 (0x00200000)
1402#define MCF5235_ETPU_ECDTROSR_DTROS22 (0x00400000)
1403#define MCF5235_ETPU_ECDTROSR_DTROS23 (0x00800000)
1404#define MCF5235_ETPU_ECDTROSR_DTROS24 (0x01000000)
1405#define MCF5235_ETPU_ECDTROSR_DTROS25 (0x02000000)
1406#define MCF5235_ETPU_ECDTROSR_DTROS26 (0x04000000)
1407#define MCF5235_ETPU_ECDTROSR_DTROS27 (0x08000000)
1408#define MCF5235_ETPU_ECDTROSR_DTROS28 (0x10000000)
1409#define MCF5235_ETPU_ECDTROSR_DTROS29 (0x20000000)
1410#define MCF5235_ETPU_ECDTROSR_DTROS30 (0x40000000)
1411#define MCF5235_ETPU_ECDTROSR_DTROS31 (0x80000000)
1412#define MCF5235_ETPU_ECIER_CIE0 (0x00000001)
1413#define MCF5235_ETPU_ECIER_CIE1 (0x00000002)
1414#define MCF5235_ETPU_ECIER_CIE2 (0x00000004)
1415#define MCF5235_ETPU_ECIER_CIE3 (0x00000008)
1416#define MCF5235_ETPU_ECIER_CIE4 (0x00000010)
1417#define MCF5235_ETPU_ECIER_CIE5 (0x00000020)
1418#define MCF5235_ETPU_ECIER_CIE6 (0x00000040)
1419#define MCF5235_ETPU_ECIER_CIE7 (0x00000080)
1420#define MCF5235_ETPU_ECIER_CIE8 (0x00000100)
1421#define MCF5235_ETPU_ECIER_CIE9 (0x00000200)
1422#define MCF5235_ETPU_ECIER_CIE10 (0x00000400)
1423#define MCF5235_ETPU_ECIER_CIE11 (0x00000800)
1424#define MCF5235_ETPU_ECIER_CIE12 (0x00001000)
1425#define MCF5235_ETPU_ECIER_CIE13 (0x00002000)
1426#define MCF5235_ETPU_ECIER_CIE14 (0x00004000)
1427#define MCF5235_ETPU_ECIER_CIE15 (0x00008000)
1428#define MCF5235_ETPU_ECIER_CIE16 (0x00010000)
1429#define MCF5235_ETPU_ECIER_CIE17 (0x00020000)
1430#define MCF5235_ETPU_ECIER_CIE18 (0x00040000)
1431#define MCF5235_ETPU_ECIER_CIE19 (0x00080000)
1432#define MCF5235_ETPU_ECIER_CIE20 (0x00100000)
1433#define MCF5235_ETPU_ECIER_CIE21 (0x00200000)
1434#define MCF5235_ETPU_ECIER_CIE22 (0x00400000)
1435#define MCF5235_ETPU_ECIER_CIE23 (0x00800000)
1436#define MCF5235_ETPU_ECIER_CIE24 (0x01000000)
1437#define MCF5235_ETPU_ECIER_CIE25 (0x02000000)
1438#define MCF5235_ETPU_ECIER_CIE26 (0x04000000)
1439#define MCF5235_ETPU_ECIER_CIE27 (0x08000000)
1440#define MCF5235_ETPU_ECIER_CIE28 (0x10000000)
1441#define MCF5235_ETPU_ECIER_CIE29 (0x20000000)
1442#define MCF5235_ETPU_ECIER_CIE30 (0x40000000)
1443#define MCF5235_ETPU_ECIER_CIE31 (0x80000000)
1444#define MCF5235_ETPU_ECDTRER_DTRE0 (0x00000001)
1445#define MCF5235_ETPU_ECDTRER_DTRE1 (0x00000002)
1446#define MCF5235_ETPU_ECDTRER_DTRE2 (0x00000004)
1447#define MCF5235_ETPU_ECDTRER_DTRE3 (0x00000008)
1448#define MCF5235_ETPU_ECDTRER_DTRE4 (0x00000010)
1449#define MCF5235_ETPU_ECDTRER_DTRE5 (0x00000020)
1450#define MCF5235_ETPU_ECDTRER_DTRE6 (0x00000040)
1451#define MCF5235_ETPU_ECDTRER_DTRE7 (0x00000080)
1452#define MCF5235_ETPU_ECDTRER_DTRE8 (0x00000100)
1453#define MCF5235_ETPU_ECDTRER_DTRE9 (0x00000200)
1454#define MCF5235_ETPU_ECDTRER_DTRE10 (0x00000400)
1455#define MCF5235_ETPU_ECDTRER_DTRE11 (0x00000800)
1456#define MCF5235_ETPU_ECDTRER_DTRE12 (0x00001000)
1457#define MCF5235_ETPU_ECDTRER_DTRE13 (0x00002000)
1458#define MCF5235_ETPU_ECDTRER_DTRE14 (0x00004000)
1459#define MCF5235_ETPU_ECDTRER_DTRE15 (0x00008000)
1460#define MCF5235_ETPU_ECDTRER_DTRE16 (0x00010000)
1461#define MCF5235_ETPU_ECDTRER_DTRE17 (0x00020000)
1462#define MCF5235_ETPU_ECDTRER_DTRE18 (0x00040000)
1463#define MCF5235_ETPU_ECDTRER_DTRE19 (0x00080000)
1464#define MCF5235_ETPU_ECDTRER_DTRE20 (0x00100000)
1465#define MCF5235_ETPU_ECDTRER_DTRE21 (0x00200000)
1466#define MCF5235_ETPU_ECDTRER_DTRE22 (0x00400000)
1467#define MCF5235_ETPU_ECDTRER_DTRE23 (0x00800000)
1468#define MCF5235_ETPU_ECDTRER_DTRE24 (0x01000000)
1469#define MCF5235_ETPU_ECDTRER_DTRE25 (0x02000000)
1470#define MCF5235_ETPU_ECDTRER_DTRE26 (0x04000000)
1471#define MCF5235_ETPU_ECDTRER_DTRE27 (0x08000000)
1472#define MCF5235_ETPU_ECDTRER_DTRE28 (0x10000000)
1473#define MCF5235_ETPU_ECDTRER_DTRE29 (0x20000000)
1474#define MCF5235_ETPU_ECDTRER_DTRE30 (0x40000000)
1475#define MCF5235_ETPU_ECDTRER_DTRE31 (0x80000000)
1476#define MCF5235_ETPU_ECPSSR_SR0 (0x00000001)
1477#define MCF5235_ETPU_ECPSSR_SR1 (0x00000002)
1478#define MCF5235_ETPU_ECPSSR_SR2 (0x00000004)
1479#define MCF5235_ETPU_ECPSSR_SR3 (0x00000008)
1480#define MCF5235_ETPU_ECPSSR_SR4 (0x00000010)
1481#define MCF5235_ETPU_ECPSSR_SR5 (0x00000020)
1482#define MCF5235_ETPU_ECPSSR_SR6 (0x00000040)
1483#define MCF5235_ETPU_ECPSSR_SR7 (0x00000080)
1484#define MCF5235_ETPU_ECPSSR_SR8 (0x00000100)
1485#define MCF5235_ETPU_ECPSSR_SR9 (0x00000200)
1486#define MCF5235_ETPU_ECPSSR_SR10 (0x00000400)
1487#define MCF5235_ETPU_ECPSSR_SR11 (0x00000800)
1488#define MCF5235_ETPU_ECPSSR_SR12 (0x00001000)
1489#define MCF5235_ETPU_ECPSSR_SR13 (0x00002000)
1490#define MCF5235_ETPU_ECPSSR_SR14 (0x00004000)
1491#define MCF5235_ETPU_ECPSSR_SR15 (0x00008000)
1492#define MCF5235_ETPU_ECPSSR_SR16 (0x00010000)
1493#define MCF5235_ETPU_ECPSSR_SR17 (0x00020000)
1494#define MCF5235_ETPU_ECPSSR_SR18 (0x00040000)
1495#define MCF5235_ETPU_ECPSSR_SR19 (0x00080000)
1496#define MCF5235_ETPU_ECPSSR_SR20 (0x00100000)
1497#define MCF5235_ETPU_ECPSSR_SR21 (0x00200000)
1498#define MCF5235_ETPU_ECPSSR_SR22 (0x00400000)
1499#define MCF5235_ETPU_ECPSSR_SR23 (0x00800000)
1500#define MCF5235_ETPU_ECPSSR_SR24 (0x01000000)
1501#define MCF5235_ETPU_ECPSSR_SR25 (0x02000000)
1502#define MCF5235_ETPU_ECPSSR_SR26 (0x04000000)
1503#define MCF5235_ETPU_ECPSSR_SR27 (0x08000000)
1504#define MCF5235_ETPU_ECPSSR_SR28 (0x10000000)
1505#define MCF5235_ETPU_ECPSSR_SR29 (0x20000000)
1506#define MCF5235_ETPU_ECPSSR_SR30 (0x40000000)
1507#define MCF5235_ETPU_ECPSSR_SR31 (0x80000000)
1508#define MCF5235_ETPU_ECSSR_SS0 (0x00000001)
1509#define MCF5235_ETPU_ECSSR_SS1 (0x00000002)
1510#define MCF5235_ETPU_ECSSR_SS2 (0x00000004)
1511#define MCF5235_ETPU_ECSSR_SS3 (0x00000008)
1512#define MCF5235_ETPU_ECSSR_SS4 (0x00000010)
1513#define MCF5235_ETPU_ECSSR_SS5 (0x00000020)
1514#define MCF5235_ETPU_ECSSR_SS6 (0x00000040)
1515#define MCF5235_ETPU_ECSSR_SS7 (0x00000080)
1516#define MCF5235_ETPU_ECSSR_SS8 (0x00000100)
1517#define MCF5235_ETPU_ECSSR_SS9 (0x00000200)
1518#define MCF5235_ETPU_ECSSR_SS10 (0x00000400)
1519#define MCF5235_ETPU_ECSSR_SS11 (0x00000800)
1520#define MCF5235_ETPU_ECSSR_SS12 (0x00001000)
1521#define MCF5235_ETPU_ECSSR_SS13 (0x00002000)
1522#define MCF5235_ETPU_ECSSR_SS14 (0x00004000)
1523#define MCF5235_ETPU_ECSSR_SS15 (0x00008000)
1524#define MCF5235_ETPU_ECSSR_SS16 (0x00010000)
1525#define MCF5235_ETPU_ECSSR_SS17 (0x00020000)
1526#define MCF5235_ETPU_ECSSR_SS18 (0x00040000)
1527#define MCF5235_ETPU_ECSSR_SS19 (0x00080000)
1528#define MCF5235_ETPU_ECSSR_SS20 (0x00100000)
1529#define MCF5235_ETPU_ECSSR_SS21 (0x00200000)
1530#define MCF5235_ETPU_ECSSR_SS22 (0x00400000)
1531#define MCF5235_ETPU_ECSSR_SS23 (0x00800000)
1532#define MCF5235_ETPU_ECSSR_SS24 (0x01000000)
1533#define MCF5235_ETPU_ECSSR_SS25 (0x02000000)
1534#define MCF5235_ETPU_ECSSR_SS26 (0x04000000)
1535#define MCF5235_ETPU_ECSSR_SS27 (0x08000000)
1536#define MCF5235_ETPU_ECSSR_SS28 (0x10000000)
1537#define MCF5235_ETPU_ECSSR_SS29 (0x20000000)
1538#define MCF5235_ETPU_ECSSR_SS30 (0x40000000)
1539#define MCF5235_ETPU_ECSSR_SS31 (0x80000000)
1540#define MCF5235_ETPU_ECnSCR_FM(x) (((x)&0x00000003)<<0)
1541#define MCF5235_ETPU_ECnSCR_OBE (0x00002000)
1542#define MCF5235_ETPU_ECnSCR_OPS (0x00004000)
1543#define MCF5235_ETPU_ECnSCR_IPS (0x00008000)
1544#define MCF5235_ETPU_ECnSCR_DTROS (0x00400000)
1545#define MCF5235_ETPU_ECnSCR_DTRS (0x00800000)
1546#define MCF5235_ETPU_ECnSCR_CIOS (0x40000000)
1547#define MCF5235_ETPU_ECnSCR_CIS (0x80000000)
1548#define MCF5235_ETPU_ECnCR_CPBA(x) (((x)&0x000007FF)<<0)
1549#define MCF5235_ETPU_ECnCR_OPOL (0x00004000)
1550#define MCF5235_ETPU_ECnCR_ODIS (0x00008000)
1551#define MCF5235_ETPU_ECnCR_CFS(x) (((x)&0x0000001F)<<16)
1552#define MCF5235_ETPU_ECnCR_ETCS (0x01000000)
1553#define MCF5235_ETPU_ECnCR_CPR(x) (((x)&0x00000003)<<28)
1554#define MCF5235_ETPU_ECnCR_DTRE (0x40000000)
1555#define MCF5235_ETPU_ECnCR_CIE (0x80000000)
1556#define MCF5235_ETPU_ECnHSSR_HSR(x) (((x)&0x00000007)<<0)
1557
1558
1559/*********************************************************************
1560*
1561* Fast Ethernet Controller (FEC)
1562*
1563*********************************************************************/
1564
1565/* Register read/write macros */
1566#define MCF5235_FEC_EIR (*(vuint32*)((uintptr_t)__IPSBAR + (0x001004)))
1567#define MCF5235_FEC_EIMR (*(vuint32*)((uintptr_t)__IPSBAR + (0x001008)))
1568#define MCF5235_FEC_RDAR (*(vuint32*)((uintptr_t)__IPSBAR + (0x001010)))
1569#define MCF5235_FEC_TDAR (*(vuint32*)((uintptr_t)__IPSBAR + (0x001014)))
1570#define MCF5235_FEC_ECR (*(vuint32*)((uintptr_t)__IPSBAR + (0x001024)))
1571#define MCF5235_FEC_MMFR (*(vuint32*)((uintptr_t)__IPSBAR + (0x001040)))
1572#define MCF5235_FEC_MSCR (*(vuint32*)((uintptr_t)__IPSBAR + (0x001044)))
1573#define MCF5235_FEC_MIBC (*(vuint32*)((uintptr_t)__IPSBAR + (0x001064)))
1574#define MCF5235_FEC_RCR (*(vuint32*)((uintptr_t)__IPSBAR + (0x001084)))
1575#define MCF5235_FEC_TCR (*(vuint32*)((uintptr_t)__IPSBAR + (0x0010C4)))
1576#define MCF5235_FEC_PALR (*(vuint32*)((uintptr_t)__IPSBAR + (0x0010E4)))
1577#define MCF5235_FEC_PAUR (*(vuint32*)((uintptr_t)__IPSBAR + (0x0010E8)))
1578#define MCF5235_FEC_OPD (*(vuint32*)((uintptr_t)__IPSBAR + (0x0010EC)))
1579#define MCF5235_FEC_IAUR (*(vuint32*)((uintptr_t)__IPSBAR + (0x001118)))
1580#define MCF5235_FEC_IALR (*(vuint32*)((uintptr_t)__IPSBAR + (0x00111C)))
1581#define MCF5235_FEC_GAUR (*(vuint32*)((uintptr_t)__IPSBAR + (0x001120)))
1582#define MCF5235_FEC_GALR (*(vuint32*)((uintptr_t)__IPSBAR + (0x001124)))
1583#define MCF5235_FEC_TFWR (*(vuint32*)((uintptr_t)__IPSBAR + (0x001144)))
1584#define MCF5235_FEC_FRBR (*(vuint32*)((uintptr_t)__IPSBAR + (0x00114C)))
1585#define MCF5235_FEC_FRSR (*(vuint32*)((uintptr_t)__IPSBAR + (0x001150)))
1586#define MCF5235_FEC_ERDSR (*(vuint32*)((uintptr_t)__IPSBAR + (0x001180)))
1587#define MCF5235_FEC_ETDSR (*(vuint32*)((uintptr_t)__IPSBAR + (0x001184)))
1588#define MCF5235_FEC_EMRBR (*(vuint32*)((uintptr_t)__IPSBAR + (0x001188)))
1589#define MCF5235_FEC_RMON_T_DROP (*(vuint32*)((uintptr_t)__IPSBAR + (0x001200)))
1590#define MCF5235_FEC_RMON_T_PACKETS (*(vuint32*)((uintptr_t)__IPSBAR + (0x001204)))
1591#define MCF5235_FEC_RMON_T_BC_PKT (*(vuint32*)((uintptr_t)__IPSBAR + (0x001208)))
1592#define MCF5235_FEC_RMON_T_MC_PKT (*(vuint32*)((uintptr_t)__IPSBAR + (0x00120C)))
1593#define MCF5235_FEC_RMON_T_CRC_ALIGN (*(vuint32*)((uintptr_t)__IPSBAR + (0x001210)))
1594#define MCF5235_FEC_RMON_T_UNDERSIZE (*(vuint32*)((uintptr_t)__IPSBAR + (0x001214)))
1595#define MCF5235_FEC_RMON_T_OVERSIZE (*(vuint32*)((uintptr_t)__IPSBAR + (0x001218)))
1596#define MCF5235_FEC_RMON_T_FRAG (*(vuint32*)((uintptr_t)__IPSBAR + (0x00121C)))
1597#define MCF5235_FEC_RMON_T_JAB (*(vuint32*)((uintptr_t)__IPSBAR + (0x001220)))
1598#define MCF5235_FEC_RMON_T_COL (*(vuint32*)((uintptr_t)__IPSBAR + (0x001224)))
1599#define MCF5235_FEC_RMON_T_P64 (*(vuint32*)((uintptr_t)__IPSBAR + (0x001228)))
1600#define MCF5235_FEC_RMON_T_P65TO127 (*(vuint32*)((uintptr_t)__IPSBAR + (0x00122C)))
1601#define MCF5235_FEC_RMON_T_P128TO255 (*(vuint32*)((uintptr_t)__IPSBAR + (0x001230)))
1602#define MCF5235_FEC_RMON_T_P256TO511 (*(vuint32*)((uintptr_t)__IPSBAR + (0x001234)))
1603#define MCF5235_FEC_RMON_T_P512TO1023 (*(vuint32*)((uintptr_t)__IPSBAR + (0x001238)))
1604#define MCF5235_FEC_RMON_T_P1024TO2047 (*(vuint32*)((uintptr_t)__IPSBAR + (0x00123C)))
1605#define MCF5235_FEC_RMON_T_P_GTE2048 (*(vuint32*)((uintptr_t)__IPSBAR + (0x001240)))
1606#define MCF5235_FEC_RMON_T_OCTETS (*(vuint32*)((uintptr_t)__IPSBAR + (0x001244)))
1607#define MCF5235_FEC_IEEE_T_DROP (*(vuint32*)((uintptr_t)__IPSBAR + (0x001248)))
1608#define MCF5235_FEC_IEEE_T_FRAME_OK (*(vuint32*)((uintptr_t)__IPSBAR + (0x00124C)))
1609#define MCF5235_FEC_IEEE_T_1COL (*(vuint32*)((uintptr_t)__IPSBAR + (0x001250)))
1610#define MCF5235_FEC_IEEE_T_MCOL (*(vuint32*)((uintptr_t)__IPSBAR + (0x001254)))
