RTEMS
5.2
bsps
include
grlib
grtc.h
1
/* GRTC Telecommand (TC) decoder driver interface
2
3
* COPYRIGHT (c) 2007.
4
* Cobham Gaisler AB.
5
6
* The license and distribution terms for this file may be
7
* found in the file LICENSE in this distribution or at
8
* http://www.rtems.org/license/LICENSE.
9
10
11
#ifndef __GRTC_H__
12
#define __GRTC_H__
13
14
#ifdef __cplusplus
15
extern
"C"
16
#endif
17
18
#define GRTC_IOC_UNUSED 0
19
20
/* Driver operation controlling commands */
21
#define GRTC_IOC_START 1
22
#define GRTC_IOC_STOP 2
23
#define GRTC_IOC_ISSTARTED 3
24
#define GRTC_IOC_SET_BLOCKING_MODE 4
/* Raw mode only */
25
#define GRTC_IOC_SET_TIMEOUT 5
/* Raw mode only */
26
27
#define GRTC_IOC_ADD_BUFF 16
/* Frame mode only */
28
#define GRTC_IOC_RECV 17
29
30
/* Available only in STOPPED mode */
31
#define GRTC_IOC_SET_MODE 32
/* Set frame mode (ioctl) or raw mode (read) */
32
#define GRTC_IOC_SET_BUF_PARAM 33
33
#define GRTC_IOC_SET_CONFIG 34
34
#define GRTC_IOC_POOLS_SETUP 35
35
36
/* Available in both running and stopped mode */
37
#define GRTC_IOC_GET_CONFIG 64
38
#define GRTC_IOC_GET_BUF_PARAM 65
39
#define GRTC_IOC_GET_HW_STATUS 66
40
#define GRTC_IOC_ASSIGN_FRM_POOL 67
41
#define GRTC_IOC_GET_CLCW_ADR 68
/* Get address of CLCWRx1 */
42
#define GRTC_IOC_GET_STATS 69
/* Get statistics, note that most of the stats are only avilable in FRAME mode */
43
#define GRTC_IOC_CLR_STATS 70
/* Clear statistics */
44
45
/* Available only in RUNNING mode */
46
47
/* Args to GRTC_IOC_GET_BUF_PARAMS */
48
#define GRTC_BUF_MAXLEN (0x100*1024)
49
#define GRTC_BUF_MASK 0xfffffc00
50
struct
grtc_ioc_buf_params
51
unsigned
int
length;
/* Length of new buffer in multiples of 1kbyte blocks */
52
void
*custom_buffer;
/* If set zero driver will allocate with malloc, set LSB to 1 to indicate remote address */
53
54
55
/* Args to GRTC_IOC_SET_BLOCKING_MODE */
56
enum
57
GRTC_BLKMODE_POLL = 0,
/* Never block (polling mode) */
58
GRTC_BLKMODE_BLK = 1,
/* Block until at least 1 byte can be read */
59
GRTC_BLKMODE_COMPLETE = 2
/* Block until all data requested has be read */
60
61
62
/* Argument of GRTC_IOC_SET_CONFIG and GRTC_IOC_GET_CONFIG
63
* Pointer to:
64
65
struct
grtc_ioc_config
66
int
psr_enable;
67
int
nrzm_enable;
68
int
pss_enable;
69
int
crc_calc;
/* Enable Software CRC calculation (only Frame mode) */
70
71
72
/* Argument of GRTC_IOC_GET_HW_STATUS:
73
* Pointer to a grtc_ioc_hw_status structure that will be filled
74
* in by driver.
75
76
struct
grtc_ioc_hw_status
77
unsigned
int
sir;
78
unsigned
int
far;
79
unsigned
int
clcw1;
80
unsigned
int
clcw2;
81
unsigned
int
phir;
82
unsigned
int
str;
83
84
85
struct
grtc_hdr
86
unsigned
short
flags_scid;
87
unsigned
short
vc_len;
88
unsigned
char
seqnum;
89
__attribute__
((packed));
90
91
/* Frame pool, all frames in pool have the same buffer length (frame mode only) */
92
struct
grtc_frame
93
struct
grtc_frame
*next;
/* Next frame in list */
94
unsigned
short
len;
/* Length of frame extracted */
95
unsigned
short
reserved;
/* Reserved */
96
struct
grtc_frame_pool
*pool;
/* The frame pool this frame belongs to */
97
98
/* The Frame content */
99
struct
grtc_hdr
hdr;
/* Primary Header */
100
unsigned
char
data[3];
/* Frame payload */
101
__attribute__
((packed));
102
103
/* GRTC_IOC_RECV argument, single linked list of received frames */
104
struct
grtc_list
105
struct
grtc_frame
*head;
/* First frame in list */
106
struct
grtc_frame
*tail;
/* Last frame in list */
107
int
cnt;
/* Number of frames in list */
108
109
110
struct
grtc_ioc_pools_setup
111
unsigned
int
pool_cnt;
/* Number of pools */
112
unsigned
int
pool_frame_len[1];
/* Array of 'pool_cnt' length: Frame length of frames in a pool
113
* Lengths must be sorted, starting with the smallest frame pool.
114
115
116
117
struct
grtc_ioc_assign_frm_pool
118
unsigned
int
frame_len;
/* The length of the pool to insert the frame into */
119
struct
grtc_frame
*frames;
/* Frames to assign to a pool */
120
121
122
enum
123
GRTC_MODE_RAW = 0,
124
GRTC_MODE_FRAME = 1
125
126
127
/* TC driver stats collected during receiving. The statistics is only available
128
* in FRAME mode. In RAW mode the user interprets the incoming frames and is
129
* therefore responsible for generating the staticstics.
130
131
struct
grtc_ioc_stats
132
unsigned
long
long
frames_recv;
/* Total number of non-erroneous frames received */
133
/* Errors related to incoming data */
134
unsigned
int
err;
/* total number of errors */
135
unsigned
int
err_hdr;
/* number of errors in Header */
136
unsigned
int
err_payload;
/* Number of errors in payload */
137
unsigned
int
err_ending;
/* Number of errors in end (Filler, end marker) */
138
unsigned
int
err_abandoned;
/* Number of abandoned frames, NOT IMPLEMENTED */
139
/* Errors related to the handling of incoming frames */
140
unsigned
int
dropped;
/* Number of dropped frames TC driver */
141
unsigned
int
dropped_no_buf;
/* Number of dropped frame caused by no buffers were available */
142
unsigned
int
dropped_too_long;
/* Number of dropped frames that was larger than any buffer available for driver */
143
144
145
/* Register GRTC driver at driver manager */
146
void
grtc_register_drv(
void
147
148
/* Register GRTC RMAP driver at driver manager */
149
void
grtc_rmap_register_drv (
void
150
151
#ifdef __cplusplus
152
153
#endif
154
155
#endif
/* __GRTC_H__ */
__attribute__
unsigned short int uint16 __attribute__((__may_alias__))
Disable IRQ Interrupts.
Definition:
mcf5282.h:37
grtc_frame_pool
Definition:
grtc.c:217
grtc_frame
Definition:
grtc.h:92
grtc_hdr
Definition:
grtc.h:85
Definition:
grtc.h:117
grtc_ioc_buf_params
Definition:
grtc.h:50
grtc_ioc_config
Definition:
grtc.h:65
grtc_ioc_hw_status
Definition:
grtc.h:76
Definition:
grtc.h:110
grtc_ioc_stats
Definition:
grtc.h:131
grtc_list
Definition:
grtc.h:104
