RTEMS 5.2
Files | Macros | Functions
MCF52235 Board Support Package. More...
file  bsp.h
 Global BSP definitions.
#define __IPSBAR   ((vuint8 *) 0x40000000)
#define CONSOLE_PORT   0
#define PIT3_IRQ_LEVEL   4
#define PIT3_IRQ_PRIORITY   0
#define UART0_IRQ_LEVEL   3
#define UART0_IRQ_PRIORITY   7
#define UART1_IRQ_LEVEL   3
#define UART1_IRQ_PRIORITY   6
#define UART2_IRQ_LEVEL   3
#define UART2_IRQ_PRIORITY   5
uint32_t bsp_get_CPU_clock_speed (void)
rtems_isr_entry set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type)
 Install an interrupt handler. More...
void Init52235 (void)
◆ __IPSBAR
Hardware data structure headers
◆ CONSOLE_PORT
Network driver configuration
User Definable configuration
◆ set_vector()
rtems_isr_entry set_vector ( rtems_isr_entry  handler,
int  type
This method installs an interrupt handle.
Parameters
[in]handleris the isr routine
[in]vectoris the vector number
[in]typeindicates whether RTEMS or RAW intr
Returns
returns old vector