1611#define MCF5235_FEC_IEEE_T_DEF (*(vuint32*)((uintptr_t)__IPSBAR + (0x001258)))
1612#define MCF5235_FEC_IEEE_T_LCOL (*(vuint32*)((uintptr_t)__IPSBAR + (0x00125C)))
1613#define MCF5235_FEC_IEEE_T_EXCOL (*(vuint32*)((uintptr_t)__IPSBAR + (0x001260)))
1614#define MCF5235_FEC_IEEE_T_MACERR (*(vuint32*)((uintptr_t)__IPSBAR + (0x001264)))
1615#define MCF5235_FEC_IEEE_T_CSERR (*(vuint32*)((uintptr_t)__IPSBAR + (0x001268)))
1616#define MCF5235_FEC_IEEE_T_SQE (*(vuint32*)((uintptr_t)__IPSBAR + (0x00126C)))
1617#define MCF5235_FEC_IEEE_T_FDXFC (*(vuint32*)((uintptr_t)__IPSBAR + (0x001270)))
1618#define MCF5235_FEC_IEEE_T_OCTETS_OK (*(vuint32*)((uintptr_t)__IPSBAR + (0x001274)))
1619#define MCF5235_FEC_RMON_R_PACKETS (*(vuint32*)((uintptr_t)__IPSBAR + (0x001284)))
1620#define MCF5235_FEC_RMON_R_BC_PKT (*(vuint32*)((uintptr_t)__IPSBAR + (0x001288)))
1621#define MCF5235_FEC_RMON_R_MC_PKT (*(vuint32*)((uintptr_t)__IPSBAR + (0x00128C)))
1622#define MCF5235_FEC_RMON_R_CRC_ALIGN (*(vuint32*)((uintptr_t)__IPSBAR + (0x001290)))
1623#define MCF5235_FEC_RMON_R_UNDERSIZE (*(vuint32*)((uintptr_t)__IPSBAR + (0x001294)))
1624#define MCF5235_FEC_RMON_R_OVERSIZE (*(vuint32*)((uintptr_t)__IPSBAR + (0x001298)))
1625#define MCF5235_FEC_RMON_R_FRAG (*(vuint32*)((uintptr_t)__IPSBAR + (0x00129C)))
1626#define MCF5235_FEC_RMON_R_JAB (*(vuint32*)((uintptr_t)__IPSBAR + (0x0012A0)))
1627#define MCF5235_FEC_RMON_R_RESVD_0 (*(vuint32*)((uintptr_t)__IPSBAR + (0x0012A4)))
1628#define MCF5235_FEC_RMON_R_P64 (*(vuint32*)((uintptr_t)__IPSBAR + (0x0012A8)))
1629#define MCF5235_FEC_RMON_R_P65T0127 (*(vuint32*)((uintptr_t)__IPSBAR + (0x0012AC)))
1630#define MCF5235_FEC_RMON_R_P128TO255 (*(vuint32*)((uintptr_t)__IPSBAR + (0x0012B0)))
1631#define MCF5235_FEC_RMON_R_P256TO511 (*(vuint32*)((uintptr_t)__IPSBAR + (0x0012B4)))
1632#define MCF5235_FEC_RMON_R_P512TO1023 (*(vuint32*)((uintptr_t)__IPSBAR + (0x0012B8)))
1633#define MCF5235_FEC_RMON_R_GTE2048 (*(vuint32*)((uintptr_t)__IPSBAR + (0x0012C0)))
1634#define MCF5235_FEC_RMON_R_P1024TO2047 (*(vuint32*)((uintptr_t)__IPSBAR + (0x0012BC)))
1635#define MCF5235_FEC_RMON_R_OCTETS (*(vuint32*)((uintptr_t)__IPSBAR + (0x0012C4)))
1636#define MCF5235_FEC_IEEE_R_DROP (*(vuint32*)((uintptr_t)__IPSBAR + (0x0012C8)))
1637#define MCF5235_FEC_IEEE_R_FRAME_OK (*(vuint32*)((uintptr_t)__IPSBAR + (0x0012CC)))
1638#define MCF5235_FEC_IEEE_R_CRC (*(vuint32*)((uintptr_t)__IPSBAR + (0x0012D0)))
1639#define MCF5235_FEC_IEEE_R_ALIGN (*(vuint32*)((uintptr_t)__IPSBAR + (0x0012D4)))
1640#define MCF5235_FEC_IEEE_R_MACERR (*(vuint32*)((uintptr_t)__IPSBAR + (0x0012D8)))
1641#define MCF5235_FEC_IEEE_R_FDXFC (*(vuint32*)((uintptr_t)__IPSBAR + (0x0012DC)))
1642#define MCF5235_FEC_IEEE_R_OCTETS_OK (*(vuint32*)((uintptr_t)__IPSBAR + (0x0012E0)))
1643
1644/* Bit definitions and macros for MCF5235_FEC_EIR */
1645#define MCF5235_FEC_EIR_UN (0x00080000)
1646#define MCF5235_FEC_EIR_RL (0x00100000)
1647#define MCF5235_FEC_EIR_LC (0x00200000)
1648#define MCF5235_FEC_EIR_EBERR (0x00400000)
1649#define MCF5235_FEC_EIR_MII (0x00800000)
1650#define MCF5235_FEC_EIR_RXB (0x01000000)
1651#define MCF5235_FEC_EIR_RXF (0x02000000)
1652#define MCF5235_FEC_EIR_TXB (0x04000000)
1653#define MCF5235_FEC_EIR_TXF (0x08000000)
1654#define MCF5235_FEC_EIR_GRA (0x10000000)
1655#define MCF5235_FEC_EIR_BABT (0x20000000)
1656#define MCF5235_FEC_EIR_BABR (0x40000000)
1657#define MCF5235_FEC_EIR_HBERR (0x80000000)
1658#define MCF5235_FEC_EIMR_UN (0x00080000)
1659#define MCF5235_FEC_EIMR_RL (0x00100000)
1660#define MCF5235_FEC_EIMR_LC (0x00200000)
1661#define MCF5235_FEC_EIMR_EBERR (0x00400000)
1662#define MCF5235_FEC_EIMR_MII (0x00800000)
1663#define MCF5235_FEC_EIMR_RXB (0x01000000)
1664#define MCF5235_FEC_EIMR_RXF (0x02000000)
1665#define MCF5235_FEC_EIMR_TXB (0x04000000)
1666#define MCF5235_FEC_EIMR_TXF (0x08000000)
1667#define MCF5235_FEC_EIMR_GRA (0x10000000)
1668#define MCF5235_FEC_EIMR_BABT (0x20000000)
1669#define MCF5235_FEC_EIMR_BABR (0x40000000)
1670#define MCF5235_FEC_EIMR_HBERR (0x80000000)
1671#define MCF5235_FEC_RDAR_R_DES_ACTIVE (0x01000000)
1672#define MCF5235_FEC_TDAR_X_DES_ACTIVE (0x01000000)
1673#define MCF5235_FEC_ECR_RESET (0x00000001)
1674#define MCF5235_FEC_ECR_ETHER_EN (0x00000002)
1675#define MCF5235_FEC_MMFR_DATA(x) (((x)&0x0000FFFF)<<0)
1676#define MCF5235_FEC_MMFR_TA(x) (((x)&0x00000003)<<16)
1677#define MCF5235_FEC_MMFR_RA(x) (((x)&0x0000001F)<<18)
1678#define MCF5235_FEC_MMFR_PA(x) (((x)&0x0000001F)<<23)
1679#define MCF5235_FEC_MMFR_OP(x) (((x)&0x00000003)<<28)
1680#define MCF5235_FEC_MMFR_ST(x) (((x)&0x00000003)<<30)
1681#define MCF5235_FEC_MMFR_ST_01 (0x40000000)
1682#define MCF5235_FEC_MMFR_OP_READ (0x20000000)
1683#define MCF5235_FEC_MMFR_OP_WRITE (0x10000000)
1684#define MCF5235_FEC_MMFR_TA_10 (0x00020000)
1685#define MCF5235_FEC_MSCR_MII_SPEED(x) (((x)&0x0000003F)<<1)
1686#define MCF5235_FEC_MSCR_DIS_PREAMBLE (0x00000080)
1687#define MCF5235_FEC_MIBC_MIB_IDLE (0x40000000)
1688#define MCF5235_FEC_MIBC_MIB_DISABLE (0x80000000)
1689#define MCF5235_FEC_RCR_LOOP (0x00000001)
1690#define MCF5235_FEC_RCR_DRT (0x00000002)
1691#define MCF5235_FEC_RCR_MII_MODE (0x00000004)
1692#define MCF5235_FEC_RCR_PROM (0x00000008)
1693#define MCF5235_FEC_RCR_BC_REJ (0x00000010)
1694#define MCF5235_FEC_RCR_FCE (0x00000020)
1695#define MCF5235_FEC_RCR_MAX_FL(x) (((x)&0x000007FF)<<16)
1696#define MCF5235_FEC_TCR_GTS (0x00000001)
1697#define MCF5235_FEC_TCR_HBC (0x00000002)
1698#define MCF5235_FEC_TCR_FDEN (0x00000004)
1699#define MCF5235_FEC_TCR_TFC_PAUSE (0x00000008)
1700#define MCF5235_FEC_TCR_RFC_PAUSE (0x00000010)
1701#define MCF5235_FEC_PAUR_TYPE(x) (((x)&0x0000FFFF)<<0)
1702#define MCF5235_FEC_PAUR_PADDR2(x) (((x)&0x0000FFFF)<<16)
1703#define MCF5235_FEC_OPD_PAUSE_DUR(x) (((x)&0x0000FFFF)<<0)
1704#define MCF5235_FEC_OPD_OPCODE(x) (((x)&0x0000FFFF)<<16)
1705#define MCF5235_FEC_TFWR_X_WMRK(x) (((x)&0x00000003)<<0)
1706#define MCF5235_FEC_FRBR_R_BOUND(x) (((x)&0x000000FF)<<2)
1707#define MCF5235_FEC_FRSR_R_FSTART(x) (((x)&0x000000FF)<<2)
1708#define MCF5235_FEC_ERDSR_R_DES_START(x) (((x)&0x3FFFFFFF)<<2)
1709#define MCF5235_FEC_ETDSR_X_DES_START(x) (((x)&0x3FFFFFFF)<<2)
1710#define MCF5235_FEC_EMRBR_R_BUF_SIZE(x) (((x)&0x0000007F)<<4)
1711#define MCF5235_FEC_TxBD_R 0x8000
1712#define MCF5235_FEC_TxBD_BUSY 0x4000
1713#define MCF5235_FEC_TxBD_TO1 0x4000
1714#define MCF5235_FEC_TxBD_W 0x2000
1715#define MCF5235_FEC_TxBD_TO2 0x1000
1716#define MCF5235_FEC_TxBD_FIRST 0x1000
1717#define MCF5235_FEC_TxBD_L 0x0800
1718#define MCF5235_FEC_TxBD_TC 0x0400
1719#define MCF5235_FEC_TxBD_DEF 0x0200
1720#define MCF5235_FEC_TxBD_HB 0x0100
1721#define MCF5235_FEC_TxBD_LC 0x0080
1722#define MCF5235_FEC_TxBD_RL 0x0040
1723#define MCF5235_FEC_TxBD_UN 0x0002
1724#define MCF5235_FEC_TxBD_CSL 0x0001
1725#define MCF5235_FEC_RxBD_E 0x8000
1726#define MCF5235_FEC_RxBD_INUSE 0x4000
1727#define MCF5235_FEC_RxBD_R01 0x4000
1728#define MCF5235_FEC_RxBD_W 0x2000
1729#define MCF5235_FEC_RxBD_R02 0x1000
1730#define MCF5235_FEC_RxBD_L 0x0800
1731#define MCF5235_FEC_RxBD_M 0x0100
1732#define MCF5235_FEC_RxBD_BC 0x0080
1733#define MCF5235_FEC_RxBD_MC 0x0040
1734#define MCF5235_FEC_RxBD_LG 0x0020
1735#define MCF5235_FEC_RxBD_NO 0x0010
1736#define MCF5235_FEC_RxBD_CR 0x0004
1737#define MCF5235_FEC_RxBD_OV 0x0002
1738#define MCF5235_FEC_RxBD_TR 0x0001
1739
1740/************************************************************
1741*
1742* Clock
1743*************************************************************/
1744/* Register read/write macros */
1745#define MCF5235_FMPLL_SYNCR (*(vuint32*)((uintptr_t)__IPSBAR + (0x120000)))
1746#define MCF5235_FMPLL_SYNSR (*(vuint32*)((uintptr_t)__IPSBAR + (0x120004)))
1747
1748/* Bit definitions and macros for MCF5235_FMPLL_SYNCR */
1749#define MCF5235_FMPLL_SYNCR_EXP(x) (((x)&0x000003FF)<<0)
1750#define MCF5235_FMPLL_SYNCR_DEPTH(x) (((x)&0x00000003)<<10)
1751#define MCF5235_FMPLL_SYNCR_RATE (0x00001000)
1752#define MCF5235_FMPLL_SYNCR_LOCIRQ (0x00002000)
1753#define MCF5235_FMPLL_SYNCR_LOLIRQ (0x00004000)
1754#define MCF5235_FMPLL_SYNCR_DISCLK (0x00008000)
1755#define MCF5235_FMPLL_SYNCR_LOCRE (0x00010000)
1756#define MCF5235_FMPLL_SYNCR_LOLRE (0x00020000)
1757#define MCF5235_FMPLL_SYNCR_LOCEN (0x00040000)
1758#define MCF5235_FMPLL_SYNCR_RFD(x) (((x)&0x00000007)<<19)
1759#define MCF5235_FMPLL_SYNCR_MFD(x) (((x)&0x00000007)<<24)
1760#define MCF5235_FMPLL_SYNSR_CALPASS (0x00000001)
1761#define MCF5235_FMPLL_SYNSR_CALDONE (0x00000002)
1762#define MCF5235_FMPLL_SYNSR_LOCF (0x00000004)
1763#define MCF5235_FMPLL_SYNSR_LOCK (0x00000008)
1764#define MCF5235_FMPLL_SYNSR_LOCKS (0x00000010)
1765#define MCF5235_FMPLL_SYNSR_PLLREF (0x00000020)
1766#define MCF5235_FMPLL_SYNSR_PLLSEL (0x00000040)
1767#define MCF5235_FMPLL_SYNSR_MODE (0x00000080)
1768#define MCF5235_FMPLL_SYNSR_LOC (0x00000100)
1769#define MCF5235_FMPLL_SYNSR_LOLF (0x00000200)
1770
1771
1772/*********************************************************************
1773*
1774* General Purpose I/O (GPIO)
1775*
1776*********************************************************************/
1777
1778/* Register read/write macros */
1779#define MCF5235_GPIO_PODR_ADDR (*(vuint8 *)((uintptr_t)__IPSBAR + (0x100000)))
1780#define MCF5235_GPIO_PODR_DATAH (*(vuint8 *)((uintptr_t)__IPSBAR + (0x100001)))
1781#define MCF5235_GPIO_PODR_DATAL (*(vuint8 *)((uintptr_t)__IPSBAR + (0x100002)))
1782#define MCF5235_GPIO_PODR_BUSCTL (*(vuint8 *)((uintptr_t)__IPSBAR + (0x100003)))
1783#define MCF5235_GPIO_PODR_BS (*(vuint8 *)((uintptr_t)__IPSBAR + (0x100004)))
1784#define MCF5235_GPIO_PODR_CS (*(vuint8 *)((uintptr_t)__IPSBAR + (0x100005)))
1785#define MCF5235_GPIO_PODR_SDRAM (*(vuint8 *)((uintptr_t)__IPSBAR + (0x100006)))
1786#define MCF5235_GPIO_PODR_FECI2C (*(vuint8 *)((uintptr_t)__IPSBAR + (0x100007)))
1787#define MCF5235_GPIO_PODR_UARTH (*(vuint8 *)((uintptr_t)__IPSBAR + (0x100008)))
1788#define MCF5235_GPIO_PODR_UARTL (*(vuint8 *)((uintptr_t)__IPSBAR + (0x100009)))
1789#define MCF5235_GPIO_PODR_QSPI (*(vuint8 *)((uintptr_t)__IPSBAR + (0x10000A)))
1790#define MCF5235_GPIO_PODR_TIMER (*(vuint8 *)((uintptr_t)__IPSBAR + (0x10000B)))
1791#define MCF5235_GPIO_PODR_ETPU (*(vuint8 *)((uintptr_t)__IPSBAR + (0x10000C)))
1792#define MCF5235_GPIO_PDDR_APDDR (*(vuint8 *)((uintptr_t)__IPSBAR + (0x100010)))
1793#define MCF5235_GPIO_PDDR_DATAH (*(vuint8 *)((uintptr_t)__IPSBAR + (0x100011)))
1794#define MCF5235_GPIO_PDDR_DATAL (*(vuint8 *)((uintptr_t)__IPSBAR + (0x100012)))
1795#define MCF5235_GPIO_PDDR_BUSCTL (*(vuint8 *)((uintptr_t)__IPSBAR + (0x100013)))
1796#define MCF5235_GPIO_PDDR_BS (*(vuint8 *)((uintptr_t)__IPSBAR + (0x100014)))
1797#define MCF5235_GPIO_PDDR_CS (*(vuint8 *)((uintptr_t)__IPSBAR + (0x100015)))
1798#define MCF5235_GPIO_PDDR_SDRAM (*(vuint8 *)((uintptr_t)__IPSBAR + (0x100016)))
1799#define MCF5235_GPIO_PDDR_FECI2C (*(vuint8 *)((uintptr_t)__IPSBAR + (0x100017)))
1800#define MCF5235_GPIO_PDDR_UARTH (*(vuint8 *)((uintptr_t)__IPSBAR + (0x100018)))
1801#define MCF5235_GPIO_PDDR_UARTL (*(vuint8 *)((uintptr_t)__IPSBAR + (0x100019)))
1802#define MCF5235_GPIO_PDDR_QSPI (*(vuint8 *)((uintptr_t)__IPSBAR + (0x10001A)))
1803#define MCF5235_GPIO_PDDR_TIMER (*(vuint8 *)((uintptr_t)__IPSBAR + (0x10001B)))
1804#define MCF5235_GPIO_PDDR_ETPU (*(vuint8 *)((uintptr_t)__IPSBAR + (0x10001C)))
1805#define MCF5235_GPIO_PPDSDR_ADDR (*(vuint8 *)((uintptr_t)__IPSBAR + (0x100020)))
1806#define MCF5235_GPIO_PPDSDR_DATAH (*(vuint8 *)((uintptr_t)__IPSBAR + (0x100021)))
1807#define MCF5235_GPIO_PPDSDR_DATAL (*(vuint8 *)((uintptr_t)__IPSBAR + (0x100022)))
1808#define MCF5235_GPIO_PPDSDR_BUSCTL (*(vuint8 *)((uintptr_t)__IPSBAR + (0x100023)))
1809#define MCF5235_GPIO_PPDSDR_BS (*(vuint8 *)((uintptr_t)__IPSBAR + (0x100024)))
1810#define MCF5235_GPIO_PPDSDR_FECI2C (*(vuint8 *)((uintptr_t)__IPSBAR + (0x100027)))
