RTEMS 5.2
ckinit.c File Reference
#include <bsp.h>
#include <bsp/irq-generic.h>
#include <bspopts.h>
#include <libcpu/cpuModel.h>
#include <assert.h>
#include <rtems/timecounter.h>
#include "../../../shared/dev/clock/clockimpl.h"
#define CLOCK_VECTOR   0
#define CLOCK_DRIVER_ISRS_PER_TICK   1
#define CLOCK_DRIVER_ISRS_PER_TICK_VALUE   pc386_isrs_per_tick
#define READ_8254(_lsb, _msb)
#define Clock_driver_support_set_interrupt_affinity(online_processors)
void Clock_isr (void *param)
void Clock_driver_install_handler (void)
void Clock_driver_support_initialize_hardware (void)
volatile uint32_t pc386_microseconds_per_isr
volatile uint32_t pc386_isrs_per_tick
uint32_t pc386_clock_click_count
volatile uint32_t Clock_driver_ticks
 ISRs until next clock tick. More...
bool Clock_isr_enabled = false
Clock Tick Device Driver
History:
◆ Clock_driver_support_set_interrupt_affinity
#define Clock_driver_support_set_interrupt_affinity (   online_processors)
Value:
do { \
/* FIXME: Is there a way to do this on x86? */ \
(void) online_processors; \
} while (0)
◆ READ_8254
#define READ_8254 (   _lsb,
  _msb
Value:
do { outport_byte(TIMER_MODE, TIMER_SEL0|TIMER_LATCH); \
inport_byte(TIMER_CNTR0, _lsb); \
inport_byte(TIMER_CNTR0, _msb); \
} while (0)
Variable Documentation
◆ Clock_driver_ticks
extern
Clock ticks since initialization
