RTEMS 5.2
m68k.h File Reference
Motorola M68K CPU Dependent Source. More...
#define CPU_NAME   "Motorola MC68xxx"
#define M68K_CPU_STACK_MINIMUM_SIZE   4096
#define M68K_CPU_PRIORITY_MAXIMUM   255
#define M68K_COLDFIRE_ARCH   0
#define m68k_disable_interrupts(_level)
#define m68k_enable_interrupts(_level)    __asm__ volatile ( "move.w %0,%%sr " : : "d" (_level) : "cc");
#define m68k_flash_interrupts(_level)
#define m68k_get_interrupt_level(_level)
#define m68k_set_interrupt_level(_newlevel)
#define m68k_get_vbr(_vbr)   _vbr = (void *)_VBR
#define m68k_set_vbr(_vbr)
#define m68k_set_cacr(_cacr)   __asm__ volatile ("movec %0,%%cacr" : : "d" (_cacr))
#define m68k_set_acr0(_acr0)   __asm__ volatile ("movec %0,%%acr0" : : "d" (_acr0))
#define m68k_set_acr1(_acr1)   __asm__ volatile ("movec %0,%%acr1" : : "d" (_acr1))
#define CPU_swap_u32(value)   m68k_swap_u32( value )
#define CPU_swap_u16(value)   m68k_swap_u16( value )
◆ m68k_disable_interrupts
#define m68k_disable_interrupts (   _level)
Value:
__asm__ volatile ( "move.w %%sr,%0\n\t" \
"or.w #0x0700,%%sr" \
: "=d" (_level) \
: : "cc" )
register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__("g6")
The pointer to the current per-CPU control is available via register g6.
◆ m68k_flash_interrupts
#define m68k_flash_interrupts (   _level)
Value:
__asm__ volatile ( "move.w %0,%%sr\n\t" \
: : "d" (_level) \
: "cc" )
◆ m68k_get_interrupt_level
#define m68k_get_interrupt_level (   _level)
Value:
do { \
uint32_t _tmpsr; \
__asm__ volatile( "move.w %%sr,%0" : "=d" (_tmpsr)); \
_level = (_tmpsr & 0x0700) >> 8; \
} while (0)
◆ m68k_set_interrupt_level
#define m68k_set_interrupt_level (   _newlevel)
Value:
do { \
uint32_t _tmpsr; \
_tmpsr = (_tmpsr & 0xf8ff) | ((_newlevel) << 8); \
__asm__ volatile( "move.w %0,%%sr" : : "d" (_tmpsr)); \
} while (0)
