RTEMS 5.2
#include <stdint.h>#include <stdbool.h>#include <bsp/tms570.h>#include <bsp/tms570-pinmux.h>#include <bsp/tms570_selftest.h>#include <bsp/tms570_hwinit.h>Enumerations | |
| enum | tms570_flash_power_modes { TMS570_FLASH_SYS_SLEEP = 0U , TMS570_FLASH_SYS_STANDBY = 1U , TMS570_FLASH_SYS_ACTIVE = 3U } |
| enum | tms570_system_clock_source { TMS570_SYS_CLK_SRC_OSC = 0U , TMS570_SYS_CLK_SRC_PLL1 = 1U , TMS570_SYS_CLK_SRC_EXTERNAL1 = 3U , TMS570_SYS_CLK_SRC_LPO_LOW = 4U , TMS570_SYS_CLK_SRC_LPO_HIGH = 5U , TMS570_SYS_CLK_SRC_PLL2 = 6U , TMS570_SYS_CLK_SRC_EXTERNAL2 = 7U , TMS570_SYS_CLK_SRC_VCLK = 9U } |
| void | tms570_pll_init (void) |
| Setup all system PLLs (HCG:setupPLL) More... | |
| void | tms570_trim_lpo_init (void) |
| Adjust Low-Frequency (LPO) oscilator (HCG:trimLPO) More... | |
| void | tms570_flash_init (void) |
| Setup Flash memory parameters and timing (HCG:setupFlash) More... | |
| void | tms570_periph_init (void) |
| Power-up all peripherals and enable their clocks (HCG:periphInit) More... | |
| void | tms570_map_clock_init (void) |
| Setup chip clocks including to wait for PLLs locks (HCG:mapClocks) More... | |
| void | tms570_system_hw_init (void) |
| TMS570 system hardware initialization (HCG:systemInit) More... | |
based on Ti HalCoGen generated file
| void tms570_flash_init | ( | void | ) |
| void tms570_map_clock_init | ( | void | ) |
Initialize Clock Tree:
| void tms570_periph_init | ( | void | ) |
| void tms570_pll_init | ( | void | ) |
Initialize Pll1:
Initialize Pll2:
| void tms570_system_hw_init | ( | void | ) |
| void tms570_trim_lpo_init | ( | void | ) |
Initialize Lpo:
Load TRIM values from OTP if present else load user defined values
