RTEMS
5.2
libfs
src
jffs2
include
linux
jffs2.h
1
2
* JFFS2 -- Journalling Flash File System, Version 2.
3
4
* Copyright © 2001-2007 Red Hat, Inc.
5
* Copyright © 2004-2010 David Woodhouse <dwmw2@infradead.org>
6
7
* Created by David Woodhouse <dwmw2@infradead.org>
8
9
* For licensing information, see the file 'LICENCE' in the
10
* jffs2 directory.
11
12
13
#ifndef __LINUX_JFFS2_H__
14
#define __LINUX_JFFS2_H__
15
16
#include <linux/types.h>
17
#include <linux/magic.h>
18
19
/* You must include something which defines the C99 uintXX_t types.
20
We don't do it from here because this file is used in too many
21
different environments. */
22
23
/* Values we may expect to find in the 'magic' field */
24
#define JFFS2_OLD_MAGIC_BITMASK 0x1984
25
#define JFFS2_MAGIC_BITMASK 0x1985
26
#define KSAMTIB_CIGAM_2SFFJ 0x8519
/* For detecting wrong-endian fs */
27
#define JFFS2_EMPTY_BITMASK 0xffff
28
#define JFFS2_DIRTY_BITMASK 0x0000
29
30
/* Summary node MAGIC marker */
31
#define JFFS2_SUM_MAGIC 0x02851885
32
33
/* We only allow a single char for length, and 0xFF is empty flash so
34
we don't want it confused with a real length. Hence max 254.
35
36
#define JFFS2_MAX_NAME_LEN 254
37
38
/* How small can we sensibly write nodes? */
39
#define JFFS2_MIN_DATA_LEN 128
40
41
#define JFFS2_COMPR_NONE 0x00
42
#define JFFS2_COMPR_ZERO 0x01
43
#define JFFS2_COMPR_RTIME 0x02
44
#define JFFS2_COMPR_RUBINMIPS 0x03
45
#define JFFS2_COMPR_COPY 0x04
46
#define JFFS2_COMPR_DYNRUBIN 0x05
47
#define JFFS2_COMPR_ZLIB 0x06
48
#define JFFS2_COMPR_LZO 0x07
49
/* Compatibility flags. */
50
#define JFFS2_COMPAT_MASK 0xc000
/* What do to if an unknown nodetype is found */
51
#define JFFS2_NODE_ACCURATE 0x2000
52
/* INCOMPAT: Fail to mount the filesystem */
53
#define JFFS2_FEATURE_INCOMPAT 0xc000
54
/* ROCOMPAT: Mount read-only */
55
#define JFFS2_FEATURE_ROCOMPAT 0x8000
56
/* RWCOMPAT_COPY: Mount read/write, and copy the node when it's GC'd */
57
#define JFFS2_FEATURE_RWCOMPAT_COPY 0x4000
58
/* RWCOMPAT_DELETE: Mount read/write, and delete the node when it's GC'd */
59
#define JFFS2_FEATURE_RWCOMPAT_DELETE 0x0000
60
61
#define JFFS2_NODETYPE_DIRENT (JFFS2_FEATURE_INCOMPAT | JFFS2_NODE_ACCURATE | 1)
62
#define JFFS2_NODETYPE_INODE (JFFS2_FEATURE_INCOMPAT | JFFS2_NODE_ACCURATE | 2)
63
#define JFFS2_NODETYPE_CLEANMARKER (JFFS2_FEATURE_RWCOMPAT_DELETE | JFFS2_NODE_ACCURATE | 3)
64
#define JFFS2_NODETYPE_PADDING (JFFS2_FEATURE_RWCOMPAT_DELETE | JFFS2_NODE_ACCURATE | 4)
65
66
#define JFFS2_NODETYPE_SUMMARY (JFFS2_FEATURE_RWCOMPAT_DELETE | JFFS2_NODE_ACCURATE | 6)
67
68
#define JFFS2_NODETYPE_XATTR (JFFS2_FEATURE_INCOMPAT | JFFS2_NODE_ACCURATE | 8)
69
#define JFFS2_NODETYPE_XREF (JFFS2_FEATURE_INCOMPAT | JFFS2_NODE_ACCURATE | 9)
70
71
/* XATTR Related */
72
#define JFFS2_XPREFIX_USER 1
/* for "user." */
73
#define JFFS2_XPREFIX_SECURITY 2
/* for "security." */
74
#define JFFS2_XPREFIX_ACL_ACCESS 3
/* for "system.posix_acl_access" */
75
#define JFFS2_XPREFIX_ACL_DEFAULT 4
/* for "system.posix_acl_default" */
76
#define JFFS2_XPREFIX_TRUSTED 5
/* for "trusted.*" */
77
78
#define JFFS2_ACL_VERSION 0x0001
79
80
// Maybe later...
