RTEMS 5.2
Data Structures | Macros | Typedefs | Enumerations | Variables
m68302.h File Reference
Definitions for Motorola MC68302 Processor. More...
struct  m302_DRAM_refresh_t
struct  m302_SCC_bd
struct  m302_SCC_bd_table_t
struct  m302_SCC_parameters_t
struct  m302_SCC_UartSpecific_t
struct  m302_SCC_HdlcSpecific_t
struct  m302_SCC_t
struct  m302_SCC_Registers_t
struct  m302_internalReg_t
struct  m302_dualPortRAM_t
#define M302_BAR   (*((volatile uint16_t *) 0xf2))
#define M302_SCR   (*((volatile uint32_t *) 0xf4))
#define RBIT_SCR_IPA   0x08000000
#define RBIT_SCR_HWT   0x04000000
#define RBIT_SCR_WPV   0x02000000
#define RBIT_SCR_ADC   0x01000000
#define RBIT_SCR_ERRE   0x00400000
#define RBIT_SCR_VGE   0x00200000
#define RBIT_SCR_WPVE   0x00100000
#define RBIT_SCR_RMCST   0x00080000
#define RBIT_SCR_EMWS   0x00040000
#define RBIT_SCR_ADCE   0x00020000
#define RBIT_SCR_BCLM   0x00010000
#define RBIT_SCR_FRZW   0x00008000
#define RBIT_SCR_FRZ2   0x00004000
#define RBIT_SCR_FRZ1   0x00002000
#define RBIT_SCR_SAM   0x00001000
#define RBIT_SCR_HWDEN   0x00000800
#define RBIT_SCR_HWDCN2   0x00000400
#define RBIT_SCR_HWDCN1   0x00000200 /* 512 clocks */
#define RBIT_SCR_HWDCN0   0x00000100 /* 128 clocks */
#define RBIT_SCR_LPREC   0x00000080
#define RBIT_SCR_LPP16   0x00000040
#define RBIT_SCR_LPEN   0x00000020
#define RBIT_SCR_LPCLKDIV   0x0000001f
#define M68K_IVEC_BUS_ERROR   2
#define M68K_IVEC_ADDRESS_ERROR   3
#define M68K_IVEC_ILLEGAL_OPCODE   4
#define M68K_IVEC_ZERO_DIVIDE   5
#define M68K_IVEC_CHK   6
#define M68K_IVEC_TRAPV   7
#define M68K_IVEC_PRIVILEGE   8
#define M68K_IVEC_TRACE   9
#define M68K_IVEC_LINE_A   10
#define M68K_IVEC_LINE_F   11
#define M68K_IVEC_UNINITIALIZED_INT   15
#define M68K_IVEC_SPURIOUS_INT   24
#define M68K_IVEC_LEVEL1_AUTOVECTOR   25
#define M68K_IVEC_LEVEL2_AUTOVECTOR   26
#define M68K_IVEC_LEVEL3_AUTOVECTOR   27
#define M68K_IVEC_LEVEL4_AUTOVECTOR   28
#define M68K_IVEC_LEVEL5_AUTOVECTOR   29
#define M68K_IVEC_LEVEL6_AUTOVECTOR   30
#define M68K_IVEC_LEVEL7_AUTOVECTOR   31
#define M68K_IVEC_TRAP0   32
#define M68K_IVEC_TRAP1   33
#define M68K_IVEC_TRAP2   34
#define M68K_IVEC_TRAP3   35
#define M68K_IVEC_TRAP4   36
#define M68K_IVEC_TRAP5   37
#define M68K_IVEC_TRAP6   38
#define M68K_IVEC_TRAP7   39
#define M68K_IVEC_TRAP8   40
#define M68K_IVEC_TRAP9   41
#define M68K_IVEC_TRAP10   42
#define M68K_IVEC_TRAP11   43
#define M68K_IVEC_TRAP12   44
#define M68K_IVEC_TRAP13   45
#define M68K_IVEC_TRAP14   46
#define M68K_IVEC_TRAP15   47
#define RBIT_GIMR_MOD   (1<<15)
#define RBIT_GIMR_IV7   (1<<14)
#define RBIT_GIMR_IV6   (1<<13)
#define RBIT_GIMR_IV1   (1<<12)
#define RBIT_GIMR_ET7   (1<<10)