1811#define MCF5235_GPIO_PPDSDR_CS (*(vuint8 *)((uintptr_t)__IPSBAR + (0x100025)))
1812#define MCF5235_GPIO_PPDSDR_SDRAM (*(vuint8 *)((uintptr_t)__IPSBAR + (0x100026)))
1813#define MCF5235_GPIO_PPDSDR_UARTH (*(vuint8 *)((uintptr_t)__IPSBAR + (0x100028)))
1814#define MCF5235_GPIO_PPDSDR_UARTL (*(vuint8 *)((uintptr_t)__IPSBAR + (0x100029)))
1815#define MCF5235_GPIO_PPDSDR_QSPI (*(vuint8 *)((uintptr_t)__IPSBAR + (0x10002A)))
1816#define MCF5235_GPIO_PPDSDR_TIMER (*(vuint8 *)((uintptr_t)__IPSBAR + (0x10002B)))
1817#define MCF5235_GPIO_PPDSDR_ETPU (*(vuint8 *)((uintptr_t)__IPSBAR + (0x10002C)))
1818#define MCF5235_GPIO_PCLRR_ADDR (*(vuint8 *)((uintptr_t)__IPSBAR + (0x100030)))
1819#define MCF5235_GPIO_PCLRR_DATAH (*(vuint8 *)((uintptr_t)__IPSBAR + (0x100031)))
1820#define MCF5235_GPIO_PCLRR_DATAL (*(vuint8 *)((uintptr_t)__IPSBAR + (0x100032)))
1821#define MCF5235_GPIO_PCLRR_BUSCTL (*(vuint8 *)((uintptr_t)__IPSBAR + (0x100033)))
1822#define MCF5235_GPIO_PCLRR_BS (*(vuint8 *)((uintptr_t)__IPSBAR + (0x100034)))
1823#define MCF5235_GPIO_PCLRR_CS (*(vuint8 *)((uintptr_t)__IPSBAR + (0x100035)))
1824#define MCF5235_GPIO_PCLRR_SDRAM (*(vuint8 *)((uintptr_t)__IPSBAR + (0x100036)))
1825#define MCF5235_GPIO_PCLRR_FECI2C (*(vuint8 *)((uintptr_t)__IPSBAR + (0x100037)))
1826#define MCF5235_GPIO_PCLRR_UARTH (*(vuint8 *)((uintptr_t)__IPSBAR + (0x100038)))
1827#define MCF5235_GPIO_PCLRR_UARTL (*(vuint8 *)((uintptr_t)__IPSBAR + (0x100039)))
1828#define MCF5235_GPIO_PCLRR_QSPI (*(vuint8 *)((uintptr_t)__IPSBAR + (0x10003A)))
1829#define MCF5235_GPIO_PCLRR_TIMER (*(vuint8 *)((uintptr_t)__IPSBAR + (0x10003B)))
1830#define MCF5235_GPIO_PCLRR_ETPU (*(vuint8 *)((uintptr_t)__IPSBAR + (0x10003C)))
1831#define MCF5235_GPIO_PAR_AD (*(vuint8 *)((uintptr_t)__IPSBAR + (0x100040)))
1832#define MCF5235_GPIO_PAR_BUSCTL (*(vuint16*)((uintptr_t)__IPSBAR + (0x100042)))
1833#define MCF5235_GPIO_PAR_BS (*(vuint8 *)((uintptr_t)__IPSBAR + (0x100044)))
1834#define MCF5235_GPIO_PAR_CS (*(vuint8 *)((uintptr_t)__IPSBAR + (0x100045)))
1835#define MCF5235_GPIO_PAR_SDRAM (*(vuint8 *)((uintptr_t)__IPSBAR + (0x100046)))
1836#define MCF5235_GPIO_PAR_FECI2C (*(vuint8 *)((uintptr_t)__IPSBAR + (0x100047)))
1837#define MCF5235_GPIO_UART (*(vuint16*)((uintptr_t)__IPSBAR + (0x100048)))
1838#define MCF5235_GPIO_PAR_QSPI (*(vuint8 *)((uintptr_t)__IPSBAR + (0x10004A)))
1839#define MCF5235_GPIO_PAR_TIMER (*(vuint16*)((uintptr_t)__IPSBAR + (0x10004C)))
1840#define MCF5235_GPIO_PAR_ETPU (*(vuint8 *)((uintptr_t)__IPSBAR + (0x10004E)))
1841#define MCF5235_GPIO_DSCR_EIM (*(vuint8 *)((uintptr_t)__IPSBAR + (0x100050)))
1842#define MCF5235_GPIO_DSCR_ETPU (*(vuint8 *)((uintptr_t)__IPSBAR + (0x100051)))
1843#define MCF5235_GPIO_DSCR_FECI2C (*(vuint8 *)((uintptr_t)__IPSBAR + (0x100052)))
1844#define MCF5235_GPIO_DSCR_UART (*(vuint8 *)((uintptr_t)__IPSBAR + (0x100053)))
1845#define MCF5235_GPIO_DSCR_QSPI (*(vuint8 *)((uintptr_t)__IPSBAR + (0x100054)))
1846#define MCF5235_GPIO_DSCR_TIMER (*(vuint8 *)((uintptr_t)__IPSBAR + (0x100055)))
1847
1848/* Bit definitions and macros for MCF5235_GPIO_PODR_ADDR */
1849#define MCF5235_GPIO_PODR_ADDR_PODR_ADDR5 (0x20)
1850#define MCF5235_GPIO_PODR_ADDR_PODR_ADDR6 (0x40)
1851#define MCF5235_GPIO_PODR_ADDR_PODR_ADDR7 (0x80)
1852#define MCF5235_GPIO_PODR_DATAH_PODR_DATAH0 (0x01)
1853#define MCF5235_GPIO_PODR_DATAH_PODR_DATAH1 (0x02)
1854#define MCF5235_GPIO_PODR_DATAH_PODR_DATAH2 (0x04)
1855#define MCF5235_GPIO_PODR_DATAH_PODR_DATAH3 (0x08)
1856#define MCF5235_GPIO_PODR_DATAH_PODR_DATAH4 (0x10)
1857#define MCF5235_GPIO_PODR_DATAH_PODR_DATAH5 (0x20)
1858#define MCF5235_GPIO_PODR_DATAH_PODR_DATAH6 (0x40)
1859#define MCF5235_GPIO_PODR_DATAH_PODR_DATAH7 (0x80)
1860#define MCF5235_GPIO_PODR_DATAL_PODR_DATAL0 (0x01)
1861#define MCF5235_GPIO_PODR_DATAL_PODR_DATAL1 (0x02)
1862#define MCF5235_GPIO_PODR_DATAL_PODR_DATAL2 (0x04)
1863#define MCF5235_GPIO_PODR_DATAL_PODR_DATAL3 (0x08)
1864#define MCF5235_GPIO_PODR_DATAL_PODR_DATAL4 (0x10)
1865#define MCF5235_GPIO_PODR_DATAL_PODR_DATAL5 (0x20)
1866#define MCF5235_GPIO_PODR_DATAL_PODR_DATAL6 (0x40)
1867#define MCF5235_GPIO_PODR_DATAL_PODR_DATAL7 (0x80)
1868#define MCF5235_GPIO_PODR_BUSCTL_PODR_BUSCTL0 (0x01)
1869#define MCF5235_GPIO_PODR_BUSCTL_PODR_BUSCTL1 (0x02)
1870#define MCF5235_GPIO_PODR_BUSCTL_PODR_BUSCTL2 (0x04)
1871#define MCF5235_GPIO_PODR_BUSCTL_PODR_BUSCTL3 (0x08)
1872#define MCF5235_GPIO_PODR_BUSCTL_PODR_BUSCTL4 (0x10)
1873#define MCF5235_GPIO_PODR_BUSCTL_PODR_BUSCTL5 (0x20)
1874#define MCF5235_GPIO_PODR_BUSCTL_PODR_BUSCTL6 (0x40)
1875#define MCF5235_GPIO_PODR_BUSCTL_PODR_BUSCTL7 (0x80)
1876#define MCF5235_GPIO_PODR_BS_PODR_BS0 (0x01)
1877#define MCF5235_GPIO_PODR_BS_PODR_BS1 (0x02)
1878#define MCF5235_GPIO_PODR_BS_PODR_BS2 (0x04)
1879#define MCF5235_GPIO_PODR_BS_PODR_BS3 (0x08)
1880#define MCF5235_GPIO_PODR_CS_PODR_CS1 (0x02)
1881#define MCF5235_GPIO_PODR_CS_PODR_CS2 (0x04)
1882#define MCF5235_GPIO_PODR_CS_PODR_CS3 (0x08)
1883#define MCF5235_GPIO_PODR_CS_PODR_CS4 (0x10)
1884#define MCF5235_GPIO_PODR_CS_PODR_CS5 (0x20)
1885#define MCF5235_GPIO_PODR_CS_PODR_CS6 (0x40)
1886#define MCF5235_GPIO_PODR_CS_PODR_CS7 (0x80)
1887#define MCF5235_GPIO_PODR_SDRAM_PODR_SDRAM0 (0x01)
1888#define MCF5235_GPIO_PODR_SDRAM_PODR_SDRAM1 (0x02)
1889#define MCF5235_GPIO_PODR_SDRAM_PODR_SDRAM2 (0x04)
1890#define MCF5235_GPIO_PODR_SDRAM_PODR_SDRAM3 (0x08)
1891#define MCF5235_GPIO_PODR_SDRAM_PODR_SDRAM4 (0x10)
1892#define MCF5235_GPIO_PODR_SDRAM_PODR_SDRAM5 (0x20)
1893#define MCF5235_GPIO_PODR_FECI2C_PODR_FECI2C0 (0x01)
1894#define MCF5235_GPIO_PODR_FECI2C_PODR_FECI2C1 (0x02)
1895#define MCF5235_GPIO_PODR_FECI2C_PODR_FECI2C2 (0x04)
1896#define MCF5235_GPIO_PODR_FECI2C_PODR_FECI2C3 (0x08)
1897#define MCF5235_GPIO_PODR_UARTH_PODR_UARTH0 (0x01)
1898#define MCF5235_GPIO_PODR_UARTH_PODR_UARTH1 (0x02)
1899#define MCF5235_GPIO_PODR_UARTL_PODR_UARTL0 (0x01)
1900#define MCF5235_GPIO_PODR_UARTL_PODR_UARTL1 (0x02)
1901#define MCF5235_GPIO_PODR_UARTL_PODR_UARTL2 (0x04)
1902#define MCF5235_GPIO_PODR_UARTL_PODR_UARTL3 (0x08)
1903#define MCF5235_GPIO_PODR_UARTL_PODR_UARTL4 (0x10)
1904#define MCF5235_GPIO_PODR_UARTL_PODR_UARTL5 (0x20)
1905#define MCF5235_GPIO_PODR_UARTL_PODR_UARTL6 (0x40)
1906#define MCF5235_GPIO_PODR_UARTL_PODR_UARTL7 (0x80)
1907#define MCF5235_GPIO_PODR_QSPI_PODR_QSPI0 (0x01)
1908#define MCF5235_GPIO_PODR_QSPI_PODR_QSPI1 (0x02)
1909#define MCF5235_GPIO_PODR_QSPI_PODR_QSPI2 (0x04)
1910#define MCF5235_GPIO_PODR_QSPI_PODR_QSPI3 (0x08)
1911#define MCF5235_GPIO_PODR_QSPI_PODR_QSPI4 (0x10)
1912#define MCF5235_GPIO_PODR_TIMER_PODR_TIMER0 (0x01)
1913#define MCF5235_GPIO_PODR_TIMER_PODR_TIMER1 (0x02)
1914#define MCF5235_GPIO_PODR_TIMER_PODR_TIMER2 (0x04)
1915#define MCF5235_GPIO_PODR_TIMER_PODR_TIMER3 (0x08)
1916#define MCF5235_GPIO_PODR_TIMER_PODR_TIMER4 (0x10)
1917#define MCF5235_GPIO_PODR_TIMER_PODR_TIMER5 (0x20)
1918#define MCF5235_GPIO_PODR_TIMER_PODR_TIMER6 (0x40)
1919#define MCF5235_GPIO_PODR_TIMER_PODR_TIMER7 (0x80)
1920#define MCF5235_GPIO_PODR_ETPU_PODR_ETPU0 (0x01)
1921#define MCF5235_GPIO_PODR_ETPU_PODR_ETPU1 (0x02)
1922#define MCF5235_GPIO_PODR_ETPU_PODR_ETPU2 (0x04)
1923#define MCF5235_GPIO_PDDR_APDDR_PDDR_APDDR5 (0x20)
1924#define MCF5235_GPIO_PDDR_APDDR_PDDR_APDDR6 (0x40)
1925#define MCF5235_GPIO_PDDR_APDDR_PDDR_APDDR7 (0x80)
1926#define MCF5235_GPIO_PDDR_DATAH_PDDR_DATAH0 (0x01)
1927#define MCF5235_GPIO_PDDR_DATAH_PDDR_DATAH1 (0x02)
1928#define MCF5235_GPIO_PDDR_DATAH_PDDR_DATAH2 (0x04)
1929#define MCF5235_GPIO_PDDR_DATAH_PDDR_DATAH3 (0x08)
1930#define MCF5235_GPIO_PDDR_DATAH_PDDR_DATAH4 (0x10)
1931#define MCF5235_GPIO_PDDR_DATAH_PDDR_DATAH5 (0x20)
1932#define MCF5235_GPIO_PDDR_DATAH_PDDR_DATAH6 (0x40)
1933#define MCF5235_GPIO_PDDR_DATAH_PDDR_DATAH7 (0x80)
1934#define MCF5235_GPIO_PDDR_DATAL_PDDR_DATAL0 (0x01)
1935#define MCF5235_GPIO_PDDR_DATAL_PDDR_DATAL1 (0x02)
1936#define MCF5235_GPIO_PDDR_DATAL_PDDR_DATAL2 (0x04)
1937#define MCF5235_GPIO_PDDR_DATAL_PDDR_DATAL3 (0x08)
1938#define MCF5235_GPIO_PDDR_DATAL_PDDR_DATAL4 (0x10)
1939#define MCF5235_GPIO_PDDR_DATAL_PDDR_DATAL5 (0x20)
1940#define MCF5235_GPIO_PDDR_DATAL_PDDR_DATAL6 (0x40)
1941#define MCF5235_GPIO_PDDR_DATAL_PDDR_DATAL7 (0x80)
1942#define MCF5235_GPIO_PDDR_BUSCTL_PDDR_BUSCTL0 (0x01)
1943#define MCF5235_GPIO_PDDR_BUSCTL_PDDR_BUSCTL1 (0x02)
1944#define MCF5235_GPIO_PDDR_BUSCTL_PDDR_BUSCTL2 (0x04)
1945#define MCF5235_GPIO_PDDR_BUSCTL_PDDR_BUSCTL3 (0x08)
1946#define MCF5235_GPIO_PDDR_BUSCTL_PDDR_BUSCTL4 (0x10)
1947#define MCF5235_GPIO_PDDR_BUSCTL_PDDR_BUSCTL5 (0x20)
1948#define MCF5235_GPIO_PDDR_BUSCTL_PDDR_BUSCTL6 (0x40)
1949#define MCF5235_GPIO_PDDR_BUSCTL_PDDR_BUSCTL7 (0x80)
1950#define MCF5235_GPIO_PDDR_BS_PDDR_BS0 (0x01)
1951#define MCF5235_GPIO_PDDR_BS_PDDR_BS3(x) (((x)&0x07)<<1)
1952#define MCF5235_GPIO_PDDR_CS_PDDR_CS1 (0x02)
1953#define MCF5235_GPIO_PDDR_CS_PDDR_CS2 (0x04)
1954#define MCF5235_GPIO_PDDR_CS_PDDR_CS3 (0x08)
1955#define MCF5235_GPIO_PDDR_CS_PDDR_CS4 (0x10)
1956#define MCF5235_GPIO_PDDR_CS_PDDR_CS5 (0x20)
1957#define MCF5235_GPIO_PDDR_CS_PDDR_CS6 (0x40)
1958#define MCF5235_GPIO_PDDR_CS_PDDR_CS7 (0x80)
1959#define MCF5235_GPIO_PDDR_SDRAM_PDDR_SDRAM0 (0x01)
1960#define MCF5235_GPIO_PDDR_SDRAM_PDDR_SDRAM1 (0x02)
1961#define MCF5235_GPIO_PDDR_SDRAM_PDDR_SDRAM2 (0x04)
1962#define MCF5235_GPIO_PDDR_SDRAM_PDDR_SDRAM3 (0x08)
1963#define MCF5235_GPIO_PDDR_SDRAM_PDDR_SDRAM4 (0x10)
1964#define MCF5235_GPIO_PDDR_SDRAM_PDDR_SDRAM5 (0x20)
1965#define MCF5235_GPIO_PDDR_FECI2C_PDDR_FECI2C0 (0x01)
1966#define MCF5235_GPIO_PDDR_FECI2C_PDDR_FECI2C1 (0x02)
1967#define MCF5235_GPIO_PDDR_FECI2C_PDDR_FECI2C2 (0x04)
1968#define MCF5235_GPIO_PDDR_FECI2C_PDDR_FECI2C3 (0x08)
1969#define MCF5235_GPIO_PDDR_UARTH_PDDR_UARTH0 (0x01)
1970#define MCF5235_GPIO_PDDR_UARTH_PDDR_UARTH1 (0x02)
1971#define MCF5235_GPIO_PDDR_UARTL_PDDR_UARTL0 (0x01)
1972#define MCF5235_GPIO_PDDR_UARTL_PDDR_UARTL1 (0x02)
1973#define MCF5235_GPIO_PDDR_UARTL_PDDR_UARTL2 (0x04)
1974#define MCF5235_GPIO_PDDR_UARTL_PDDR_UARTL3 (0x08)
1975#define MCF5235_GPIO_PDDR_UARTL_PDDR_UARTL4 (0x10)
1976#define MCF5235_GPIO_PDDR_UARTL_PDDR_UARTL5 (0x20)
1977#define MCF5235_GPIO_PDDR_UARTL_PDDR_UARTL6 (0x40)
1978#define MCF5235_GPIO_PDDR_UARTL_PDDR_UARTL7 (0x80)
1979#define MCF5235_GPIO_PDDR_QSPI_PDDR_QSPI0 (0x01)
1980#define MCF5235_GPIO_PDDR_QSPI_PDDR_QSPI1 (0x02)
1981#define MCF5235_GPIO_PDDR_QSPI_PDDR_QSPI2 (0x04)
1982#define MCF5235_GPIO_PDDR_QSPI_PDDR_QSPI3 (0x08)
1983#define MCF5235_GPIO_PDDR_QSPI_PDDR_QSPI4 (0x10)
1984#define MCF5235_GPIO_PDDR_TIMER_PDDR_TIMER0 (0x01)
1985#define MCF5235_GPIO_PDDR_TIMER_PDDR_TIMER1 (0x02)
1986#define MCF5235_GPIO_PDDR_TIMER_PDDR_TIMER2 (0x04)
1987#define MCF5235_GPIO_PDDR_TIMER_PDDR_TIMER3 (0x08)
1988#define MCF5235_GPIO_PDDR_TIMER_PDDR_TIMER4 (0x10)
1989#define MCF5235_GPIO_PDDR_TIMER_PDDR_TIMER5 (0x20)
1990#define MCF5235_GPIO_PDDR_TIMER_PDDR_TIMER6 (0x40)
1991#define MCF5235_GPIO_PDDR_TIMER_PDDR_TIMER7 (0x80)
1992#define MCF5235_GPIO_PDDR_ETPU_PDDR_ETPU0 (0x01)
1993#define MCF5235_GPIO_PDDR_ETPU_PDDR_ETPU1 (0x02)
1994#define MCF5235_GPIO_PDDR_ETPU_PDDR_ETPU2 (0x04)
1995#define MCF5235_GPIO_PPDSDR_ADDR_PPDSDR_ADDR5 (0x20)
1996#define MCF5235_GPIO_PPDSDR_ADDR_PPDSDR_ADDR6 (0x40)
1997#define MCF5235_GPIO_PPDSDR_ADDR_PPDSDR_ADDR7 (0x80)
1998#define MCF5235_GPIO_PPDSDR_DATAH_PPDSDR_DATAH0 (0x01)
1999#define MCF5235_GPIO_PPDSDR_DATAH_PPDSDR_DATAH1 (0x02)
2000#define MCF5235_GPIO_PPDSDR_DATAH_PPDSDR_DATAH2 (0x04)
2001#define MCF5235_GPIO_PPDSDR_DATAH_PPDSDR_DATAH3 (0x08)
2002#define MCF5235_GPIO_PPDSDR_DATAH_PPDSDR_DATAH4 (0x10)
2003#define MCF5235_GPIO_PPDSDR_DATAH_PPDSDR_DATAH5 (0x20)
2004#define MCF5235_GPIO_PPDSDR_DATAH_PPDSDR_DATAH6 (0x40)
2005#define MCF5235_GPIO_PPDSDR_DATAH_PPDSDR_DATAH7 (0x80)
2006#define MCF5235_GPIO_PPDSDR_DATAL_PPDSDR_DATAL0 (0x01)
2007#define MCF5235_GPIO_PPDSDR_DATAL_PPDSDR_DATAL1 (0x02)
