RTEMS 5.2
API of the GPIO driver for the lpc176x bsp in RTEMS. More...
| rtems_status_code | lpc176x_gpio_config (lpc176x_pin_number pin, lpc176x_gpio_direction dir) |
| Configures the pin as input or output GPIO. More... | |
| rtems_status_code | lpc176x_gpio_config_input_with_interrupt (lpc176x_pin_number pin, lpc176x_gpio_interrupt edge, lpc176x_gpio_interrupt_function isrfunct) |
| Configures the pin as input, enables interrupt for an edge/s and sets isrfunct as the function to call when that interrupt occurs. More... | |
| rtems_status_code | lpc176x_gpio_set_pin (lpc176x_pin_number pin) |
| Sets the output pin to 1. More... | |
| rtems_status_code | lpc176x_gpio_clear_pin (lpc176x_pin_number pin) |
| Sets the output pin to 0. More... | |
| rtems_status_code | lpc176x_gpio_write_pin (lpc176x_pin_number pin, bool value) |
| Sets the output pin to 0 or 1 according to value. More... | |
| rtems_status_code | lpc176x_gpio_get_pin_value (lpc176x_pin_number pin, bool *pin_value) |
| Returns the value at the given input pin. More... | |
| rtems_status_code lpc176x_gpio_clear_pin | ( | lpc176x_pin_number | pin | ) |
| pin | The pin to set |
| rtems_status_code lpc176x_gpio_config | ( | lpc176x_pin_number | pin, |
| lpc176x_gpio_direction | dir | ||
| pin | The pin to configure |
| dir | Input or output. |
| rtems_status_code lpc176x_gpio_config_input_with_interrupt | ( | lpc176x_pin_number | pin, |
| lpc176x_gpio_interrupt | edge, | ||
| lpc176x_gpio_interrupt_function | isrfunct | ||
| pin | The pin to configure. |
| edge | Which edge or edges will activate the interrupt. |
| isrfunct | The function that is called when the interrupt occurs. |
inline |
| pin | The pin where to read the value. |
| pin_value | TRUE if the pin value was getted successfuly. |
| rtems_status_code lpc176x_gpio_set_pin | ( | lpc176x_pin_number | pin | ) |
| rtems_status_code lpc176x_gpio_write_pin | ( | lpc176x_pin_number | pin, |
| bool | value | ||
| value | the value to set. |