#define RBIT_GIMR_ET6   (1<<9)
#define RBIT_GIMR_ET1   (1<<8)
#define RBIT_GIMR_VECTOR   (7<<5)
#define RBIT_IPR_PB11   (1<<15)
#define RBIT_IPR_PB10   (1<<14)
#define RBIT_IPR_SCC1   (1<<13)
#define RBIT_IPR_SDMA   (1<<12)
#define RBIT_IPR_IDMA   (1<<11)
#define RBIT_IPR_SCC2   (1<<10)
#define RBIT_IPR_TIMER1   (1<<9)
#define RBIT_IPR_SCC3   (1<<8)
#define RBIT_IPR_PB9   (1<<7)
#define RBIT_IPR_TIMER2   (1<<6)
#define RBIT_IPR_SCP   (1<<5)
#define RBIT_IPR_TIMER3   (1<<4)
#define RBIT_IPR_SMC1   (1<<3)
#define RBIT_IPR_SMC2   (1<<2)
#define RBIT_IPR_PB8   (1<<1)
#define RBIT_IPR_ERR   (1<<0)
#define RBIT_ISR_PB11   (1<<15)
#define RBIT_ISR_PB10   (1<<14)
#define RBIT_ISR_SCC1   (1<<13)
#define RBIT_ISR_SDMA   (1<<12)
#define RBIT_ISR_IDMA   (1<<11)
#define RBIT_ISR_SCC2   (1<<10)
#define RBIT_ISR_TIMER1   (1<<9)
#define RBIT_ISR_SCC3   (1<<8)
#define RBIT_ISR_PB9   (1<<7)
#define RBIT_ISR_TIMER2   (1<<6)
#define RBIT_ISR_SCP   (1<<5)
#define RBIT_ISR_TIMER3   (1<<4)
#define RBIT_ISR_SMC1   (1<<3)
#define RBIT_ISR_SMC2   (1<<2)
#define RBIT_ISR_PB8   (1<<1)
#define RBIT_IMR_PB11   (1<<15) /* PB11 Interrupt Mask */
#define RBIT_IMR_PB10   (1<<14) /* PB10 Interrupt Mask */
#define RBIT_IMR_SCC1   (1<<13) /* SCC1 Interrupt Mask */
#define RBIT_IMR_SDMA   (1<<12) /* SDMA Interrupt Mask */
#define RBIT_IMR_IDMA   (1<<11) /* IDMA Interrupt Mask */
#define RBIT_IMR_SCC2   (1<<10) /* SCC2 Interrupt Mask */
#define RBIT_IMR_TIMER1   (1<<9) /* TIMER1 Interrupt Mask */
#define RBIT_IMR_SCC3   (1<<8) /* SCC3 Interrupt Mask */
#define RBIT_IMR_PB9   (1<<7) /* PB9 Interrupt Mask */
#define RBIT_IMR_TIMER2   (1<<6) /* TIMER2 Interrupt Mask */
#define RBIT_IMR_SCP   (1<<5) /* SCP Interrupt Mask */
#define RBIT_IMR_TIMER3   (1<<4) /* TIMER3 Interrupt Mask */
#define RBIT_IMR_SMC1   (1<<3) /* SMC1 Interrupt Mask */
#define RBIT_IMR_SMC2   (1<<2) /* SMC2 Interrupt Mask */
#define RBIT_IMR_PB8   (1<<1) /* PB8 Interrupt Mask */
#define RBIT_TMR_ICLK_STOP   (0<<1)
#define RBIT_TMR_ICLK_MASTER   (1<<1)
#define RBIT_TMR_ICLK_MASTER16   (2<<1)
#define RBIT_TMR_ICLK_TIN   (3<<1)
#define RBIT_TMR_OM   (1<<5)
#define RBIT_TMR_ORI   (1<<4)
#define RBIT_TMR_FRR   (1<<3)
#define RBIT_TMR_RST   (1<<0)
#define RBIT_TER_REF   (1<<1) /* Output Reference Event */
#define RBIT_TER_CAP   (1<<0) /* Capture Event */
#define RCV_ERR   0x003F
#define RBIT_UART_CTRL   (1<<11) /* buffer contains a control char */
#define RBIT_UART_ADDR   (1<<10) /* first byte contains an address */
#define RBIT_UART_MATCH   (1<<9) /* indicates which addr char matched */
#define RBIT_UART_IDLE   (1<<8) /* buffer closed due to IDLE sequence */
#define RBIT_UART_BR   (1<<5) /* break sequence was received */