2008#define MCF5235_GPIO_PPDSDR_DATAL_PPDSDR_DATAL2 (0x04)
2009#define MCF5235_GPIO_PPDSDR_DATAL_PPDSDR_DATAL3 (0x08)
2010#define MCF5235_GPIO_PPDSDR_DATAL_PPDSDR_DATAL4 (0x10)
2011#define MCF5235_GPIO_PPDSDR_DATAL_PPDSDR_DATAL5 (0x20)
2012#define MCF5235_GPIO_PPDSDR_DATAL_PPDSDR_DATAL6 (0x40)
2013#define MCF5235_GPIO_PPDSDR_DATAL_PPDSDR_DATAL7 (0x80)
2014#define MCF5235_GPIO_PPDSDR_BUSCTL_PPDSDR_BUSCTL0 (0x01)
2015#define MCF5235_GPIO_PPDSDR_BUSCTL_PPDSDR_BUSCTL1 (0x02)
2016#define MCF5235_GPIO_PPDSDR_BUSCTL_PPDSDR_BUSCTL2 (0x04)
2017#define MCF5235_GPIO_PPDSDR_BUSCTL_PPDSDR_BUSCTL3 (0x08)
2018#define MCF5235_GPIO_PPDSDR_BUSCTL_PPDSDR_BUSCTL4 (0x10)
2019#define MCF5235_GPIO_PPDSDR_BUSCTL_PPDSDR_BUSCTL5 (0x20)
2020#define MCF5235_GPIO_PPDSDR_BUSCTL_PPDSDR_BUSCTL6 (0x40)
2021#define MCF5235_GPIO_PPDSDR_BUSCTL_PPDSDR_BUSCTL7 (0x80)
2022#define MCF5235_GPIO_PPDSDR_BS_PPDSDR_BS0 (0x01)
2023#define MCF5235_GPIO_PPDSDR_BS_PPDSDR_BS1 (0x02)
2024#define MCF5235_GPIO_PPDSDR_BS_PPDSDR_BS2 (0x04)
2025#define MCF5235_GPIO_PPDSDR_BS_PPDSDR_BS3 (0x08)
2026#define MCF5235_GPIO_PPDSDR_FECI2C_PPDSDR_FECI2C0 (0x01)
2027#define MCF5235_GPIO_PPDSDR_FECI2C_PPDSDR_FECI2C1 (0x02)
2028#define MCF5235_GPIO_PPDSDR_FECI2C_PPDSDR_FECI2C2 (0x04)
2029#define MCF5235_GPIO_PPDSDR_FECI2C_PPDSDR_FECI2C3 (0x08)
2030#define MCF5235_GPIO_PPDSDR_CS_PPDSDR_CS1 (0x02)
2031#define MCF5235_GPIO_PPDSDR_CS_PPDSDR_CS2 (0x04)
2032#define MCF5235_GPIO_PPDSDR_CS_PPDSDR_CS3 (0x08)
2033#define MCF5235_GPIO_PPDSDR_CS_PPDSDR_CS4 (0x10)
2034#define MCF5235_GPIO_PPDSDR_CS_PPDSDR_CS5 (0x20)
2035#define MCF5235_GPIO_PPDSDR_CS_PPDSDR_CS6 (0x40)
2036#define MCF5235_GPIO_PPDSDR_CS_PPDSDR_CS7 (0x80)
2037#define MCF5235_GPIO_PPDSDR_SDRAM_PPDSDR_SDRAM0 (0x01)
2038#define MCF5235_GPIO_PPDSDR_SDRAM_PPDSDR_SDRAM1 (0x02)
2039#define MCF5235_GPIO_PPDSDR_SDRAM_PPDSDR_SDRAM2 (0x04)
2040#define MCF5235_GPIO_PPDSDR_SDRAM_PPDSDR_SDRAM3 (0x08)
2041#define MCF5235_GPIO_PPDSDR_SDRAM_PPDSDR_SDRAM4 (0x10)
2042#define MCF5235_GPIO_PPDSDR_SDRAM_PPDSDR_SDRAM5 (0x20)
2043#define MCF5235_GPIO_PPDSDR_SDRAM_PPDSDR_SDRAM6 (0x40)
2044#define MCF5235_GPIO_PPDSDR_SDRAM_PPDSDR_SDRAM7 (0x80)
2045#define MCF5235_GPIO_PPDSDR_UARTH_PPDSDR_UARTH0 (0x01)
2046#define MCF5235_GPIO_PPDSDR_UARTH_PPDSDR_UARTH1 (0x02)
2047#define MCF5235_GPIO_PPDSDR_UARTL_PPDSDR_UARTL0 (0x01)
2048#define MCF5235_GPIO_PPDSDR_UARTL_PPDSDR_UARTL1 (0x02)
2049#define MCF5235_GPIO_PPDSDR_UARTL_PPDSDR_UARTL2 (0x04)
2050#define MCF5235_GPIO_PPDSDR_UARTL_PPDSDR_UARTL3 (0x08)
2051#define MCF5235_GPIO_PPDSDR_UARTL_PPDSDR_UARTL4 (0x10)
2052#define MCF5235_GPIO_PPDSDR_UARTL_PPDSDR_UARTL5 (0x20)
2053#define MCF5235_GPIO_PPDSDR_UARTL_PPDSDR_UARTL6 (0x40)
2054#define MCF5235_GPIO_PPDSDR_UARTL_PPDSDR_UARTL7 (0x80)
2055#define MCF5235_GPIO_PPDSDR_QSPI_PPDSDR_QSPI0 (0x01)
2056#define MCF5235_GPIO_PPDSDR_QSPI_PPDSDR_QSPI1 (0x02)
2057#define MCF5235_GPIO_PPDSDR_QSPI_PPDSDR_QSPI2 (0x04)
2058#define MCF5235_GPIO_PPDSDR_QSPI_PPDSDR_QSPI3 (0x08)
2059#define MCF5235_GPIO_PPDSDR_QSPI_PPDSDR_QSPI4 (0x10)
2060#define MCF5235_GPIO_PPDSDR_TIMER_PPDSDR_TIMER0 (0x01)
2061#define MCF5235_GPIO_PPDSDR_TIMER_PPDSDR_TIMER1 (0x02)
2062#define MCF5235_GPIO_PPDSDR_TIMER_PPDSDR_TIMER2 (0x04)
2063#define MCF5235_GPIO_PPDSDR_TIMER_PPDSDR_TIMER3 (0x08)
2064#define MCF5235_GPIO_PPDSDR_TIMER_PPDSDR_TIMER4 (0x10)
2065#define MCF5235_GPIO_PPDSDR_TIMER_PPDSDR_TIMER5 (0x20)
2066#define MCF5235_GPIO_PPDSDR_TIMER_PPDSDR_TIMER6 (0x40)
2067#define MCF5235_GPIO_PPDSDR_TIMER_PPDSDR_TIMER7 (0x80)
2068#define MCF5235_GPIO_PPDSDR_ETPU_PPDSDR_ETPU0 (0x01)
2069#define MCF5235_GPIO_PPDSDR_ETPU_PPDSDR_ETPU1 (0x02)
2070#define MCF5235_GPIO_PPDSDR_ETPU_PPDSDR_ETPU2 (0x04)
2071#define MCF5235_GPIO_PCLRR_ADDR_PCLRR_ADDR5 (0x20)
2072#define MCF5235_GPIO_PCLRR_ADDR_PCLRR_ADDR6 (0x40)
2073#define MCF5235_GPIO_PCLRR_ADDR_PCLRR_ADDR7 (0x80)
2074#define MCF5235_GPIO_PCLRR_DATAH_PCLRR_DATAH0 (0x01)
2075#define MCF5235_GPIO_PCLRR_DATAH_PCLRR_DATAH1 (0x02)
2076#define MCF5235_GPIO_PCLRR_DATAH_PCLRR_DATAH2 (0x04)
2077#define MCF5235_GPIO_PCLRR_DATAH_PCLRR_DATAH3 (0x08)
2078#define MCF5235_GPIO_PCLRR_DATAH_PCLRR_DATAH4 (0x10)
2079#define MCF5235_GPIO_PCLRR_DATAH_PCLRR_DATAH5 (0x20)
2080#define MCF5235_GPIO_PCLRR_DATAH_PCLRR_DATAH6 (0x40)
2081#define MCF5235_GPIO_PCLRR_DATAH_PCLRR_DATAH7 (0x80)
2082#define MCF5235_GPIO_PCLRR_DATAL_PCLRR_DATAL0 (0x01)
2083#define MCF5235_GPIO_PCLRR_DATAL_PCLRR_DATAL1 (0x02)
2084#define MCF5235_GPIO_PCLRR_DATAL_PCLRR_DATAL2 (0x04)
2085#define MCF5235_GPIO_PCLRR_DATAL_PCLRR_DATAL3 (0x08)
2086#define MCF5235_GPIO_PCLRR_DATAL_PCLRR_DATAL4 (0x10)
2087#define MCF5235_GPIO_PCLRR_DATAL_PCLRR_DATAL5 (0x20)
2088#define MCF5235_GPIO_PCLRR_DATAL_PCLRR_DATAL6 (0x40)
2089#define MCF5235_GPIO_PCLRR_DATAL_PCLRR_DATAL7 (0x80)
2090#define MCF5235_GPIO_PCLRR_BUSCTL_PCLRR_BUSCTL0 (0x01)
2091#define MCF5235_GPIO_PCLRR_BUSCTL_PCLRR_BUSCTL1 (0x02)
2092#define MCF5235_GPIO_PCLRR_BUSCTL_PCLRR_BUSCTL2 (0x04)
2093#define MCF5235_GPIO_PCLRR_BUSCTL_PCLRR_BUSCTL3 (0x08)
2094#define MCF5235_GPIO_PCLRR_BUSCTL_PCLRR_BUSCTL4 (0x10)
2095#define MCF5235_GPIO_PCLRR_BUSCTL_PCLRR_BUSCTL5 (0x20)
2096#define MCF5235_GPIO_PCLRR_BUSCTL_PCLRR_BUSCTL6 (0x40)
2097#define MCF5235_GPIO_PCLRR_BUSCTL_PCLRR_BUSCTL7 (0x80)
2098#define MCF5235_GPIO_PCLRR_BS_PCLRR_BS0 (0x01)
2099#define MCF5235_GPIO_PCLRR_BS_PCLRR_BS1 (0x02)
2100#define MCF5235_GPIO_PCLRR_BS_PCLRR_BS2 (0x04)
2101#define MCF5235_GPIO_PCLRR_BS_PCLRR_BS3 (0x08)
2102#define MCF5235_GPIO_PCLRR_CS_PCLRR_CS1 (0x02)
2103#define MCF5235_GPIO_PCLRR_CS_PCLRR_CS2 (0x04)
2104#define MCF5235_GPIO_PCLRR_CS_PCLRR_CS3 (0x08)
2105#define MCF5235_GPIO_PCLRR_CS_PCLRR_CS4 (0x10)
2106#define MCF5235_GPIO_PCLRR_CS_PCLRR_CS5 (0x20)
2107#define MCF5235_GPIO_PCLRR_CS_PCLRR_CS6 (0x40)
2108#define MCF5235_GPIO_PCLRR_CS_PCLRR_CS7 (0x80)*/
2109#define MCF5235_GPIO_PCLRR_SDRAM_PCLRR_SDRAM0 (0x01)
2110#define MCF5235_GPIO_PCLRR_SDRAM_PCLRR_SDRAM1 (0x02)
2111#define MCF5235_GPIO_PCLRR_SDRAM_PCLRR_SDRAM2 (0x04)
2112#define MCF5235_GPIO_PCLRR_SDRAM_PCLRR_SDRAM3 (0x08)
2113#define MCF5235_GPIO_PCLRR_SDRAM_PCLRR_SDRAM4 (0x10)
2114#define MCF5235_GPIO_PCLRR_SDRAM_PCLRR_SDRAM5 (0x20)
2115#define MCF5235_GPIO_PCLRR_FECI2C_PCLRR_FECI2C0 (0x01)
2116#define MCF5235_GPIO_PCLRR_FECI2C_PCLRR_FECI2C1 (0x02)
2117#define MCF5235_GPIO_PCLRR_FECI2C_PCLRR_FECI2C2 (0x04)
2118#define MCF5235_GPIO_PCLRR_FECI2C_PCLRR_FECI2C3 (0x08)
2119#define MCF5235_GPIO_PCLRR_UARTH_PCLRR_UARTH0 (0x01)
2120#define MCF5235_GPIO_PCLRR_UARTH_PCLRR_UARTH1 (0x02)
2121#define MCF5235_GPIO_PCLRR_UARTL_PCLRR_UARTL0 (0x01)
2122#define MCF5235_GPIO_PCLRR_UARTL_PCLRR_UARTL1 (0x02)
2123#define MCF5235_GPIO_PCLRR_UARTL_PCLRR_UARTL2 (0x04)
2124#define MCF5235_GPIO_PCLRR_UARTL_PCLRR_UARTL3 (0x08)
2125#define MCF5235_GPIO_PCLRR_UARTL_PCLRR_UARTL4 (0x10)
2126#define MCF5235_GPIO_PCLRR_UARTL_PCLRR_UARTL5 (0x20)
2127#define MCF5235_GPIO_PCLRR_UARTL_PCLRR_UARTL6 (0x40)
2128#define MCF5235_GPIO_PCLRR_UARTL_PCLRR_UARTL7 (0x80)
2129#define MCF5235_GPIO_PCLRR_QSPI_PCLRR_QSPI0 (0x01)
2130#define MCF5235_GPIO_PCLRR_QSPI_PCLRR_QSPI1 (0x02)
2131#define MCF5235_GPIO_PCLRR_QSPI_PCLRR_QSPI2 (0x04)
2132#define MCF5235_GPIO_PCLRR_QSPI_PCLRR_QSPI3 (0x08)
2133#define MCF5235_GPIO_PCLRR_QSPI_PCLRR_QSPI4 (0x10)
2134#define MCF5235_GPIO_PCLRR_TIMER_PCLRR_TIMER0 (0x01)
2135#define MCF5235_GPIO_PCLRR_TIMER_PCLRR_TIMER1 (0x02)
2136#define MCF5235_GPIO_PCLRR_TIMER_PCLRR_TIMER2 (0x04)
2137#define MCF5235_GPIO_PCLRR_TIMER_PCLRR_TIMER3 (0x08)
2138#define MCF5235_GPIO_PCLRR_TIMER_PCLRR_TIMER4 (0x10)
2139#define MCF5235_GPIO_PCLRR_TIMER_PCLRR_TIMER5 (0x20)
2140#define MCF5235_GPIO_PCLRR_TIMER_PCLRR_TIMER6 (0x40)
2141#define MCF5235_GPIO_PCLRR_TIMER_PCLRR_TIMER7 (0x80)
2142#define MCF5235_GPIO_PCLRR_ETPU_PCLRR_ETPU0 (0x01)
2143#define MCF5235_GPIO_PCLRR_ETPU_PCLRR_ETPU1 (0x02)
2144#define MCF5235_GPIO_PCLRR_ETPU_PCLRR_ETPU2 (0x04)
2145#define MCF5235_GPIO_PAR_AD_PAR_DATAL (0x01)
2146#define MCF5235_GPIO_PAR_AD_PAR_ADDR21 (0x20)
2147#define MCF5235_GPIO_PAR_AD_PAR_ADDR22 (0x40)
2148#define MCF5235_GPIO_PAR_AD_PAR_ADDR23 (0x80)
2149#define MCF5235_GPIO_PAR_BUSCTL_PAR_TIP(x) (((x)&0x0003)<<0)
2150#define MCF5235_GPIO_PAR_BUSCTL_PAR_TS(x) (((x)&0x0003)<<2)
2151#define MCF5235_GPIO_PAR_BUSCTL_PAR_TSIZ0 (0x0010)
2152#define MCF5235_GPIO_PAR_BUSCTL_PAR_TSIZ1 (0x0040)
2153#define MCF5235_GPIO_PAR_BUSCTL_PAR_RWB (0x0100)
2154#define MCF5235_GPIO_PAR_BUSCTL_PAR_TEA(x) (((x)&0x0003)<<10)
2155#define MCF5235_GPIO_PAR_BUSCTL_PAR_TA (0x1000)
2156#define MCF5235_GPIO_PAR_BUSCTL_PAR_OE (0x4000)
2157#define MCF5235_GPIO_PAR_BUSCTL_PAR_TEA_GPIO (0x0000)
2158#define MCF5235_GPIO_PAR_BUSCTL_PAR_TEA_DMA (0x0800)
2159#define MCF5235_GPIO_PAR_BUSCTL_PAR_TEA_TEA (0x0C00)
2160#define MCF5235_GPIO_PAR_BUSCTL_PAR_TS_GPIO (0x0000)
2161#define MCF5235_GPIO_PAR_BUSCTL_PAR_TS_DMA (0x0080)
2162#define MCF5235_GPIO_PAR_BUSCTL_PAR_TS_TS (0x00C0)
2163#define MCF5235_GPIO_PAR_BUSCTL_PAR_TIP_GPIO (0x0000)
2164#define MCF5235_GPIO_PAR_BUSCTL_PAR_TIP_DMA (0x0002)
2165#define MCF5235_GPIO_PAR_BUSCTL_PAR_TIP_TEA (0x0003)
2166#define MCF5235_GPIO_PAR_BS_PAR_BS0 (0x01)
2167#define MCF5235_GPIO_PAR_BS_PAR_BS1 (0x02)
2168#define MCF5235_GPIO_PAR_BS_PAR_BS2 (0x04)
2169#define MCF5235_GPIO_PAR_BS_PAR_BS3 (0x08)
2170#define MCF5235_GPIO_PAR_CS_PAR_CS1 (0x02)
2171#define MCF5235_GPIO_PAR_CS_PAR_CS2 (0x04)
2172#define MCF5235_GPIO_PAR_CS_PAR_CS3 (0x08)
2173#define MCF5235_GPIO_PAR_CS_PAR_CS4 (0x10)
2174#define MCF5235_GPIO_PAR_CS_PAR_CS5 (0x20)
2175#define MCF5235_GPIO_PAR_CS_PAR_CS6 (0x40)
2176#define MCF5235_GPIO_PAR_CS_PAR_CS7 (0x80)
2177#define MCF5235_GPIO_PAR_SDRAM_PAR_SDCS0 (0x01)
2178#define MCF5235_GPIO_PAR_SDRAM_PAR_SDCS1 (0x02)
2179#define MCF5235_GPIO_PAR_SDRAM_PAR_SCKE (0x04)
2180#define MCF5235_GPIO_PAR_SDRAM_PAR_SRAS (0x08)
2181#define MCF5235_GPIO_PAR_SDRAM_PAR_SCAS (0x10)
2182#define MCF5235_GPIO_PAR_SDRAM_PAR_SDWE (0x20)
2183#define MCF5235_GPIO_PAR_SDRAM_PAR_CSSDCS(x) (((x)&0x03)<<6)
2184#define MCF5235_GPIO_PAR_FECI2C_PAR_SDA(x) (((x)&0x03)<<0)
2185#define MCF5235_GPIO_PAR_FECI2C_PAR_SCL(x) (((x)&0x03)<<2)
2186#define MCF5235_GPIO_PAR_FECI2C_PAR_EMDIO(x) (((x)&0x03)<<4)
2187#define MCF5235_GPIO_PAR_FECI2C_PAR_EMDC(x) (((x)&0x03)<<6)
2188#define MCF5235_GPIO_PAR_FECI2C_PAR_EMDC_GPIO (0x00)
2189#define MCF5235_GPIO_PAR_FECI2C_PAR_EMDC_UART2 (0x40)
2190#define MCF5235_GPIO_PAR_FECI2C_PAR_EMDC_I2C (0x80)
2191#define MCF5235_GPIO_PAR_FECI2C_PAR_EMDC_FEC (0xC0)
2192#define MCF5235_GPIO_PAR_FECI2C_PAR_EMDIO_GPIO (0x00)
2193#define MCF5235_GPIO_PAR_FECI2C_PAR_EMDIO_UART2 (0x10)
2194#define MCF5235_GPIO_PAR_FECI2C_PAR_EMDIO_I2C (0x20)
2195#define MCF5235_GPIO_PAR_FECI2C_PAR_EMDIO_FEC (0x30)
2196#define MCF5235_GPIO_PAR_FECI2C_PAR_SCL_GPIO (0x00)
2197#define MCF5235_GPIO_PAR_FECI2C_PAR_SCL_FLEX (0x08)
2198#define MCF5235_GPIO_PAR_FECI2C_PAR_SCL_I2C (0x0C)
2199#define MCF5235_GPIO_PAR_FECI2C_PAR_SDA_GPIO (0x00)
2200#define MCF5235_GPIO_PAR_FECI2C_PAR_SDA_FLEX (0x02)
2201#define MCF5235_GPIO_PAR_FECI2C_PAR_SDA_I2C (0x03)
2202#define MCF5235_GPIO_PAR_UART_PAR_U0RTS (0x0001)
2203#define MCF5235_GPIO_PAR_UART_PAR_U0CTS (0x0002)
2204#define MCF5235_GPIO_PAR_UART_PAR_U0TXD (0x0004)
2205#define MCF5235_GPIO_PAR_UART_PAR_U0RXD (0x0008)
2206#define MCF5235_GPIO_PAR_UART_PAR_U1RTS(x) (((x)&0x0003)<<4)
2207#define MCF5235_GPIO_PAR_UART_PAR_U1CTS(x) (((x)&0x0003)<<6)
2208#define MCF5235_GPIO_PAR_UART_PAR_U1TXD(x) (((x)&0x0003)<<8)
2209#define MCF5235_GPIO_PAR_UART_PAR_U1RXD(x) (((x)&0x0003)<<10)
2210#define MCF5235_GPIO_PAR_UART_PAR_U2TXD (0x1000)
2211#define MCF5235_GPIO_PAR_UART_PAR_U2RXD (0x2000)
2212#define MCF5235_GPIO_PAR_UART_PAR_CAN1EN (0x4000)
2213#define MCF5235_GPIO_PAR_UART_PAR_DREQ2 (0x8000)
2214#define MCF5235_GPIO_PAR_UART_PAR_U1RXD_GPIO (0x0000)
2215#define MCF5235_GPIO_PAR_UART_PAR_U1RXD_FLEX (0x0800)
2216#define MCF5235_GPIO_PAR_UART_PAR_U1RXD_UART1 (0x0C00)