81
//#define JFFS2_NODETYPE_CHECKPOINT (JFFS2_FEATURE_RWCOMPAT_DELETE | JFFS2_NODE_ACCURATE | 3)
82
//#define JFFS2_NODETYPE_OPTIONS (JFFS2_FEATURE_RWCOMPAT_COPY | JFFS2_NODE_ACCURATE | 4)
83
84
85
#define JFFS2_INO_FLAG_PREREAD 1
/* Do read_inode() for this one at
86
mount time, don't wait for it to
87
happen later */
88
#define JFFS2_INO_FLAG_USERCOMPR 2
/* User has requested a specific
89
compression type */
90
91
92
/* These can go once we've made sure we've caught all uses without
93
byteswapping */
94
95
typedef
struct
96
__u32 v32;
97
__attribute__
((packed)) jint32_t;
98
99
typedef
struct
100
__u32 m;
101
__attribute__
((packed)) jmode_t;
102
103
typedef
struct
104
__u16 v16;
105
__attribute__
((packed)) jint16_t;
106
107
struct
jffs2_unknown_node
108
109
/* All start like this */
110
jint16_t magic;
111
jint16_t nodetype;
112
jint32_t totlen;
/* So we can skip over nodes we don't grok */
113
jint32_t hdr_crc;
114
115
116
struct
jffs2_raw_dirent
117
118
jint16_t magic;
119
jint16_t nodetype;
/* == JFFS2_NODETYPE_DIRENT */
120
jint32_t totlen;
121
jint32_t hdr_crc;
122
jint32_t pino;
123
jint32_t version;
124
jint32_t ino;
/* == zero for unlink */
125
jint32_t mctime;
126
__u8 nsize;
127
__u8 type;
128
__u8 unused[2];
129
jint32_t node_crc;
130
jint32_t name_crc;
131
__u8 name[0];
132
133
134
/* The JFFS2 raw inode structure: Used for storage on physical media. */
135
/* The uid, gid, atime, mtime and ctime members could be longer, but
136
are left like this for space efficiency. If and when people decide
137
they really need them extended, it's simple enough to add support for
138
a new type of raw node.
139
140
struct
jffs2_raw_inode
141
142
jint16_t magic;
/* A constant magic number. */
143
jint16_t nodetype;
/* == JFFS2_NODETYPE_INODE */
144
jint32_t totlen;
/* Total length of this node (inc data, etc.) */
145
jint32_t hdr_crc;
146
jint32_t ino;
/* Inode number. */
147
jint32_t version;
/* Version number. */
148
jmode_t mode;
/* The file's type or mode. */
149
jint16_t uid;
/* The file's owner. */
150
jint16_t gid;
/* The file's group. */
151
jint32_t isize;
/* Total resultant size of this inode (used for truncations) */
152
jint32_t atime;
/* Last access time. */
153
jint32_t mtime;
/* Last modification time. */
154
jint32_t ctime;
/* Change time. */
155
jint32_t offset;
/* Where to begin to write. */
156
jint32_t csize;
/* (Compressed) data size */
157
jint32_t dsize;
/* Size of the node's data. (after decompression) */
158
__u8 compr;
/* Compression algorithm used */
159
__u8 usercompr;
/* Compression algorithm requested by the user */
160
jint16_t flags;
/* See JFFS2_INO_FLAG_* */
161
jint32_t data_crc;
/* CRC for the (compressed) data. */
162
jint32_t node_crc;
/* CRC for the raw inode (excluding data) */
163
__u8 data[0];
164
165
166
struct
jffs2_raw_xattr
167
jint16_t magic;
168
jint16_t nodetype;
/* = JFFS2_NODETYPE_XATTR */
169
jint32_t totlen;
170
jint32_t hdr_crc;
171
jint32_t xid;
/* XATTR identifier number */
172
jint32_t version;
173
__u8 xprefix;
174
__u8 name_len;
175
jint16_t value_len;
176
jint32_t data_crc;
177
jint32_t node_crc;
178
__u8 data[0];
179
__attribute__
((packed));
180
181
struct
jffs2_raw_xref
182
183
jint16_t magic;
184
jint16_t nodetype;
/* = JFFS2_NODETYPE_XREF */
185
jint32_t totlen;
186
jint32_t hdr_crc;
187
jint32_t ino;
/* inode number */
188
jint32_t xid;
189
jint32_t xseqno;
/* xref sequential number */
190
jint32_t node_crc;
191
__attribute__
((packed));
192
193
struct
jffs2_raw_summary
194
195
jint16_t magic;
196
jint16_t nodetype;
/* = JFFS2_NODETYPE_SUMMARY */
197
jint32_t totlen;
198
jint32_t hdr_crc;
199
jint32_t sum_num;
/* number of sum entries*/
200
jint32_t cln_mkr;
/* clean marker size, 0 = no cleanmarker */
201
jint32_t padded;
/* sum of the size of padding nodes */
202
jint32_t sum_crc;
/* summary information crc */
203
jint32_t node_crc;
/* node crc */
204
jint32_t sum[0];
/* inode summary info */
205
206
207
union
jffs2_node_union
208
209
struct
jffs2_raw_inode
i;
210
struct
jffs2_raw_dirent
d;
211
struct
jffs2_raw_xattr
x;
212
struct
jffs2_raw_xref
r;
213
struct
jffs2_raw_summary
s;
214
struct
jffs2_unknown_node
u;
215
216
217
/* Data payload for device nodes. */
218
union
jffs2_device_node
219
jint16_t old_id;
220
jint32_t new_id;
221
222
223
#endif
/* __LINUX_JFFS2_H__ */
__attribute__
unsigned short int uint16 __attribute__((__may_alias__))
Disable IRQ Interrupts.
Definition:
mcf5282.h:37
jffs2_raw_dirent
Definition:
jffs2.h:114
jffs2_raw_inode
Definition:
jffs2.h:138
jffs2_raw_summary
Definition:
jffs2.h:191
jffs2_raw_xattr
Definition:
jffs2.h:163
jffs2_raw_xref
Definition:
jffs2.h:179
jffs2_unknown_node
Definition:
jffs2.h:105
jffs2_device_node
Definition:
jffs2.h:215
jffs2_node_union
Definition:
jffs2.h:205