#define RBIT_UART_FR   (1<<4) /* framing error was received */
#define RBIT_UART_PR   (1<<3) /* parity error was received */
#define RBIT_UART_OV   (1<<1) /* receiver overrun occurred */
#define RBIT_UART_CD   (1<<0) /* carrier detect lost */
#define RBIT_UART_STATUS   0x003B /* all status bits */
#define RBIT_UART_CR
#define RBIT_UART_A
#define RBIT_UART_PREAMBLE   (1<<9) /* send preamble before data */
#define RBIT_UART_CTS_LOST   (1<<0) /* CTS lost */
#define M302_UART_EV_CTS   (1<<7) /* CTS status changed */
#define M302_UART_EV_CD   (1<<6) /* carrier detect status changed */
#define M302_UART_EV_IDL   (1<<5) /* IDLE sequence status changed */
#define M302_UART_EV_BRK   (1<<4) /* break character was received */
#define M302_UART_EV_CCR   (1<<3) /* control character received */
#define M302_UART_EV_TX   (1<<1) /* buffer has been transmitted */
#define M302_UART_EV_RX   (1<<0) /* buffer has been received */
#define RBIT_HDLC_EMPTY_BIT   0x8000 /* buffer associated with BD is empty */
#define RBIT_HDLC_LAST_BIT   0x0800 /* buffer is last in a frame */
#define RBIT_HDLC_FIRST_BIT   0x0400 /* buffer is first in a frame */
#define RBIT_HDLC_FRAME_LEN   0x0020 /* receiver frame length violation */
#define RBIT_HDLC_NONOCT_Rx   0x0010 /* received non-octet aligned frame */
#define RBIT_HDLC_ABORT_SEQ   0x0008 /* received abort sequence */
#define RBIT_HDLC_CRC_ERROR   0x0004 /* frame contains a CRC error */
#define RBIT_HDLC_OVERRUN   0x0002 /* receiver overrun occurred */
#define RBIT_HDLC_CD_LOST   0x0001 /* carrier detect lost */
#define RBIT_HDLC_READY_BIT   0x8000 /* buffer is ready to transmit */
#define RBIT_HDLC_EXT_BUFFER   0x4000 /* buffer is in external memory */
#define RBIT_HDLC_WRAP_BIT   0x2000 /* last buffer in bd table, so wrap */
#define RBIT_HDLC_WAKE_UP   0x1000 /* interrupt when buffer serviced */
#define RBIT_HDLC_LAST_BIT   0x0800 /* buffer is last in the frame */
#define RBIT_HDLC_TxCRC_BIT   0x0400 /* transmit a CRC sequence */
#define RBIT_HDLC_UNDERRUN   0x0002 /* transmitter underrun */
#define RBIT_HDLC_CTS_LOST   0x0001 /* CTS lost */
#define RBIT_HDLC_CTS   0x80 /* CTS status changed */
#define RBIT_HDLC_CD   0x40 /* carrier detect status changed */
#define RBIT_HDLC_IDL   0x20 /* IDLE sequence status changed */
#define RBIT_HDLC_TXE   0x10 /* transmit error */
#define RBIT_HDLC_RXF   0x08 /* received frame */
#define RBIT_HDLC_BSY
#define RBIT_HDLC_TXB   0x02 /* buffer has been transmitted */
#define RBIT_HDLC_RXB   0x01 /* received buffer */
#define RBIT_SCON_WOMS
#define RBIT_SCON_EXTC   (1<<14) /* External Clock Source */
#define RBIT_SCON_TCS   (1<<13) /* Transmit Clock Source */
#define RBIT_SCON_RCS   (1<<12) /* Receive Clock Source */