2217#define MCF5235_GPIO_PAR_UART_PAR_U1TXD_GPIO (0x0000)
2218#define MCF5235_GPIO_PAR_UART_PAR_U1TXD_FLEX (0x0200)
2219#define MCF5235_GPIO_PAR_UART_PAR_U1TXD_UART1 (0x0300)
2220#define MCF5235_GPIO_PAR_UART_PAR_U1CTS_GPIO (0x0000)
2221#define MCF5235_GPIO_PAR_UART_PAR_U1CTS_UART2 (0x0080)
2222#define MCF5235_GPIO_PAR_UART_PAR_U1CTS_UART1 (0x00C0)
2223#define MCF5235_GPIO_PAR_UART_PAR_U1RTS_GPIO (0x0000)
2224#define MCF5235_GPIO_PAR_UART_PAR_U1RTS_UART2 (0x0020)
2225#define MCF5235_GPIO_PAR_UART_PAR_U1RTS_UART1 (0x0030)
2226#define MCF5235_GPIO_PAR_QSPI_PAR_SCK(x) (((x)&0x03)<<0)
2227#define MCF5235_GPIO_PAR_QSPI_PAR_DOUT (0x04)
2228#define MCF5235_GPIO_PAR_QSPI_PAR_DIN(x) (((x)&0x03)<<3)
2229#define MCF5235_GPIO_PAR_QSPI_PAR_PCS0 (0x20)
2230#define MCF5235_GPIO_PAR_QSPI_PAR_PCS1(x) (((x)&0x03)<<6)
2231#define MCF5235_GPIO_PAR_QSPI_PAR_PCS1_GPIO (0x00)
2232#define MCF5235_GPIO_PAR_QSPI_PAR_PCS1_SDRAMC (0x80)
2233#define MCF5235_GPIO_PAR_QSPI_PAR_PCS1_QSPI (0xC0)
2234#define MCF5235_GPIO_PAR_QSPI_PAR_DIN_GPIO (0x00)
2235#define MCF5235_GPIO_PAR_QSPI_PAR_DIN_I2C (0x10)
2236#define MCF5235_GPIO_PAR_QSPI_PAR_DIN_QSPI (0x1C)
2237#define MCF5235_GPIO_PAR_QSPI_PAR_SCK_GPIO (0x00)
2238#define MCF5235_GPIO_PAR_QSPI_PAR_SCK_I2C (0x02)
2239#define MCF5235_GPIO_PAR_QSPI_PAR_SCK_QSPI (0x03)
2240#define MCF5235_GPIO_PAR_TIMER_PAR_T0OUT(x) (((x)&0x0003)<<0)
2241#define MCF5235_GPIO_PAR_TIMER_PAR_T1OUT(x) (((x)&0x0003)<<2)
2242#define MCF5235_GPIO_PAR_TIMER_PAR_T2OUT(x) (((x)&0x0003)<<4)
2243#define MCF5235_GPIO_PAR_TIMER_PAR_T3OUT(x) (((x)&0x0003)<<6)
2244#define MCF5235_GPIO_PAR_TIMER_PAR_T0IN(x) (((x)&0x0003)<<8)
2245#define MCF5235_GPIO_PAR_TIMER_PAR_T1IN(x) (((x)&0x0003)<<10)
2246#define MCF5235_GPIO_PAR_TIMER_PAR_T2IN(x) (((x)&0x0003)<<12)
2247#define MCF5235_GPIO_PAR_TIMER_PAR_T3IN(x) (((x)&0x0003)<<14)
2248#define MCF5235_GPIO_PAR_TIMER_PAR_T3IN_GPIO (0x0000)
2249#define MCF5235_GPIO_PAR_TIMER_PAR_T3IN_QSPI (0x4000)
2250#define MCF5235_GPIO_PAR_TIMER_PAR_T3IN_UART2 (0x8000)
2251#define MCF5235_GPIO_PAR_TIMER_PAR_T3IN_T3IN (0xC000)
2252#define MCF5235_GPIO_PAR_TIMER_PAR_T2IN_GPIO (0x0000)
2253#define MCF5235_GPIO_PAR_TIMER_PAR_T2IN_T2OUT (0x1000)
2254#define MCF5235_GPIO_PAR_TIMER_PAR_T2IN_DMA (0x2000)
2255#define MCF5235_GPIO_PAR_TIMER_PAR_T2IN_T2IN (0x3000)
2256#define MCF5235_GPIO_PAR_TIMER_PAR_T1IN_GPIO (0x0000)
2257#define MCF5235_GPIO_PAR_TIMER_PAR_T1IN_T1OUT (0x0400)
2258#define MCF5235_GPIO_PAR_TIMER_PAR_T1IN_DMA (0x0800)
2259#define MCF5235_GPIO_PAR_TIMER_PAR_T1IN_T1IN (0x0C00)
2260#define MCF5235_GPIO_PAR_TIMER_PAR_T0IN_GPIO (0x0000)
2261#define MCF5235_GPIO_PAR_TIMER_PAR_T0IN_DMA (0x0200)
2262#define MCF5235_GPIO_PAR_TIMER_PAR_T0IN_T0IN (0x0300)
2263#define MCF5235_GPIO_PAR_TIMER_PAR_T3OUT_GPIO (0x0000)
2264#define MCF5235_GPIO_PAR_TIMER_PAR_T3OUT_QSPI (0x0040)
2265#define MCF5235_GPIO_PAR_TIMER_PAR_T3OUT_UART2 (0x0080)
2266#define MCF5235_GPIO_PAR_TIMER_PAR_T3OUT_T3OUT (0x00C0)
2267#define MCF5235_GPIO_PAR_TIMER_PAR_T2OUT_GPIO (0x0000)
2268#define MCF5235_GPIO_PAR_TIMER_PAR_T2OUT_DMA (0x0020)
2269#define MCF5235_GPIO_PAR_TIMER_PAR_T2OUT_T2OUT (0x0030)
2270#define MCF5235_GPIO_PAR_TIMER_PAR_T1OUT_GPIO (0x0000)
2271#define MCF5235_GPIO_PAR_TIMER_PAR_T1OUT_DMA (0x0008)
2272#define MCF5235_GPIO_PAR_TIMER_PAR_T1OUT_T1OUT (0x000C)
2273#define MCF5235_GPIO_PAR_TIMER_PAR_T0OUT_GPIO (0x0000)
2274#define MCF5235_GPIO_PAR_TIMER_PAR_T0OUT_DMA (0x0002)
2275#define MCF5235_GPIO_PAR_TIMER_PAR_T0OUT_T0OUT (0x0003)
2276#define MCF5235_GPIO_PAR_ETPU_PAR_LTPU_ODIS (0x01)
2277#define MCF5235_GPIO_PAR_ETPU_PAR_UTPU_ODIS (0x02)
2278#define MCF5235_GPIO_PAR_ETPU_PAR_TCRCLK (0x04)
2279#define MCF5235_GPIO_DSCR_EIM_DSCR_EIM0 (0x01)
2280#define MCF5235_GPIO_DSCR_EIM_DSCR_EIM1 (0x10)
2281#define MCF5235_GPIO_DSCR_ETPU_DSCR_ETPU_7_0 (0x01)
2282#define MCF5235_GPIO_DSCR_ETPU_DSCR_ETPU_15_8 (0x04)
2283#define MCF5235_GPIO_DSCR_ETPU_DSCR_ETPU_23_16 (0x10)
2284#define MCF5235_GPIO_DSCR_ETPU_DSCR_ETPU_31_24 (0x40)
2285#define MCF5235_GPIO_DSCR_FECI2C_DSCR_I2C (0x01)
2286#define MCF5235_GPIO_DSCR_FECI2C_DSCR_FEC (0x10)
2287#define MCF5235_GPIO_DSCR_UART_DSCR_UART0 (0x01)
2288#define MCF5235_GPIO_DSCR_UART_DSCR_UART1 (0x04)
2289#define MCF5235_GPIO_DSCR_UART_DSCR_UART2 (0x10)
2290#define MCF5235_GPIO_DSCR_UART_DSCR_IRQ (0x40)
2291#define MCF5235_GPIO_DSCR_QSPI_DSCR_QSPI (0x01)*/
2292#define MCF5235_GPIO_DSCR_TIMER_DSCR_TIMER (0x01)
2293
2294/*********************************************************************
2295*
2296* I2C Module (I2C)
2297*
2298*********************************************************************/
2299
2300/* Register read/write macros */
2301#define MCF5235_I2C_I2AR (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000300)))
2302#define MCF5235_I2C_I2FDR (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000304)))
2303#define MCF5235_I2C_I2CR (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000308)))
2304#define MCF5235_I2C_I2SR (*(vuint8 *)((uintptr_t)__IPSBAR + (0x00030C)))
2305#define MCF5235_I2C_I2DR (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000310)))
2306#define MCF5235_I2C_I2ICR (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000320)))
2307
2308/* Bit definitions and macros for MCF5235_I2C_I2AR */
2309#define MCF5235_I2C_I2AR_ADR(x) (((x)&0x7F)<<1)
2310#define MCF5235_I2C_I2FDR_IC(x) (((x)&0x3F)<<0)
2311#define MCF5235_I2C_I2CR_RSTA (0x04)
2312#define MCF5235_I2C_I2CR_TXAK (0x08)
2313#define MCF5235_I2C_I2CR_MTX (0x10)
2314#define MCF5235_I2C_I2CR_MSTA (0x20)
2315#define MCF5235_I2C_I2CR_IIEN (0x40)
2316#define MCF5235_I2C_I2CR_IEN (0x80)
2317#define MCF5235_I2C_I2SR_RXAK (0x01)
2318#define MCF5235_I2C_I2SR_IIF (0x02)
2319#define MCF5235_I2C_I2SR_SRW (0x04)
2320#define MCF5235_I2C_I2SR_IAL (0x10)
2321#define MCF5235_I2C_I2SR_IBB (0x20)
2322#define MCF5235_I2C_I2SR_IAAS (0x40)
2323#define MCF5235_I2C_I2SR_ICF (0x80)
2324#define MCF5235_I2C_I2ICR_IE (0x01)
2325#define MCF5235_I2C_I2ICR_RE (0x02)
2326#define MCF5235_I2C_I2ICR_TE (0x04)
2327#define MCF5235_I2C_I2ICR_BNBE (0x08)
2328
2329/*********************************************************************
2330*
2331* Interrupt Controller 0 (INTC0)
2332*
2333*********************************************************************/
2334
2335/* Register read/write macros */
2336#define MCF5235_INTC0_IPRH (*(vuint32*)((uintptr_t)__IPSBAR + (0x000C00)))
2337#define MCF5235_INTC0_IPRL (*(vuint32*)((uintptr_t)__IPSBAR + (0x000C04)))
2338#define MCF5235_INTC0_IMRH (*(vuint32*)((uintptr_t)__IPSBAR + (0x000C08)))
2339#define MCF5235_INTC0_IMRL (*(vuint32*)((uintptr_t)__IPSBAR + (0x000C0C)))
2340#define MCF5235_INTC0_INTFRCH (*(vuint32*)((uintptr_t)__IPSBAR + (0x000C10)))
2341#define MCF5235_INTC0_INTFRCL (*(vuint32*)((uintptr_t)__IPSBAR + (0x000C14)))
2342#define MCF5235_INTC0_IRLR (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C18)))
2343#define MCF5235_INTC0_IACKLPR (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C19)))
2344#define MCF5235_INTC0_ICR0 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C40)))
2345#define MCF5235_INTC0_ICR1 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C41)))
2346#define MCF5235_INTC0_ICR2 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C42)))
2347#define MCF5235_INTC0_ICR3 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C43)))
2348#define MCF5235_INTC0_ICR4 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C44)))
2349#define MCF5235_INTC0_ICR5 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C45)))
2350#define MCF5235_INTC0_ICR6 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C46)))
2351#define MCF5235_INTC0_ICR7 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C47)))
2352#define MCF5235_INTC0_ICR8 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C48)))
2353#define MCF5235_INTC0_ICR9 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C49)))
2354#define MCF5235_INTC0_ICR10 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C4A)))
2355#define MCF5235_INTC0_ICR11 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C4B)))
2356#define MCF5235_INTC0_ICR12 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C4C)))
2357#define MCF5235_INTC0_ICR13 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C4D)))
2358#define MCF5235_INTC0_ICR14 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C4E)))
2359#define MCF5235_INTC0_ICR15 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C4F)))
2360#define MCF5235_INTC0_ICR16 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C50)))
2361#define MCF5235_INTC0_ICR17 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C51)))
2362#define MCF5235_INTC0_ICR18 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C52)))
2363#define MCF5235_INTC0_ICR19 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C53)))
2364#define MCF5235_INTC0_ICR20 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C54)))
2365#define MCF5235_INTC0_ICR21 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C55)))
2366#define MCF5235_INTC0_ICR22 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C56)))
2367#define MCF5235_INTC0_ICR23 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C57)))
2368#define MCF5235_INTC0_ICR24 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C58)))
2369#define MCF5235_INTC0_ICR25 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C59)))
2370#define MCF5235_INTC0_ICR26 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C5A)))
2371#define MCF5235_INTC0_ICR27 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C5B)))
2372#define MCF5235_INTC0_ICR28 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C5C)))
2373#define MCF5235_INTC0_ICR29 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C5D)))
2374#define MCF5235_INTC0_ICR30 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C5E)))
2375#define MCF5235_INTC0_ICR31 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C5F)))
2376#define MCF5235_INTC0_ICR32 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C60)))
2377#define MCF5235_INTC0_ICR33 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C61)))
2378#define MCF5235_INTC0_ICR34 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C62)))
2379#define MCF5235_INTC0_ICR35 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C63)))
2380#define MCF5235_INTC0_ICR36 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C64)))
2381#define MCF5235_INTC0_ICR37 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C65)))
2382#define MCF5235_INTC0_ICR38 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C66)))
2383#define MCF5235_INTC0_ICR39 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C67)))
2384#define MCF5235_INTC0_ICR40 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C68)))
2385#define MCF5235_INTC0_ICR41 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C69)))
2386#define MCF5235_INTC0_ICR42 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C6A)))
2387#define MCF5235_INTC0_ICR43 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C6B)))
2388#define MCF5235_INTC0_ICR44 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C6C)))
2389#define MCF5235_INTC0_ICR45 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C6D)))
2390#define MCF5235_INTC0_ICR46 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C6E)))
2391#define MCF5235_INTC0_ICR47 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C6F)))
2392#define MCF5235_INTC0_ICR48 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C70)))
2393#define MCF5235_INTC0_ICR49 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C71)))
2394#define MCF5235_INTC0_ICR50 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C72)))
2395#define MCF5235_INTC0_ICR51 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C73)))
2396#define MCF5235_INTC0_ICR52 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C74)))
