RTEMS 5.2
timer.c File Reference
Timer Init. More...
#include <bsp.h>
#include <rtems/btimer.h>
#include "mcf5206/mcf5206e.h"
#define TRR2_VAL   65530
#define AVG_OVERHEAD   0 /* It typically takes 2.0 microseconds */
#define LEAST_VALID   1 /* Don't trust a clicks value lower than this */
rtems_isr timerisr (rtems_vector_number vector)
void benchmark_timer_initialize (void)
 Initialize the Benchmark Timer. More...
benchmark_timer_t benchmark_timer_read (void)
 Read the Benchmark Timer. More...
void benchmark_timer_disable_subtracting_average_overhead (bool find_flag)
 Disable Average Overhead Removal from the Benchmark Timer. More...
uint32_t Timer_interrupts
bool benchmark_timer_find_average_overhead
Timer Init.
This module initializes TIMER 2 for on the MCF5206E for benchmarks.
◆ benchmark_timer_disable_subtracting_average_overhead()
void benchmark_timer_disable_subtracting_average_overhead ( bool  find_flag)
This method places the benchmark timer in a "raw" mode where it returns the actual number of units which have passed between calls to benchmark_timer_initialize and benchmark_timer_read counting.
Parameters
[in]find_flagindicates to enable or disable the mode
◆ benchmark_timer_initialize()
void benchmark_timer_initialize ( void  )
This method initializes the benchmark timer and resets it to begin counting.
◆ benchmark_timer_read()
benchmark_timer_t benchmark_timer_read ( void  )
This method stops the benchmark timer and returns the number of units that have passed since benchmark_timer_initialize was invoked.
Returns
This method returns the number of units with the average overhead removed. If the value is below the minimum trusted value, zero is returned.