#define RBIT_SCM_ENR   (1<<3) /* Enable receiver */
#define RBIT_SCM_ENT   (1<<2) /* Enable transmitter */
#define BR_ENABLED   1
#define BR_DISABLED   0
#define BR_FC_NULL   0
#define BR_READ_ONLY   0
#define BR_READ_WRITE   2
#define OR_DTACK_0   0x0000
#define OR_DTACK_1   0x2000
#define OR_DTACK_2   0x4000
#define OR_DTACK_3   0x6000
#define OR_DTACK_4   0x8000
#define OR_DTACK_5   0xA000
#define OR_DTACK_6   0xC000
#define OR_DTACK_EXT   0xE000
#define OR_SIZE_64K   0x1FE0
#define OR_SIZE_128K   0x1FC0
#define OR_SIZE_256K   0x1F80
#define OR_SIZE_512K   0x1F00
#define OR_SIZE_1M   0x1E00
#define OR_SIZE_2M   0x1C00
#define OR_MASK_RW   0x0000
#define OR_NO_MASK_RW   0x0002
#define OR_MASK_FC   0x0000
#define OR_NO_MASK_FC   0x0001
#define MAKE_BR(base_address, enable, rw, fc)    ((base_address >> 11) | fc | rw | enable)
#define MAKE_OR(bsize, DtAck, RW_Mask, FC_Mask)    (DtAck | ((~(bsize - 1) & 0x00FFFFFF) >> 11) | FC_Mask | RW_Mask)
#define __REG_CAT(r, n)   r ## n
#define WRITE_BR(csel, base_address, enable, rw, fc)    __REG_CAT(m302.reg.br, csel) = MAKE_BR(base_address, enable, rw, fc)
#define WRITE_OR(csel, bsize, DtAck, RW_Mask, FC_Mask)    __REG_CAT(m302.reg.or, csel) = MAKE_OR(bsize, DtAck, RW_Mask, FC_Mask)
#define WATCHDOG_ENABLE   (1)
#define WATCHDOG_TRIGGER()   (m302.reg.wrr = 0x10 | WATCHDOG_ENABLE, m302.reg.wcn = 0)
#define WATCHDOG_TOGGLE()   (m302.reg.wcn = WATCHDOG_TIMEOUT_PERIOD)
#define DISABLE_WATCHDOG()   (m302.reg.wrr = 0)
typedef struct m302_SCC_bd m302_SCC_bd_t
enum  m68302_ivec_e {
  M302_IVEC_ERR =0 , M302_IVEC_PB8 =1 , M302_IVEC_SMC2 =2 , M302_IVEC_SMC1 =3 ,
  M302_IVEC_TIMER3 =4 , M302_IVEC_SCP =5 , M302_IVEC_TIMER2 =6 , M302_IVEC_PB9 =7 ,
  M302_IVEC_SCC3 =8 , M302_IVEC_TIMER1 =9 , M302_IVEC_SCC2 =10 , M302_IVEC_IDMA =11 ,
  M302_IVEC_SDMA =12 , M302_IVEC_SCC1 =13 , M302_IVEC_PB10 =14 , M302_IVEC_PB11 =15 ,
  M302_IVEC_IRQ1 =17 , M302_IVEC_IRQ6 =22 , M302_IVEC_IRQ7 =23
volatile m302_dualPortRAM_t m302
Section references in this file refer to revision 2 of Motorola's "MC68302 Integrated Multiprotocol Processor User's Manual". (Motorola document MC68302UM/AD REV 2.)
Based on Don Meyer's cpu68302.h that was posted in comp.sys.m68k on 17 February, 1993.
◆ RBIT_HDLC_BSY
Value:
0x04 /* frame rcvd and discarded due to
* lack of buffers
◆ RBIT_SCON_WOMS
Value:
(1<<15) /* Wired-OR Mode Select (NMSI mode only)
* When set, the TXD driver is an
* open-drain output */
◆ RBIT_UART_A
#define RBIT_UART_A
Value:
(1<<10) /* buffer contains address characters
* only valid in multidrop mode (UM0=1)
◆ RBIT_UART_CR
Value:
(1<<11) /* clear-to-send report
* this results in two idle bits
* between back-to-back frames