2397#define MCF5235_INTC0_ICR53 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C75)))
2398#define MCF5235_INTC0_ICR54 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C76)))
2399#define MCF5235_INTC0_ICR55 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C77)))
2400#define MCF5235_INTC0_ICR56 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C78)))
2401#define MCF5235_INTC0_ICR57 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C79)))
2402#define MCF5235_INTC0_ICR58 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C7A)))
2403#define MCF5235_INTC0_ICR59 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C7B)))
2404#define MCF5235_INTC0_ICR60 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C7C)))
2405#define MCF5235_INTC0_ICR61 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C7D)))
2406#define MCF5235_INTC0_ICR62 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C7E)))
2407#define MCF5235_INTC0_ICR63 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C7F)))
2408#define MCF5235_INTC0_ICRn(x) (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000C40+((x)*0x001))))
2409#define MCF5235_INTC0_SWIACK (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000CE0)))
2410#define MCF5235_INTC0_L1IACK (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000CE4)))
2411#define MCF5235_INTC0_L2IACK (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000CE8)))
2412#define MCF5235_INTC0_L3IACK (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000CEC)))
2413#define MCF5235_INTC0_L4IACK (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000CF0)))
2414#define MCF5235_INTC0_L5IACK (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000CF4)))
2415#define MCF5235_INTC0_L6IACK (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000CF8)))
2416#define MCF5235_INTC0_L7IACK (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000CFC)))
2417#define MCF5235_INTC0_LnIACK(x) (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000CE4+((x)*0x004))))
2418#define MCF5235_INTC1_IPRH (*(vuint32*)((uintptr_t)__IPSBAR + (0x000D00)))
2419#define MCF5235_INTC1_IPRL (*(vuint32*)((uintptr_t)__IPSBAR + (0x000D04)))
2420#define MCF5235_INTC1_IMRH (*(vuint32*)((uintptr_t)__IPSBAR + (0x000D08)))
2421#define MCF5235_INTC1_IMRL (*(vuint32*)((uintptr_t)__IPSBAR + (0x000D0C)))
2422#define MCF5235_INTC1_INTFRCH (*(vuint32*)((uintptr_t)__IPSBAR + (0x000D10)))
2423#define MCF5235_INTC1_INTFRCL (*(vuint32*)((uintptr_t)__IPSBAR + (0x000D14)))
2424#define MCF5235_INTC1_IRLR (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D18)))
2425#define MCF5235_INTC1_IACKLPR (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D19)))
2426#define MCF5235_INTC1_ICR0 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D40)))
2427#define MCF5235_INTC1_ICR1 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D41)))
2428#define MCF5235_INTC1_ICR2 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D42)))
2429#define MCF5235_INTC1_ICR3 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D43)))
2430#define MCF5235_INTC1_ICR4 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D44)))
2431#define MCF5235_INTC1_ICR5 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D45)))
2432#define MCF5235_INTC1_ICR6 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D46)))
2433#define MCF5235_INTC1_ICR7 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D47)))
2434#define MCF5235_INTC1_ICR8 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D48)))
2435#define MCF5235_INTC1_ICR9 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D49)))
2436#define MCF5235_INTC1_ICR10 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D4A)))
2437#define MCF5235_INTC1_ICR11 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D4B)))
2438#define MCF5235_INTC1_ICR12 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D4C)))
2439#define MCF5235_INTC1_ICR13 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D4D)))
2440#define MCF5235_INTC1_ICR14 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D4E)))
2441#define MCF5235_INTC1_ICR15 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D4F)))
2442#define MCF5235_INTC1_ICR16 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D50)))
2443#define MCF5235_INTC1_ICR17 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D51)))
2444#define MCF5235_INTC1_ICR18 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D52)))
2445#define MCF5235_INTC1_ICR19 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D53)))
2446#define MCF5235_INTC1_ICR20 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D54)))
2447#define MCF5235_INTC1_ICR21 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D55)))
2448#define MCF5235_INTC1_ICR22 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D56)))
2449#define MCF5235_INTC1_ICR23 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D57)))
2450#define MCF5235_INTC1_ICR24 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D58)))
2451#define MCF5235_INTC1_ICR25 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D59)))
2452#define MCF5235_INTC1_ICR26 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D5A)))
2453#define MCF5235_INTC1_ICR27 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D5B)))
2454#define MCF5235_INTC1_ICR28 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D5C)))
2455#define MCF5235_INTC1_ICR29 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D5D)))
2456#define MCF5235_INTC1_ICR30 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D5E)))
2457#define MCF5235_INTC1_ICR31 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D5F)))
2458#define MCF5235_INTC1_ICR32 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D60)))
2459#define MCF5235_INTC1_ICR33 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D61)))
2460#define MCF5235_INTC1_ICR34 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D62)))
2461#define MCF5235_INTC1_ICR35 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D63)))
2462#define MCF5235_INTC1_ICR36 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D64)))
2463#define MCF5235_INTC1_ICR37 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D65)))
2464#define MCF5235_INTC1_ICR38 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D66)))
2465#define MCF5235_INTC1_ICR39 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D67)))
2466#define MCF5235_INTC1_ICR40 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D68)))
2467#define MCF5235_INTC1_ICR41 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D69)))
2468#define MCF5235_INTC1_ICR42 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D6A)))
2469#define MCF5235_INTC1_ICR43 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D6B)))
2470#define MCF5235_INTC1_ICR44 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D6C)))
2471#define MCF5235_INTC1_ICR45 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D6D)))
2472#define MCF5235_INTC1_ICR46 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D6E)))
2473#define MCF5235_INTC1_ICR47 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D6F)))
2474#define MCF5235_INTC1_ICR48 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D70)))
2475#define MCF5235_INTC1_ICR49 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D71)))
2476#define MCF5235_INTC1_ICR50 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D72)))
2477#define MCF5235_INTC1_ICR51 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D73)))
2478#define MCF5235_INTC1_ICR52 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D74)))
2479#define MCF5235_INTC1_ICR53 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D75)))
2480#define MCF5235_INTC1_ICR54 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D76)))
2481#define MCF5235_INTC1_ICR55 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D77)))
2482#define MCF5235_INTC1_ICR56 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D78)))
2483#define MCF5235_INTC1_ICR57 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D79)))
2484#define MCF5235_INTC1_ICR58 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D7A)))
2485#define MCF5235_INTC1_ICR59 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D7B)))
2486#define MCF5235_INTC1_ICR60 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D7C)))
2487#define MCF5235_INTC1_ICR61 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D7D)))
2488#define MCF5235_INTC1_ICR62 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D7E)))
2489#define MCF5235_INTC1_ICR63 (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D7F)))
2490#define MCF5235_INTC1_ICRn(x) (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000D40+((x)*0x001))))
2491#define MCF5235_INTC1_SWIACK (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000DE0)))
2492#define MCF5235_INTC1_L1IACK (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000DE4)))
2493#define MCF5235_INTC1_L2IACK (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000DE8)))
2494#define MCF5235_INTC1_L3IACK (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000DEC)))
2495#define MCF5235_INTC1_L4IACK (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000DF0)))
2496#define MCF5235_INTC1_L5IACK (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000DF4)))
2497#define MCF5235_INTC1_L6IACK (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000DF8)))
2498#define MCF5235_INTC1_L7IACK (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000DFC)))
2499#define MCF5235_INTC1_LnIACK(x) (*(vuint8 *)((uintptr_t)__IPSBAR + (0x000DE4+((x)*0x004))))
2500
2501/* Bit definitions and macros for MCF5235_INTC0_IPRH */
2502#define MCF5235_INTC0_IPRH_INT32 (0x00000001)
2503#define MCF5235_INTC0_IPRH_INT33 (0x00000002)
2504#define MCF5235_INTC0_IPRH_INT34 (0x00000004)
2505#define MCF5235_INTC0_IPRH_INT35 (0x00000008)
2506#define MCF5235_INTC0_IPRH_INT36 (0x00000010)
2507#define MCF5235_INTC0_IPRH_INT37 (0x00000020)
2508#define MCF5235_INTC0_IPRH_INT38 (0x00000040)
2509#define MCF5235_INTC0_IPRH_INT39 (0x00000080)
2510#define MCF5235_INTC0_IPRH_INT40 (0x00000100)
2511#define MCF5235_INTC0_IPRH_INT41 (0x00000200)
2512#define MCF5235_INTC0_IPRH_INT42 (0x00000400)
2513#define MCF5235_INTC0_IPRH_INT43 (0x00000800)
2514#define MCF5235_INTC0_IPRH_INT44 (0x00001000)
2515#define MCF5235_INTC0_IPRH_INT45 (0x00002000)
2516#define MCF5235_INTC0_IPRH_INT46 (0x00004000)
2517#define MCF5235_INTC0_IPRH_INT47 (0x00008000)
2518#define MCF5235_INTC0_IPRH_INT48 (0x00010000)
2519#define MCF5235_INTC0_IPRH_INT49 (0x00020000)
2520#define MCF5235_INTC0_IPRH_INT50 (0x00040000)
2521#define MCF5235_INTC0_IPRH_INT51 (0x00080000)
2522#define MCF5235_INTC0_IPRH_INT52 (0x00100000)
2523#define MCF5235_INTC0_IPRH_INT53 (0x00200000)
2524#define MCF5235_INTC0_IPRH_INT54 (0x00400000)
2525#define MCF5235_INTC0_IPRH_INT55 (0x00800000)
2526#define MCF5235_INTC0_IPRH_INT56 (0x01000000)
2527#define MCF5235_INTC0_IPRH_INT57 (0x02000000)
2528#define MCF5235_INTC0_IPRH_INT58 (0x04000000)
2529#define MCF5235_INTC0_IPRH_INT59 (0x08000000)
2530#define MCF5235_INTC0_IPRH_INT60 (0x10000000)
2531#define MCF5235_INTC0_IPRH_INT61 (0x20000000)
2532#define MCF5235_INTC0_IPRH_INT62 (0x40000000)
2533#define MCF5235_INTC0_IPRH_INT63 (0x80000000)
2534#define MCF5235_INTC0_IPRL_INT1 (0x00000002)
2535#define MCF5235_INTC0_IPRL_INT2 (0x00000004)
2536#define MCF5235_INTC0_IPRL_INT3 (0x00000008)
2537#define MCF5235_INTC0_IPRL_INT4 (0x00000010)
2538#define MCF5235_INTC0_IPRL_INT5 (0x00000020)
2539#define MCF5235_INTC0_IPRL_INT6 (0x00000040)
2540#define MCF5235_INTC0_IPRL_INT7 (0x00000080)
2541#define MCF5235_INTC0_IPRL_INT8 (0x00000100)
2542#define MCF5235_INTC0_IPRL_INT9 (0x00000200)
2543#define MCF5235_INTC0_IPRL_INT10 (0x00000400)
2544#define MCF5235_INTC0_IPRL_INT11 (0x00000800)
2545#define MCF5235_INTC0_IPRL_INT12 (0x00001000)
2546#define MCF5235_INTC0_IPRL_INT13 (0x00002000)
2547#define MCF5235_INTC0_IPRL_INT14 (0x00004000)
2548#define MCF5235_INTC0_IPRL_INT15 (0x00008000)
2549#define MCF5235_INTC0_IPRL_INT16 (0x00010000)
2550#define MCF5235_INTC0_IPRL_INT17 (0x00020000)
2551#define MCF5235_INTC0_IPRL_INT18 (0x00040000)
2552#define MCF5235_INTC0_IPRL_INT19 (0x00080000)
2553#define MCF5235_INTC0_IPRL_INT20 (0x00100000)
2554#define MCF5235_INTC0_IPRL_INT21 (0x00200000)
2555#define MCF5235_INTC0_IPRL_INT22 (0x00400000)
2556#define MCF5235_INTC0_IPRL_INT23 (0x00800000)
2557#define MCF5235_INTC0_IPRL_INT24 (0x01000000)
2558#define MCF5235_INTC0_IPRL_INT25 (0x02000000)
2559#define MCF5235_INTC0_IPRL_INT26 (0x04000000)
2560#define MCF5235_INTC0_IPRL_INT27 (0x08000000)
2561#define MCF5235_INTC0_IPRL_INT28 (0x10000000)
2562#define MCF5235_INTC0_IPRL_INT29 (0x20000000)
2563#define MCF5235_INTC0_IPRL_INT30 (0x40000000)
2564#define MCF5235_INTC0_IPRL_INT31 (0x80000000)
2565#define MCF5235_INTC0_IMRH_INT32 (0x00000001)
2566#define MCF5235_INTC0_IMRH_INT33 (0x00000002)
2567#define MCF5235_INTC0_IMRH_INT34 (0x00000004)
2568#define MCF5235_INTC0_IMRH_INT35 (0x00000008)
2569#define MCF5235_INTC0_IMRH_INT36 (0x00000010)
2570#define MCF5235_INTC0_IMRH_INT37 (0x00000020)
2571#define MCF5235_INTC0_IMRH_INT38 (0x00000040)
2572#define MCF5235_INTC0_IMRH_INT39 (0x00000080)
2573#define MCF5235_INTC0_IMRH_INT40 (0x00000100)
2574#define MCF5235_INTC0_IMRH_INT41 (0x00000200)
2575#define MCF5235_INTC0_IMRH_INT42 (0x00000400)
2576#define MCF5235_INTC0_IMRH_INT43 (0x00000800)
2577#define MCF5235_INTC0_IMRH_INT44 (0x00001000)
2578#define MCF5235_INTC0_IMRH_INT45 (0x00002000)
2579#define MCF5235_INTC0_IMRH_INT46 (0x00004000)
2580#define MCF5235_INTC0_IMRH_INT47 (0x00008000)
2581#define MCF5235_INTC0_IMRH_INT48 (0x00010000)
2582#define MCF5235_INTC0_IMRH_INT49 (0x00020000)
2583#define MCF5235_INTC0_IMRH_INT50 (0x00040000)
2584#define MCF5235_INTC0_IMRH_INT51 (0x00080000)
2585#define MCF5235_INTC0_IMRH_INT52 (0x00100000)
2586#define MCF5235_INTC0_IMRH_INT53 (0x00200000)
2587#define MCF5235_INTC0_IMRH_INT54 (0x00400000)
2588#define MCF5235_INTC0_IMRH_INT55 (0x00800000)
2589#define MCF5235_INTC0_IMRH_INT56 (0x01000000)
2590#define MCF5235_INTC0_IMRH_INT57 (0x02000000)
2591#define MCF5235_INTC0_IMRH_INT58 (0x04000000)
2592#define MCF5235_INTC0_IMRH_INT59 (0x08000000)
2593#define MCF5235_INTC0_IMRH_INT60 (0x10000000)
2594#define MCF5235_INTC0_IMRH_INT61 (0x20000000)
2595#define MCF5235_INTC0_IMRH_INT62 (0x40000000)
2596#define MCF5235_INTC0_IMRH_INT63 (0x80000000)
2597#define MCF5235_INTC0_IMRL_MASKALL (0x00000001)
2598#define MCF5235_INTC0_IMRL_INT1 (0x00000002)
2599#define MCF5235_INTC0_IMRL_INT2 (0x00000004)
2600#define MCF5235_INTC0_IMRL_INT3 (0x00000008)
2601#define MCF5235_INTC0_IMRL_INT4 (0x00000010)
2602#define MCF5235_INTC0_IMRL_INT5 (0x00000020)
2603#define MCF5235_INTC0_IMRL_INT6 (0x00000040)
2604#define MCF5235_INTC0_IMRL_INT7 (0x00000080)
2605#define MCF5235_INTC0_IMRL_INT8 (0x00000100)
2606#define MCF5235_INTC0_IMRL_INT9 (0x00000200)
2607#define MCF5235_INTC0_IMRL_INT10 (0x00000400)
2608#define MCF5235_INTC0_IMRL_INT11 (0x00000800)
2609#define MCF5235_INTC0_IMRL_INT12 (0x00001000)
2610#define MCF5235_INTC0_IMRL_INT13 (0x00002000)
2611#define MCF5235_INTC0_IMRL_INT14 (0x00004000)
2612#define MCF5235_INTC0_IMRL_INT15 (0x00008000)
2613#define MCF5235_INTC0_IMRL_INT16 (0x00010000)
2614#define MCF5235_INTC0_IMRL_INT17 (0x00020000)
2615#define MCF5235_INTC0_IMRL_INT18 (0x00040000)
2616#define MCF5235_INTC0_IMRL_INT19 (0x00080000)
2617#define MCF5235_INTC0_IMRL_INT20 (0x00100000)
2618#define MCF5235_INTC0_IMRL_INT21 (0x00200000)
2619#define MCF5235_INTC0_IMRL_INT22 (0x00400000)
2620#define MCF5235_INTC0_IMRL_INT23 (0x00800000)
2621#define MCF5235_INTC0_IMRL_INT24 (0x01000000)
2622#define MCF5235_INTC0_IMRL_INT25 (0x02000000)
2623#define MCF5235_INTC0_IMRL_INT26 (0x04000000)
2624#define MCF5235_INTC0_IMRL_INT27 (0x08000000)
2625#define MCF5235_INTC0_IMRL_INT28 (0x10000000)
2626#define MCF5235_INTC0_IMRL_INT29 (0x20000000)
2627#define MCF5235_INTC0_IMRL_INT30 (0x40000000)
2628#define MCF5235_INTC0_IMRL_INT31 (0x80000000)
2629#define MCF5235_INTC0_INTFRCH_INTFRC32 (0x00000001)
2630#define MCF5235_INTC0_INTFRCH_INTFRC33 (0x00000002)
2631#define MCF5235_INTC0_INTFRCH_INTFRC34 (0x00000004)
2632#define MCF5235_INTC0_INTFRCH_INTFRC35 (0x00000008)
2633#define MCF5235_INTC0_INTFRCH_INTFRC36 (0x00000010)
2634#define MCF5235_INTC0_INTFRCH_INTFRC37 (0x00000020)
2635#define MCF5235_INTC0_INTFRCH_INTFRC38 (0x00000040)
2636#define MCF5235_INTC0_INTFRCH_INTFRC39 (0x00000080)
2637#define MCF5235_INTC0_INTFRCH_INTFRC40 (0x00000100)
2638#define MCF5235_INTC0_INTFRCH_INTFRC41 (0x00000200)
2639#define MCF5235_INTC0_INTFRCH_INTFRC42 (0x00000400)
2640#define MCF5235_INTC0_INTFRCH_INTFRC43 (0x00000800)
2641#define MCF5235_INTC0_INTFRCH_INTFRC44 (0x00001000)
2642#define MCF5235_INTC0_INTFRCH_INTFRC45 (0x00002000)
2643#define MCF5235_INTC0_INTFRCH_INTFRC46 (0x00004000)
2644#define MCF5235_INTC0_INTFRCH_INTFRC47 (0x00008000)
2645#define MCF5235_INTC0_INTFRCH_INTFRC48 (0x00010000)
2646#define MCF5235_INTC0_INTFRCH_INTFRC49 (0x00020000)
2647#define MCF5235_INTC0_INTFRCH_INTFRC50 (0x00040000)
2648#define MCF5235_INTC0_INTFRCH_INTFRC51 (0x00080000)
2649#define MCF5235_INTC0_INTFRCH_INTFRC52 (0x00100000)
2650#define MCF5235_INTC0_INTFRCH_INTFRC53 (0x00200000)
2651#define MCF5235_INTC0_INTFRCH_INTFRC54 (0x00400000)
2652#define MCF5235_INTC0_INTFRCH_INTFRC55 (0x00800000)
2653#define MCF5235_INTC0_INTFRCH_INTFRC56 (0x01000000)
2654#define MCF5235_INTC0_INTFRCH_INTFRC57 (0x02000000)
2655#define MCF5235_INTC0_INTFRCH_INTFRC58 (0x04000000)
2656#define MCF5235_INTC0_INTFRCH_INTFRC59 (0x08000000)
2657#define MCF5235_INTC0_INTFRCH_INTFRC60 (0x10000000)
2658#define MCF5235_INTC0_INTFRCH_INTFRC61 (0x20000000)
2659#define MCF5235_INTC0_INTFRCH_INTFRC62 (0x40000000)
2660#define MCF5235_INTC0_INTFRCH_INTFRC63 (0x80000000)
2661#define MCF5235_INTC0_INTFRCL_INTFRC1 (0x00000002)
2662#define MCF5235_INTC0_INTFRCL_INTFRC2 (0x00000004)
2663#define MCF5235_INTC0_INTFRCL_INTFRC3 (0x00000008)
2664#define MCF5235_INTC0_INTFRCL_INTFRC4 (0x00000010)
2665#define MCF5235_INTC0_INTFRCL_INTFRC5 (0x00000020)
2666#define MCF5235_INTC0_INTFRCL_INT6 (0x00000040)
2667#define MCF5235_INTC0_INTFRCL_INT7 (0x00000080)
2668#define MCF5235_INTC0_INTFRCL_INT8 (0x00000100)
2669#define MCF5235_INTC0_INTFRCL_INT9 (0x00000200)
2670#define MCF5235_INTC0_INTFRCL_INT10 (0x00000400)
2671#define MCF5235_INTC0_INTFRCL_INTFRC11 (0x00000800)
2672#define MCF5235_INTC0_INTFRCL_INTFRC12 (0x00001000)
2673#define MCF5235_INTC0_INTFRCL_INTFRC13 (0x00002000)
2674#define MCF5235_INTC0_INTFRCL_INTFRC14 (0x00004000)
2675#define MCF5235_INTC0_INTFRCL_INT15 (0x00008000)
2676#define MCF5235_INTC0_INTFRCL_INTFRC16 (0x00010000)
2677#define MCF5235_INTC0_INTFRCL_INTFRC17 (0x00020000)
2678#define MCF5235_INTC0_INTFRCL_INTFRC18 (0x00040000)
2679#define MCF5235_INTC0_INTFRCL_INTFRC19 (0x00080000)
2680#define MCF5235_INTC0_INTFRCL_INTFRC20 (0x00100000)
2681#define MCF5235_INTC0_INTFRCL_INTFRC21 (0x00200000)
2682#define MCF5235_INTC0_INTFRCL_INTFRC22 (0x00400000)
2683#define MCF5235_INTC0_INTFRCL_INTFRC23 (0x00800000)
2684#define MCF5235_INTC0_INTFRCL_INTFRC24 (0x01000000)
2685#define MCF5235_INTC0_INTFRCL_INTFRC25 (0x02000000)
2686#define MCF5235_INTC0_INTFRCL_INTFRC26 (0x04000000)
2687#define MCF5235_INTC0_INTFRCL_INTFRC27 (0x08000000)
2688#define MCF5235_INTC0_INTFRCL_INTFRC28 (0x10000000)
2689#define MCF5235_INTC0_INTFRCL_INTFRC29 (0x20000000)
2690#define MCF5235_INTC0_INTFRCL_INTFRC30 (0x40000000)
2691#define MCF5235_INTC0_INTFRCL_INTFRC31 (0x80000000)
2692#define MCF5235_INTC0_IRLR_IRQ(x) (((x)&0x7F)<<1)
2693#define MCF5235_INTC0_IACKLPR_PRI(x) (((x)&0x0F)<<0)
2694#define MCF5235_INTC0_IACKLPR_LEVEL(x) (((x)&0x07)<<4)
2695#define MCF5235_INTC_ICR_IP(x) (((x)&0x07)<<0)
2696#define MCF5235_INTC_ICR_IL(x) (((x)&0x07)<<3)
2697#define MCF5235_INTC1_IPRH_INT32 (0x00000001)
2698#define MCF5235_INTC1_IPRH_INT33 (0x00000002)
2699#define MCF5235_INTC1_IPRH_INT34 (0x00000004)
2700#define MCF5235_INTC1_IPRH_INT35 (0x00000008)
2701#define MCF5235_INTC1_IPRH_INT36 (0x00000010)
2702#define MCF5235_INTC1_IPRH_INT37 (0x00000020)
2703#define MCF5235_INTC1_IPRH_INT38 (0x00000040)
2704#define MCF5235_INTC1_IPRH_INT39 (0x00000080)
2705#define MCF5235_INTC1_IPRH_INT40 (0x00000100)
2706#define MCF5235_INTC1_IPRH_INT41 (0x00000200)
2707#define MCF5235_INTC1_IPRH_INT42 (0x00000400)
2708#define MCF5235_INTC1_IPRH_INT43 (0x00000800)
2709#define MCF5235_INTC1_IPRH_INT44 (0x00001000)
2710#define MCF5235_INTC1_IPRH_INT45 (0x00002000)
2711#define MCF5235_INTC1_IPRH_INT46 (0x00004000)
2712#define MCF5235_INTC1_IPRH_INT47 (0x00008000)
2713#define MCF5235_INTC1_IPRH_INT48 (0x00010000)
2714#define MCF5235_INTC1_IPRH_INT49 (0x00020000)
2715#define MCF5235_INTC1_IPRH_INT50 (0x00040000)
2716#define MCF5235_INTC1_IPRH_INT51 (0x00080000)
2717#define MCF5235_INTC1_IPRH_INT52 (0x00100000)
2718#define MCF5235_INTC1_IPRH_INT53 (0x00200000)
2719#define MCF5235_INTC1_IPRH_INT54 (0x00400000)
2720#define MCF5235_INTC1_IPRH_INT55 (0x00800000)
2721#define MCF5235_INTC1_IPRH_INT56 (0x01000000)
2722#define MCF5235_INTC1_IPRH_INT57 (0x02000000)
2723#define MCF5235_INTC1_IPRH_INT58 (0x04000000)
2724#define MCF5235_INTC1_IPRH_INT59 (0x08000000)
2725#define MCF5235_INTC1_IPRH_INT60 (0x10000000)
2726#define MCF5235_INTC1_IPRH_INT61 (0x20000000)
2727#define MCF5235_INTC1_IPRH_INT62 (0x40000000)
2728#define MCF5235_INTC1_IPRH_INT63 (0x80000000)
2729#define MCF5235_INTC1_IPRL_INT1 (0x00000002)
2730#define MCF5235_INTC1_IPRL_INT2 (0x00000004)
2731#define MCF5235_INTC1_IPRL_INT3 (0x00000008)
2732#define MCF5235_INTC1_IPRL_INT4 (0x00000010)
2733#define MCF5235_INTC1_IPRL_INT5 (0x00000020)
2734#define MCF5235_INTC1_IPRL_INT6 (0x00000040)
2735#define MCF5235_INTC1_IPRL_INT7 (0x00000080)
2736#define MCF5235_INTC1_IPRL_INT8 (0x00000100)
2737#define MCF5235_INTC1_IPRL_INT9 (0x00000200)
2738#define MCF5235_INTC1_IPRL_INT10 (0x00000400)
2739#define MCF5235_INTC1_IPRL_INT11 (0x00000800)
2740#define MCF5235_INTC1_IPRL_INT12 (0x00001000)
2741#define MCF5235_INTC1_IPRL_INT13 (0x00002000)
2742#define MCF5235_INTC1_IPRL_INT14 (0x00004000)
2743#define MCF5235_INTC1_IPRL_INT15 (0x00008000)
2744#define MCF5235_INTC1_IPRL_INT16 (0x00010000)
2745#define MCF5235_INTC1_IPRL_INT17 (0x00020000)
2746#define MCF5235_INTC1_IPRL_INT18 (0x00040000)
2747#define MCF5235_INTC1_IPRL_INT19 (0x00080000)
2748#define MCF5235_INTC1_IPRL_INT20 (0x00100000)
2749#define MCF5235_INTC1_IPRL_INT21 (0x00200000)
2750#define MCF5235_INTC1_IPRL_INT22 (0x00400000)
2751#define MCF5235_INTC1_IPRL_INT23 (0x00800000)
2752#define MCF5235_INTC1_IPRL_INT24 (0x01000000)
2753#define MCF5235_INTC1_IPRL_INT25 (0x02000000)
2754#define MCF5235_INTC1_IPRL_INT26 (0x04000000)
2755#define MCF5235_INTC1_IPRL_INT27 (0x08000000)
2756#define MCF5235_INTC1_IPRL_INT28 (0x10000000)
2757#define MCF5235_INTC1_IPRL_INT29 (0x20000000)
2758#define MCF5235_INTC1_IPRL_INT30 (0x40000000)
2759#define MCF5235_INTC1_IPRL_INT31 (0x80000000)
2760#define MCF5235_INTC1_IMRH_INT_MASK32 (0x00000001)
2761#define MCF5235_INTC1_IMRH_INT_MASK33 (0x00000002)
2762#define MCF5235_INTC1_IMRH_INT_MASK34 (0x00000004)
2763#define MCF5235_INTC1_IMRH_INT_MASK35 (0x00000008)
2764#define MCF5235_INTC1_IMRH_INT_MASK36 (0x00000010)
2765#define MCF5235_INTC1_IMRH_INT_MASK37 (0x00000020)
2766#define MCF5235_INTC1_IMRH_INT_MASK38 (0x00000040)
2767#define MCF5235_INTC1_IMRH_INT_MASK39 (0x00000080)
2768#define MCF5235_INTC1_IMRH_INT_MASK40 (0x00000100)
2769#define MCF5235_INTC1_IMRH_INT_MASK41 (0x00000200)
2770#define MCF5235_INTC1_IMRH_INT_MASK42 (0x00000400)
2771#define MCF5235_INTC1_IMRH_INT_MASK43 (0x00000800)
2772#define MCF5235_INTC1_IMRH_INT_MASK44 (0x00001000)
2773#define MCF5235_INTC1_IMRH_INT_MASK45 (0x00002000)
2774#define MCF5235_INTC1_IMRH_INT_MASK46 (0x00004000)
2775#define MCF5235_INTC1_IMRH_INT_MASK47 (0x00008000)
2776#define MCF5235_INTC1_IMRH_INT_MASK48 (0x00010000)
2777#define MCF5235_INTC1_IMRH_INT_MASK49 (0x00020000)
2778#define MCF5235_INTC1_IMRH_INT_MASK50 (0x00040000)
2779#define MCF5235_INTC1_IMRH_INT_MASK51 (0x00080000)
2780#define MCF5235_INTC1_IMRH_INT_MASK52 (0x00100000)
2781#define MCF5235_INTC1_IMRH_INT_MASK53 (0x00200000)
2782#define MCF5235_INTC1_IMRH_INT_MASK54 (0x00400000)
2783#define MCF5235_INTC1_IMRH_INT_MASK55 (0x00800000)
2784#define MCF5235_INTC1_IMRH_INT_MASK56 (0x01000000)
2785#define MCF5235_INTC1_IMRH_INT_MASK57 (0x02000000)
2786#define MCF5235_INTC1_IMRH_INT_MASK58 (0x04000000)
2787#define MCF5235_INTC1_IMRH_INT_MASK59 (0x08000000)
2788#define MCF5235_INTC1_IMRH_INT_MASK60 (0x10000000)
2789#define MCF5235_INTC1_IMRH_INT_MASK61 (0x20000000)
2790#define MCF5235_INTC1_IMRH_INT_MASK62 (0x40000000)
2791#define MCF5235_INTC1_IMRH_INT_MASK63 (0x80000000)
2792#define MCF5235_INTC1_IMRL_MASKALL (0x00000001)
2793#define MCF5235_INTC1_IMRL_INT_MASK1 (0x00000002)
2794#define MCF5235_INTC1_IMRL_INT_MASK2 (0x00000004)
2795#define MCF5235_INTC1_IMRL_INT_MASK3 (0x00000008)
2796#define MCF5235_INTC1_IMRL_INT_MASK4 (0x00000010)
2797#define MCF5235_INTC1_IMRL_INT_MASK5 (0x00000020)
2798#define MCF5235_INTC1_IMRL_INT_MASK6 (0x00000040)
2799#define MCF5235_INTC1_IMRL_INT_MASK7 (0x00000080)
2800#define MCF5235_INTC1_IMRL_INT_MASK8 (0x00000100)
2801#define MCF5235_INTC1_IMRL_INT_MASK9 (0x00000200)
2802#define MCF5235_INTC1_IMRL_INT_MASK10 (0x00000400)
2803#define MCF5235_INTC1_IMRL_INT_MASK11 (0x00000800)
2804#define MCF5235_INTC1_IMRL_INT_MASK12 (0x00001000)
2805#define MCF5235_INTC1_IMRL_INT_MASK13 (0x00002000)
2806#define MCF5235_INTC1_IMRL_INT_MASK14 (0x00004000)
2807#define MCF5235_INTC1_IMRL_INT_MASK15 (0x00008000)
2808#define MCF5235_INTC1_IMRL_INT_MASK16 (0x00010000)
2809#define MCF5235_INTC1_IMRL_INT_MASK17 (0x00020000)
2810#define MCF5235_INTC1_IMRL_INT_MASK18 (0x00040000)
2811#define MCF5235_INTC1_IMRL_INT_MASK19 (0x00080000)
2812#define MCF5235_INTC1_IMRL_INT_MASK20 (0x00100000)
2813#define MCF5235_INTC1_IMRL_INT_MASK21 (0x00200000)
2814#define MCF5235_INTC1_IMRL_INT_MASK22 (0x00400000)
2815#define MCF5235_INTC1_IMRL_INT_MASK23 (0x00800000)
2816#define MCF5235_INTC1_IMRL_INT_MASK24 (0x01000000)
2817#define MCF5235_INTC1_IMRL_INT_MASK25 (0x02000000)
2818#define MCF5235_INTC1_IMRL_INT_MASK26 (0x04000000)
2819#define MCF5235_INTC1_IMRL_INT_MASK27 (0x08000000)
2820#define MCF5235_INTC1_IMRL_INT_MASK28 (0x10000000)
2821#define MCF5235_INTC1_IMRL_INT_MASK29 (0x20000000)
2822#define MCF5235_INTC1_IMRL_INT_MASK30 (0x40000000)
2823#define MCF5235_INTC1_IMRL_INT_MASK31 (0x80000000)
2824#define MCF5235_INTC1_INTFRCH_INTFRC32 (0x00000001)
2825#define MCF5235_INTC1_INTFRCH_INTFRC33 (0x00000002)
2826#define MCF5235_INTC1_INTFRCH_INTFRC34 (0x00000004)
2827#define MCF5235_INTC1_INTFRCH_INTFRC35 (0x00000008)
2828#define MCF5235_INTC1_INTFRCH_INTFRC36 (0x00000010)
2829#define MCF5235_INTC1_INTFRCH_INTFRC37 (0x00000020)
2830#define MCF5235_INTC1_INTFRCH_INTFRC38 (0x00000040)
2831#define MCF5235_INTC1_INTFRCH_INTFRC39 (0x00000080)
2832#define MCF5235_INTC1_INTFRCH_INTFRC40 (0x00000100)
2833#define MCF5235_INTC1_INTFRCH_INTFRC41 (0x00000200)
2834#define MCF5235_INTC1_INTFRCH_INTFRC42 (0x00000400)
2835#define MCF5235_INTC1_INTFRCH_INTFRC43 (0x00000800)
2836#define MCF5235_INTC1_INTFRCH_INTFRC44 (0x00001000)
2837#define MCF5235_INTC1_INTFRCH_INTFRC45 (0x00002000)
2838#define MCF5235_INTC1_INTFRCH_INTFRC46 (0x00004000)
2839#define MCF5235_INTC1_INTFRCH_INTFRC47 (0x00008000)
2840#define MCF5235_INTC1_INTFRCH_INTFRC48 (0x00010000)
2841#define MCF5235_INTC1_INTFRCH_INTFRC49 (0x00020000)
2842#define MCF5235_INTC1_INTFRCH_INTFRC50 (0x00040000)
2843#define MCF5235_INTC1_INTFRCH_INTFRC51 (0x00080000)
2844#define MCF5235_INTC1_INTFRCH_INTFRC52 (0x00100000)
2845#define MCF5235_INTC1_INTFRCH_INTFRC53 (0x00200000)
2846#define MCF5235_INTC1_INTFRCH_INTFRC54 (0x00400000)
2847#define MCF5235_INTC1_INTFRCH_INTFRC55 (0x00800000)
2848#define MCF5235_INTC1_INTFRCH_INTFRC56 (0x01000000)
2849#define MCF5235_INTC1_INTFRCH_INTFRC57 (0x02000000)
2850#define MCF5235_INTC1_INTFRCH_INTFRC58 (0x04000000)
2851#define MCF5235_INTC1_INTFRCH_INTFRC59 (0x08000000)
2852#define MCF5235_INTC1_INTFRCH_INTFRC60 (0x10000000)
2853#define MCF5235_INTC1_INTFRCH_INTFRC61 (0x20000000)
2854#define MCF5235_INTC1_INTFRCH_INTFRC62 (0x40000000)
2855#define MCF5235_INTC1_INTFRCH_INTFRC63 (0x80000000)
2856#define MCF5235_INTC1_INTFRCL_INTFRC1 (0x00000002)
2857#define MCF5235_INTC1_INTFRCL_INTFRC2 (0x00000004)
2858#define MCF5235_INTC1_INTFRCL_INTFRC3 (0x00000008)
2859#define MCF5235_INTC1_INTFRCL_INTFRC4 (0x00000010)
2860#define MCF5235_INTC1_INTFRCL_INTFRC5 (0x00000020)
2861#define MCF5235_INTC1_INTFRCL_INT6 (0x00000040)
2862#define MCF5235_INTC1_INTFRCL_INT7 (0x00000080)
2863#define MCF5235_INTC1_INTFRCL_INT8 (0x00000100)
2864#define MCF5235_INTC1_INTFRCL_INT9 (0x00000200)
2865#define MCF5235_INTC1_INTFRCL_INT10 (0x00000400)
2866#define MCF5235_INTC1_INTFRCL_INTFRC11 (0x00000800)
2867#define MCF5235_INTC1_INTFRCL_INTFRC12 (0x00001000)
2868#define MCF5235_INTC1_INTFRCL_INTFRC13 (0x00002000)
2869#define MCF5235_INTC1_INTFRCL_INTFRC14 (0x00004000)
2870#define MCF5235_INTC1_INTFRCL_INT15 (0x00008000)
2871#define MCF5235_INTC1_INTFRCL_INTFRC16 (0x00010000)
2872#define MCF5235_INTC1_INTFRCL_INTFRC17 (0x00020000)
2873#define MCF5235_INTC1_INTFRCL_INTFRC18 (0x00040000)
2874#define MCF5235_INTC1_INTFRCL_INTFRC19 (0x00080000)
2875#define MCF5235_INTC1_INTFRCL_INTFRC20 (0x00100000)
2876#define MCF5235_INTC1_INTFRCL_INTFRC21 (0x00200000)
2877#define MCF5235_INTC1_INTFRCL_INTFRC22 (0x00400000)
2878#define MCF5235_INTC1_INTFRCL_INTFRC23 (0x00800000)
2879#define MCF5235_INTC1_INTFRCL_INTFRC24 (0x01000000)
2880#define MCF5235_INTC1_INTFRCL_INTFRC25 (0x02000000)
2881#define MCF5235_INTC1_INTFRCL_INTFRC26 (0x04000000)
2882#define MCF5235_INTC1_INTFRCL_INTFRC27 (0x08000000)
2883#define MCF5235_INTC1_INTFRCL_INTFRC28 (0x10000000)
2884#define MCF5235_INTC1_INTFRCL_INTFRC29 (0x20000000)
2885#define MCF5235_INTC1_INTFRCL_INTFRC30 (0x40000000)
2886#define MCF5235_INTC1_INTFRCL_INTFRC31 (0x80000000)
2887#define MCF5235_INTC1_IRLR_IRQ(x) (((x)&0x7F)<<1)
2888#define MCF5235_INTC1_IACKLPR_PRI(x) (((x)&0x0F)<<0)
2889#define MCF5235_INTC1_IACKLPR_LEVEL(x) (((x)&0x07)<<4)
2890
2891/*********************************************************************
2892*
2893* Programmable Interrupt Timer Modules (PIT)
2894*
2895*********************************************************************/
2896
2897/* Register read/write macros */
2898#define MCF5235_PIT_PCSR0 (*(vuint16*)((uintptr_t)__IPSBAR + (0x150000)))
2899#define MCF5235_PIT_PMR0 (*(vuint16*)((uintptr_t)__IPSBAR + (0x150002)))
2900#define MCF5235_PIT_PCNTR0 (*(vuint16*)((uintptr_t)__IPSBAR + (0x150004)))
2901#define MCF5235_PIT_PCSR1 (*(vuint16*)((uintptr_t)__IPSBAR + (0x160000)))
2902#define MCF5235_PIT_PMR1 (*(vuint16*)((uintptr_t)__IPSBAR + (0x160002)))
2903#define MCF5235_PIT_PCNTR1 (*(vuint16*)((uintptr_t)__IPSBAR + (0x160004)))
2904#define MCF5235_PIT_PCSR2 (*(vuint16*)((uintptr_t)__IPSBAR + (0x170000)))
2905#define MCF5235_PIT_PMR2 (*(vuint16*)((uintptr_t)__IPSBAR + (0x170002)))
2906#define MCF5235_PIT_PCNTR2 (*(vuint16*)((uintptr_t)__IPSBAR + (0x170004)))
2907#define MCF5235_PIT_PCSR3 (*(vuint16*)((uintptr_t)__IPSBAR + (0x180000)))
2908#define MCF5235_PIT_PMR3 (*(vuint16*)((uintptr_t)__IPSBAR + (0x180002)))
2909#define MCF5235_PIT_PCNTR3 (*(vuint16*)((uintptr_t)__IPSBAR + (0x180004)))
2910#define MCF5235_PIT_PCSR(x) (*(vuint16*)((uintptr_t)__IPSBAR + (0x150000+((x)*0x10000))))
2911#define MCF5235_PIT_PMR(x) (*(vuint16*)((uintptr_t)__IPSBAR + (0x150002+((x)*0x10000))))
2912#define MCF5235_PIT_PCNTR(x) (*(vuint16*)((uintptr_t)__IPSBAR + (0x150004+((x)*0x10000))))
2913#define MCF5235_PIT_PCSR_EN (0x0001)
2914#define MCF5235_PIT_PCSR_RLD (0x0002)
2915#define MCF5235_PIT_PCSR_PIF (0x0004)
2916#define MCF5235_PIT_PCSR_PIE (0x0008)
2917#define MCF5235_PIT_PCSR_OVW (0x0010)
2918#define MCF5235_PIT_PCSR_HALTED (0x0020)
2919#define MCF5235_PIT_PCSR_DOZE (0x0040)
2920#define MCF5235_PIT_PCSR_PRE(x) (((x)&0x000F)<<8)
2921#define MCF5235_PIT_PMR_PM0 (0x0001)
2922#define MCF5235_PIT_PMR_PM1 (0x0002)
2923#define MCF5235_PIT_PMR_PM2 (0x0004)
2924#define MCF5235_PIT_PMR_PM3 (0x0008)
2925#define MCF5235_PIT_PMR_PM4 (0x0010)
2926#define MCF5235_PIT_PMR_PM5 (0x0020)
2927#define MCF5235_PIT_PMR_PM6 (0x0040)
2928#define MCF5235_PIT_PMR_PM7 (0x0080)
2929#define MCF5235_PIT_PMR_PM8 (0x0100)
2930#define MCF5235_PIT_PMR_PM9 (0x0200)
2931#define MCF5235_PIT_PMR_PM10 (0x0400)
2932#define MCF5235_PIT_PMR_PM11 (0x0800)
2933#define MCF5235_PIT_PMR_PM12 (0x1000)
2934#define MCF5235_PIT_PMR_PM13 (0x2000)
2935#define MCF5235_PIT_PMR_PM14 (0x4000)
2936#define MCF5235_PIT_PMR_PM15 (0x8000)
2937#define MCF5235_PIT_PCNTR_PC0 (0x0001)
2938#define MCF5235_PIT_PCNTR_PC1 (0x0002)
2939#define MCF5235_PIT_PCNTR_PC2 (0x0004)
2940#define MCF5235_PIT_PCNTR_PC3 (0x0008)
2941#define MCF5235_PIT_PCNTR_PC4 (0x0010)
2942#define MCF5235_PIT_PCNTR_PC5 (0x0020)
2943#define MCF5235_PIT_PCNTR_PC6 (0x0040)
2944#define MCF5235_PIT_PCNTR_PC7 (0x0080)
2945#define MCF5235_PIT_PCNTR_PC8 (0x0100)
2946#define MCF5235_PIT_PCNTR_PC9 (0x0200)
2947#define MCF5235_PIT_PCNTR_PC10 (0x0400)
2948#define MCF5235_PIT_PCNTR_PC11 (0x0800)
2949#define MCF5235_PIT_PCNTR_PC12 (0x1000)
2950#define MCF5235_PIT_PCNTR_PC13 (0x2000)
2951#define MCF5235_PIT_PCNTR_PC14 (0x4000)
2952#define MCF5235_PIT_PCNTR_PC15 (0x8000)
2953
2954/*********************************************************************
2955*
2956* Queued Serial Peripheral Interface (QSPI)
2957*
2958*********************************************************************/
2959
2960/* Register read/write macros */
2961#define MCF5235_QSPI_QMR (*(vuint16*)((uintptr_t)__IPSBAR + (0x000340)))
2962#define MCF5235_QSPI_QDLYR (*(vuint16*)((uintptr_t)__IPSBAR + (0x000344)))
2963#define MCF5235_QSPI_QWR (*(vuint16*)((uintptr_t)__IPSBAR + (0x000348)))
2964#define MCF5235_QSPI_QIR (*(vuint16*)((uintptr_t)__IPSBAR + (0x00034C)))
2965#define MCF5235_QSPI_QAR (*(vuint16*)((uintptr_t)__IPSBAR + (0x000350)))
2966#define MCF5235_QSPI_QDR (*(vuint16*)((uintptr_t)__IPSBAR + (0x000354)))
2967
2968/* Bit definitions and macros for MCF5235_QSPI_QMR */
2969#define MCF5235_QSPI_QMR_BAUD(x) (((x)&0x00FF)<<0)
2970#define MCF5235_QSPI_QMR_CPHA (0x0100)
2971#define MCF5235_QSPI_QMR_CPOL (0x0200)
2972#define MCF5235_QSPI_QMR_BITS(x) (((x)&0x000F)<<10)
2973#define MCF5235_QSPI_QMR_DOHIE (0x4000)
2974#define MCF5235_QSPI_QMR_MSTR (0x8000)
2975#define MCF5235_QSPI_QDLYR_DTL(x) (((x)&0x00FF)<<0)
2976#define MCF5235_QSPI_QDLYR_QCD(x) (((x)&0x007F)<<8)
2977#define MCF5235_QSPI_QDLYR_SPE (0x8000)
2978#define MCF5235_QSPI_QWR_NEWQP(x) (((x)&0x000F)<<0)
2979#define MCF5235_QSPI_QWR_ENDQP(x) (((x)&0x000F)<<8)
2980#define MCF5235_QSPI_QWR_CSIV (0x1000)
2981#define MCF5235_QSPI_QWR_WRTO (0x2000)
2982#define MCF5235_QSPI_QWR_WREN (0x4000)
2983#define MCF5235_QSPI_QWR_HALT (0x8000)
2984#define MCF5235_QSPI_QIR_SPIF (0x0001)
2985#define MCF5235_QSPI_QIR_ABRT (0x0004)
2986#define MCF5235_QSPI_QIR_WCEF (0x0008)
2987#define MCF5235_QSPI_QIR_SPIFE (0x0100)
2988#define MCF5235_QSPI_QIR_ABRTE (0x0400)
2989#define MCF5235_QSPI_QIR_WCEFE (0x0800)
2990#define MCF5235_QSPI_QIR_ABRTL (0x1000)
2991#define MCF5235_QSPI_QIR_ABRTB (0x4000)
2992#define MCF5235_QSPI_QIR_WCEFB (0x8000)
2993#define MCF5235_QSPI_QAR_ADDR(x) (((x)&0x003F)<<0)
2994
2995/********************************************************************/
2996
2997
2998#endif /* _CPU_MCF5235_H */
#define __IPSBAR
Definition: bsp.h:40
volatile unsigned char vuint8
